Old 27th June 2005, 22:33   #1  |  Link
Zenitram
MediaInfo(Lib) 0.7 - Reading information about media files
I develop MediaInfo, which is a tool to show technical information (container format, codec, width, heigth...) and tags (Title, Artist, Language...) about all kind of multimedia files. Main purpose is to have a library for third-parties, but there is a graphical interface too.
I wish have some beta testers with complex files, to "stress" the program just released.
http://mediainfo.sf.net
There are :
- A graphical interface
- A command line interface
- A DLL for programers (with C++, C#, J#, VB.nt, VB5, Delphi, ActiveX examples)
I already did some tests on :
Matroska, Avi, Wav, Ogg, Ogm, Mpg, Vob, Mp4, M4a, 3gp, M2v, mp3, Wma, Wmv, Mov, Rm, Rmvb, Ifo of DVD, Aac, Ac3, Dts, Monkey Audio, Ape, Flac, Au, Aiff.
I am working on H264.
Did I forget a container?
Want to know all about your media files? http://mediaarea.net/MediaInfo
Zenitram is offline   Reply With Quote
Old 28th June 2005, 04:55   #2  |  Link
SCIF
AMD fan
Good idea! It'll be useful. GSpot not support anything except *.avi. Cheers.
SCIF is offline   Reply With Quote
Old 29th June 2005, 10:35   #3  |  Link
thana
thana's Avatar
just tested some files of my collection:
  • first of all, is .swf (flash) supported? its not mentioned anywhere but mediainfo finds mpeg-audio streams in some of them (albeit with bitrate 0).. i'm not sure if those are really mpeg audio streams, but it could very well be so..
  • i guess "S-Mpeg 4 v3" should really be "MS-Mpeg 4 v3", right?
  • why is the mpeg container called "MPEG 1 Multiplexer" instead of simply "MPEG 1"? is this the official name?
  • "MPEG-4 Video" should maybe renamed to "MPEG-4 (A)SP" and "MPEG-4 AVC" to better differentiate the two variants
  • while "MPEG-4 Audio" is technically correct, i think it would be more helpfull for users if you would write "MPEG-4 Audio (AAC)" and maybe even "MPEG-4 Audio (HE-AAC)" too.
  • the codecs in this .mov here (http://download.theforce.net/theater..._web_large.zip) are not recognised at all. according to mplayer they should be "ima4" (IMA ADPCM) for audio and "SVQ3" (Sorensen Video 3) for the video track.
  • this movie here (http://www.kollektiv-kaffeemaschine....erarbeitQT.mov) has exactly the same codecs, but this time "ima4" is detected as a second video track instead of the audio track.
  • i would appreciate it if the actual FOURCC would be displayed somewhere in conjunction with your "translated" description
  • whenever there is no audio or video track in a container, the codec name is displayed in the format-column too instead of the real container name, which is very confusing (at least for me).
  • i have another .mov on my hd (sorry, no link) which isn't recognised at all too. codecs are "Sorensen Video 3" and uncompressed pcm audio (FOURCC: "twos"). i can upload it somewhere if you want.
that's it for now, more to come later =)
thana is offline   Reply With Quote
Old 29th June 2005, 10:59   #4  |  Link
Zenitram
Thank you for your tests.
  • No support of SWF.
    My MPEG audio parser has difficulties to detect false MPEG Audio, because MPEG Audio "magic value" is only 12 bits
    I will put more tests about coherancy of value (bitrate 0 and so on...)
  • Writing error, will be corrected ;-)
  • MPEG is a group (Movie Picture Expert Group), who released a lot of standarts, with MPEG 1 Video, MPEG 1 Audio, MPEG1 Multiplexer and so on...
    I would like to differenciate them.
  • I will look at what I can do. Not sur to be able to always differenciate them.
  • I will download theses files
  • in the menu : Debug-->Advanced mode.
    Or : you can edit preferences (for "sheet" view, or HTML...), and add "%Codec%" (instead of "%Codec_String%)
  • I don't have files with a container but without streams, could you send me one?
Interested to have it.
I am waiting for it
You can contact me with private messages.
