#1 | Link | |
MKVToolNix author
MKVToolNix v100.0 released
Note: The latest release is v100.0.
Hello everyone, July's release of MKVToolNix is here: v25.0.0. After two smaller ones, this one packs quite a number of bug fixes and enhancements, including fixing a regression in the GUI's header editor preventing elements from being removed that was introduced in v24.0.0. Sorry about that. AV1 support hasn't changed. While the bitstream format's been finalized in the meantime, the mapping to Matroska & WebM hasn't. It's currently being discussed on the CELLAR mailing list. Here are the usual links: the MKVToolNix home page, the Windows installer/portable version & macOS DMG & Linux AppImage and the source code. The Windows and macOS binaries as well as the Linux AppImage are available already. The other Linux binaries are still being built and will be available of the course of the next couple of hours. Here are the NEWS since the previous release: Quote:
Latest MKVToolNix is v100.0 If I ever ask you to upload something, please use my file server. Last edited by Mosu; 5th July 2026 at 18:59. |
#2 | Link |
Life's clearer in 4K UHD
Nice one Mosu
#3 | Link |
Slightly incorrect chapters time
I took 9 wav files (pcm 96 kHz/16 bits), all exacly one second (96000 samples) long, merged them to mka using MKVToolnix 25.0.0 with creating chapters for each appended file.
It seems obvious that each chapter should be exactly 1 second long and second chapter should start exactly at 1 second, third chapter should start exactly at 2 second and so on. But using Info tool in MKVToolnix or MKVCleaver i can see that chapters time is slightly off. So question: is this normal? If not, then what can be reason of this? Here are chapters as extracted by MKVCleaver: Code:
<?xml version="1.0"?>
<!-- <!DOCTYPE Chapters SYSTEM "matroskachapters.dtd"> -->
<Chapters>
<EditionEntry>
<EditionFlagHidden>0</EditionFlagHidden>
<EditionFlagDefault>0</EditionFlagDefault>
<EditionUID>6106875923387060889</EditionUID>
<ChapterAtom>
<ChapterUID>7385917724078987421</ChapterUID>
<ChapterTimeStart>00:00:00.000000000</ChapterTimeStart>
<ChapterDisplay>
<ChapterString>Chapter 01</ChapterString>
<ChapterLanguage>eng</ChapterLanguage>
</ChapterDisplay>
</ChapterAtom>
<ChapterAtom>
<ChapterUID>12105901406932053652</ChapterUID>
<ChapterTimeStart>00:00:00.999996225</ChapterTimeStart>
<ChapterDisplay>
<ChapterString>Chapter 02</ChapterString>
</ChapterDisplay>
</ChapterAtom>
<ChapterAtom>
<ChapterUID>4640490012402631944</ChapterUID>
<ChapterTimeStart>00:00:02.000002865</ChapterTimeStart>
<ChapterDisplay>
<ChapterString>Chapter 03</ChapterString>
</ChapterDisplay>
</ChapterAtom>
<ChapterAtom>
<ChapterUID>143719244427371845</ChapterUID>
<ChapterTimeStart>00:00:02.999999090</ChapterTimeStart>
<ChapterDisplay>
<ChapterString>Chapter 04</ChapterString>
</ChapterDisplay>
</ChapterAtom>
<ChapterAtom>
<ChapterUID>11556711324240879944</ChapterUID>
<ChapterTimeStart>00:00:03.999995315</ChapterTimeStart>
<ChapterDisplay>
<ChapterString>Chapter 05</ChapterString>
</ChapterDisplay>
</ChapterAtom>
<ChapterAtom>
<ChapterUID>6789293790652085347</ChapterUID>
<ChapterTimeStart>00:00:05.000001955</ChapterTimeStart>
<ChapterDisplay>
<ChapterString>Chapter 06</ChapterString>
</ChapterDisplay>
</ChapterAtom>
<ChapterAtom>
<ChapterUID>815895495329946186</ChapterUID>
<ChapterTimeStart>00:00:05.999998180</ChapterTimeStart>
<ChapterDisplay>
<ChapterString>Chapter 07</ChapterString>
</ChapterDisplay>
</ChapterAtom>
<ChapterAtom>
<ChapterUID>13740887356558005711</ChapterUID>
<ChapterTimeStart>00:00:07.000004820</ChapterTimeStart>
<ChapterDisplay>
<ChapterString>Chapter 08</ChapterString>
</ChapterDisplay>
</ChapterAtom>
<ChapterAtom>
<ChapterUID>7577353493033748017</ChapterUID>
<ChapterTimeStart>00:00:08.000001045</ChapterTimeStart>
<ChapterDisplay>
<ChapterString>Chapter 09</ChapterString>
</ChapterDisplay>
</ChapterAtom>
</EditionEntry>
</Chapters>
#4 | Link |
I have a little problem with MKVToolnix: I used nPlayer to copy the 4K recorded video from my iPAD PRO 10.5 to another folder, so it was converted from MOV to MP4.
