#4402 | Link | ||
First of all - thanks for reply.
I didn't know ffmpeg can split without encoding. What GUI are you prefer or command line only? Quote:
On common: I was need in cut from i.e. 5 minutes, 3 seconds, 200 ms to 7 minutes, 7 seconds, 700 ms and "split by parts based on timecodes" "00:05:03.200-00:07:07.700" solved it... Quote:
Do you know any such application except VirtualDub: it's a pity it can not seek I-frames only (even if I press Shift+arrow or key button by mouse) in h265 files I tried. Last edited by VictorLS; 15th November 2016 at 22:34. |
#4403 | Link |
I am having a problem with MKVExtractGUI2, the app that comes with MKVToolnix.
Multiple MKV lossless files don't work with it. When you tell the app to extract one track among many, it refuses and ends the command with an "OK" (in fact, it is not extracting any of these tracks, not just one of them). I had to remove all tracks from another video and let just one in it for this app to extract it. In this second case, two .SUP tracks (Blu-ray subtitles). Look at the situation below: ![]() This is a big file, with more than 25 GB. I can't use MKVToolnix to remove all tracks and let just one, then use MKVExtractGUI2 to extract this track, and repeat this procedure 7 more times. There's nothing wrong with my MKV file. Why is this happening with random files? I always used MKVExtractGUI2, I don't get why it refuses to work sometimes. |
#4404 | Link |
gMKVExtractGUI author
@Perenista
Actually MKVExtractGUI2 DOES NOT come with MKVToolNix, it is an external GUI application for mkvextract.exe CLI utility that MKVToolNix provides. It is also quite outdated, hence you should either use gMKVExtractGUI or MKVCleaver, as the official MKVToolNix states at the end of the installtion. Links: gMKVExtractGUI http://forum.doom9.org/showthread.php?t=170249 MKVCleaver http://forum.doom9.org/showthread.php?t=152108 Please ask any questions at the appropriate threads, thanks!
#4405 | Link |
![]() Left is source .ass. Right is read from the MKV after muxing. Timings are screwed up on playback, too. Demuxing it with gMKVExtractGUI restores it. No delays set. E: OK, setting all frames to +5ms in Aegisub fixed the timings. mkvtoolnix is still setting a -5ms delay from that, though. E: also, I've noticed mkvtoonix won't save its settings. Is it set to save that to a directory it doesn't have write access to in Windows? E2: YUP. I ran it as administrator and it made a mkvtoolnix-gui.ini file in c:\Program Files\mkvtoolnix. That's a no-no. So the installer's default install location and mkvtoolnix's default config save path are incompatible. Last edited by kuchikirukia; 22nd November 2016 at 06:00. |
#4406 | Link |
ffx264/ffhevc author
![]() Join Date: May 2007
@Mosu,
Any plans in adding Dolby AC-4 support? Is that even doable at this moment? I mean, is there enough info available that is required for adding this new audio codec?
The Cyberpunk Database || NTP & NTS Time Server || Mirror Services ffhevc || ffx264 || ffxvid |
#4407 | Link |
MKVToolNix author
I don't know; I haven't looked into it yet. This also means that I don't have any information about AC-4 yet, never mind test files.
Latest MKVToolNix is v101.0 If I ever ask you to upload something, please use my file server. |
#4408 | Link | |
Life's clearer in 4K UHD
I suppose you've downloaded all of this: http://www.dolby.com/us/en/technologies/ac-4.html Cheers
#4409 | Link |
ETSI has the download(s):
http://www.etsi.org/standards-search...arch=103%20190 But is anyone using it already? Seems to be a contender for ATSC 3.0, haven't seen it in actual use anywhere yet. |
#4410 | Link |
MKVToolNix author
As I haven't looked into AC-4 yet, I also haven't downloaded anything
But thanks for both links. I will definitely look into implementing AC-4, but I cannot give you guys a time frame.
#4411 | Link |
MKVToolNix author
Dolby's site doesn't seem to offer sample files. Googling for some reveals nothing either. No sample files, no joy.
#4412 | Link | |
https://en.wikipedia.org/wiki/Dolby_AC-4
The Cyberpunk Database || NTP & NTS Time Server || Mirror Services ffhevc || ffx264 || ffxvid Last edited by microchip8; 23rd November 2016 at 00:36. |
#4415 | Link | ||
MKVToolNix author
The GUI's code determines wheter or not it's supposed to work as a portable or as an installed version by the presence or absence of the file "data\portable-app". So there are two things to remember for you:
If you did use the installer
#4416 | Link | ||
Nope. Like I showed, that's how it shows up in Aegisub. It's not a playback filter. [s]Perhaps it has a problem with open GOP?[/s] Figured out what was causing it. It was the Opus track. I think I set a delay for that track (and an AC-3 one) in mkvmerge in a previous mux. Adding subs now causes a -50ms delay when the Opus track is included. And how the heck do we do strikethrough on this forum? I know I've seen it done. Quote:
#4417 | Link | |
Now the interesting part is Aegisub's behavior when it comes to different audio formats. It reacts to delayed Opus in a strange way which I believe may be unintended (even when keeping encoder delay in mind). The underlying ffms2 should be able to handle delays more cleanly. Maybe I will look closer and report to Aegisub team later. /edit: It's related to the 80ms Opus pre-roll. If delay is less than 80ms Aegisub will skew the subtitle timings according to audio delay. Maybe it's a hack that is ugly but intended. Have to ask them... Last edited by sneaker_ger; 27th November 2016 at 13:24. |
#4418 | Link | |
#4419 | Link | |
MKVToolNix author
MKVToolNix v9.6.0 released
This release fixes one major bug in mkvmerge (an endless loop) when appending files. It mostly occurred when muxing MPLS playlists. Several other minor bug fixes and usability enhancements were implemented.
Nothing's been changed regarding the packaging since v9.5.0. Here are the usual links: the MKVToolNix home page, the Windows installer/portable version & Mac OS DMG and the source code. All of the binaries that I provide myself have been built already and are available for download. Here's the ChangeLog sincee v9.5.0: Quote:
#4420 | Link | ||
Matroska find' ich toll
Many thanks for the new version and your continuously work!
(from user: manolito which uploaded the Test-Bluray "Run-Moonfans") Quote:
best regards hubble Last edited by hubblec4; 30th November 2016 at 17:04. |
