Old 4th November 2022, 11:13   #1421  |  Link
flossy_cake
Originally Posted by FranceBB View Post
About the "I'm using it only to play stuff in my library", why not using PotPlayer which supports Avisynth post-processing via an Avisynth Script?
PotPlayer will pipe to Avisynth automatically under the hood, thus avoiding indexing.
Thanks for the tip. Currently I'm exploring the same kind of thing with MPC-HC using CrendKing's Avisynth filter. As far as I can tell it inserts Avisynth between LAV decoders and the renderer, so no indexing required either, but I'm having a couple of dealbreaking issues with it (see Issues tab in the Git).
Old 9th November 2022, 12:49   #1422  |  Link
kedautinh12
L-SMASH-Works 20221109
https://github.com/HomeOfAviSynthPlu...Works/releases
Old 9th November 2022, 13:27   #1423  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Originally Posted by kedautinh12 View Post
What an important changelog!
AviSynth: added support for XYZ12LE format (represented as RGB48).
Thank you so so so so much Asd-g!
I've never felt so welcomed and cared for, honestly!
Every single time I raise an issue with this indexer, it's taken into consideration and addressed.
I love LWLibav
By the way, I tested it and it does indeed work.
While FFVideoSource() converts XYZ to YUV, LWLibavVideoSource() preserves the original XYZ inside the video, thus displaying it correctly and allowing us to work directly with XYZ!
Old 9th November 2022, 13:48   #1424  |  Link
kedautinh12
@FranceBB, you can comment about XYZ in FFMpeg, i think author will update for it
Old 18th November 2022, 10:43   #1425  |  Link
flossy_cake
Here is a clip which LWlibavVideoSource cannot seem to play properly: https://drive.google.com/file/d/1lHB...usp=share_link
It seems to have something to do with that soft telecine / repeat fields issue causing it to go out of sync with audio because the repeat field flags aren't being obeyed correctly (discussion about that back on page 58).
file = "480i multiple cadences.mkv"
AudioDub(LWlibavVideoSource(file, repeat=false), LWLibavAudioSource(file, stream_index=-1))
ScriptClip(last, """SubTitle(String(propGetAny(last, "_FieldBased")))""")
If I set repeat=true I get:
The _FieldBased frame property might offer a clue: the panning sequence starting at 1:25 is showing a _FieldBased value with pattern: 0-1-2, which means "progressive-bff-tff" which doesn't seem right for a 3:2 sequence, so maybe it has something to do with that?
FFMpegSource2 doesn't populate the _FieldBased prop, but can play it correctly with rffmode=1 which means "Honor all pulldown flags":
FFMpegSource2(file, rffmode=1, atrack=-1)
But, something is still not right: if I do simple bob deinterlacing with:
Bob()
The result is that "jumping back and forth" artefact which looks like the field order is wrong. So I try to correct that with:
AssumeTFF()
Bob()
^ this is better, but there are still some sequences which appear to have the wrong field order -- look at the "Series Story Editor" at 00:14, it still moves in the wrong direction for one frame before jumping forward 2 frames. I would have thought that was impossible with Bob().
edit: it seems these dynamic changes in field order need to be obeyed, in addition to the repeat field flags, in order to get correct playback. Still, it doesn't make sense to me as I thought analogue CRT would just scan field1 followed by field2 at all times. Seems my understanding is completely wrong: https://www.dvmp.co.uk/digital-video.htm
Old 18th November 2022, 11:26   #1426  |  Link
kedautinh12
I think you need report here to fix faster
https://github.com/HomeOfAviSynthPlu...H-Works/issues
Old 18th November 2022, 12:33   #1427  |  Link
flossy_cake
Thanks, done.
Old 24th November 2022, 17:10   #1428  |  Link
isidroco
I have a problem with small lagarith clips made from pictures with repeated null frames: https://www.mediafire.com/file/hwdf8...ditos.avi/file
Using it to make a slideshow. DirectShowSource will add an extra frame. And LWLibavVideoSource will only return one frame instead of 150.
