#1 | Link |
MatteCrop - automatic framing and crop
I made this function to fix certain films with varying and asymmetrical borders. You have two options, mode=0 which only recenters the frame within borders, and mode=2 which scales it to fill the width (no side borders). I find this workflow more straight forward as it doesn't require an analysis pass, but you can scrub through the video and given you choose mode=0, find a minimal or maximal border size to set a fixed crop value (set width and height in DogCrop below original res), in case mode=2 (scaling) is a nono. mode=0 ![]() ![]() mode=2 ![]() ![]() It's not Credits proof, so I recommend you to use trims, to trim out problematic areas. Download from my Github Code:
### Automatic cropping and/or centering function.
### It works more like a recentering function when borders are asymmetrical or varying between shots.
### Which makes it easier to crop later after inspection (with width/height params) to the minimum or maximal found border.
### "Width/Height" Destination width/height
### "thr" Threshold, pixel values above this will be considered borders
### "CropMore" In case of odd cropping, either crop 1 pixel out or leave 1 pixel of the border
### "ScanW/ScanH" Range of pixels for scanning borders, set this to minimum to enhance performance
### "mode" Mode of the function. 0: centers the frame within borders
### 1: crops to minimum found borders
### 2: resize bordered shots to destination width/height (Default)
### "Kernel" Kernel to use for resizing
### i.e.
### DogCrop(1920,1080,thr=16.0,cropmore=true,ScanW=90,ScanH=0,mode=2)
function DogCrop(clip c, int "width", int "height", float "thr", bool "CropMore", int "ScanW", int "ScanH", int "mode", string "kernel") {
c
w = width()
h = height()
nw = Default(width,w)
nh = Default(height,h)
addw = Default(ScanW,round((width()/5)))
addh = Default(ScanH,round((height()/4)))
thr = Default(thr, 16.0) # Threshold, pixel values above this will be considered borders
CM = Default(CropMore, False) # In case of odd cropping, either crop 1 pixel out or leave 1 pixel of the border
mode = Default(mode, 2) # 0: center+pad 1: crop to minimum (WIP) 2: resize to maximum
kernel = Default(kernel, "spline36") # Kernel to use when resizing (mode=2)
sisphbd = AvsPlusVersionNumber > 2294
contoy = sisphbd ? !isy() : !isy8()
ScriptClip("""
contoy ? sisphbd ? converttoy() : converttoy8() : last
x1=0 x2=0
y1=0 y2=0
for (li=2, addw, 2) {
L1=crop(0,0,-w+li,0)
avgLL=AverageLuma(L1)
if (avgLL>thr) {
x1= addw == 0 ? 0 : CM ? li : li-2
li=addw
for (ri=2, addw, 2) {
R1=crop(w-ri,0,0 ,0)
avgLR=AverageLuma(R1)
if (avgLR>thr) {
x2= addw == 0 ? 0 : CM ? ri : ri-2
ri=addw
for (ti=2, addh, 2) {
T1=crop(0,0,0,-h+ti)
avgLT=AverageLuma(T1)
if (avgLT>thr) {
y1= addh == 0 ? 0 : CM ? ti : ti-2
ti=addh
for (bi=2, addh, 2) {
B1=crop(0,h-bi,0 ,0)
avgLB=AverageLuma(B1)
if (avgLB>thr) {
y2= addh == 0 ? 0 : CM ? bi : bi-2
bi=addh
crop(c,x1,y1,-x2,-y2)
mode == 0 ? padresize(w,h) : \
mode == 1 ? padresize(w,h) : \
RatioResize(float(nw),"adjust2w", kernel=kernel).padresize(w,h)
""",args="c,nw,nh,addw,addh,w,h,thr,CM,sisphbd,contoy,mode,kernel")
padresize(nw,nh)
I had two issues in case someone can help me optimize it further. I could not use eval inside ScriptClip to skip when ScanH/ScanW is 0. Using nnedi3 for RatioResize() calls nnedi3_resize16(), this causes a memory leak when used inside ScriptClip, is this a nnedi3 issue? Last edited by Dogway; 3rd April 2021 at 22:39. |
#2 | Link | |
ColorBars(width=640, height=480, pixel_type="yv12")
ScriptClip("""
Spline36Resize(Width(),Height()*2).Spline36Resize(Width(),Height())
See My Avisynth Stuff Last edited by real.finder; 2nd April 2021 at 20:10. |
#4 | Link |
nnedi3 =/= nnedi3_resize16
and seems you didn't see this https://forum.doom9.org/showthread.php?p=1939782 it's Dither_resize16 problem since nnedi3_resize16 use Dither_resize16, I did try nnedi3 alone and didn't note any leak ColorBars(width=640, height=480, pixel_type="yv12") ScriptClip(""" ConvertBits(16).ConvertToStacked.Dither_resize16(Width(),Height()*2).Dither_resize16(Width(),Height()).ConvertfromStacked.ConvertBits(8) """)
See My Avisynth Stuff Last edited by real.finder; 2nd April 2021 at 22:53. |
#5 | Link | |
same method you used in SMDegrain but seems you forget
See My Avisynth Stuff |
#6 | Link |
Oh my gosh... I've been prepending "if" before ternaries lol. Long time away from avs and too much with Python lately.
