Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > Advanced authoring
Old 23rd October 2004, 07:15   #1  |  Link
_argos
is there a scenarist log file
hi there,
i am trying to build the backup of "star wars episode iv" (numenu4u, dif4u, scenaid ...) but the build failed and scenarist exits. i would like to see the log. is there kind of an external log file for the build (i could not find one) because the build log from scenarist itself is gone when the program crashed. i would like to know what the problem was.
thx
_argos
_argos is offline   Reply With Quote
Old 23rd October 2004, 07:27   #2  |  Link
Zeul
did scenarist fail on numenu4u or scenaid?
Zeul is offline   Reply With Quote
Old 25th October 2004, 02:15   #3  |  Link
D3s7
ScenAid
D3s7's Avatar
with either application there isn't directly a log file however if automate_scenarist did it's job there should be a <SCRIPT>_import.log which records the import and <SCRIPT>_build.log which records the build
ScenAid
May just replace the dog as man's best friend
http://www.scenaid.com
D3s7 is offline   Reply With Quote