This is my test script:
nameS="07 - creditos"
extS=".avi"
# v= DirectShowSource( nameS + extS , ConvertFPS=true)
# v= trim(v, 1, length= framecount(v)-1 )
v= LWLibavVideoSource(nameS+extS)
v= ScriptClip(v, """
Subtitle(String( int(current_frame/30))+" seconds",
\ align=5, size=height(v)/16 )
# v= info(v, size= height(v)*.05)
return v
isidroco is offline   Reply With Quote
Old 12th December 2022, 20:18   #1429  |  Link
Hotte
LSmashAudio PCM Distortion
Originally Posted by LigH View Post
Video: AVDH 1280x720 29.97fps 97223kbps [V: Apple Video Media Handler [eng] (dnxhd dnxhr hqx, yuv422p10le, 1280x720, 97223 kb/s)]
Audio: PCM 48000Hz stereo 1536kbps [A: Apple Sound Media Handler [eng] (pcm_s16le, 48000 Hz, stereo, s16, 1536 kb/s)]
Codec ID: sowt
My guess would be that the endianness of the PCM audio was not correctly respected.
Hi, all my Videos containing pcm_s16be or pcm_s16le audio are fully distorted when read with LSmashAudioSource, while LSmashVideoSource is just fine. I've got the latest build from 20221109. It is a pity to wait for indexing of workaround solutions just to get audio right.
Any news about this ?
Hotte is offline   Reply With Quote
Old 13th December 2022, 00:54   #1430  |  Link
kedautinh12
Are you try LWLibavAudioSource??
Old 13th December 2022, 01:48   #1431  |  Link
Hotte
I did and it works. But it needs indexing, which I'd like to avoid and should not be necessary due to the fact that LSmashVideoSource works perfectly on my files for the video-stream without any indexing.
And: I do not understand why these files play instantly without issues and without any indexing if you open them directly with VDub2.
Something seems wrong with LSmashAudioSource and PCM-Audio from everyday-movs from everyday-cams like Nikon D5300 or Panasonic G9.
Old 13th December 2022, 02:02   #1432  |  Link
kedautinh12
You can create issue to fix faster or developer will explain about it
Old 15th December 2022, 15:33   #1433  |  Link
Hotte
Thanks. I opened issue #26
Old 16th December 2022, 19:29   #1434  |  Link
I think that is because the ISO container files [mp4 etc] that LSmashVideoSource() opens, already have some sort of index, as do AVI files.
EDIT: As posted in #1422,
    Function IsISOFileName(String s)        {s=RT_GetFileExtension(s) Return(s==".mov"||s==".mp4"||s==".m4v"||s==".3gp"||s==".3gpp2"||s==".3g2"||s==".mj2"||s==".dvb"||
                                            \ s==".dcf"||s==".m21"||s==".m4a"||s==".m4b"||s==".m4p"||s==".k3g"||s==".jpm"||s==".jpx"||s==".mqv"||s==".ismv"||s==".isma"||s==".f4v")}
At least one of above is an audio-only ISO file. [".m4a"]
Only use LWLibavVideoSource() for non ISO video files. [attempt to open non ISO with LSmashVideoSource() will fail].
EDIT:
Here is a reasonably simple function to open files based on extension, works pretty well and could be used as an example to create your own,
https://forum.doom9.org/showthread.p...68#post1874068
Is implemented as an Avisynthesizer_Mod template.
See also the following posts where may have been improved.
And here:- https://forum.doom9.org/showthread.p...11#post1880511
Hello_Hello did his own version of a similar script.
Edit: Also, here description of my function (presumably the last mod of mine in that thread), where can change preferred order of source filters tried [EDIT: via Pref arg].
Well sometimes a source filter dont work proper, and is good to have an alternative, and way to force that alternative. [and 5 is better than 2]
Currently lookin' summick like this
    Req:- RT_Stats, CallCmd, MIFO_Lib(MediaInfo script lib),  MediaInfo CLI v0.7.83+ (may work with later versions)
        Also, FFMS, LSmash, RawSourcePlus or RawSource (one of them), DSS2.
    Function GetSeq(String "vFn",String "aFn"="",String "Pref"="",Int "VTrack"=-1,Int "ATrack"=-1,Val "fpsNum"=Undefined,Val "fpsDen"=Undefined,
                    \ Bool "Cache"=True,String "CacheDir"="",Bool "CacheDel"=False,Int "Threads"=0,Int "RFFMode"=0,String "TimeCodes"="",Int "AdjustDelay"=-1,String "VarPrefix"="",
    vFn,            Default "", default is NO video file. Can also use VTrack=-2 for no video. If "" and Vtrack != -2, then returns a single frame BlankClip, YV12 640x480, subtitle "No Video File".
    aFn,            Default "". Where "", will use audio from vFn. Can use ATrack=-2 for no audio.