Old 29th June 2005, 15:24   #5  |  Link
thana
thana's Avatar
yeah, i know. but then the really correct name would be "MPEG-1 Systems Multiplex". also the codecs are correctly written with a dash before the number, f.e. "MPEG-1 Audio" or "MPEG-2 Video" instead of "MPEG Audio 1" or "MPEG Video 2".
What about MPEG transport streams? are they supported? i tried a sample but mediainfo found only the video stream and no audio stream.. (http://www.nextcomwireless.com/R5000/samples.htm)
if they are not supported, the correct description for the MPEG-2 container would be "MPEG-2 Program Stream", because "MPEG-2 Systems Multiplex" describes both, program streams and transport streams.
i didn't mean a container without any stream (would be quite useless), just one without an audio stream but with a video stream or the inverse.
but i just saw that this isn't a real problem, i was only confused because you called MPEG Elementary Streams "MPEG Video 1" etc. but you are probably correct, an elementary stream really doesn't have a container/format, its just the audio/video stream.
i put it on my ftp. also i found some other samples which are detected incorrect. you can find them all in "video-samples" on my ftp. i will send you the address per pm.
Old 29th June 2005, 16:16   #6  |  Link
Zenitram
OK, I will change for this.
But : what should I write for "MPEG Audio 2.5 (some MP3 have this, extended version of MPEG-2 Audio...)? MPEG-2.5 Audio?
but : "MPEG-1 Systems Multiplex" is long . I think I will change it in MPEG-x PS, and MPEG-x TS (see below for TS)
TS? Not yet, because I didn't find documentation on this (which bit for what),
if you know MPEG system, could you tel me where PS is used (DVD, and?), and where TS is used?
I have difficulties to understand all in the MPEG standarts, they are a little difficult with a lot of standarts
OK, I understand more what you said.
And as you said, Video ES or Audio ES (=MP3 or raw AAC) doesn't have a container, so I use the ES name in place of the container name, and I think to not change this.
Thank you for your analysis.
Old 29th June 2005, 17:32   #7  |  Link
thana
thana's Avatar
yes, looks good to me. or maybe just leave it at MPEG-2, and describe the .5 part somewhere in the advanced mode text. MPEG-2.5 is a proprietary extension by FHG that only allows for some lower sample frequencies and bitrates, but it's not officially endorsed by the MPEG committee in any way.
yes, that is ok too.
you can find the last draft on this page: http://www.le-hacker.org/dvd.html, this should be a good starting point.
afaik (but i'm not an expert) PS are officially used on VCD, SVCD and all variants thereof. VOBs on DVD contain several ES as well as other stuff for menu's etc.
TS are mainly used for digital broadcasting (DVB/ATSC/ISDB).
EDIT: typos
Old 2nd July 2005, 23:20   #8  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Hi Zenitram,
First of all, many thanks for this tool. It's very nice.... I'll use mediainfo.dll in the next YAMB release. (not finished yet but I'll release it very soon). I'd like to suggest you to use some GPAC code for mp4 files. It's up to date comparing to the mpeg4ip libraries...(h264, ,avc supports...) Hope this help.
Old 3rd July 2005, 01:14   #9  |  Link
Prodater64
@Zenitram:
Could you post how can I call mediainfo.dll from VB6 files please.
Just for 1 file (not several media files).
If you can, post examples to obtain width, height, fps, bitrate, etc.
Prodater64
Prodater64 is offline   Reply With Quote
Old 3rd July 2005, 01:42   #10  |  Link
Doom9
clueless n00b
phew, just spotted this.. might come in very handy for MeGUI.. right now I only have AVIFile and basically have to make up something for every other format.
Doom9 is offline   Reply With Quote
Old 3rd July 2005, 02:19   #11  |  Link
Sirber
retired developer
Sirber's Avatar
Gonna add it to RealAnime. Many thanks for the great tool!
