#3661 | Link |
MKVToolNix author
mkvmerge already does its best trying to recover as much data as possible. The message "Still resyncing…" means that it cannot find valid Matroska cluster IDs in the data. Basically there is no valid data left to recover.
To me it looks like an incomplete download, e.g. you started downloading via a BitTorrent client which pre-allocates the space, but it only the first part was actually downloaded. The rest of the file's allocated space is just garbage.
Latest MKVToolNix is v101.0 If I ever ask you to upload something, please use my file server. |
#3662 | Link |
MKVToolNix author
The MKVToolNix package contains a command-line only tool mkvextract for extraction. The MKVToolNix GUI doesn't have functionality for this yet, but it is on the TODO list.
There are third-party GUIs for mkvextract available, see e.g. the MKVToolNix links page.
#3663 | Link |
MKVToolNix author
No, not really.
#3664 | Link |
Does mkvtoolnix proprerly handle the A/V sync issues that sometimes happen with seamless branching blurays?
Makemkv always removes 1 video frame as soon as the sync issue reaches 10ms to keep it properly in sync. Does mkvtoolnix also do this, or is it still better to use makemkv to remux blurays? Thanks. Last edited by Bigmango; 13th October 2015 at 09:27. |
#3665 | Link |
MKVToolNix author
I honestly cannot answer that.
Have you given MKVToolNix a try? Did you encounter any problems with the sync in such a situation?
#3666 | Link |
Is seamless branching support a planned feature for mkvtoonlix?
So we can:
Thanks. |
#3667 | Link | |
Ok, unless someone has the answer untill then, I'll try it next time I encounter this with makemkv. Last edited by Bigmango; 13th October 2015 at 10:23. |
#3668 | Link |
Matroska find' ich toll
I use my chapterEditor to prepare Bluray-disks and I get then a mtxcfg-file. So I can use MKVToolNiX-GUI for all BD's. I have a lot of multi-editions(seamless branching) BD's mux to mkv without sync issues.
#3669 | Link | |
![]() I am floored. I just remuxed my Avatar Collector's Edition bluray and got an MKV with the 3 editions (Extended, Special and Theatrical). And only 40Gb instead of 100+Gb. Awesome. VLC sees the 3 editions and I can switch between them in the menu. You are a genius. But, when I load this mkv (which was created by mkvtoolnix with your chapter editor) in mkvtoolnix it only sees it as 1 video track (with single audio tracks) and doesn't see the 2 other editions the mkv contains. @ Mosu:
This would also attract more player support (for title selection) as this ordered chapters mkv feature (in the mkv specs for many years) would become more used and widely known. I, for one, have used mkvtoolnix for years and had absolutely no clue this even existed. WHY isn't this HUGE mkv feature used everywhere? -> Because no one knows about it as mkvtoonlix isn't even showing this exists. Many thanks. Last edited by Bigmango; 13th October 2015 at 13:13. |
#3670 | Link | |
How do you demux, or extract / separate the multiple editions into separate mkv files if need be (for future safe keeping /availability of the separate editions)? Neither mkvtoolnix nor gmkvextractgui sees the multiple editions contained in the mkv (they only see the first title). |
#3671 | Link |
I'm pretty sure they don't see any of the "titles", just the base streams that the titles are constructed from.
The "titles" are in the chapters, but MKVMerge -I doesn't seem to mention the existence of multiple editions... MKVMerge could provide a more detailed breakdown of the chapters that includes editions, but if you want to "see" each individual title as a separate file Mosu would have to either completely reinvent the -I option or create a secondary Info option to support it. |
#3673 | Link | |||
#3674 | Link | ||
This means that when using mkvtoolnix to load the bluray playlist directly there will be sync issues? This is what I get in the output with Makemkv on the Avatar extended cut: Quote:
@ Mosu This happens with all of the seamless branching blurays. I have now also tested remuxing this by loading the playlist directly in mkvtoolnix: it shows absolutely no information regarding audio skew or dropped frames. I understand this means mkvtoolnix has a sync issue when seamless branching happens? Until this is fixed, shouldn't the output display a warning that the resulting mkv will have sync issues to at least let the user know? Thanks. Last edited by Bigmango; 13th October 2015 at 16:35. |
#3675 | Link | |
And here is the output with eac3to.
Eac3to starts a 2nd pass to fix the audio gaps. The result leaves it with only a 1 ms skew. Quote:
#3676 | Link | |
I never extract from mkv. The editions are generated while loading a mkv in your player. When the player can interpret the chapters.xml(inside mkv) then it shows and work. BUT there are every ONE big video stream(audio and subs too). Last edited by hubblec4; 14th October 2015 at 10:21. |
#3677 | Link | |
When you load a playlist directly in the MTX-GUI you will never get multi editions mkv's, also not if you all m2ts load manually. The "editions-magic" is a part of the chapters.xml AND the tags.xml. I could do a bit more for Matroska, but the old song: no player or splitter supports this features. |
#3680 | Link | |
MKVToolNix author
