Old 30th November 2015, 08:53   #3821  |  Link
ndjamena
I think this is a continuation of Jamaikas desire to add interactive tags to his files.
JSON changes NOTHING about the files themselves, it has nothing to do with the Matroska Specs. All it does is change the OUTPUT of a single command in the MKVMerge application.
MKVMerge -I file.mkv
or
MKVMerge -i file.mkv
It just makes it easier for other applications to decipher MKVMerges identification output, nothing more.
ndjamena is offline
Old 30th November 2015, 08:58   #3822  |  Link
Jamaika
Originally Posted by Mosu View Post
no, that's way too much effort for not enough gain.
Thanks all. Now I understand everything.
Jamaika is offline
Old 30th November 2015, 18:34   #3823  |  Link
cengizhan
That's normal, intentional and exactly how it should work. The file's duration is the difference between its maximum timestamp and its minimum timestamp. Just because players stop when the video track stop doesn't mean the file ends there.
i thought my video was corrupted or mkvmerge is bugged until i opened the subtitle file with an editor and saw it is longer than video.
cengizhan is offline
Old 1st December 2015, 10:11   #3824  |  Link
ndjamena
Is there a technical reason the header editor wouldn't be allowed to shuffle the positions of tracks, ie like rearranging subtitles?
I've been doing it manually, but it would be much easier if I could just drag and drop and not have to keep track of which track number was where in case I wind up duplicating one (or leaving one out, which is the same thing).
ndjamena is offline
Old 1st December 2015, 10:38   #3825  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
That functionality hasn't been implemented yet, neither in the GUI nor in mkvpropedit. I don't know if I'll ever implement it, though it's that I'd consider sometime in the future.
Latest MKVToolNix is v101.0
Mosu is offline
Old 1st December 2015, 10:54   #3826  |  Link
ndjamena
I'll stick to doing it manually then.
ndjamena is offline
Old 1st December 2015, 16:32   #3827  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Can someone please remind me what the final discussion was regarding to the possibility of muxing Dolby TrueHD streams and preserving the Dolby Digital core within the .mkv container? Is it technically possible now?
Cheers
SeeMoreDigital is offline
Old 1st December 2015, 16:42   #3828  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
If you mean you want to keep both the TrueHD and the AC3 data inside the same track: mkvmerge doesn't support that. Instead it will separate that data into two independent tracks. Meaning all of the data is preserved, but mkvmerge "sees" two tracks in such a case instead of a single one. That works even when re-muxing from M2TS, not just from elementary TrueHD files (.thd+ac3).
Mosu is offline
Old 1st December 2015, 17:32   #3829  |  Link
SeeMoreDigital
Yes, I realize that mkvmerge does not support this.
What I'd like to know is, is it now technically possible to do this with the Matroska container?
Old 1st December 2015, 17:40   #3830  |  Link
sneaker_ger
Mkvmerge does not support it because it is regarded as non-spec-compliant. The Matroska specs have not changed in this regard. (That may not hinder other software developers (makemkv?) to ignore that or interpret the specs in a different way.)
sneaker_ger is offline
Old 1st December 2015, 18:49   #3831  |  Link
SeeMoreDigital
Okay, thanks for the confirmation about this!
The reason I asked is because Oppo Digital recently removed TrueHD pass-through support for .mkv contained files due to a reliably issue with the Mediatek A/V decoding chip-set.
Oppo Digital have developed a work-around by transcoding multi-channel TrueHD audio to multi-channel PCM audio. But sadly if the TrueHD stream contains Atmos, the Atmos (object based) data is completely lost.
Sufficed to say, the Mediatek A/V decoding chip-set is able to 'pass-through' a TrueHD stream just fine when it's placed within the .m2ts container.
Cheers
Old 1st December 2015, 18:56   #3832  |  Link
nevcairiel
Sounds like they should fix their software. When you transmit TrueHD over HDMI, then the AC3 part is no longer present. The HDMI specs are pretty strict about that.
nevcairiel is offline
Old 1st December 2015, 19:30   #3833  |  Link
SeeMoreDigital
Yes and no. In the case of TrueHD in m2ts, the AC3 core is still present within the stream as is the AC3 flag. And you are able to select the different streams.
Old 1st December 2015, 19:40   #3834  |  Link
nevcairiel
Not once it reaches HDMI. What the player does in between is not really important there. Of course it can let you select the AC3 stream.
Old 1st December 2015, 19:59   #3835  |  Link
SeeMoreDigital
Regardless, it would still be useful if the Matroska container supported TrueHD along with the core (as it does with DTS-HD MA). As it would provide more logical support with playback devices such as Smart TV's.
It's a right pain having to go through all your Blu-ray .mkv back-ups to add the AC3 stream... Indeed, last night I fancied watching a bit of Gravity on my LG television but was greeted with an 'Audio format not supported' message.
Anyway, if it can't be done. It can't be done
Old 1st December 2015, 20:06   #3836  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
DTS-HD MA is a very different case. TrueHD and AC3 are completely independent sets of data. One can be decoded without the other. The TrueHD data can exist and be decoded alone. So can the AC3 data.
For DTS-HD MA the situation is vastly different. Here the MA part can, in general, NOT be decoded alone. Instead the DTS core is required for decoding the MA part, too.
Mosu is offline
Old 1st December 2015, 20:09   #3837  |  Link
nevcairiel
The only way this actually works in MPEG-TS is that it has special metadata to mark the AC3 frames as a "substream", only this way can players identify which frames belong to the TrueHD stream, and which belong to the AC3 stream. You can't just mux both together and hope for the best, it has to be muxed properly - otherwise every player is going to break.
It seems rather unlikely that inventing a new muxing scheme for such tracks would magically fix smart TVs. It seems far more likely that they are designed to deal with this MPEG-TS variant somehow, but their MKV implementation is just broken. If you have to cater to such a TV, it seems sensible to just keep your videos in MPEG-TS.
Surely it could be muxed in MKV say using BlockAdditions or something like that, just for the sake of keeping the two streams packed "together", but players would still need to handle that, so it wouldn't make any sense and wouldn't fix anything automagically.
Old 1st December 2015, 20:46   #3838  |  Link
SeeMoreDigital
I guess it's like any other implementation. Until somebody comes up with a method of doing it, device manufacturers wont be able to support it. Which really should be the advantage of adopting 'open-source' software in the first place
Old 1st December 2015, 21:11   #3839  |  Link
nevcairiel
You could just mux them in two distinct streams like it is today, and a device manufacturer could read it. Why it would need the AC3 stream in the first place is beyond me, however.
Screams faulty implementation to me. The AC3 stream is not required for the TrueHD stream to work.
Old 1st December 2015, 21:51   #3840  |  Link
SeeMoreDigital
You could just mux them in two distinct streams like it is today, and a device manufacturer could read it...
Yes I know I can. And I do. But that's not what I was enquiring about
