Thread Tools Display Modes
Old 22nd January 2023, 11:24   #1  |  Link
tebasuna51
tebasuna51's Avatar
New versions of free software used in the GUI's
I make this thread to replace the announcements than fill the thread "MeGUI: bug reports and feature requests", with also discussions about differences between versions than can't be tested by MeGUI (without AVS, AQ-MODE 5 support for x265).
These software can be used by many GUI's and not only by MeGUI, any new announcement in that thread will be moved to this thread.
Please link only official, tested and legal versions with the inprovements or bug fixes (or changelog), than justify the download and replace the new version in at last in one GUI of this sub-forum.
EDIT: Deleted some off-topic or outdated posts to let like second post the Barough excellent updated recopilation
Also:
x265 with AVS input:
https://github.com/Patman86/x265-Mod-by-Patman/releases
https://github.com/jpsdr/x265/releases
MkvToolNix for W7 or old W10, search at end of this thread:
NON-OFFICIAL-Windows-builds-of-MKVtoolnix
Old 28th January 2023, 23:18   #2  |  Link
Barough
Donor
Barough's Avatar
AviSynth+ v3.7.5 (Stable and Official Test builds)
https://forum.doom9.org/showthread.p...98#post1909698
https://github.com/AviSynth/AviSynthPlus/releases
AviSynthPlus r4483 (Test Clang and IntelLLVM builds)
https://gitlab.com/uvz/AviSynthPlus-Builds/
AOM AV1 v3.13.1-187-g9d8eb51c
https://www.mediafire.com/file/p65vjeaz4dwo5j1
BestSource R16
https://github.com/vapoursynth/bestsource/releases
dav1d v1.5.3-5-gafd13d8
https://www.mediafire.com/file/x1y7rcxhtbksmsu
DGDecNV 257 (2026-12-03)
https://www.rationalqm.us/dgdecnv/binaries/
DGDemux v1.0.0.82 (2025-12-19)
https://www.rationalqm.us/dgdemux/binaries
DGMPGDec/DGIndex v2.0.0.9 (2024-03-29)
https://www.rationalqm.us/dgmpgdec/
DGMPGDec/DGIndex v3.0.0.1 (2025-08-09) (x64)
eac3to v3.59 (2026-03-02)
https://www.rationalqm.us/eac3to/
exhale v1.2.2-c33cf75b
https://www.mediafire.com/file/23lu2wpw5tw920w
FAAC v1.31.1-05f85a5
https://www.mediafire.com/file/eh75wxsg0xdogfv
FDK-AAC v1.0.6
https://www.mediafire.com/file/6vxvbnok57clejp
FFmpeg version n8.0.1-48-g0592be14ff (x86)
https://www.mediafire.com/file/17dgz9k6fa9ptnz
FFmpeg version n8.0.1-48-g0592be14ff (x64)
https://www.mediafire.com/file/fkqzxjhr12lf0b5
FFmpeg version n8.0.x (x86)
https://github.com/defisym/FFmpeg-Builds-Win32/releases
FFmpeg version n8.0.x (x64)
https://github.com/BtbN/FFmpeg-Builds/releases
FFmpegSource - ffms2 r2395
https://codeberg.org/StvG/ffms2/releases
ffms2 v5.0
https://github.com/FFMS/ffms2
https://forum.doom9.org/showthread.php?t=127037
FLAC v1.5.0 (Release)
https://www.mediafire.com/file/jsj1qkzt4o32ksf
GPAC-MP4Box v2.4-rev1-gb6cea0cd-ab-suite
https://www.mediafire.com/file/h7ic8wiipzft4g1
GPAC-MP4Box v2.5-DEV-rev2123-g92663ab1
https://www.mediafire.com/file/m27z6dqliydorvh
Kvazaar v2.3.2-1-g2e27a02
https://www.mediafire.com/file/9ko4zlhv2hpqjfb
L-SMASH-Works Release 20260212 1278.0.0.0
https://github.com/HomeOfAviSynthPlu...Works/releases
MediaInfo v26.01
https://mediaarea.net/en/MediaInfo/Download
https://mediaarea.net/MediaInfo/ChangeLog
MKVToolNix v97.0
https://mkvtoolnix.download/windows/releases/97.0/
https://mkvtoolnix.download/doc/NEWS.md
Monkeys Audio v12.50
https://monkeysaudio.com/versionhistory.html
https://monkeysaudio.com/download.html
Opus-tools v0.2-38-g0686cfb (using libopus 1.6.1)
https://www.mediafire.com/file/f2ms1wa67rhrxkq
Opus-tools v0.2-39-g9b1ca51 (using libopus 1.6.1-6-ga3f0ec0)
https://www.mediafire.com/file/xulyaq9ykhfu4k2
QAAC v2.85
https://github.com/nu774/qaac/releases
SoX Binary v14.4.2 (2026-01-13)
https://www.mediafire.com/file/3auwqmnwj1zros1
