#1 | Link |
Apprentice
x264: stat file error
Hello there. I'm coding an anime release and get these messages:
avis [info] 640x480 @ 23.98 fps (34640 frames) x264 [info] using CPU capabilities MMX MMXEXT SSE SSE2 x264 [warning] VBR maxrate specified, but no buffsize x264 [error] ratecontron_init: can't open stats file x264 [error] x264_encoder_open failed CLI settings are: --pass 2 --bitrate 950 --stats ".stats" --ref 3 --no-fast-pskip --bframes 3 --b-pyramid --b-rdo --bime --weightb --nf --subme 6 --trellis 1 --analyse all --8x8dct --vbv-maxrate 25000 --threads auto --thread-input --progress --no-psnr --no-ssim --output "C:\c\l_115\115.mp4" "C:\c\l_115\115.avs" AVS is like: Avisource("BLEACH 115 (DivX6.25 640x480 120fps).avi").ChangeFPS(23.976) sing1=avisource("s5_logo.avi") trim(0,245)+trim(246,335).overlay(sing1,mask=sing1.showalpha())+trim(336,0) textsub("bl_115_credits.ass") textsub("OP_5_KARA.ass") textsub("BLEACH_115_TS.ass") textsub("ED_10_KARA.ass") freezeframe(0,4,5) What can i possibly do to avoid this? Just in case, BLEACH is not licenced in Russia. |
#2 | Link |
If you are using only a CLI version (no GUI) this setting are bad, because you need a first pass before apply a second pass. The first pass analyze and distribute bitrate for the second pass and create a .stats file where this datas are store. Your setting said --pass 2, so... where are --pass 1? you need make a first pass.
If you are using megui (for example) the most probable you don't choose automated 2pass, and select only second pass, so only second pass are make. Second pass need .stats for encode proccess. Anyway, copy/paste entire logs |
#3 | Link |
Apprentice
I'm using meGUI, and I'm using Automated 2 pass. But it gets stuck at 100% of the 1st pass, still showing me some FPS data. So I just copy-pasted the command line parameters from the box to cmd. So there are no meGUI logs.
I'm pretty dumb, didn't notice --pass 2. Changed it to --pass 1. Then the 1st pass ran up to 100%, and I had this: http://i4.photobucket.com/albums/y124/RazorAV/001-1.jpg Windows has pretty dumb commandline with no possibility to select it, so I had to do a screenshot. It just stuck there for approx 30 min. Is this really ok? I had to CTRL-C it =__= |
#4 | Link |
ok ok
![]() all right ![]() You use megui to generate the command line right? then you copy the command and paste in command pronts. ![]() When you select automated 2 pass in megui, he send to the queue the two pass. in command line box in megui you only can view the second pass, the first pass only in logs. the best options are using megui for all, but if you want use command pront, you need add before the first pass. For your options, before use your options, you need the first pass. First Pass: (for a normal and slow first pass) Code:
--pass 1 --bitrate 950 --stats "1.stats" --ref 3 --no-fast-pskip --bframes 3 --b-pyramid --b-rdo --bime --weightb --nf --subme 6 --trellis 1 --analyse all --8x8dct --vbv-maxrate 25000 --threads auto --thread-input --progress --no-psnr --no-ssim --output NULL "C:\c\l_115\115.avs" Second pass, your pass: Code:
--pass 2 --bitrate 950 --stats "1.stats" --ref 3 --no-fast-pskip --bframes 3 --b-pyramid --b-rdo --bime --weightb --nf --subme 6 --trellis 1 --analyse all --8x8dct --vbv-maxrate 25000 --threads auto --thread-input --progress --no-psnr --no-ssim --output "C:\c\l_115\115.mp4" "C:\c\l_115\115.avs" Last edited by Theliel; 28th March 2007 at 10:49. |
#5 | Link |
Apprentice
Well.. I tried that. But it still halted at the same point for some reason. Then I stopped it with CTRL-C. Then I initiated the 2nd pass, which halted there as well. The resulting file was not playable, though the size seemed ok.
http://i4.photobucket.com/albums/y124/RazorAV/002-1.jpg -- that's what it looks like And you know.. this preset did actually encode me a file named NULL after the 1st pass
#6 | Link |
ok, the only problems I can see its the stats name, I have edit my previous post, try again please.
