Old 14th April 2014, 20:29   #2661  |  Link
sneaker_ger
(44*60+58)/(44*60+58+3.5) or (44*60+58+3.5)/(44*60+58)?
sneaker_ger is offline
Old 14th April 2014, 21:02   #2662  |  Link
Simon88
Simon88 is offline
Old 16th April 2014, 00:48   #2663  |  Link
Simon88
Matroska File - How to set Aspect Ratio
I have a Matroska file that has an Aspect Ratio of 16/9. However, it has a VobSub subtitle that looks stretched. So I force the display of the Matroska video with a 4:3 Aspect Ratio and the subtitle looks OK, but the video of course does not.
I realize there is an IDX file for each SUP where I can alter the scale, but the Matroska file container must have a switch somewhere where I can set the Aspect Ratio in the IDX during the importing of the IDX/SUB bitmaps, like the same way we can override the video Aspect Ratio. I'm hoping I don't have to do it manually... :-)
Thanks...
Simon88 is offline
Old 16th April 2014, 06:26   #2664  |  Link
LeMoi
You can manually edit the .idx file and change the "# Original frame size" item or the "# Image scaling (hor,ver), origin is at the upper-left corner or at the alignment coord (x, y)" item
LeMoi is offline
Old 16th April 2014, 09:17   #2665  |  Link
hubblec4
Matroska find' ich toll
@ Simon you could use BDSUP2Sub.
hubblec4 is offline
Old 16th April 2014, 16:34   #2666  |  Link
Simon88
@hubblec4: I'll definitely look at this neat program you mentioned...
@LeMoi: Do you know of generic changes to the IDX that will work for ALL cases of 4:3 --> 16:9 subtitle conversion?
I'm thinking of creating a simple batch file where I can mkvextract the IDX/SUB, then use SED to modify the IDX, and then re-integrate the new one into a new file in a separate directory, whenever I find one in my collection.
Thanks..
Simon88 is offline
Old 16th April 2014, 17:35   #2667  |  Link
Ars92
Don't know why I didn't use this tool from the start. So much more reliable than mediacoder. Effortlessly muxes my drm less iTunes file with subs in less than 10 seconds!
Sent from my SM-N9005 using Tapatalk
Ars92 is offline
Old 18th April 2014, 15:19   #2668  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
MKVToolNix v6.9.0 released
Hey,
I've released MKVToolNix 6.9.0. There the usual bug fixes all over the place but nothing major, but it was time for a new release.
For package maintainers nothing has changed compared to 6.8.0.
Here are the usual links:
…to the source code:
http://www.bunkus.org/videotools/mkvtoolnix/source.html
…to the binaries:
http://www.bunkus.org/videotools/mkv...downloads.html
Here's the full ChangeLog since release 6.8.0:
2014-04-18 Moritz Bunkus <moritz@bunkus.org>
* Released v6.9.0.
* all: new feature: added a Brazilian Portuguese translation of the programs by Thiago Kühn (see AUTHORS).
* mkvpropedit, mmg's header editor: bug fix: fixed a failed assertion in libEBML when writing the same changes twice to certain files (those for which a seek head with a single entry pointing to the elements modified by mkvpropedit/mmg's header editor; e.g. x264 creates such files). Fixes #1007.
2014-03-22 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: bug fix: reading fonts embedded in SSA/ASS files was sometimes truncating the attachments created from them. Fixes #1003.
* mkvmerge: bug fix: fixed display of very large IDs during attachment extraction.
* mkvmerge: enhancement: improved file type detection speed for text subtitle formats.
2014-03-10 Moritz Bunkus <moritz@bunkus.org>
* mkvextract: bug fix: during the extraction of chapters, tags or segment info XML files with the --redirect-output parameter the BOM (byte order mark) was written twice.
2014-03-05 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: bug fix: MPEG TS: timestamp outliers are ignored if they differ at least five minutes from the last valid timestamp. Fixes #998.
* mkvmerge: enhancements: trailing zero bytes will be removed from AVC/h.264 NALUs. Implements #997.
2014-03-04 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: bug fix: fixed timestamp assignment for AVC/h.264 videos in which recovery point SEIs occur in front of the second field of two interlaced fields.
Have fun.
Latest MKVToolNix is v101.0
Mosu is offline
Old 18th April 2014, 16:32   #2669  |  Link
schorman
Just installed the newest version, 6.9.0, for 64 bit Windows. When I add tracks it uses up to 10Gb of memory and basically stalls the system. I think there is some kind of memory leak.
I would advise not installing this version yet.
schorman is offline
Old 18th April 2014, 16:40   #2670  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
What kind of file have you added? What kind of tracks are in it?
Mosu is offline
Old 18th April 2014, 16:44   #2671  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Oh wait, I can reproduce this easily. I'll fix it and prepare a new release for that.
Mosu is offline
Old 18th April 2014, 17:04   #2672  |  Link
schorman
Wow, that was fast. Thanks. Just for good measure, it stalled while adding an h264 video track.
schorman is offline
Old 18th April 2014, 17:04   #2673  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Fixed. I'm now preparing release v6.9.1 which will take the usual two to three hours (building all binaries, posting in the usual places etc). Stick to 6.8.0 until then, please.
Mosu is offline
Old 18th April 2014, 17:09   #2674  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
The file type actually doesn't really matter. One of the file type detection modules (called »readers« in mkvmerge terms) was accidentally reading the whole file into memory.
Back with 6.8.0 that reader (a subtitle reader) was probed almost last. Therefore that issue pretty much never came to light. For 6.9.0 I've moved all subtitle readers up to the top because normally they're way, way faster than a lot of other readers (especially the h.264/h.265 ones). That exposed the bug.
As I usually test with small files due to muxing large files taking a lot of time I haven't noticed it before…
Shit happens and stuff
Mosu is offline
Old 18th April 2014, 17:16   #2675  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Mosu,
is it generally "safe" to join two mkv files by appending them? The video, audio and subtitle tracks have the same characteristics. I have a few blu-rays which have a documentary part and a concert part which I'd like to join for viewing and then archive that version instead of archiving two clips.
What I've noticed is that the chapter points do not work correctly with joint files, I guess I need to create a new file manually.
Boulder is offline
Old 18th April 2014, 17:18   #2676  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Chapters usually work just fine with appending. And yes, appending is generally safe.
Mosu is offline
Old 18th April 2014, 19:02   #2677  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
MKVToolNix v6.9.1 released
Hey,
I've released MKVToolNix 6.9.1 mere hours after the release of 6.9.0 due to a severe bug that wasn't present in 6.8.0. Here's the combined announcement for both releases.
There were the usual bug fixes all over the place. No major new features, but it was time for a new release.
…to the binaries:
* Released v6.9.1.
* mkvmerge: bug fix: fixed huge memory usage when probing files (it was reading the whole file into memory for that).
* Released v6.9.0.
Have fun.
Mosu is offline
Old 18th April 2014, 19:18   #2678  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
I see no package for openSUSE 13.1. Still building/packaging?
microchip8 is offline
Old 18th April 2014, 19:23   #2679  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Yes, packages for certain distros/versions are still being built. I simply didn't want to hold off too long as more and more bug reports were coming in.
Mosu is offline
Old 19th April 2014, 02:03   #2680  |  Link
schorman
Thanks again for the fix and thank you for your wonderful work on mkvmerge. Great program and truly invaluable.
schorman is offline
