#3482 | Link |
Before I go and make an account to ask the Mediainfo guy, I thought I'd ask the mkv experts here.
Mediainfo currently doesn't support showing individual audio/video bitrates when combined in MKV. It does in MP4. Is there a limitation of the MKV container that prevents this information being discovered, or is this a feature that Mediainfo could support? |
#3483 | Link |
To find out such information parsing of the complete Matroska file might be necessary so it can't be done within a few seconds by MediaInfo for every file (there are tricks for good estimates but they only work for specific files). Newer mkvmerge versions write the tracks' bitrates as tags and the MediaInfo author has said he has reading these tags (and other Matroska improvements) on his to-do list. So there is no need to contact him.
#3486 | Link |
MKVToolNix author
I'm afraid that's way too difficult to implement. Option files, just like command line arguments, are pretty free in the order they can do things. I also don't see much of a use-case for this (meaning only a very small number of people would actually use such a feature). I have an idea what you would use it for (generating option files instead of .mtxcfg files like you're trying to do at the moment), but to be honest the amount of work would be daunting.
Sorry.
Latest MKVToolNix is v101.0 If I ever ask you to upload something, please use my file server. |
#3489 | Link | |
Matroska find' ich toll
I thought so that it will be too complicated. Creating a mtxcfg file is done in my chapterEditor(next rev), but for muxing separete mkv-parts(split by timecodes), i can just create such mtxcfg file for the cutting-process when is done. (scan the mkv-parts with mkvmerge --identify-for-mmg) Maybe i can create an option and cmd file for the mkv-parts. mkvmerge: when i use such option file, mkvmerge will scan the mkv-parts automaticly? There are no settings in the option file for --identify-for-mmg(properties). Last edited by hubblec4; 3rd August 2015 at 12:35. |
#3490 | Link |
MKVToolNix author
File identification is always and automatically done by mkvmerge for each input file. The step with »mkvmerge --identify… yourfile.ext« is separately only so that the GUI can retrieve certain parameters to use (container type, track types, current properties like language, title, track name…).
#3492 | Link |
I am reporting to have the same problem with Windows 10 (64bit) as HassiD. For some reason I am still able to use the old gui version.
I'm liking the new GUI version so far. At first, I hate it but I got used to it very quickly. Please verify this problem in Windows 10 (64bit) when you can. I really want to keep using the new GUI because it's easier to edit chapters with it. Thanks you. |
#3493 | Link |
MKVToolNix author
Problem is that I don't have Windows 10 yet, nor do I want to upgrade my sole Windows machine to it just yet...
#3494 | Link |
And rightfully so: https://i.imgur.com/iHge6RJ.jpg.
Slighty OT as mentioned in the other thread but since you've brought it up...
MultiMakeMKV: MakeMKV batch processing (Win) MultiShrink: DVD Shrink batch processing Offizieller Übersetzer von DVD Shrink deutsch |
#3495 | Link |
MKVToolNix author
@RDF: I've opened an issue for it and will investigate it, but as I don't have Windows 10 yet (nor an idea what the cause might be) I cannot say when I'll be able to fix it.
#3496 | Link | |
#3497 | Link |
MKVToolNix author
@RDF: You might give pre-builds 838 or 839 a try. Note that I haven't tried them myself, but they've been built with a newer version of the GUI toolkit library I'm using (Qt 5.5.0 instead of 5.4.2).
#3498 | Link |
You can test your app on virtual machine. I'm using free Vware player with win10. You can easily download iso from torrent sites. (key/activation is not required for trial mode)
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 7th August 2015 at 22:37. |
#3500 | Link |
MKVToolNix author
That is on the TODO list but still a couple of months off.
