Go Back   Doom9's Forum > Video Encoding > (Auto) Gordian Knot
Old 24th June 2005, 08:24   #1  |  Link
jj12
AutoGK 1.96 and 2.09+ no adware ?
Hi
A maybe needless question, but i havent found any answer elsewhere (only saw dae.dll isnt contained anymore in the versions mentioned here):
are autogk 1.96 and 2.09 and above completely free from spyware/adware?
Thanks and regards Jorn
jj12 is offline   Reply With Quote
Old 24th June 2005, 14:05   #2  |  Link
BillyBlue77
AutoGK FAQ
5.10 ...*Update* versions 1.96 / 2.08+ are no longer bundled with DAE.
BillyBlue77 is offline   Reply With Quote
Old 24th June 2005, 14:39   #3  |  Link
jj12
Hi
thanks, but that i already know and also mentioned in my question, but that is not the same as autogk not being bundled with spyware/adware - it could be something else than dae.dll.
Any remark appreciated
Jorn
Old 24th June 2005, 14:45   #4  |  Link
BillyBlue77
No, it's not! (at least I'm not aware of it)
My Spyware and AV-Soft also don't complain anymore...
If there would be anything else, I'm sure it would be in the FAQ. It has never been a secret here that the old versioins came bundled with dae