These are the details from the MP4 (now saved in my PC): https://pastebin.com/GWRkfxyD And as you can see the file is playing fine. https://imgur.com/a/PRKWy0P Now watch what happens when I add the MP4 to MKVToolnix and save as MKV: https://imgur.com/a/uWTiCx5 Why? And how to avoid this? It seems the iPAD is sending a command (embedded inside the MP4, of course) to MKVToolnix, to turn the image upside down. The funny thing is that everywhere I play this content it is not upside down. When added to MKVToolnix it changes to this. Edit: now I spotted this in the file properties: Rotation: 180° What the hell? Last edited by Perenista; 19th July 2018 at 21:20. |
#5 | Link |
The video has been recorded upside-down but a flag in the MP4 container tells players to rotate the video by 180° upon display (so that display is corrected). When mkvtoolnix remuxes the mp4 file this flag is lost because such a flag doesn't exist for mkv. Nothing you can do except re-encode the video or stick to mp4. (There are SEI messages for orientation in H.264 that mkvtoolnix would keep but I don't know a software to change them nor if any player supports them.)
#6 | Link | |
If this was an AVI I could easily open VirtualDUB and use directstream copy to save without reencode. I need to edit this MP4 in this way: - I recorded with the iPAD, however I used a tape recorder which then saved the ambient audio as a MP3. (this is way better than the audio recorded from the iPAD) What I need to do: 1) Remove the audio stream from the MP4 recorded by the iPAD. 2) Add the MP3 from the tape recorder, which is now synchronized. I did this: - Extracted the video as RAW (Yamb option). I did this with the MP4 taken from the iPAD. Resulting file: IMG_1513_track1.h264 Then I used Yamb to join the video and audio streams. Again upside down. Why Apple continues to do this sort of c.rap to force users into reencodes is beyond me. In a 2013/14 PC it takes several hours to reencode in 4K quality, using Sony Vegas. And the final result, even if it's good, it's not as good as the original MP4 file (and there was a reduction from 6.82 to 3.63 GB). I'll see if there's something that can be done... It makes no sense to say this was recorded upside down since I only used landscape mode and while I was looking at the iPAD camera the image was not upside down. ![]() ***** Edit: I did it! Problem solved! There was no need to reencode. ![]() https://stackoverflow.com/questions/...ut-re-encoding This is what should be done: Look at that part... True lossless rotation of MP4: open mp4 with hex editor and search for vide to find the metadata of the video track some rows above (for my files mostly 9, sometimes 12) you should see trak...\tkhd in between there should be an @ sign (HEX 40) in the two rows before it the rotation matrix is stored (...) Last edited by Perenista; 20th July 2018 at 04:43. |
#8 | Link |
MKVToolNix author
You can generally see available shortcuts on controls by pressing and holding Alt. In case of the English variant, you'll then see that the "Add source files" button has an accelerator on the A, meaning you can press Alt+A to activate it.
Latest MKVToolNix is v100.0 If I ever ask you to upload something, please use my file server. |
#10 | Link |
MKVToolNix author
That's intentional so that things such as adding files to a running instance via the command line (or drag & drop onto the program icon or via Windows "send to" functionality) works.
