Old 31st October 2020, 01:02   #1281  |  Link
kedautinh12
Originally Posted by manolito View Post
DSS2Mod with LAV Filters (preroll=15):
Perfect
Can you share link download??
Old 31st October 2020, 03:42   #1282  |  Link
poisondeathray
http://avisynth.nl/index.php/DSS2mod
The seeking might be ok, but beware DSS2mod usually drops the last 1 or 2 frames. 1 frame in this example. You might not "see" it if the test limit was 1000 frames
Old 31st October 2020, 08:38   #1283  |  Link
StvG
I thinks thread=8 very strong for weak computer, can you fixed with default thread for both ffms2 and lsmash??
I should clarify that threads=8 for ffms2 from my previous post is cpu_threads/2. So you can try with that cpu_threads/2.
Yes, I used the version you linked to from October 2020.
I got curious and made a couple of tests using different source filters with Atak's SeekTester 1.2. I used the default frame limit of 1000 frames. As the source I took the "Letter - SHE'S.mkv" (VP9 Video 1080p). My CPU is a Core i5 third generation (2 physical cores plus hyperthreading). I used the default thread values for all source filters which would be 4 for this CPU.
FFMS2 StvG from Oct. 2020:
There were 12 corrupted frames out of 1000 frames.
FFMS2 StvG from Aug. 2020:
Same
FFMS2 StvG from April 2020:
Same
FFMS2 StvG from Nov. 2019:
Same
FFMS2 C-Plugin latest 2.31 by qyot27
Perfect
FFMS2 C-Plugin by Reino:
Both available versions fail miserably. Mainly corrupted or inserted frames
FFMS2 official version 2.40 by Myrsloik:
Fails miserably. Mostly corrupted or inserted frames
DirectShowSource with LAV Filters:
Many inserted frames
Perfect
LWLibavVideoSource by HolyWu:
Perfect
Ok, these results are only for this specific VP9 source file. Other source formats may behave differently, but I find this very interesting. Any comments?
Thanks for sharing.
StvG is offline   Reply With Quote
Old 7th December 2020, 05:29   #1284  |  Link
kedautinh12
I meet many corrupted frames in STVG ver with default threads, only work with threads >= 2. But with HolyWu ver, i don't meet error with default threads:
My video test:
https://drive.google.com/file/d/17yc...ew?usp=sharing
My scripts:
nnedi3_rpow2(rfactor=2, cshift="spline64resizemt", fwidth=1920, fheight=1080)
F3KDB_3(range=12, y=60, cb=40, cr=40, grainy=0, grainc=0)
f3kgrain()
Old 7th December 2020, 07:19   #1285  |  Link
manolito
manolito's Avatar
Yes, I also had to return to the HolyWu build for exactly this reason...
I believe that StvG should implement a similar logic for the number of threads which he used in his last ffms2 build:
- changed the default threads number:
* VP9 - min(CPU logical processors, 8);
* AV1 - 1 when CPU logical processors = 1, otherwise 2;
* rest - CPU logical processors;
Old 8th December 2020, 15:19   #1286  |  Link
real.finder
maybe it's time for new update from StvG, since there are new small update here https://github.com/Asd-g/L-SMASH-Works
See My Avisynth Stuff
Old 11th December 2020, 23:44   #1287  |  Link
StvG
Update - included the latest commit; ffmpeg@494f868e93; zlib 1.2.11; lsmash@18a9ed2; xxHash 0.8.0; dav1d 0.8.0; changed VP9 default threads to 2 when CPU logical processors > 2.
Old 11th December 2020, 23:55   #1288  |  Link
kedautinh12
Thanks
Old 15th December 2020, 20:57   #1289  |  Link
stax76
stax76's Avatar
vs support?
Old 16th December 2020, 22:05   #1290  |  Link
StvG
Originally Posted by stax76 View Post
vs support?
Here dualsynth ver.
Old 17th December 2020, 20:24   #1291  |  Link
stax76
stax76's Avatar
Here dualsynth ver.
Awesome, thanks!
Old 18th December 2020, 08:43   #1292  |  Link
LigH
I shot my foot with sugar
LigH's Avatar
@StvG: Are there easy-to-apply patches so that you could e.g. suggest them to media-autobuild suite?
New German Gleitz board
Old 18th December 2020, 20:42   #1293  |  Link
StvG
It's not only patches. You need Visual C++ libraries for Avisynth but media-autobuild suite doesn't provide such. If you have them installed then using mingw could be easily used.
Old 20th December 2020, 07:39   #1294  |  Link
LigH
LigH's Avatar
Oh, I believe I replied to the wrong thread. I was rather interested in patches for x265 like the aMod by DJATOM.
Old 13th January 2021, 16:34   #1295  |  Link
Nico8583
Here dualsynth ver.
Hi, what is dualsynth version ? Does it work wit AviSynth or do I use the 12.12.2020 version ? Thank you.
Nico8583 is offline   Reply With Quote
Old 13th January 2021, 18:24   #1296  |  Link
ChaosKing
The DLL works with Avisynth and Vapoursynth.
Old 14th January 2021, 18:05   #1297  |  Link
Nico8583
Thank you !
Old 8th February 2021, 11:01   #1298  |  Link
kedautinh12
I seen new commit here, any compile update for this??
https://github.com/HomeOfAviSynthPlu.../L-SMASH-Works
Old 15th February 2021, 07:17   #1299  |  Link
MeteorRain
結城有紀
It's for my own use. You shouldn't use my version unless you know what you are doing.
My Projects
x265 - Yuuki-Asuna-mod
TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS
Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median
MeteorRain is offline   Reply With Quote
Old 25th March 2021, 15:54   #1300  |  Link
frank
Banned
Sorry, in the latest binaries from StvG the hardware decoders don't work anymore.
With v20200728 from HolyWu they work.
frank is offline   Reply With Quote