I wasn't using lsb on my nnedi3_resize16 () call so I didn't expect Dither_resize16 to be used, but I haven't inspected the code closely. Maybe the function needs an update since there are so many alternatives lately. I'm going to update DogCrop() for moving mattes, that means pixel accuracy (maybe subpixel?) and optimize it a bit further. |
#7 | Link |
Here is the latest version (renamed to MatteCrop), now it samples the average per row of pixels instead of aggregated rows, this makes it faster. Also I implemented a 1 pixel accuracy for moving mattes.
There's some little jump on moving mattes since after all I have to crop on a mod2 basis, unless I convert to RGB which I want to avoid. I will test with a reencode of my source sample if it is too distracting. Here before and after: Source: https://www.mediafire.com/file/ao9zccmqlft8vlm Processed: https://www.mediafire.com/file/vd8vajaccpl7449 Code:
### "Moving" If the matte is moving (sliding) it defaults to 1 pixel accuracy, among other settings (check defaults)
### 1: crops to minimum found borders (Work in Progress)
### i.e.
### MatteCrop(1920,1080,thr=16.0,cropmore=true,ScanW=90,ScanH=0,mode=2)
function MatteCrop(clip c, int "width", int "height", float "thr", bool "CropMore", bool "Moving", int "ScanW", int "ScanH", int "mode", string "kernel") {
c
w = width()
h = height()
addw = Default(ScanW,int(round((width()/5))))
addh = Default(ScanH,int(round((height()/4))))
Mot = Default(Moving, False) # If the matte is moving (sliding) this enables pixel level accuracy.
CM = Default(CropMore, Mot ? True : False) # In case of odd cropping, either crop 1 pixel out or leave 1 pixel of the border
thr = Default(thr, Mot ? 16.3 : 16.0) # Threshold, pixel values above this will be considered borders
ScriptClip("""
x1=0 x2=0
y1=0 y2=0
step = Mot ? 1 : 2
addw != 0 ? Eval("
for (li=step, addw, step) {
if (AverageLuma(crop(li-step,0,-w+li,0))>thr) {
x1= CM ? li : li-step
li=addw
for (ri=step, addw, step) {
if (AverageLuma(crop(w-ri,0,-ri+step,0))>thr) {
x2= CM ? ri : ri-step
ri=addw
}") : nop()
addh != 0 ? Eval("
for (ti=step, addh, step) {
if (AverageLuma(crop(0,ti-step,0,-h+ti))>thr) {
y1= CM ? ti : ti-step
ti=addh
for (bi=step, addh, step) {
if (AverageLuma(crop(0,h-bi,0 ,-bi+step))>thr) {
y2= CM ? bi : bi-step
bi=addh
}") : nop()
MotW = Mot ? round(w-x1-x2) : nop()
MotH = Mot ? round(h-y1-y2) : nop()
Mot ? spline36resize(c,MotW+MotW%2,MotH+MotH%2,src_left=x1,src_width=-x2,src_top=y1,src_height=-y2) : \
""",args="c,nw,nh,addw,addh,w,h,thr,CM,sisphbd,contoy,mode,kernel,Mot",local=true)
padresize(nw,nh) }
#8 | Link |
Doggy,
If you have Cabaret [Minnelli/York] on DVD, suggest chop 10 minitue section starting at [I think] "Prairie Oyster" scene [when Minnelli & York first meet] and test on that 10 mins. I know that AutoCrop totally butchers it with its default settings. [just to get an idea of how well it performs in bad situations, maybe].
#9 | Link |
There are some false-positives in the section where she changes the turntable, but nothing else otherwise (is the DVD bordered?).
Autocrop would overcrop a little overall. In any case I designed this for the source at OP, like digital mattes, for DVDs and some crappy borders I think maybe I would need to average a selectevery range of frames and maybe SC on top. Makes things more difficult. But if anyone can provide a sample I can give it a look. |
#10 | Link | ||
According to IMDB Quote:
autocrop on my copy chopped off a good third off left edge I think, almost nothing left. EDIT: By default, [original] autocrop only samples 5 frames.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 4th April 2021 at 02:20. |
#11 | Link | |||
also there are SmoothAdjust that has no alternatives and the worst is close source so for HBD there are many things that will not work as I said before (but I will put it here with some edit) Quote:
See My Avisynth Stuff Last edited by real.finder; 3rd April 2021 at 20:54. |
#12 | Link |
Yeah, as you might expect I have been giving a glimpse to nnedi3_resize16() to find out what makes it so special about Dither.