You can easily work on multiple things at the same time in that single instance, though: just open new tabs in the tool you need. Note that the job queue is run asynchronously, meaning you can continue using the tools (multiplexer, info too, chapter editor, header editor) while jobs are being executed.
#11 | Link |
the build "mkvtoolnix-32-bit-25.0.0-revision-008-ga86e6cece" is broken
it can't open mkv file, nothing happen, no error message, nothing, all buttons stay disable I have to kill the task for close mkvtoolnix.
#12 | Link |
Useful n00b
Your problem is described in #6 here:
https://forum.doom9.org/forum-rules.htm Just like the good ol' days.
#13 | Link |
And instead of chastizing posters you should adhere to what a former moderator had to say about such things:
https://forum.doom9.org/showthread.p...68#post1432768 |
#15 | Link |
MKVToolNix author
Thanks for the heads-up. It actually does work, it just accidentally reads the whole file during identification which can take quite a long time. I've fixed it.
#16 | Link | |
![]() PS: is there a button in the attachment tab, or do I need to use the right click? |
#17 | Link |
MKVToolNix author
The latter.
#18 | Link | |
Is the RHEL repo URL wrong?
Adding the repo and then trying to update produces: Quote:
Edit: Looks like CentOS and RHEL use different $releasever variables: https://github.com/alanfranz/docker-...lder/issues/15 & https://stackoverflow.com/questions/...or-7-as-output Last edited by Snowknight26; 30th July 2018 at 17:20. |
#19 | Link |
![]() Join Date: Oct 2001
How experimental is av1 support atm. ?
Using: Code:
ffmpeg -y -loglevel fatal -threads 8 -i "D:\TestClips&Co\files\test.avi" -map 0:0 -an -sn -vf zscale=rangein=tv:range=tv -pix_fmt yuv422p -vsync 0 -f yuv4mpegpipe - | aomenc --passes=1 --pass=1 --end-usage=cq --cq-level=18 --target-bitrate=15000 --profile=1 --cpu-used=6 --min-q=0 --max-q=63 --undershoot-pct=0 --buf-sz=6 --buf-initial-sz=4 --buf-optimal-sz=5 --drop-frame=0 --kf-min-dist=0 --kf-max-dist=250 --auto-alt-ref=0 --noise-sensitivity=0 --sharpness=0 --static-thresh=0 --tune-content=default --tile-columns=2 --tile-rows=1 --min-gf-interval=0 --max-gf-interval=0 --threads=2 --width=640 --height=352 --i422 --input-bit-depth=8 --bit-depth=8 -o "E:\Temp\22_34_07_3710_01.ivf" - Code:
mkvmerge --ui-language en -o "E:\Output\test.mkv" -d 0 --default-track 0:yes --default-duration 0:25/1fps --aspect-ratio-factor 0:1/1 --engage enable_av1 --no-chapters --compression -1:none --forced-track 0:yes --no-audio --no-subtitles "E:\Temp\22_34_07_3710_01.ivf" Code:
mkvmerge v25.0.0 ('Prog Noir') 64-bit
'E:\Temp\22_34_07_3710_01.ivf': Using the demultiplexer for the format 'IVF (AV1, VP8, VP9)'.
'E:\Temp\22_34_07_3710_01.ivf' track 0: Using the output module for the format 'AV1'.
The file 'E:\Output\test.mkv' has been opened for writing.
Error: An exception occurred when writing the destination file. The drive may be full. Exception details: end of file error; No error
Cu Selur Ps.: uploaded the ivf file to: https://drive.google.com/open?id=0B_...TlILW54VThMTFU |
#20 | Link |
MKVToolNix author
It's completely unusable. Treat the code as if it didn't exist.
Longer explanation: The specs for AV1-in-Matroska and AV1-in-WebM haven't been finalized yet. They will definitely look differently than what mkvmerge produces. mkvmerge's OBU parser is also based on an older bitstream format and cannot process 1.0 bitstreams. Currently work on the specification for AV1-in-Matroska/WebM is ongoing on the CELLAR list (and other threads about "AV1 seeking" & "AV1 init" on the same ML).
| Tags |
| matroska |
