Old 14th August 2010, 14:55   #1  |  Link
nevcairiel
LAV Filters - DirectShow Media Splitter and Decoders
LAV Filters 0.75.1 (released 2021/06/21)
including LAV Splitter, LAV Video and LAV Audio.
Hi folks,
We've been working on this for quite a while already, and i feel its time to release it into the wild for some more comprehensive testing.
LAVFSplitter is a multi-format media splitter that uses libavformat (the demuxing library from ffmpeg) to demux all sorts of media files.
The project has been growing in my mind for quite a while, until i found out that Ti-BEN from the XBMC DSPlayer team was working on this as well,
so we joined forces and developed the first prototype together. Since then some time passed, and this is the third design that came out of
our combined efforts. It is already in use in the XBMC DSPlayer branch as the internal splitter, and now available as a standalone for everyone!
At this point i would like to thank Ti-BEN for his contributions. Without his work on this project, it probably would have stayed a design in my mind.
State of the project
Note that this list only lists properly tested formats/codecs, many others may just work!
Containers
MKV/WebM, AVI, MP4/MOV, MPEG-TS/PS (including basic EVO support), FLV, OGG, and many more that are supported by ffmpeg!
Video Codecs
H264, VC-1, MPEG-2, MPEG4-ASP (Divx/Xvid), VP8, MJPEG and many more.
Audio Codecs
AAC, AC3, DTS(-HD), TrueHD, MP3/MP2, Vorbis, LPCM and more.
Subtitles
VOB, DVB Subs, PGS, SRT, SSA/ASS, Text
BluRay Support
Support for opening BluRay playlists (.mpls), as well as the index.bdmv file, which will try to detect the main movie playlist!
Full support for Seamless Branching Blu-rays as well as HD audio (including native full DTS HD-MA support as of 0.65!)
Other Notable Features
- MKV Edition/Ordered Chapters/Segment linking support
- Full Stream switching
- MKV Embedded Fonts
- Audio Bitstreaming (through LAV Audio)
Note:
Not all containers are equally supported, so some formats may fail in one container and work in another.
Also note that "tested" doesn't mean it won't fail eventually. There are many combinations of codecs, and its impossible to test all of them for me.
How to Use
Here are some guides that include LAV Filters (but are usually not limited to them):
Advanced MPC-HC Setup Guide (by mindbomb)
Watching H.264 videos using Compute Unified Device Architecture (CUDA)
Those guides are in no way "official", and I do not guarantee for the accuracy of these guides, but they should get you started.
If you know about a good guide that should be added here, please say so!
Feedback
When reporting problems, please always state the Container Format, the Codec, and the Decoder you're trying to use. If possible, a short sample will help greatly to resolve any issues!
Please report issues on the GitHub project page: https://github.com/Nevcairiel/LAVFilters/issues
Download
The source can be found on the GitHub project pages:
https://github.com/Nevcairiel/LAVFilters (development repository)
LAV Filters work on Vista/7/8/8.1 and Windows 10. Older versions of Windows are not supported.
Note that some functionality may require newer operating systems (primarily hardware acceleration options).
Binaries for the most recent version are available here:
Version 0.75.1: Installer (both x86/x64) -- Zips: 32-bit & 64-bit
Download 3D Plugin: 32-bit & 64-bit
Debug Symbols: 32-bit & 64-bit
The debug symbols can be used to help determine the cause of crashes, usually you only need them when trying to create a crash dump.
