#1 | Link |
real.finder's Avisynth Stuff
also AKA A.SONY's Avisynth Stuff
I decided to open this Thread like what Groucho2004 did AudSub Splitter GUI for vfr.py and trimsubs https://forum.doom9.org/showthread.p...13#post1673913 some moded macros for avsp note:- Zs_RF_Shared.avsi (Shared Functions and utility V1.05 or up) is needed note 2:- many scripts support native HBD now, some for few settings and some others for all settings depending on the used dll's in the function update note: new scripts and updates will be on github from now on https://github.com/realfinder/AVS-Stuff/tree/master avs/avs+ Universal Plugins Folders daa3mod daa with nnedi3 and ss (slow) method have less artifacts and less loss of details and others dfttestMC and MC things my mod for dfttestmc admfilter and edgesidebleed and others (Advanced Denoising.avsi) bob for anime, smam to clean up the bob Artifacts admfilter is Adaptive motion denoise that use dfttestmc, the goal of it to get rational denoise in all cases (whether motions or not), and other functions DDComb I just did some edit in it QTGMC edit to use YUY2 in avs 2.6 and others NotSMDegrain my old SMDegrain mod RemoveDirtMC_SE stab3 and others AnimeIVTC 2 mod, bug fixed and more ASTDR DeRainbow chroma blend/bleed/halo fix DeHaloHmod maa2 insertsign aWarpSharp4xx eedi3_resize16, ResizeX, edi_rpow2 and IResize nnedi3_resize16 nnedi3_resize16 speed up with nnedi3 for avs 2.6 especially with not yv12 MP_Pipeline not much edit, just support avs mt inside mpp block, my goal now is here https://github.com/SAPikachu/MP_Pipeline/issues/1 nnchromaupsubsampling NNEDI chroma upsubsampling VHSHaloremover abcxyz DeHalo_alpha_MT2 BlindDeHalo3_mt2 Masked_DHA FastLineDarken mod FineDehalo srestore LSFmod BalanceBorders FixBlendIVTC DebilinearM SeeSaw Deblock_QED_MT2 YAHRmods F3KDB_s (now with F3KDB_3_adg and F3KDB_3) smaskmerge GrainFactory3 GrainFactory3mod MCTDmod this is modified so can put MCTemporalDenoise.avsi and MCTD.avsi together in auto-load folder Hysteria.avsi FineSharp EdgeCleaner HQDeringmod LUTDeCrawl LUTDeRainbow Spresso STpresso MCTemporalDenoise YLevels_mt oSmoothLevels mToon unb_s.avsi *.mp4 guy unbt GrainStabilizeMC LRemoveDust DFMDeRainbow Santiag GradFun2DBmod MCBob Vinverse_avsi AutoDeblock2 LimitedSharpen2 chikuzen plugins that I edit/build https://forum.doom9.org/showpost.php...7&postcount=36 maki mod of DGIndex & DGMPGDec I build https://forum.doom9.org/showpost.php...6&postcount=15 ... aside from https://github.com/realfinder/AVS-Stuff/tree/Community , there maybe others in pastebin but I don't remember them now
See My Avisynth Stuff Last edited by real.finder; 28th February 2022 at 00:01. |
#2 | Link |
47.952fps@71.928Hz
Great stuff! What a nice collection.
Win10 (x64) build 19041 NVIDIA GeForce GTX 1060 3GB (GP106) 3071MB/GDDR5 | (r435_95-4) NTSC | DVD: R1 | BD: A AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
#3 | Link |
*** these OUTDATED now ***
new SMDegrain edit https://pastebin.com/4y4Zw2xG now all KNLMeansCL workaround in SMDegrain_KNLMeansCL and support last KNLMeansCL
See My Avisynth Stuff Last edited by real.finder; 9th March 2020 at 16:37. |
#4 | Link |
new QTGMC edit to use SMDegrain_KNLMeansCL to process chroma too http://forum.doom9.org/showpost.php?...postcount=2041
See My Avisynth Stuff |
#5 | Link |
did a lot of changed in SMDegrain last days, it should be faster in yv16 without lsb now (there was a bug that call SSE*Tools)
#6 | Link |
You're still referencing EdiMode and ChromaEdi from within QTGMC_ApplySourceMatch. Those variables are neither declared global nor are they passed to the QTGMC_ApplySourceMatch function, therefore SourceMatch will not work until those references are removed.