Detritus Software
Sirber is offline   Reply With Quote
Old 3rd July 2005, 02:31   #12  |  Link
Doom9
clueless n00b
Hmm... could it be that the feature matrix (http://mediainfo.sourceforge.net/formats.html) is incomplete? Looking at the screenshots I see "play length" but that doesn't seem to be listed in the matrix. For me getting the length of a file (audio or video) as well as number of frames (in case of video) are the features I'm most interested in.
Old 3rd July 2005, 04:15   #13  |  Link
Sirber
retired developer
Sirber's Avatar
Track information seems to be missing for MKV... could be cool to have it
Detritus Software
Old 3rd July 2005, 12:31   #14  |  Link
Zenitram
Thanks for your replies...
I should.
But this is actually hard to understand GPAC interface (mainly for tags).
I use mp4ff for codecs, and mp4v2 for tags.
I know how to do for codecs with GPAC, but I don't know how to do for tags.
I will work on it, but some difficulties... ;-)
There is an VB5 (works on VB6 too) example with the DLL package, in the "Contrib" Directory.
Not exactly what you want, but you should easily understand how to do
little outdated
Duration is the same as "Play length", I changed the name in MediaInfo, but not in the matrix
MediaInfo_Option(NULL, "Info_Parameters") to have all available parameters.
MediaInfo_Get(Handle, Stream_General, 0, "PlayTime", Info_Text, Info_Name) to have the length in millisecond (or "PlayTime_String1" or 2 or 3 to have formated text ("?h ?mn ?s"...)
MediaInfo_Get(Handle, Stream_Video, 0, "FrameCount", Info_Text, Info_Name) to have number of Frames (or PlayTime*FrameRate if you prefer...)
The complete work on MKV is not done yet, this will come soon!
Old 3rd July 2005, 12:34   #15  |  Link
Doom9
clueless n00b
@Zenitram: thanks for the info.
Am I correct assuming you wrote your own code to parse the files and are not relying on any external APIs?
Old 3rd July 2005, 13:02   #16  |  Link
Zenitram
You are not 100% correct, depend of what I found on Internet :
- AAC : internal
- AC3 : internal
- APE : MACLib
- CDXA : internal
- DVD : internal
- DTS : internal
- Flac : FlacLib
- MKV/MKA : libmatroska & libebml
- MPEG-1 and 2 multiplex : internal
- MPEG-1 & 2 Video : internal
- MPEG-1 & 2 Audio (technical) : internal
- MPEG-1 & 2 Audio (tags) : Id3Lib
- MPEG-4 (technical) : mp4ff (faac)
- MPEG-4 (tags) : mp4v2 (faad)
- Ogg : internal
- Quicktime : internal
- Riff (WAV/AVI/the stupid .divx extension) : internal
- AIFF, and other old audio : SndFile
- ASF/WMV/WMA : internal
Note : I sent you a submission for have MediaInfo in your 1st page, did you receive it?
Old 3rd July 2005, 13:14   #17  |  Link
Doom9
clueless n00b
I don't recall but I don't have access to my latest inbox right now (it's on my new box that runs unstable so I'm currently running lenghty tests to try and figure out which is the faulty component.. and I can't get to my mails from a linux boot CD).
It's not really the news for your average users, but since I find the library useful I guess I could make an exception.
Old 3rd July 2005, 13:22   #18  |  Link
bond
mp4v2 is mpeg4ip's lib, which faad uses too (but only the parts it needs i think), you might find a more complete version in the mpeg4ip cvs
Ogg Theora | Ogg Vorbis
Old 3rd July 2005, 13:33   #19  |  Link
Zenitram
So, what is the best library (mp4ff, mp4v2 from mpeg4ip, or GPAC) to have technical AND tags info from mp4 files?
I am a little lost with MPEG4 libraries, I didn't find yet the perfect library for my needs
Old 3rd July 2005, 13:59   #20  |  Link
bond
tags are a special issue in mp4 because there is an official tagging standard for mp4, but the power of itunes (which uses a private tagging way) lead to that people use only the itunestagging
and as always private stuff leads to a mess...
i would say there are two good mp4 libs available: the one from mpeg4ip and the one from gpac
mpeg4ip tags in the itunesway, gpac i think in the official mpeg way (but i have to admit i never really tested it so i dunno much about it)
