Old 16th August 2015, 04:52   #3521  |  Link
rsotome
So far, a great deal of nice improvements to the new GUI, especially storing each job in a separate file, thank you for all your hard work.
I do have 2 questions about the .mtxcfg format & jobQueue.
-Is it possible to generate better filenames in the jobQueue, instead of what seems like a mix of random letters & numbers?
-Will it ever be just as easy to mass edit .mtxcfg files as it is the older .mmg files with a text editor (eg. Notepad++) ?
The .mtxcfg is hard to make heads or tails out of, and mass editing 20+ TV series jobs is still much easier with the .mmg format.
Hopefully I didn't put a damper on your new release, since it's really starting to take shape.
rsotome is offline
Old 16th August 2015, 07:14   #3522  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Hey,
You (and the others who thanked me) are quite welcome
Those are GUIDs (Globally Unique Identifiers). They're used by the GUI in order to ensure that each job file has a unique name. This also facilitates copying those job files to another installation without clashing with any existing job queue file on that installation, be it on the same computer or on other computers.
I don't have any plans on changing that schema as I don't see a compelling reason. If you want to manually add your own jobs to the queue without the GUI and you're worried about having to name the files in a similar way: don't be. The GUI should pick up all files in the jobQueue directory whose extension is ».mtxcfg« and assign a GUID automatically.
Knowing that do you still want the GUI to use different a file naming scheme? If so what are the reasons?
Like I've said above in a reply to hubblec4: the GUI uses JSON for writing .mtxcfg files now. If you want to edit those files manually make sure the environment variable »MTX_JSON_FORMAT« is set to »indented«. That way they'll even look nice.
I consider JSON to be a good choice. There are bindings for parsing and writing JSON available in pretty much each and every programming language. Modifying those files should be very, very easy.
You already know the .mmg format, you don't know the .mtxcfg format yet. Of course .mmg is easier for you under those circumstances. Why don't you just ask about the points in .mtxcfg that you don't understand? I'm happy to explain the meaning of those things, you know
The internal format won't change, sorry, you should get used to it if you want to fiddle around with it.
hubblec4 generates his own .mtxcfgs, too. Here are a couple of points I've explained to him a while ago:
  • It's UTF-8 encoded JSON. The same JSON used everywhere else.
  • There's one important distinction between .mtxcfg saved from the merge tool and the .mtxcfg used in the jobQueue. The files in the jobQueue contain more information on the top level, and the merge configuration is nested one level down in the »muxConfig« key. Think of structures/classes in a programming language. There's a class called »MuxConfig« and one called »Job«. »Job« contains a member of type »MuxConfig«, and that's how they're stored in the jobQueue. Manually-saved .mtxcfg files from the merge tool, however, only contain the »MuxConfig« instance and aren't wrapped in an instance of »Job«.
  • objectId is just a numeric value uniquely identifying each object within the file. The GUI uses memory addresses, but you could just as well use serial numbers.
  • properties are the key/value pairs output by »mkvmerge --identify-for-mmg«. Note that mkvmerge escapes certain characters, and that escaping has already been undone when the values are stored in the .mtxcfg.
  • The »type« member for a track is the numeric track type. See this list: audio equals 0, all following are numbered sequentially.
  • Tye »type« member for containers is the numeric container type. See this list: unkown equals 0, all following are numbered sequentially.
Latest MKVToolNix is v101.0
Mosu is offline
Old 16th August 2015, 12:00   #3523  |  Link
hubblec4
Matroska find' ich toll
I can feel with you, in the past i have do the same.
Create one mmg manually, and all other episodes by copy/paste(replace) the paths in the mmg.
@Mosu
puuhhh the new format JSON looks like not so well for me.
There is only one line in the mtxcfg.
But the old mtxcfg will supported in future? So I can use this?
hubblec4 is offline
Old 16th August 2015, 12:55   #3524  |  Link
hubblec4
The new JSON mtxcfg seems to be easier.
When path's contains "ä , ö , ü ..etc" the format will not changed like in the old mtxcfg (ä = \xe4). Now its very easy to change mass mtxcfg's with an editor.
I will change to JSON too.
hubblec4 is offline
Old 16th August 2015, 13:12   #3525  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Like I said: set that environment variable and the GUI will write nicely formatted JSON. It can always read both the compact and the indented variants.
Mosu is offline
Old 16th August 2015, 17:13   #3526  |  Link
AYColumbia
AYColumbia's Avatar
Mosu, any estimate on when the command line stuff will be complete in the new UI? Also, I noticed the current Windows cmd.exe is escaping the double quotes, i.e., ^" but they don't need to be escaped, however, the parans do, i.e., ^( and ^). Thank you.
BTW, I copied the current command line and tried to run it manually and received an error. Obviously if CLI not ready you can ignore this.
"mkvmerge.exe" "--output" "title.mkv" "--language" "0:und" ( "sourceTitle.mkv" ) "--language" "0:und"
( "sourceTitle.ac3" ) "--language" "0:und" ( "sourceTitle.sup" ) "--chapters" "sourceTitle_chapters.txt"
"--engage" "no_cue_duration" "--engage" "no_cue_relative_position" "--track-order" "0:0,1:0,2:0")
mkvmerge v8.3.0 ('Over the Horizon') 64bit
Error: '0)' is not a valid file ID in '--track-order 0:0,1:0,2:0)'.