You can find the slightly modified/tuned version of ffmpeg used for LAV Filters here:
https://git.1f0.de/gitweb?p=ffmpeg.git;a=summary
Nightly testing builds are available here:
https://files.1f0.de/lavf/nightly/
Previous releases are available on GitHub:
https://github.com/Nevcairiel/LAVFilters/releases
Changelog
0.75.1 - 2021/06/21 - Release Notes
LAV Splitter
- Changed: AV1 files with no extradata will now generate a format header with stream information for decoders to use
- Fixed: Improved stream selection when multiple "default" video tracks are present
LAV Video
- Changed: Updated dav1d for significant improvements in AV1 10-bit decoding performance
- Changed: AV1 hardware decoding will more reliably engage when provided with additional stream information from the demuxer
LAV Audio
- Fixed: Opus decoding had audible artifacts in some files in 0.75
0.75
LAV Splitter
- NEW: Support for DASH streaming
- NEW: WebVTT support in Matroska/WebM
- Changed: Improved Font support from Matroska files
- Fixed: Large queue size limits could result in the wrong limit being applied
- Fixed: Resolved a memory leak in Matroska demuxing
- Fixed: Avoid selecting a stream with only a single video frame in MP4 files, which is often a cover art
- Fixed: Seeking in Matroska files with only audio cue points did not function
- Fixed: Seeking to the beginning of certain HLS streams did not work properly
- Fixed: Duration information in Matroska files is more reliable
LAV Video
- NEW: AV1 DXVA2/D3D11 hardware decoding support
- NEW: ProRes 4444 XQ support
- Faster: Updated dav1d decoder and improved thread configuration for significantly improved AV1 decoding speed
- Fixed: Added a workaround for VP9 hardware decoding on AMD video cards
- Fixed: H.264 streams exceeding the Level 5.1 DPB limit will no longer be hardware decoded
- Fixed: Improved handling of missing reference frames in H.264 streams with hardware decoding
- Fixed: HEVC streams encoding 8-bit video in a Main10 profile can be properly hardware decoded
- Deprecated: NVIDIA CUVID and Intel QuickSync have been deprecated for future removal/replacement
LAV Audio
- Fixed: Resolved an issue with glitching TrueHD bitstreaming on seamless-branching titles
- Fixed: Resolved a compatibility issue with some playback applications
- Deprecated: Support for the binary DTS decoder (dtsdecoderdll.dll) has been deprecated for future removal
For the full changelog, see CHANGELOG.txt in the download!
Old 14th August 2010, 14:55   #2  |  Link
nevcairiel
Known issues
Audio Decoder
- DTS Express and other "core-less" DTS-HD streams cannot be bitstreamed
Frequently asked Question
Q: Will you write a Subtitle Filter?
A: Its possible, nothing has been determined yet. But its not likely going to be anytime soon.
Q: Can LAV Audio decode DTS-HD?
A: Yes! As of 0.65 DTS-HD is fully supported!
Q: I do not get any audio when using ffdshow as a post processor. What gives?
A: When using ffdshow as post-processor, under some circumstances, you might need to force ffdshow to only use one output format. In this case, i recommend turning off all output formats in ffdshow, except one, preferably either 24-bit int or 32-bit float.
Q: GraphEdit crashes after i installed LAV Video!
A: This is a GraphEdit bug. It will crash as soon as one filter supports more then 100 formats. There is nothing to be done. Personally, i suggest using GraphStudio instead!
Building LAV
Building LAV requires Visual Studio 2015 Update 3, and a recent version of mingw-w64 GCC with a MSYS environment and YASM.
You can get the GCC i use to compile here: http://files.1f0.de/mingw/
I recommend to combine it with MSYS2, or a MSYS package from XhmikosR (http://xhmikosr.1f0.de/tools/msys/)
Old 14th August 2010, 16:38   #3  |  Link
b66pak
b66pak's Avatar
thanks a lot...
_
if you ask a question and somebody give you the correct answer don't forget to leave a "thank you" note...
Visit The Land Of Dracula (Romania - EU)!
Old 14th August 2010, 19:07   #4  |  Link
pdanpdan
I only tested it for mkv with h264 video and multiple AAC audio tracks and subtitle tracks. Everything seems to work fine, except:
I found 2 problems
- the track title is not displayed anywhere (even though this filter shows much more info than any other)
- in mkv files, the default track flag is not respected
And a request:
- can you please implement stream selection order priority by language list?
Thank you,
PDan
pdanpdan is offline   Reply With Quote
Old 14th August 2010, 19:16   #5  |  Link
nevcairiel
Smart stream selection is not implemented yet, but that will be done, including configurable language priorities and default/forced flags.
