Old 17th December 2023, 14:28   #1521  |  Link
Dogway
I know FFMS2 can't but does LSMASH support image batch loading? something like IMG_%04d.JPG?
The only image loader that I know that does this is ImageSource, but that one converts the images to RGB internally.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
Old 17th December 2023, 17:03   #1522  |  Link
kedautinh12
You can try ImageSequence
http://avisynth.nl/index.php/ImageSequence
Old 17th December 2023, 17:36   #1523  |  Link
Dogway
CoronaSequence outputs RGB, I tried RawSequence() but it gives an error:
Error requesting frame 0
Cache: Filter returned invalid response to
CACHE_GETCHILD_AUDIO_MODE.10
Anyway, for today I solved it using batch scripts, but would be good to have a nice image sequence loader for next times.
Old 17th December 2023, 17:59   #1524  |  Link
kedautinh12
You can try JpegSource too
http://avisynth.nl/index.php/JpegSource
Old 20th December 2023, 23:17   #1525  |  Link
Dogway
JpegSource can load image sequences? Anyway it's an outdated (x86) closed source plugin, it's the best jpeg decoder quality wise but no help there.
Old 21st December 2023, 03:25   #1526  |  Link
qyot27
qyot27's Avatar
To answer this original question, yes it does (at least on Linux, but as filename handling should be internal to the plugin, I would assume that's also true on Windows).
I output a sequence of PNG files as well as a sequence of JPGs, and LwLibavVideoSource was totally cool opening the entire sequence using:
The PNG sequence remained bgr24, the JPG sequence remained yuv420p.
Old 21st December 2023, 14:31   #1527  |  Link
at least on Linux
On W10 [EDIT: x64],
create_RGB.avs
# Export "Image Sequence" to ".\PIC_RGB" existing directory via VDUB2,  png with basename="RGBIMAGE_" and 6 digits
Colorbars(Pixel_Type="RGB24")
ShowFrameNumber
Trim(0,-100)
RgbIn.avs
LwLibavVideoSource(".\PIC_RGB\RGBIMAGE_%06d.png")    # "PIC_RGB" directory within the current directory.
Works OK,
create_YUV.avs
# Export "Image Sequence" to ".\PIC_YUV" existing directory via VDUB2,  jpeg  with basename="YUVIMAGE_" and 6 digits
Colorbars(Pixel_Type="YV12")
ShowFrameNumber
Trim(0,-100)
YuvIn.avs
LwLibavVideoSource(".\PIC_YUV\YUVIMAGE_%06d.jpg")    # "PIC_YUV" directory within the current directory.
Avisynth open failure.
[Fatal]: Failed to avformat_open_input.
EDIT: Oops, WORKS (returned as YV24, pre save source was YV12 [VDUB may have changed for save])
YuvIn.avs
LwLibavVideoSource(".\PIC_YUV\YUVIMAGE_%06d.jpeg")    # VDub2 exported with 'jpeg' extension
Old 22nd December 2023, 00:44   #1528  |  Link
Reel.Deel
It cannot. SEt had it on his todo list but never happened.
Nice tip, I had no idea LwLibavVideoSource was able to do that.
Another method of opening up image sequences is ImageSourceNV but requires an NVidia GPU and it converts YUV images to 4:4:4.
Old 22nd December 2023, 00:45   #1529  |  Link
flossy_cake
I am confused about drc_scale:
0.0 : DRC disabled. Produces full range audio.
# ok I understand this
0.0 < drc_scale <= 1.0 : DRC enabled. Applies a fraction of the stream DRC value. Audio reproduction is between full range and full compression.
# ok so 0.5 gives half compression, 1.0 gives full compression, understood
> 1.0 : DRC enabled. Applies drc_scale asymmetrically. Loud sounds are fully compressed. Soft sounds are enhanced.
# I thought 1.0 was already fully compressed?  What is meant by "asymmetrically"?
Old 22nd December 2023, 10:52   #1530  |  Link
tebasuna51
tebasuna51's Avatar
You can read this thread about DRC and see the attached image with the volume amplify/ attenuation values (the most common is Film Standard) applied to the audio.
With drc=0 the 'None' curve is applied, with drc=1 the showed curve is applied and with drc>1 a more agresive (plane) curve must be applied with all sounds at same volume.
