#11542 | Link |
![]() Join Date: Feb 2005
madshi is still active here http://forum.doom9.org/showthread.php?t=146228
I can't answer to second question. |
#11545 | Link |
I tried using gui's, but no luck as well.
Eac3to and More GUI This one got crash all the time. Another mod of this is Eac3to and More GUI v.1.10.01. Even the input file is given, it is asking to give again and again, it can not be started. eac3to µGUI Third one i tried is this. But the needed button is inactive in the gui. Is that possible it is just a planned feature which does not work momentarily? bye szabi |
#11551 | Link |
Blu-ray and DVD use different types of LPCM encoding, so with some confidence i can say that it won't be compatible with both at the same time.
#11555 | Link |
so, im not completely clear on the use of flac for things above 6 channels.
WAVEFORMATEXTENSIBLE_CHANNEL_MASK is supposed to be used? and eac3to does this by default? And decoders should be able to use that for to figure out the channels? If my ultimate goal is to use this in a matroska file, does the channel mask remain through the muxing process? Last edited by mindbomb; 12th March 2012 at 05:36. |
#11556 | Link | ||
There are a unique channel mask supported for each num_channels type, and undefined for 7 and 8 channels. |
#11557 | Link | |
eac3to doesn't seem to like 5.0 content. I have a 5.0 DTS Master Audio tracks that I want to encode to 5.0 AC3, but eac3to crashes with an error:
If I use eac3to to create a 5.0 wav file and encode it with a standalone AC3 encoder, do I need to worry about channel order? |
#11558 | Link |
NY Frame of Mind
Audio question about my logic :
If I extract a 385 Mb AC-3, 5.1, 640 Kbps track to 6 wavs, the results are 975 Mb wavs @1152 Kbps each. Enter the wavs into DTS-MA suite, encode them into DTS-High Res audio track format with a bitrate @ 3840 Kbps. The result is still lossy ( I know they can't be converted to DTS-HD) but much higher bitrate and, I would think, higher quality than DTS @ 1509 Kbps and the original AC-3 track. Is my reasoning correct or am I out in left field somewhere ?
"Talk to me Goose" |
#11559 | Link | |
How much lower is dependent on the settings and in your case I would assume not much. Still it is better to just leave it as the AC3 if you can. |
| Tags |
| eac3to |
