#1 | Link |
Matroska find' ich toll
chapterEditor(Chapter-Database Disc2mkv Matroska-Tools[Tags,Menu,Multi-MKV])+CLI
Hi everyone
I have started for a while with a simple and small chapter Editor project. The project has grown and now are 4 diffrent Format Editors avalible and an editor for muxing multi editions mkvs (like Xin1Generator). There is now a Reddit for chapterEditor. Matroska Multi-MKV Editor With this editor you can create easy and fast multi-mkv files from normal Matroska files(mkv,mka,mk3d). Only the chapters and tags are replaced and no video or audio data is manipulated. You can download here some tutorial videos. Multi-Editions-Editor (MEE): With this editor you can backup your Blu-Ray to mkv. If there are multiple editions on the BluRay, they can be stored in a space-saving mkv with "ordered chapters". here an old Tutorial(with rev0.14) Matroska Menu Editor (MME) The new MME helping a while Matroska files (mkv, mka, mk3d) that are located in a folder and the same specifications (number of tracks in the correct order and the same codecs for video, audio, subs) have, to connect with each other via the menu. In this case, no files need to be remuxed. Tutorial-Video DVD2mkv: is a small tool to quickly mux the tracks on a DVD to a mkv. Functions for edit the mkv's are also available. Matroska Tags: With this editor you can provided Matroska files with Tags. Tags contain useful information that can be collected and processed by other programs. Functions: supported file formats:
Special tools:
Editors:
Additional functions for the chapter editors (OGG, XML, TTXT, multiAVCHD)
Languages:
CLI support (GUI) chapterEditor rev1.xx download chapterEditor(rev1.31 Windows) download chapterEditor(rev1.31 Linux) This version is deprecated and no longer supported. Furthermore, a maximum of MKVToolNix version 19 can be used. download chapterEditor(rev0.51) Alternate download on Softpedia or Videohelp. You find here chapter samples and here new samples. ***************************************************************************************************************** ********** chapterEditorCLI ********** cE CLI is a small command line tool with which you can generate chapter files from the chapter database. Furthermore, you can create Blu-Rays or DVDs chapter files and expand the chapter names from the database. The chapter files can be output in OGG format or Matroska XML format. download chapterEditorCLI(rev0.01) Code:
chapterEditorCLI(rev0.01) help --------------------------- -a / --anleitung The help on german -f / --fps FPS Conversion switch "FPS value" source/target fps value "file path" source/target file path or a folder -h / --help Show this help --mid Movie ID, an integer greater then 0 Displays all movie information and chapters --names Save a simple chapter names list of a movie output: a file name without an extension --ogg Output format: ogg-chapter.txt output: a file name without an extension --pass your database password --range A Movie ID. Displays the following 200 movies --title Displays all movies(max: 200) with titles (at least 2 characters) --user your database user name --xml Output format: matroska-xml-chapter.xml output: a file name without an extension X: / X:\ a drive "path DVD" a DVD path to VIDEO_TS folder "path Blu-Ray" a Blu-Ray path to BDMV or PLAYLIST folder VTS_xx_0 VTS ifo file: xx = 01 .. 99 without the ".ifo" extension 1..99 a title number for VTS ifo file 00000..99999 a mpls file/number without the ".mpls" extension --------------------------- Mode 1: database syntax 1-2.parameter: --user="your name" --pass="your password" 3.parameter: --mid= OR --range= OR --title="a title" If 3.parameter equal --mid you can enter a 4. parameter 4.parameter: --ogg="output txt" OR --xml="output xml" OR --names="file path and name" --------------------------- Mode 2: DVD/Blu-Ray/folder syntax 1.parameter: Drive(X:) OR a folder path "DVD/Blu-Ray path" *** Blu-Ray *** 2.parameter: 00000..99999 3.parameter: --ogg="output txt" OR --xml="output xml" generate a chapter file with chapter names 4-6.parameters: --user="your name" --pass="your password" --mid= *** DVD *** 2.parameter: VTS_xx_0 3.parameter: 1..99 4.parameter: --ogg="output txt" OR --xml="output xml" generate a chapter file with chapter names 5-7.parameters: --user="your name" --pass="your password" --mid= NOTE: File names can be empty, a default file is then created in the root directory. --------------------------- Mode 3: FPS Conversion syntax 1. parameter: -f or --fps (FPS init) 2. parameter: 24000/1001 or 23.976 (source fps) 3. parameter: 30 or 23,97 (target fps) 4. parameter: "source file path or source folder" 5. parameter: "target file path" (optional and for source file only) examples: Mode 1: Viewing the movie information and list of chapters Code:
chapterEditorCLI.exe --user="username" --pass="the password" --mid=99 Code:
chapterEditorCLI.exe --user="username" --pass="the password" --range=99 Code:
chapterEditorCLI.exe --user="username" --pass="the password" --title="cap" Code:
chapterEditorCLI.exe --user="username" --pass="the password" --mid=99 --ogg="c:\path\chapter file" chapterEditorCLI.exe --user="username" --pass="the password" --mid=99 --xml= Code:
chapterEditorCLI.exe --user="username" --pass="the password" --mid=32000 --names= Mode 2: Drive(Blu-Ray or DVD) or folder Code:
chapterEditorCLI.exe D: chapterEditorCLI.exe D:\a folder\BDMV chapterEditorCLI.exe D:\a folder\BDMV\PLAYLIST chapterEditorCLI.exe D:\a folder\VIDEO_TS Choose an MPLS and list the chapter times Code:
chapterEditorCLI.exe D: 00001 Code:
chapterEditorCLI.exe D: 00001 --ogg= chapterEditorCLI.exe D: 00001 --xml="c:\chapter file" Choose an IFO and view the track numbers Code:
chapterEditorCLI.exe D: VTS_01_0 Code:
chapterEditorCLI.exe D: VTS_01_0 3 Code:
chapterEditorCLI.exe D: VTS_01_0 3 --ogg= chapterEditorCLI.exe D: VTS_01_0 3 --xml="c:\chapter file" Code:
--user="username" --pass="the password" --mid=99 Modus 3: It is expected at least 4 parameters. FPS conversion always starts with the -f or --fps switch a Matroska XML file from 24000/1001 to 25 FPS without target file path Code:
chapterEditorCLI.exe -f 24000/1001 25 "D:\Matroska chapter.xml" (a new target file is automatically created in the same folder) Code:
chapterEditorCLI.exe -f 29,97 23.976 "D:\OGG Chapter file.txt" "E:\new OGG file" (FPS float values can be specified with a point or comma) Code:
chapterEditorCLI.exe -f 24000/1001 25 "D:\folder with source files(\)" Last edited by hubblec4; 9th March 2022 at 01:46. Reason: update |
#4 | Link |
a mini tiny small error has crept in the procurement of the end times.
