#1 | Link |
brainless
automated NTSC -> PAL conversion for hybrid clips
Function
function converter(clip input, int x, int y, bool TFF, int "combth", bool "speedup", bool "show") { function kernelbob(clip a, int th) { f=a. \kerneldeint(order=0, sharp=true, twoway=true, threshold=th) e=a.separatefields.trim(1,0).weave. \kerneldeint(order=1, sharp=true, twoway=true, threshold=th) interleave(f,e) } function speeduphybrid(clip i, int width, int height, bool debug) { comb = telecide(i,order=1,post=0).decimate(5) f = framerate(comb) film = comb.lanczosresize(width,height).assumefps(25,true) film = (debug == false) ? film : film.subtitle("film -> IVTC -> speedup") video = i.kernelbob(5).lanczosresize(width,height). \convertfps(2*f).assumefps(50,true).separatefields.selectevery(4,0,3).weave video = (debug == false) ? video : video.subtitle("video -> blending -> speedup") conditionalfilter(comb,video,film,"iscombed(combthr)","=","true") } function speedupfilm(clip i, int width, int height, bool debug) { film = i.assumefps(25,true).lanczosresize(width,height) film = (debug == false) ? film : film.subtitle("film -> speedup") return film } function converthybrid(clip i, int width, int height, bool debug) { comb = telecide(i,order=1,post=0).decimate(5) film = comb.lanczosresize(width,height). \changefps(50).separatefields.selectevery(4,0,3).weave film = (debug == false) ? film : film.subtitle("film -> IVTC -> convert") video = i.kernelbob(5).lanczosresize(width,height). \convertfps(50).separatefields.selectevery(4,0,3).weave video = (debug == false) ? video : video.subtitle("video -> blending") conditionalfilter(convertfps(comb,25),video,film,"iscombed(combthr)","=","true") } function convertfilm(clip i, int width, int height, bool debug) { film = i.lanczosresize(width,height). \changefps(50).separatefields.selectevery(4,0,3).weave film = (debug == false) ? film : film.subtitle("film -> convert") return film } combth = default(combth,20) global combthr=combth speed = default(speedup,true) debug = default(show ,false) input = (TFF == true) ? input.assumetff : input.assumebff speedupout = (framerate(input) < 26) ? \speedupfilm(input,x,y,debug) : speeduphybrid(input,x,y,debug) convertout = (framerate(input) < 26) ? \convertfilm(input,x,y,debug) : converthybrid(input,x,y,debug) final = (speed == true) ? speedupout : convertout final.resampleaudio(audiorate(input)) } Code:
loadplugin("...\kerneldeint140.dll") loadplugin("...\decomb510.dll") import("...\converter.avs") avisource("hybrid.avi") converter(768,576,TFF=true,combth=20,speedup=true,show=false) to PAL using IVTC on Telecined Film and blending on the other parts. You can decide, wheater the video should be speeded up by 25/23.976 to get progressive Film-parts. If no speedup is whished, the Film-parts get interlaced, too. But with better quality then with stupid blending. If the input-clip is already 23.976 fps, this will be detected and just a speedup or conversion from 23.976 to 25 will be made. Parameters: x - new width y - new height TFF - true for TFF-clips, false for BFF-clips combth - (default = 20) defines the threshold weather the .........input clip is interlaced or progressive (telecined) speedup - (default = true) show - (default = false) shows, which conversion is applied .........to the video: 29.97 fps input-clip with speedup gives either "film -> IVTC -> speedup" or "video -> blending -> speedup" 29.97 fps input-clip without speedup gives either "film -> IVTC -> convert" or "video -> blending" 23.976 fps input-clip shows: with speedup "film -> speedup" without speedup "film -> convert" The Audio stays always in sync with the Video.
Don't forget the 'c'! Don't PM me for technical support, please. Last edited by scharfis_brain; 27th December 2003 at 02:57. |
#2 | Link |
Now, this is a nice one! Pity I've not one single NTSC source to test it on.
Remarks: 1) Is "IsCombed = 20" the one-and-only sweetspot, or should that value also be parametrized? 2) For the not-so-advanced users, it should be mentioned that when using speedup, the audio part also gets (dumbly) speed up by ~4% to stay in synch. This is okay since it is the only way to do it in AviSynth. A better solution, though, is to change audio speed with an appropriate external audio editor to preserve pitch. Once more, good work, Scharfi! - Didée
#3 | Link |
brainless
I've already tried to make something like that:
function speeduphybrid(clip i, int width, int height, int th, bool debug) {i.iscombed(th)} thats really weird
Don't forget the 'c'! Don't PM me for technical support, please. |
#4 | Link |
Oh, yes.
Some time ago, this was driving me nuts, too. Try Code:
function speeduphybrid(clip i, int width, int height, int "th", bool debug) - Didée
#5 | Link |
brainless
Grrrrrrrrrrrrrrrrrrrr
can't even get Code:
x=avisource("hybrid.avi").assumetff a=x.IsCombed() x = ( a== true) ? x.subtitle("interlaced") : x.subtitle("progressive") return x It always claims Invalid arguments to function "IsCombed" no matter weather I use x.iscombed() x.iscombed(20) iscombed(x) or iscombed(x,20) but within my NTSC->PAL converter it is working... I am totally confused. Can anybody clear this up?