Of course apply drc is only recommended at play time, never when you want recode or recover the original audio.
Old 23rd December 2023, 05:38   #1531  |  Link
flossy_cake
Very useful, thanks.
I can now try to emulate these in soxfilter as well - great!
Old 24th December 2023, 00:47   #1532  |  Link
tebasuna51
tebasuna51's Avatar
Maybe like this?
Old 24th December 2023, 04:05   #1533  |  Link
kedautinh12
L-SMASH-Works 1161.0.0.0 (info in this link, just click. If you confused, don't use it)
https://github.com/HomeOfAviSynthPlu...Works/releases
Old 24th December 2023, 11:58   #1534  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Thanks for the Christmas present, asd-g!
Old 25th December 2023, 05:59   #1535  |  Link
flossy_cake
Hell yes that's just what I wanted
Old 26th January 2024, 20:17   #1536  |  Link
Dogway
On W10 [EDIT: x64],
create_YUV.avs
ShowFrameNumber
Trim(0,-100)
YuvIn.avs
YuvIn.avs
That's the error I get for an image sequence of P1000054.JPG, P1000070.JPG, P1000074.JPG, etc.
Explicitly loading by the filename opens it but the sprint syntax calls that error. Tried with "P1000%03d.JPG", on Win11 x64.
Old 27th January 2024, 03:20   #1537  |  Link
poisondeathray
Is that the right numbering ?
If "gap" / "gapless" isn't supported maybe you can request that feature
What should it return ? Black "placeholder" frames inbetween ? Or just the frames present ?
Old 27th January 2024, 17:12   #1538  |  Link
Try "P1%06d.JPG" (or for Vdub2 output "P1%06d.JPEG")
EDIT: Maybe the literal "000" of "P1000%03d.JPG" is confusing the code, somehow.
EDIT: Also if prob try,
".\P1%06d.JPG" or ".\P1%06d.JPEG",
or full path in place of current directory relative ".\".
EDIT: OK, maybe I misunderstood, looks like PDR got it.
EDIT: LWLibavVideoSource seems not to have equivalent to ImageSource("...",end=100)
LWLibavVideoSource(string source, int stream_index = -1, int threads = 0, bool cache = true, string cachefile = source + ".lwi",
int seek_mode = 0, int seek_threshold = 10, bool dr = false, int fpsnum = 0, int fpsden = 1,
bool repeat = unspecified, int dominance = 0, string format = "", string decoder = "", int prefer_hw = 0,
int ff_loglevel = 0, string cachedir = "", string ff_options = "")
Old 28th January 2024, 00:09   #1539  |  Link
Dogway
Thanks StainlessS, tried P1%06d.JPG, no dice.
Frames present. These are the photos I selected from the set, and want to bulk filter them (resize, etc) with AVS+ tools.
I just tested renaming them to P1000000.JPG and P1000001.JPG and they load (both) fine. Also starting from P1000001, and so on. So the only problem it has is the numbering gaps. I can rename them to sequential temporally but could great to have this feature embedded.
Old 28th January 2024, 14:28   #1540  |  Link
Doggy, loads all files matching, "P1??????.JPG|JPEG" # "P1" + 6 characters (hopefully Digits) + "." + ("JPG" OR "JPEG")
Untested.
IN_FILES = "P1??????.JPG|JPEG"                           # "P1" + 6 characters (hopefully Digits) + "." + ("JPG" OR "JPEG")
OUT_FILE = "FILE.List"
result   = RT_WriteFileList(IN_FILES,OUT_FILE)          # Create a listing file of Pic filenames
Assert((result!=0), "No files found")
FILELIST = RT_ReadTxtFromFile(OUT_FILE)                 # Get list of files
#RT_FileDelete(OUT_FILE)                                # we are done with the temp file
NFILES   = RT_TxtQueryLines(FILELIST)                   # Query Number of lines in String ie number of files.
RT_Debug("Found files = " + String(NFILES))
C=0                                                     # Dummy clip
For(i=0,NFILES-1) {
    FN=RT_TxtGetLine(FILELIST,i)                        # Filename
    tmpC = ImageSource(FN,end=0)
#    tmpC = LwLibavVideoSource(FN)
    C = (C.IsInt) ? TmpC : C + TmpC                     # All clips must be same size.
C # EDIT: OOps, forgot this
EDITED: still untested.
