Thread Tools
Old 30th April 2021, 12:50   #1  |  Link
bystander1
Flickering elements around the subtitles
Hello! Subtitles in Media Player Classic are being displayed with some flickering rectangles on the background (see attachments or this link: https://imgur.com/a/JxoEdsA).
Why does it happen and how can I fix it? Operating system is Windows 10 Home.
bystander1 is offline   Reply With Quote
Old 30th April 2021, 13:01   #2  |  Link
Rectangles are sometimes used where some character is 'unknown' [does not have any representation, in fonts and such), I imagine that they [rectangles] could be used in subtitling too, perhaps some character encoding problem.
EDIT: Attachments still pending.
Old 30th April 2021, 13:10   #3  |  Link
bystander1
Can you see the link to imgur? There are just the same images as in attachments.
All characters in subtitles appear as normal characters, they are recognized, but some flickering stuff appears around them.
Old 30th April 2021, 15:39   #4  |  Link
Sorry, I did not see your Imgur link.
No, those are not the rectangular thingies that I was talking about, no idea what that is, I've never seen anything like them.
Maybe you can give some clue as to Subtitling software, so that others may be able to assist.
Also, does it do same in eg PotPlayer ? [if not then maybe MPC-HC prob].
Old 30th April 2021, 16:23   #5  |  Link
bystander1
I don't use subtitling software, I just download subtitles in .srt format and open it in MPC videos.
In Microsoft Movies & TV and in VLC media player the bug doesn't appear. Changing MPC subtitles settings didn't help though.
Old 30th April 2021, 16:29   #6  |  Link
Dont think I can help, but suggest post link to the subs file.
[Maybe MPC-HC devs (or others) would like to look at it]
Old 30th April 2021, 16:52   #7  |  Link
bystander1
The subs file doesn't matter much, it happens to any video with any subs.
Old 1st May 2021, 11:56   #8  |  Link
Make sure that you have latest version MPC-HC, maybe its been fixed already.
(sounds like player problem).
Old 1st May 2021, 18:08   #9  |  Link
bystander1
I do. It's from 12 April.
Old 1st May 2021, 20:27   #10  |  Link
Ghitulescu
Ghitulescu's Avatar
No way a on-demand subtitle would look this way.
I would have expected "broken" ones (like a bad download) to present these random errors.
Born in the USB (not USA)
Old 1st May 2021, 22:41   #11  |  Link
bystander1
No, it is the case with all subtitles on my laptop (on another laptop all the same subtitles look fine).
Old 1st May 2021, 22:49   #12  |  Link
clsid
This seems to be a bug in your current Intel driver. Update the driver.
If that does not solve it, then change the video renderer in MPC-HC. Use EVR-CP or madVR instead of MPCVR.
But first press Ctrl+J to show renderer debug overlay and make a screenshot. Post that in the MPC-BE topic, maybe the devs can fix it in case the bug is in MPCVR instead of the driver.
Old 2nd May 2021, 12:41   #13  |  Link
bystander1
You mean the video card? I have Intel Iris Xe Graphics from 14.10.20, it's up to date. Changing the renderer to EVR-CP didn't fix the problem.
(Just in case: here is the screenshot form Ctrl+J https://imgur.com/a/8Eql1rf)
Old 2nd May 2021, 14:51   #14  |  Link
clsid
That driver is 6 months old. Latest one is from two weeks ago:
https://downloadcenter.intel.com/dow...10-DCH-Drivers
Also check the Windows 10 display settings to see if you can change it to 8-bit bit depth.
Old 3rd May 2021, 11:12   #15  |  Link
bystander1
My drivers are provided by Dell, Dell's website indicates my current Intel Iris Xe driver (version 27.20.100.8853) as the latest suitable one for my laptop.
As for bit depth, it is 6-bit. I searched how to change it, it is said I should change adapter mode to 32-bit, but my adapter mode is already 1920*1080, True color (32 bit), 60 Hz.
Old 9th May 2021, 09:10   #16  |  Link
bystander1
Solved! My fault - I tried only renderers available by default and didn't instal the MadVR mentioned above. When I downloaded and installed it, the bug disappeared (yet I still don't know what it was). Thanks to everybody who paid attention!
