10th March 2009, 13:58 | #1 | Link |
UsEac3to v1.3.4: a different GUI for eac3to
With this GUI you need know and type the eac3to parameters, but there are some help for you.
Was made this GUI for me and make more easy test eac3to, if you want use it you can try, also you can modify the source. Initial version: UsEac3to06.7z New version (only the GUI): UsEac3to 1.3.4 Support until eac3to 3.49 The atached one are only the source, readme and only text files, the exe's are big to be attached here. But you can compile yourself with free Autoit3 to be sure than is virus free. WARNING: the file Vid_enc.par is only my example file, if you have a customized one preserve it.
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 11th February 2024 at 10:57. Reason: New version and link |
11th March 2009, 00:49 | #5 | Link |
Try this other, or say me a site to upload.
11th March 2009, 02:17 | #7 | Link |
н∂-ƒαиαтι¢
thanks tebasuna51! always appreciate a new gui for eac3to
edit: a few bugs maybe? when a default output folder is selected, it should be set to that when gui starts. is mp3 automatically set to downmix to stereo? i think not.. also, maybe u can add -progress numbers by default? Last edited by ~bT~; 11th March 2009 at 02:43. |
11th March 2009, 03:42 | #8 | Link | |||
12th October 2009, 19:27 | #12 | Link | ||
New version 0.4
Solved in new version 0.4 (first post) Quote:
I added also the -progressnumbers parameter.
15th October 2009, 11:10 | #15 | Link | |
v1.09 ... * SurCode DVD DTS encoding automation added * new options "-768" and "-1536" for DTS encoding
22nd October 2009, 12:57 | #16 | Link | |
22nd October 2009, 15:18 | #17 | Link |
One more time:
http://www.ebu.ch/CMSimages/en/tec_d...tcm6-53801.pdf http://www.hemagazine.com/node/Dolby...compressed_PCM
23rd October 2009, 01:19 | #19 | Link | |
In the Readme file there are all the links to the files I used. And I think all of them have public source code. But if you think is not enough, please explain me what can I do. Thanks.