    Pref,           Default "" {Same as "AIRFLD"). Order in which source filters are tried.
                    "A" = AviSource() (Only if extension is *.AVI, WavSource if Audio is WAV).
                    "I" = LSmashVideoSource() (Only if extension is an ISO type file, ie mov, mp4, m4v, 3gp, 3g2, mj2, dvb, dcf, m21.).
                    "R" = RawSourcePlus() (Only if extension is ".y4m".) RawSourcePlus if Avs+ and RawSource if Not Avs+.
                    "F" = FFVideoSource().
                    "L" = LWLibavVideoSource(), from LSMash.
                    "D" = DSS2()
    VTrack,         Default: -1 (auto. Video track number. If -2, disable video.
    ATrack,         Default: -1 (auto). Audio track number. If -2, disable audio.
    Cache,          Default True. False disables the writing of an index file (LWLibavSource and FFMS2 only).
    CacheDir,       Default Undefined. The directory location of the index file written by FFMS2 only. NOTE Directory NOT filename, No backslash at end of folder name.
                    If cache==true and CacheDir = "%TEMP%" then will be set to system environment user TEMP folder.
    CacheDel,       Default False [forced False if Cache=false] . If true, then auto delete FFMS[.ffindex] & LWLibavSource[.lwi] index files on clip closure.
    Threads,        Default 0(auto). The number of threads for LSMASH / FFMS4 to use.
    RFFMode,        Default 0. Honour repeat field flags (LWLibavSource & FFMS2 only).
                        FFMS2:         0=false, 1=true, 2=force film.
                        LWLibavSource: 0=false, 1=true, 2=false.
    fpsnum,
    fpsden,         Defaults Undefined. Framerate for VFR->CFR conversion. # *** INGNORED if AVI ***
                        Specify FrameRate using fpsnum (Numerator) and fpsden (Denominator)
                        num only,  eg fpsnum=25.0,               FrameRate = 25.0  FPS
                        num & den, eg fpsnum=24000 fpsden=1001,  FrameRate = 23.976 FPS (Both should be type Int).
                        neither specified                        FrameRate = UnDefined, ie whatever source filter thinks it is. (no VFR->CFR conversion)
    Timecodes,      Default "". FFMS only, write Matroska Timecodes to filename Timecodes.
    AdjustDelay,    Default -1. FFMS Only.
    VarPrefix,      Default "". FFMS only, Variable for FFInfo().
Old 19th December 2022, 02:25   #1435  |  Link
Katie Boundary
Katie Boundary's Avatar
lsmash-r784-150316-XP Here :- http://megui.tmebi.de/stable/
Have I mentioned this year that you're my favorite person on Doom9?
I ask unusual questions but always give proper thanks to those who give correct and useful answers.
Katie Boundary is offline   Reply With Quote
Old 19th December 2022, 03:00   #1436  |  Link
It's lovely to be somebodies fav, cos everybody else hates me
but, seems hello_hello posted about the file first on the D9, [2017]
Originally Posted by hello_hello View Post
It appears to be missing for a 32bit operating system setup and dare I say it..... XP.
I think for the older L-Smash it should be msvcr100.dll.
There's a copy in the "lsmash-r784-150316-XP.7z" file but not in the "MeGUI\tools\lsmash" folder. I assume there should be?
I'm not having problems as I have the appropriate runtime installed, but I thought I'd mention it.
Old 19th December 2022, 15:05   #1437  |  Link
real.finder
but I don't hate you
See My Avisynth Stuff
Old 19th December 2022, 18:35   #1438  |  Link
Not yet you dont, give it time.
EDIT: In reply to gispos next post::
Well you should, I'm nasty
Old 19th December 2022, 20:07   #1439  |  Link
gispos
I don't hate you either, my dear.
Live and let live
gispos is offline   Reply With Quote
Old 22nd December 2022, 21:02   #1440  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Nah, who could hate you?
You're like a lovely added grandpa for us ehehehehehe
