Old 22nd December 2022, 22:11   #1441  |  Link
I've had enough of you sychophants, now be quiet.
Sick-o-phants
EDIT To Below, : And MXM 2U2 LigH.
where is HanFrunz, bit late again.
Old 23rd December 2022, 12:58   #1442  |  Link
LigH
I shot my foot with sugar
LigH's Avatar
MXM 2U2, Tinman.
New German Gleitz board
Old 20th February 2023, 21:11   #1443  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
For those who didn't get the GitHub notification, asd-g posted a new version here:
https://github.com/HomeOfAviSynthPlu...Works/releases
Changelog:
LSMASHAudioSource: fixed lsmash wrong endian box. (#26)
FFmpeg updated to e0cb89c.
l-smash updated to 642c4cd.
Old 19th April 2023, 09:24   #1444  |  Link
LeXXuz
24 years and counting...
LeXXuz's Avatar
Anyone else still having problems with special characters in the file path/name like German umlauts?
LeXXuz is offline   Reply With Quote
Old 28th April 2023, 08:37   #1445  |  Link
nechto
I have issues with Ru symbols ...
nechto is offline   Reply With Quote
Old 28th April 2023, 09:25   #1446  |  Link
kedautinh12
Me too with Vietnamese alphabet
Old 5th May 2023, 13:38   #1447  |  Link
guest
Posts: n/a
@ LeXXuz, nechto & kedautinh12...
check this out:-
https://github.com/HomeOfAviSynthPlu...orks/issues/31
and
https://superuser.com/questions/1715...t-another-enco
This may "fix" the special characters problems...
But I'm having decoder problems.
UPDATE:- Setting the UTF-8 didn't fix my decoding problem, BUT, either of the "test" builds DID . So now "we" just need a "fixed" L-Smash release.
Old 5th May 2023, 15:18   #1448  |  Link
LeXXuz
LeXXuz's Avatar
I'll give that a spin.
Old 8th May 2023, 06:53   #1449  |  Link
guest
Posts: n/a
There's a new build
https://github.com/HomeOfAviSynthPlu...s/tag/20230507
Old 8th May 2023, 08:16   #1450  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Yep, I've got the notification from GitHub yesterday evening but I was watching the Coronation Concert on the BBC (the lights display with the drones was stunning as always) and I didn't feel like booting Windows ehehehehehe
Anyway, as far as Italian characters are concerned, looks like the UTF-8 issue is fixed.
I'll leave you guys testing on other esoteric languages :P
Old 11th June 2023, 05:56   #1451  |  Link
kedautinh12
L-SMASH-Works 20230611
Fixed _EncodedFrameTop and _EncodedFrameTop, close #32. Changed behavior - they are showed only when there are frames to be repeated.
Fixed _FieldBased when repeat is not false.
Used libraries:
FFmpeg d78bffb.
l-smash 2c0696c.
obuparse 055be27.
zlib 1.2.13.
dav1d 1.2.1.
libxml2 v2.11.4.
nv-codec-headers n12.0.16.0.
xxHash v0.8.1.
mfx_dispatch 5a3f178.
Old 22nd June 2023, 07:58   #1452  |  Link
flossy_cake
Unfortunately not fixed in latest version:
Originally Posted by flossy_cake View Post
Here is a clip which LWlibavVideoSource cannot seem to play properly: https://drive.google.com/file/d/1lHB...usp=share_link
file = "480i multiple cadences.mkv"
AudioDub(LWlibavVideoSource(file, repeat=true), LWLibavAudioSource(file, stream_index=-1))
ScriptClip(last, """SubTitle(String(propGetAny(last, "_FieldBased")))""")
However I have done rips of my own physical copy NTSC dvd's using MakeMKV and those work fine with repeat=true so I'm thinking it's some issue with the software that was used to create the MKV file. In all cases it's MPEG2 video stream remux.
Another test clip same problem: https://rationalqm.us/misc/lainvob.vob
Old 8th July 2023, 13:14   #1453  |  Link
tebasuna51
tebasuna51's Avatar
Please support AviSynth+ r4001 including the audio channel mask.
Old 9th July 2023, 02:46   #1454  |  Link
kedautinh12
Report here will be faster
https://github.com/HomeOfAviSynthPlu...H-Works/issues
Old 9th July 2023, 11:31   #1455  |  Link
tebasuna51
tebasuna51's Avatar
Done https://github.com/HomeOfAviSynthPlu...orks/issues/35
Old 15th July 2023, 11:13   #1456  |  Link
tebasuna51
tebasuna51's Avatar
A new version to test in https://github.com/HomeOfAviSynthPlu...orks/issues/35
For me work fine with some samples ac3, eac3 and dts.
Old 16th July 2023, 17:24   #1457  |  Link
kedautinh12
L-SMASH-Works 20230716
AviSynth: set audio property Channel Mask (#35).
Used libraries:
FFmpeg e62f344.
l-smash 2c0696c.
obuparse f40598f.
zlib 1.2.13.
dav1d 1.2.1.
libxml2 v2.11.4.
xxHash v0.8.1.
Old 31st July 2023, 23:19   #1458  |  Link
almosely
Just wanted to report that I have updated from L-SMASH-Works (2022-11-09) to the newest and it did not work for me anymore. I tried to play a youtube video from 2017 ...
LWLibavVideoSource("Federer.vs.Nadal.720p.HD.Australian.Open.Final.2017.mkv", format="YUV420P8", prefer_hw=1)
Video
Format : AVC
Format profile : High@L4.1
Format settings : CABAC / 7 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 7 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 3 h 18 min
Bit rate : 3 778 kb/s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 59.940 (60000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.068
Stream size : 5.24 GiB (96%)
Default : Yes
Forced : No
... but it stuttered and had pixel errors all over. Hardware is GeForce GTX 660 TI and Core i7-3770. Windows 10.
Then I tried backwards until L-SMASH-Works (2023-05-07) is working for me again. So 06 and 07 aren't working anymore. I am using the newest AVS+ 64 and my C++ Runtimes are up to date too. Just my 2ct.
almosely is offline   Reply With Quote
Old 1st August 2023, 03:01   #1459  |  Link
kedautinh12
Old 1st August 2023, 14:37   #1460  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Also keep in mind that hardware accelerated decoding has always been a hit and miss.
If you want something reliable, software decoding is the way to go (i.e don't specify prefer_hw=1).