Name of the streams is one thing on my list as well, right now the whole stream naming just dumps the descriptive codec info from libavformat into there.
Old 14th August 2010, 23:30   #6  |  Link
liquidskin76
liquidskin76's Avatar
Hey nev,
About to test now. Can't wait to see the finished splitter and see it in mpc-hc!
Are mkv chapters supported yet? Also, how about sup and sub/idx subtitles?
Thanks
liquidskin76 is offline   Reply With Quote
Old 15th August 2010, 08:45   #7  |  Link
nevcairiel
Chapters are not yet supported, but thats one of the things to do next.
For the subtitles, well, try it. If it works, yay, if it doesnt, send me a sample =)
Old 15th August 2010, 18:08   #8  |  Link
nevcairiel
LAVFSplitter 0.3
- Added Chapter support
- Improved stream descriptions
- 64-bit support
Download: 32-bit & 64-bit
Old 15th August 2010, 18:16   #9  |  Link
Sebastiii
Thanks Nev
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355.
Sebastiii is offline   Reply With Quote
Old 15th August 2010, 19:28   #10  |  Link
_xxl
ffdshow user
_xxl's Avatar
Great work! LAVFSplitter could be added to MPC-HC?
_xxl is offline   Reply With Quote
Old 15th August 2010, 19:35   #11  |  Link
nevcairiel
Its the plan to replace the majority of the internal splitters in MPC-HC at some point when its more complete.
Old 15th August 2010, 19:45   #12  |  Link
_xxl
ffdshow user
_xxl's Avatar
I had just tested LAVFSplitter 0.3 with MPC-HC 2235 (VS 2008 build) and some random XVID in avi sample. Internal avi splitter is disabled. MPC-HC stops responding when I try to exit, also it takes a lot time to seek. Thanks for your work!
Old 15th August 2010, 19:53   #13  |  Link
nevcairiel
Are you sure its really using it? AVIs have generally always worked rather good.
You can check the filters menu, if the last entry has a sub menu that shows streams, its probably active, as no other avi splitter does that.
Also, x86 oder x64?
Old 15th August 2010, 19:58   #14  |  Link
stax76
stax76's Avatar
Exiting news, thanks a lot. Would it be possible to configure which formats it should handle?
mpv.net - StaxRip - MediaInfo.NET - Get-MediaInfo - More
Old 15th August 2010, 19:59   #15  |  Link
nevcairiel
Yes, that will be in there as well. I'll build a typical property page for the filter where you can select what formats it should be handling, and some other options for preferred languages, and similar things.
Old 15th August 2010, 20:00   #16  |  Link
tetsuo55
MPC-HC Project Manager
_xxl, please provide a sample too if you can
@all, think of this as a full replacement with all the features the current splitters have.
But its only a begin, and obviously not everything is in there yet.
tetsuo55 is offline   Reply With Quote
Old 15th August 2010, 21:21   #17  |  Link
nevcairiel
I found the issue why it was causing MPC-HC to freeze on shutdown, fixed for next version, sorry about that.
Still wondering why your seeking was slow. Seems pretty good for AVIs for me.
Old 15th August 2010, 21:47   #18  |  Link
STaRGaZeR
4:2:0 hater
Looks awesome, keep pushing it!
Specs, GTX970 - PLS 1440p@96Hz
Originally Posted by Manao View Post
That way, you have xxxx[p|i]yyy, where xxxx is the vertical resolution, yyy is the temporal resolution, and 'i' says the image has been irremediably destroyed.
STaRGaZeR is offline   Reply With Quote
Old 15th August 2010, 21:53   #19  |  Link
Underground78
Underground78's Avatar
Really interesting ! I understand why all the slitters related bug reports have been assigned to nevcairiel now ...
I will test if the issues I reported earlier about the MPEG TS Splitter are fixed with the new splitter. Thank you very much for your work nevcairiel !
Underground78 is offline   Reply With Quote
Old 15th August 2010, 22:47   #20  |  Link
STaRGaZeR
4:2:0 hater
Only 1 pin per stream type (video, audio, subs) + stream switching = win