#7 | Link |
brainless
Okay. Found out that (Pseudocode)
function x(clip x, clip y, clip z, int th) { conditionalfilter(x,y,z,"iscombed(th)","=","true") } didn't work but global th = yourvalue function x(clip x, clip y, clip z) { conditionalfilter(x,y,z,"iscombed(th)","=","true") } worked.... weird again. btw. I've updated the NTSC->PAL conversion-function above with variable combingthreshold
#8 | Link |
![]() Join Date: Nov 2001
Variables in the conditional invironment need to be global and initiated. Thus something like
function x(clip x, clip y, clip z, int th) { global th2 = th conditionalfilter(x,y,z,"iscombed(th2)","=","true") } should also work ... |
#9 | Link |
Invalid arguments to function “converter”?
@scharfis_brain
I have tried your “converter” but I got the error message in VirtualDubMob: Invalid arguments to function “converter”. The script is: ++++++++++ loadplugin("...\mpeg2dec3.dll") loadplugin("...\kerneldeint140.dll") loadplugin("...\decomb510.dll") import("...\converter.avs") video1=MPEG2Source("...\Concert.d2v") video=converter(video1,768,576,true,20,true,false) return video ++++++++++++++++++ How to put right arguments? I suppose that the problem is argument “input”, type clip? The source clip must be AVI? Thank you very much in advance. |
#10 | Link |
If you replace your last 3 lines of script with:
MPEG2Source("...\Concert.d2v") ConvertToYUY2(interlaced=true) #so convertfps(...) will work (only used when blending video sections) converter(768,576,true,20,true,false) it should be OK. ConvertToYUY2(...) is not required if your source is 100% film. |
#11 | Link |
Thanks, but it doesn't work.
Actually it cannot work. If the function is defined as function converter(clip input, int x, int y, bool TFF, int "combth", bool "speedup", bool "show") with 7 arguments, function call must have 7 input values. Function call: converter(768,576,true,20,true,false) has 6 input values. The input clip that should be converted is missing? |
#12 | Link |
brainless
just use:
loadplugin("...\mpeg2dec3.dll") loadplugin("...\kerneldeint140.dll") loadplugin("...\decomb510.dll") import("...\converter.avs") MPEG2Source("...\Concert.d2v") converttoyuy2(interlaced=true) converter(768,576,true)
#14 | Link |
brainless
Nice to hear, yuo had success!
I have one question: sometimes my script fails and thus detecting FILM as Video and vice versa. could you check your video for some of those parts and report whether the are causing jerks or not? Please do the same with the cut-points, where Film is becoming Video & vice versa. use show=true for examining this. I ask this, because I am PAL-Man who doesn't have any hybrid NTSC. This function is only build out of theory and synthetic generated clips....
#15 | Link |
Could I suggest that you can replace convertfps(50) in the "function converthybrid" section with changefps(60).decimate(6)
This has the advantage of not having to change to YUY2 and also has no blending. However video may be slightly jerky. See which you prefer.... (The above is only applicable if you set speedup=false) In my very swift test, I did find that the default value for combth of 20 did result in a large amount of video sections being detected as film - around 30% - which obviously results in a few jerky bits. Reducing this to 10 did help greatly. There were naturally still a few errors but never more than a few isolated frames. |
#16 | Link |
brainless
just replace convertfps with changefps and you'll get your jerky result.
I dislike discharding 10 out of 60 frames to get 50 fps, because you'll get a really weird 10 Hz motion-stutter. This is flatten out by convertfps as you can see, I use changfps for converting 24fps to 25fps (no speedup), (inserting 2 fields per second -> two slight stutters per second) instead of using convertfps here, because this case isn't worth heavy blending.
#17 | Link |
interlace this!
this script is superb! i've been looking for a pain free solution for hybrid clips, but just couldn't be bothered writing one for myself
![]() thanks heaps. will try it out right away. [edit] nice. i'm curious as to how it handles 30p content? it seems to treat them as filmlike. that's okay, but it means i get the occasional jerky pan in some animes (chobits disc 2, R1) [edit edit] ha. looks like you posted while i was editing. yeah, i'd discovered that problem ![]() ![]()
sucking the life out of your videos since 2004 Last edited by Mug Funky; 7th January 2004 at 16:02. |
#18 | Link |
brainless
If you want to have even more superbness (does this word exist?), just replace kernelbob with TMCkernelbob or TMCbob...
btw. One thing is unsolved with this converter.avs: 30p Video will be detected as progressive. That means every 5. Frame is taken out, which results in heavy jerkieness on 30p sequences. But maybe there is a decomb-parameter which can do some blending in such cases?!? I don't know much about tweaking filters, I am just toooo lazy for doing so... btw. maybe, I am writing the vice versa script for PAL-hybrids to NTSC, hehe (this will be MUCH easier than NTSC -> PAL)
#19 | Link |
He!
Is there already a compiled version of this DLL-funktion (Hybrid NTSC > PAL) available to download, or do i have to compile it oneself? I,ll encode Star Trek NG Season 2 (Hybrid NTSC) soon and i never had such material, so i need to think about a method to handle this. thanks Last edited by gomi; 9th January 2004 at 22:37. |
#20 | Link |
Pig on the wing
You don't need a dll, the function is there already. You'll need KernelDeint and Decomb 5 though.
You may want to copy-paste the whole function to Notepad and save it to your plugins folder with any name but with the extension avsi so it will be loaded whenever you call any of the included functions in your script.