AYColumbia is offline
Old 16th August 2015, 17:24   #3527  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
The command line handling is ready: Merge → Show command line. The quoting is intentional. It may look ugly, but it actually is the only proper way to escape for cmd.exe.
What you think you know about escaping for cmd.exe is most likely incorrect or at least incomplete. See this informative but frightening blog post from a Microsoft employee.
BTW: I'm sorry to say but cmd.exe stinks. Especially if one is used to sane shells like zsh or bash.
And what do you mean – you »copied the current command line«? You definitely copied one closing parenthesis too much, I have no idea where you got that one from.
Mosu is offline
Old 16th August 2015, 18:40   #3528  |  Link
AYColumbia
AYColumbia's Avatar
I copied the command line string from the UI from the same location you mention, i.e., Merge > Show command line. I didn't notice that it had an extra paran on the end so good catch.
Regarding the escaping, yes, I just realized that it's fine the way it is since it's meant to be copied and executed on the command line directly as opposed to be consumed by a script/batch file. I was looking at it from a command file script perspective which is not correct here.
I don't use zsh or bash. Just basic Windows CLI to batch process stuff. I'm sure you're passionate about not liking CLI but please don't be condescending towards those of us that still use it. Speaking for myself, the reason I still use it, is the lack of a UI to accomplish what I need for each situation whether it's re-encoding, re-muxing or what have you.
Old 16th August 2015, 18:49   #3529  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Not liking the CLI? Geez, you misunderstood me completely I love the command line! But cmd.exe is simply not a good shell. zsh and bash are: way more powerful, much saner… That's all I wanted to say.
What you've pasted above doesn't look like the new GUI's version of a command line escaped for cli.exe but for Linux shells. You should not use that escaping with cmd.exe, instead switch to the cmd.exe escaping mechanism. And if you're still using mmg.exe for generating command lines: please use the new GUI instead. mmg.exe's command lines are not correct for cmd.exe in certain situations (e.g. if quotation marks are involved).
Mosu is offline
Old 16th August 2015, 18:55   #3530  |  Link
sneaker_ger
This is intended?
sneaker_ger is offline
Old 16th August 2015, 18:59   #3531  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Like I've said above: yes.
Mosu is offline
Old 16th August 2015, 19:10   #3532  |  Link
sneaker_ger
Quoting the path to mkvmerge.exe in this manner does not work here. It stops at the first space in the path. (c:/program not found)
Old 16th August 2015, 19:19   #3533  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
That's interesting. I'll have to look into it.
Mosu is offline
Old 16th August 2015, 19:24   #3534  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Probably because there's a slash instead of a backslash (Windows paths..)
Boulder is offline
Old 16th August 2015, 19:24   #3535  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Like I said: cmd.exe and command line parsing on Windows is completely bonkers.
Looks like cmd.exe uses different rules for escaping the initial argument than the MS Visual C libraries use for all remaining arguments. The joy!
I'll have to fix that and will open an issue for it in the meantime. Note that only the escaping of the very first argument (the path to mkvmerge.exe) has to be changed – the other arguments are escaped correctly.
Mosu is offline
Old 16th August 2015, 19:25   #3536  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
No, backslashes vs. slashes is not what's wrong here. cmd.exe doesn't interpret ^" the way that CommandLineToArgvW() does. If you just use "C:/Program Files/MKVToolNix/mkvmerge.exe" and leave the rest as it is then it does work. Windows does support forward slashes just fine.
Mosu is offline
Old 16th August 2015, 19:31   #3537  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Whoa..you definitely learn something new each day. That one just removed one almost 30-year-old piece of knowledge off my head
Boulder is offline
Old 16th August 2015, 20:31   #3538  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
The cmd.exe escaping snafu has been fixed in pre-builds 867/868.
Mosu is offline
Old 16th August 2015, 23:12   #3539  |  Link
AYColumbia
AYColumbia's Avatar
All good. Sorry for the misunderstanding on my part. It just came across as harsh rather than sarcastic is all.
You're correct. I had to remove the ^" because am running in a Windows cmd.exe (already addressed by earlier posts by others so won't delve further). I saw you had a fix build already in the latest post. Many thanks for jumping on this so quickly. Very much appreciated.
BTW, I have switched over to the new GUI which is how I ran into the escaping thingy. It's taking some getting used to but I like it.
Old 16th August 2015, 23:55   #3540  |  Link
ShadyCrab
Whenever I select a video file in the new GUI (8.3.0 and current nightly 64 bit, both through the Installer) an error pops up saying 'the mkvmerge executable was not found'. I went to task manager, opened the file location and its definitely launching from the same folder as mkvmerge.exe. I deleted the bunkus.org AppData folder, didn't help. Portable edition works, but installer will not. Tried reinstalling 4 times, even deleting old regedit data (though the new one doesn't use it, just to be sure).
ShadyCrab is offline