#7 | Link |
I didn't get what you say, but I did nothing to original design of QTGMC, if you see a bug in it then explain it clearly where it is
#8 | Link |
http://pastebin.com/dS06e6p8
Line 1002 Code:
yv16match1Edi = EdiMode=="NNEDI2" || EdiMode=="NNEDI" || EdiMode=="EEDI3+NNEDI3" || EdiMode=="EEDI3" || EdiMode=="EEDI2" || EdiMode=="TDeint" || EdiMode=="cYadif" || EdiMode=="RepcYadif" || ChromaEdi=="cYadif" |
#9 | Link | |
#11 | Link | |
See My Avisynth Stuff Last edited by real.finder; 26th December 2016 at 03:48. |
#12 | Link |
With many plugs, an S suffix, means Static ie no dll required, SSE means Pentium 4 +. (thats about it).
#13 | Link |
new SMDegrain and DDComb edits
#14 | Link |
Methinks you misunderstood. The "_SE" in this case relates to GPU support. By the way, SSE means >= P3/Athlon XP.
Groucho's Avisynth Stuff |
#15 | Link |
Yes of course.
#16 | Link |
QTGM with avisynth 64 bit YUY2 source problem
Hi real.finder!
Thank You for Your effort. I am try Your QTGMC script after Windows 10 Reset. Script Code:
AVISource("cap1.avi") AssumeTFF() #ConvertToYV16(interlaced=true) QTGMC(Edithreads=1,dct=5) prefetch(8) Afer adding line ConvertToYV16(interlaced=true) problem gone. My avsmeter log Code:
C:\Video\AVSMeter246>avsmeter -avsinfo AVSMeter 2.4.6 (x86) - Copyright (c) 2012-2016, Groucho2004 VersionString: AviSynth+ 0.1 (r2294, MT, i386) VersionNumber: 2.60 File version: 0.1.0.0 Interface Version: 6 Multi-threading support: Yes Linker/compiler version: 14.0 Avisynth.dll location: C:\Windows\syswow64\AviSynth.dll Avisynth.dll time stamp: 2016-10-26, 15:29:36 (UTC) PluginDir+ (HKLM, x86): C:\Program Files (x86)\AviSynth+\plugins+ PluginDir2_5 (HKLM, x86): C:\Program Files (x86)\AviSynth+\plugins [CPP 2.5 plugins] C:\Program Files (x86)\AviSynth+\plugins\avstp.dll [1.0.3.0] C:\Program Files (x86)\AviSynth+\plugins\dither.dll [n/a] [CPP 2.6 plugins] C:\Program Files (x86)\AviSynth+\plugins+\ConvertStacked.dll [n/a] C:\Program Files (x86)\AviSynth+\plugins+\DirectShowSource.dll [n/a] C:\Program Files (x86)\AviSynth+\plugins+\ImageSeq.dll [n/a] C:\Program Files (x86)\AviSynth+\plugins+\masktools2.dll [2.1.0.0] C:\Program Files (x86)\AviSynth+\plugins+\mvtools2.dll [2.7.9.22] C:\Program Files (x86)\AviSynth+\plugins+\nnedi3.dll [0.9.4.32] C:\Program Files (x86)\AviSynth+\plugins+\RgTools.dll [0.93.0.0] C:\Program Files (x86)\AviSynth+\plugins+\Shibatch.dll [n/a] C:\Program Files (x86)\AviSynth+\plugins+\TimeStretch.dll [n/a] C:\Program Files (x86)\AviSynth+\plugins+\VDubFilter.dll [n/a] C:\Video\AVSMeter246>avsmeter64 -avsinfo AVSMeter 2.4.6 (x64) - Copyright (c) 2012-2016, Groucho2004 VersionString: AviSynth+ 0.1 (r2294, MT, x86_64) VersionNumber: 2.60 File version: 0.1.0.0 Interface Version: 6 Multi-threading support: Yes Linker/compiler version: 14.0 Avisynth.dll location: C:\Windows\System32\AviSynth.dll Avisynth.dll time stamp: 2016-10-26, 15:06:10 (UTC) PluginDir+ (HKLM, x64): C:\Program Files (x86)\AviSynth+\plugins64+ PluginDir2_5 (HKLM, x64): C:\Program Files (x86)\AviSynth+\plugins64 [CPP 2.5 plugins] C:\Program Files (x86)\AviSynth+\plugins64\avstp.dll [1.0.3.0] C:\Program Files (x86)\AviSynth+\plugins64\dither.dll [n/a] [CPP 2.6 plugins] C:\Program Files (x86)\AviSynth+\plugins64+\ConvertStacked.dll [n/a] C:\Program Files (x86)\AviSynth+\plugins64+\DirectShowSource.dll [n/a] C:\Program Files (x86)\AviSynth+\plugins64+\ImageSeq.dll [n/a] C:\Program Files (x86)\AviSynth+\plugins64+\masktools2.dll [2.1.0.0] C:\Program Files (x86)\AviSynth+\plugins64+\mvtools2.dll [2.7.9.22] C:\Program Files (x86)\AviSynth+\plugins64+\nnedi3.dll [0.9.4.32] C:\Program Files (x86)\AviSynth+\plugins64+\RgTools.dll [0.93.0.0] C:\Program Files (x86)\AviSynth+\plugins64+\Shibatch.dll [n/a] C:\Program Files (x86)\AviSynth+\plugins64+\TimeStretch.dll [n/a] C:\Program Files (x86)\AviSynth+\plugins64+\VDubFilter.dll [n/a] |
#17 | Link | |
ColorBars(width=640, height=480, pixel_type="yuy2") nnedi3 and if you use this http://www.dropbox.com/s/fovpn5z9jy4...4_x64.zip?dl=1 will work fine but this 2.5 one (just yv12 and yuy2 and rgb)
See My Avisynth Stuff Last edited by real.finder; 27th December 2016 at 10:59. |
#18 | Link |
added aWarpSharp4xx with new Feature aWarp4 bool (should make the output quality better)
added insertsign with new Features like deal with HD and UHD automatically and if the source is RGBA (Packed) then it will use layer instead of overlay for speed and not lost original alpha
See My Avisynth Stuff Last edited by real.finder; 30th December 2016 at 07:49. |
#19 | Link |
Happy New Year
![]() new QTGMC and sanimebob try with sanimebob(8) and enjoy
#20 | Link |
I'm getting the following error message: I don't know what "merge 16" means. Can you confirm that it should be shift16 instead?
# Threshold Merging & Output enable ? \ Eval(""" merge16 = !nnt ? flat16 \ : mixed ? Dither_limit_dif16(flat16, edge16, thr=thr, elast=elast, y=Ynn, u=Unn, v=Vnn) \ : Ynnt==Unnt && Unnt==Vnnt || IsY8 ? edge16 \ : mt_lutxy(edge16, flat16, Y=Yt?Ynnt?2:4:1, U=Ut?Unnt?2:4:1, V=Vt?Vnnt?2:4:1) merge16 = IsY8 ? output=="Y8" ? merge16.ConvertToY8() : Eval("merge16.ConvertTo"+oCSP).Dither_lut16(Y=2, U=-32768, V=-32768) : merge16 final = IsRGB ? merge16.Dither_convert_yuv_to_rgb(matrix=matrix, tv_range=tv_range, lsb_in=True, mode=dither, output=output) \ : lsb ? merge16 \ : merge16.nnedi3_resize16_Down8(tv_range, True, !IsY8, !IsY8, dither) """) : \ Eval(""" shift16 = input16.Dither_resize16(ow, oh, src_left, src_top, src_width, src_height, kernel="point", y=Y, u=U, v=V) shift16 = IsY8 ? output=="Y8" ? merge16.ConvertToY8() : Eval("shift16.ConvertTo"+oCSP).Dither_lut16(Y=2, U=-32768, V=-32768) : shift16 final = IsRGB ? shift16.Dither_convert_yuv_to_rgb(matrix=matrix, tv_range=tv_range, lsb_in=True, mode=dither, output=output) \ : lsb ? shift16 \ : shift16.nnedi3_resize16_Down8(tv_range, True, !IsY8, !IsY8, dither) """) return final } |
avisynth, avs script, avs+, banding, generator, hbd, mod |