Sound eXchange NG v14.7.1
https://codeberg.org/sox_ng
https://codeberg.org/sox_ng/sox_ng/releases
tsMuxer v2.7.0
https://github.com/justdan96/tsMuxer/releases
uvg266 VVC v0.8.1-9f9f5d1
https://www.mediafire.com/file/jyiruu2mfy949sh
Vorbis-tools v1.4.3-abdfdfb
https://www.mediafire.com/file/d2g9gu5cuwpkz2t
Wavpack v5.9.0
https://github.com/dbry/WavPack/releases
x264 0.165.3223 0480cb0
(libswscale 9.3.100)(libavformat 62.8.101)(ffmpegsource 5.1.1.0)(lsmash 2.16.1)
https://www.mediafire.com/file/dsc1jccpxkxdisx
x265 v4.1+222-afa0028
https://www.mediafire.com/file/wqtdn8iwhgby53m
Old 29th January 2023, 02:48   #3  |  Link
guest
Posts: n/a
x264-r3106-eaa68fa
https://artifacts.videolan.org/x264/...06-eaa68fa.exe
Avs+ r3849 clang build (thanks to kedautinh12, for the link)
https://forum.doom9.org/showthread.p...30#post1981730
Old 29th January 2023, 05:29   #4  |  Link
kedautinh12
You need thank to Asd-g not me
Old 29th January 2023, 06:16   #5  |  Link
Yeah, Ked is just the messenger, (they dont shoot as many/enough, messengers as they used to).
Thanx, Asd-g, much appreciated.
Old 29th January 2023, 07:14   #6  |  Link
guest
Posts: n/a
Well you posted the link, otherwise I wouldn't have found it.
So thanks to both of you, then.
Were does Asd-g post these updates, I can't find them on his git !?!
Old 30th January 2023, 00:55   #7  |  Link
guest
Posts: n/a
FFmpegSource (ffms2)
StvG
new out today
https://forum.doom9.org/showthread.p...35#post1982035
Old 2nd February 2023, 04:34   #8  |  Link
guest
Posts: n/a
New: Visual C++ 2022 Redistributable - 14.34.31938.0
https://github.com/abbodi1406/vcredi...es/tag/v0.65.0
Old 17th February 2023, 04:30   #9  |  Link
kedautinh12
FLAC git-3f1f82c8 20230211
Built on February 11, 2023, GCC 12.2.0
(Code Base : 1.4.2)
https://forum.doom9.org/showthread.p...18#post1983118
Old 19th February 2023, 06:42   #10  |  Link
kedautinh12
What different, oldman???
Old 19th February 2023, 09:33   #11  |  Link
guest
Posts: n/a
Wow, I completely missed that...I will remove it.
Old 21st February 2023, 16:14   #12  |  Link
DMD
DMD's Avatar
x265 v3.5+93 Mod by Patman
Good morning.
I would like to replace the version "3.5+37+12-4e46995bc-.Mod-by-Patman.-x64-msvc1931" embedded in StaxRip 2.13.0.
I am in confusion and don't know which version to install to replace the previous version.
Thank you
my PC with Ryzen 7950X
DMD is offline   Reply With Quote
Old 22nd February 2023, 02:05   #13  |  Link
kedautinh12
Originally Posted by DMD View Post
Good morning.
Thank you
You can check speed result one by one to choose what best speed ver
Old 23rd February 2023, 01:19   #14  |  Link
LigH
LigH's Avatar
MP4Box 2.3-DEV-rev45-gb964fe422-ab-suite
MediaInfo CLI 22.12
__
PS: uvz AviSynthPlus-Builds got updated to r3936.
New German Gleitz board
Old 23rd February 2023, 02:18   #15  |  Link
kedautinh12
Will mp4box different with Barough's share??
Old 23rd February 2023, 02:24   #16  |  Link
guest
Posts: n/a
Don't forget new AVS, now in 2 "flavour's"...hmm, which one to choose ??
There also seems to be a revised x264 build (same build #, tho)
https://forum.doom9.org/showthread.p...73#post1983473
Old 23rd February 2023, 04:26   #17  |  Link
kedautinh12
You need check what build faster by yourself
Old 23rd February 2023, 15:19   #18  |  Link
kedautinh12
FLAC git-9382c537 20230223
Built on February 23, 2023, GCC 12.2.0
(Code Base : 1.4.2)
https://github.com/xiph/flac/commits/master
DL :
https://www.mediafire.com/file/8tn6z6i7tgo2vdk
Old 24th February 2023, 04:13   #19  |  Link
guest
Posts: n/a
But test #7 is the latest
Old 24th February 2023, 04:47   #20  |  Link
kedautinh12
I know but lazy to delete old post. Pinterf don't do that too
Thread Tools
