Old 8th June 2022, 04:31   #1  |  Link
LightArrowsEXE
Mt. Fuji Encoding Alumni
LightArrowsEXE's Avatar
lvsfunc: Light's VapourSynth functions
Figured I'd throw my hat in the ring and upload my function collection here too. It's been around for a couple of years and has been a rollercoaster the entire way.
Source code | Documentation | Support | Issues
"lvsfunc" is a multi-use function and wrapper collection aimed at offering a one-stop-shop for a lot of common operations used for anime encoding.
It's been slowly getting worked on over the years, and will be actively maintained for the foreseeable future.
lvsfunc, at the time of writing, contains the following sub-modules. For a list of all the functions contained in each sub-module, please consult the documentation.
Installation is simple. Open up a terminal and write:
pip3 install lvsfunc
This will download the latest release version. For the "nightly" or upstream builds, you can run the following command in your terminal:
pip3 install git+https://github.com/Irrational-Encoding-Wizardry/lvsfunc.git
Almost all the functions in lvsfunc are available in the global scope. It's good practice to call them from their specific sub-module, but the ability to just call them directly is there.
import lvsfunc as lvf
example_a = lvf.deinterlace.tivtc_vfr()
example_b = lvf.tivtc_vfr()
Support is primarily given through the Irrational-Encoding-Wizardry discord server (linked above), but I figured having an additional place for users to leave behind ideas, issues, complaints, etc. would be a good idea.
I am also open to porting commonly-used AVS(+) scripts. If you have any requests, please leave a reply here or ideally in the dedicated issue.
Hope you enjoy using lvsfunc!
LightArrowsEXE is offline   Reply With Quote
Old 8th June 2022, 18:39   #2  |  Link
Kogarou
1st
Kogarou is offline   Reply With Quote
Old 11th June 2022, 09:24   #3  |  Link
unix
Thank you sir =)
unix is offline   Reply With Quote
Old 12th July 2022, 00:58   #4  |  Link
LightArrowsEXE
v0.4.3 is out.
## What's Changed
* Minor updates by @LightArrowsEXE in https://github.com/Irrational-Encodi...sfunc/pull/103
* Source: Fix d2v files not working by @LightArrowsEXE in https://github.com/Irrational-Encodi...sfunc/pull/105
* Update vsdpir with new [code single]zones[/code] parameter, update typing by @Setsugennoao in https://github.com/Irrational-Encodi...sfunc/pull/106
* add downloads counter by @LightArrowsEXE in https://github.com/Irrational-Encodi...sfunc/pull/107
* Fix doc typing by @LightArrowsEXE in https://github.com/Irrational-Encodi...sfunc/pull/108
* chickendream: Update warning, make it so res is used by @LightArrowsEXE in https://github.com/Irrational-Encodi...sfunc/pull/109
* Update workflows by @LightArrowsEXE in https://github.com/Irrational-Encodi...sfunc/pull/112
* Fine dehalo update by @LightArrowsEXE in https://github.com/Irrational-Encodi...sfunc/pull/113
* Minor fixes by @LightArrowsEXE in https://github.com/Irrational-Encodi...sfunc/pull/114
* pick_rgvs/rgsf: Fix wrong plugin call by @LightArrowsEXE in https://github.com/Irrational-Encodi...sfunc/pull/117
* Rfs updates by @LightArrowsEXE in https://github.com/Irrational-Encodi...sfunc/pull/116
* ivtc_crdits: Rename to [code single]pulldown_credits[/code] by @LightArrowsEXE in https://github.com/Irrational-Encodi...sfunc/pull/118
* Flake8 docstrings by @LightArrowsEXE in https://github.com/Irrational-Encodi...sfunc/pull/119
* Deprecate .kernels in favour of vs-kernels by @LightArrowsEXE in https://github.com/Irrational-Encodi...sfunc/pull/111
* Update get_matrix, other related updates by @LightArrowsEXE in https://github.com/Irrational-Encodi...sfunc/pull/122
* source: Rewrite function by @LightArrowsEXE in https://github.com/Irrational-Encodi...sfunc/pull/123
* Update matrices by @LightArrowsEXE in https://github.com/Irrational-Encodi...sfunc/pull/124
* check_patterns: New function by @LightArrowsEXE in https://github.com/Irrational-Encodi...sfunc/pull/125
* vsdpir: Fix strength clip size error by @LightArrowsEXE in https://github.com/Irrational-Encodi...sfunc/pull/126
* vsdpir: Default args for Backend if not in kwargs by @LightArrowsEXE in https://github.com/Irrational-Encodi...sfunc/pull/127
* source: [code single]tail_lines[/code] params, check if FILM/ORDER exists by @LightArrowsEXE in https://github.com/Irrational-Encodi...sfunc/pull/128
* Fix vsmlrt stubs by @Setsugennoao in https://github.com/Irrational-Encodi...sfunc/pull/129
* Fix trim shift in replace_ranges by @Setsugennoao in https://github.com/Irrational-Encodi...sfunc/pull/132
* Rework and speed up vsdpir function by @Setsugennoao in https://github.com/Irrational-Encodi...sfunc/pull/130
* setsu made flake8 upset by @LightArrowsEXE in https://github.com/Irrational-Encodi...sfunc/pull/134
* Update release.yml by @LightArrowsEXE in https://github.com/Irrational-Encodi...sfunc/pull/136
* Source updates by @LightArrowsEXE in https://github.com/Irrational-Encodi...sfunc/pull/137
* Doc updates electric boogaloo + bonus fixes by @LightArrowsEXE in https://github.com/Irrational-Encodi...sfunc/pull/138
* Pre-v0.4.3 by @LightArrowsEXE in https://github.com/Irrational-Encodi...sfunc/pull/139
Full Changelog: https://github.com/Irrational-Encodi...0.4.2...v0.4.3
anime, filtering, maintained, package, vapoursynth