extra-make a new version now would be too much of a good. please you downloaded the version again. Last edited by hubblec4; 28th December 2013 at 13:00. |
#8 | Link |
00:00:00.000 Chapter1Line1\nChapter1Line2\nChapter1Line3\nChapter1Line4 00:00:00.999 00:10:00.000 Chapter2Line1\nChapter2Line2\nChapter2Line3\nChapter2Line4 00:10:00.999 00:20:00.000 Chapter3Line1\nChapter3Line2\nChapter3Line3\nChapter3Line4 00:20:00.999 Note: 1) The time codes ending with 000 are chapter position. 2) The time codes ending with 999 are chapter thumb position. 3) Total of 4 descriptive lines supported, separated by \n. 4) Not clear about the field left blank. For what are the blue entries? (Maybe chapter names?) The green time codes are these used for anything? Last edited by hubblec4; 29th December 2013 at 18:01. |
#9 | Link |
1. The blue entries are the chapter name(s). Dean provided a very generous 4 lines for this.
2. The green entries are the time position of the thumbs to appear in the chapters menu page.. If none specified, the midway point between the current and the next chapter is used. 3. There could be a 4th parameter sandwiched between time code and name, but could not figure out what it is. So use a <space> between the two <tab> characters. The attached screen caps should be self explanatory. Last edited by mariner; 30th December 2013 at 06:16. |
#10 | Link |
I asked deank for the specs of his own chapter format.
brainstorming : in what for a format would you convert the multiAVCHD.chapter? // OGG I can use the first timecode and the 4-Chaptername-Lines (generate one line with one chapter name) to convert it to ogg.chapter. The last timecodes(thumbs) can not be used. // XML The firsttimecode is normal starttime. The 4-Chaptername-Lines should be compressed to one line, because the chaptername-system in XML works different to the 4-Chaptername-Lines-system of multiAVCHD. It is possible to generate more chapternames for the chaptertimestamp but the player will shown only the first chaptername at the moment. there is no splitter(or player) avalible that can handle this mkv-feature. The last timecodes(thumbs) could be stored as nested chapters. // 3GPP TTXT The firsttimecode is normal starttime. The 4-Chaptername-Lines can be saved in the same way. 3GPP TTXT supported Multi-chaptername-lines. The last timecodes(thumbs) can not be used. the chaptername-line are ever 4? what is when set no chaptername or only one chapterline, how looks the chapter.file now? i hope deank will give me the specs then it will be easy to support it. |
#11 | Link | ||
00:00:00.000 00:10:00.000 Chapter2Line1 |
#12 | Link | |
A solution will be i write a new own format editor for multiAVCHD which supports other formats. But i think this take a bit time. without the right syntax of the chapter.files could be hard. I will think about it, but i don't promise anything. |
#14 | Link |
i have tested a bit multiAVCHD.
The chapters can saved with or without the chaptername(s) and the thumbtime. without: the chapterformat is the same like Timecodes Text File (see the chapter sample folder). multiAVCHD is able to handle to following chapter formats - CCE SP Text File - Celltimes Text - HC Enc Text file - Muxman - OGG Chapter Text File - Timecodes Text File of what for a format you would like convert it to mulitAVCHD.chapter? can you explain me what is the number right of the "apply"-button? |
#15 | Link | |||
The multiAVCHD chapters txt file is basically a Timecodes Text File with chapter name and thumbnail position. Quote:
That's the number of chapters multiAVCHD will create if the auto button is clicked. Many thanks and best regards. |
#16 | Link | ||
multiAVCHD works not perfect with frame-based chapter formats. there is a standard source fps set (i think 24000/1001), but you can't change it. Quote:
at the moment i work on some fixes and improvements but i add it to my todo list. i plan the same support like the other editors(formats,FPS,Naming,Time adjustment and cuting). you would like to have a "auto" button to generate thumbnail positions? what you need too? but it will take a while, maybe on next revision. |
#19 | Link |
hi mariner
i need your help to write a perfect procedur for the auto-thumbnail position button. multiAVCHD set for the last chapter a thumbnail position thats greater as the chapter time. is this correct? to generate the middle time of two chapters is easy but the last chapter has no next chapter. Which time should be used? Last edited by hubblec4; 4th January 2014 at 02:29. |
#20 | Link |
Chapter time is used for thumbnail position if it is the last chapter.
Perhaps you'd like to consider doing the same for the other chapters as well. So if no thumbnail is specified, multiAVCHD can default to using the midway point for thumbnail position. |
bluray backup, chapter editor, dvd2mkv, matroska menu, metadata, multi-edition-mkv, xml tag |