yes, the first pass only output are a 1.stats file, that is specificate in --stats "1.stats" so the output file are NULL Last edited by Theliel; 28th March 2007 at 10:51. |
#8 | Link |
then i cant help you much more, sorry
, for me work perfectly, I have done some test exactly with your same settings, and all work fine. I hope anyone can help you:![]() and video play fine. I can't test all because i haven't your sample, subtitules, logo... if you can upload all them i can do more test Only I can said more, sure you have the latest megui/x264/avisynth... luck. |
#9 | Link |
Apprentice
Yep, I have the latest software.. =__=
Just wondered, can it possibly because I have a two-core CPU.. My friend told me to switch threads to 2, but still I had the same problem. This time I put it in the meGUI. Looks kinda hopeless ) I've reinstalled windows three times, so this must not be the case. I did render similar avs scripts on the older machine, and it all worked fine. The raws were the same, the logo was the same.. I'm kinda puzzled O_o Code:
Looking for job processor for job... Processor found! Starting job job1-1 at 16:38:15 Starting preprocessing of job... Preprocessing finished! encoder commandline: --pass 1 --bitrate 950 --stats "C:\c\l_115\115.stats" --bframes 3 --b-pyramid --nf --subme 1 --analyse none --vbv-maxrate 25000 --me dia --threads 2 --thread-input --progress --no-psnr --no-ssim --output NUL "C:\c\l_115\115.avs" successfully started encoding Job aborted, deleting output file...Deletion failed. Processing ended at 16:54:19 ---------------------------------------------------------------------------------------------------------- Log for job job1-1 avis [info]: 640x480 @ 23.98 fps (34640 frames) x264 [info]: using cpu capabilities MMX MMXEXT SSE SSE2 x264 [warning]: VBV maxrate specified, but no bufsize. x264 [info]: slice I:303 Avg QP:16.43 size: 28290 x264 [info]: slice P:19843 Avg QP:19.07 size: 7075 x264 [info]: slice B:14494 Avg QP:20.41 size: 1698 x264 [info]: mb I I16..4: 31.9% 0.0% 68.1% x264 [info]: mb P I16..4: 13.2% 0.0% 0.0% P16..4: 46.9% 0.0% 0.0% 0.0% 0.0% skip:39.9% x264 [info]: mb B I16..4: 0.6% 0.0% 0.0% B16..8: 13.5% 0.0% 0.0% direct:13.5% skip:72.4% x264 [info]: final ratefactor: 23.33 x264 [info]: kb/s:961.1 ---------------------------------------------------------------------------------------------------------- The current job was aborted. Stopping queue mode The current job contains errors. Skipping chained jobs |
#11 | Link |
Angel of Night
![]() Join Date: Nov 2004
Is it hanging with or without cpu usage? If you could use process explorer to look at the threads, you might be able to find what's hanging. Maybe it's avisynth.
btw, to copy from a command window, right click and choose "mark", then select what you want and right click again to copy. In the window's properties is a "quickedit" option that leaves this mark mode on all the time, quite handy. |
#13 | Link |
Angel of Night
Pegging the cpu without performing useful work is hanging, whether it's x264 or megui or the command window doing it. That's why I was asking you to look at the threads (of x264 specifically), you might get a clearer idea of what's causing the hang. For instance, vsfilter had a bug for a while that would cause this exact sort of hang, except for remaining in memory after being closed until terminated.
#14 | Link |
Apprentice
At 100% of progress:
x264 - 132 mb, 98-99% of CPU. megui - 38 mb, 0-1% of CPU And no side processes are shown.. just exactly the programmes that are running. meGUI is actually responding to all the commands. And strangely enough, it still has some FPS data showing, which is gradually slowing down. |
#17 | Link |
6 -> No warez, cracks, serials or illegally obtained copyrighted content! Links to content of a questionable nature, asking for, offering, or asking for help/helping to process such content in any way or form is not tolerated??
I dont understand. |
#20 | Link |
Angel of Night
Doom9 decided that fansubs were off limits a long time ago, regardless of their licensing status in individual countries. This has been discussed here many times, you must have been aware of it. You'll have to PM him if you want the thread reopened and the strike revoked.
I obviously didn't read the script closely (probably half asleep), but now that I have I know exactly what the problem is. I guess I should have earlier. Oh well. |