I'm very tempted to simplify it but I'm aware that you are more apt to the task than me, if you haven't tried already. Can't you use cube instead of fmtconv? HBD on 420 is what most need in any case, to start things up. |
#13 | Link |
IIRC cube is RGB only, also I don't think anything can fully replace Dither_resize16 aside from fmtconv since fmtconv is like dither tools but for vs (it's made by same developer)
#14 | Link |
AFAIK Dither tools also required conversion to RGB for color matrix operations, not sure about fmtconv but I doubt it's not the same, color space operations are always performed on RGB.
Updated MatteCrop to fix edges on moving mattes, and also added support for HBD. Code:
### https://forum.doom9.org/showthread.php?t=182678
### Dependencies (for Moving=true):
### EdgeFixer (http://avisynth.nl/index.php/EdgeFixer)
### i.e.
c
w = width(c)
h = height(c)
bdpth = sisphbd ? pow(256.,c.BitsPerComponent()/8.)/256. : 1.
fullchr = contoy ? UtoY().width() == w : true
addw = Default(ScanW,int(round((w/5))))
addh = Default(ScanH,int(round((h/4))))
CM = Default(CropMore, Mot || fullchr ? True : False) # In case of odd cropping, either crop 1 pixel out or leave 1 pixel of the border
thr = thr*bdpth
pclip=contoy ? sisphbd ? converttoy() : converttoy8() : last
ScriptClip("""
x1=0 x2=0
y1=0 y2=0
step = Mot ? 1 : 2
pclip
addw != 0 ? Eval("
li=addw
ri=addw
}") : nop()
addh != 0 ? Eval("
ti=addh
bi=addh
}") : nop()
Mot ? spline36resizeMT(c,fullchr?MotW:MotW+MotW%2,fullchr?MotH:MotH+MotH%2,src_left=x1,src_width=-x2,src_top=y1,src_height=-y2) : \
RatioResize(float(w),"adjust2w", kernel=kernel).padresize(w,h,mirror=!CM)
""",args="c,nw,nh,addw,addh,w,h,thr,CM,sisphbd,contoy,mode,kernel,Mot,fullchr,pclip",local=true)
padresize(nw,nh)
(!CM || Mot) && mode==2 ? ContinuityFixer(left=addw>0?2:0, top=addh>0?2:0, right=addw>0?2:0, bottom=addh>0?2:0, radius=CM && w>720?0:1) : last }
#15 | Link |
Doggy, this is what it looks like, borders on all 4 sides [have not as yet ascertained aspect ratio]
![]() EDIT: OK, DAR = about 1.817687, or thereabouts, not 1.60 like I said, musta been the side borders that put me off the scent. ![]() Code:
# Mpeg2Source(...)
DAR=4.0/3.0 # full frame
SAR=Last.RT_GetSAR(DAR) # Sample ie pixel aspect ratio
X=RoboCrop() # auto cropped
DAR=X.RT_GetDAR(SAR) # DAR after crop
RoboCrop(Show=true) # Now re-do crop but keep borders, show where cropped
Subtitle("DAR="+String(DAR),Align=2) # Show DAR
Double or wiggly lines [top, right, bottom] are where extra cropping was applied due to colorspace or default xmod/ymod requirements [I just used robocrop without specifying WMod/HMod and whether interlaced] EDIT: Convert to YV24 and WMod=1,HMod=1,Laced=False, DAR=1.802020, so as exact detected edges Code:
ConvertToYV24
DAR=4.0/3.0
X=RoboCrop(WMod=1,HMod=1,Laced=false)
DAR=X.RT_GetDAr(SAR)
RoboCrop(WMod=1,HMod=1,Laced=false,Show=true)
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 4th April 2021 at 02:28. |
#16 | Link |
The script works better than autocrop as in it doesn't butcher the left side, but it's not designed for these kind of sources with dirty mattes nor even fixed mattes (just manually insert crop()? ) but varying border mattes or border sizes, that's why the code is in runtime. In any case I crafted some kind of prefilter and got very stable results with some occasional 1 pixel matte resize, which in my book isn't allowed neither. Ideally one would want to create equally weighted temporal averages of shots, I had a look yesterday, I'm sure it can be done using DBSC or some of your tools.
One main problem with your sample is that there's a bright column right in the middle of the border, which triggers the detection and forces you to raise the thr therefore having that jumping matte as result (I tried to remove it with median in prefilter). ![]() As for Robocrop it detects the furthermost border, so for my source it will leave lots of innermost borders. Yesterday I gave a thorought look to DBSC following your guide for dynamic cropping and I managed to get it somewhere, but there were some borders left untouched, some overcropping, some anamorphic scaling, and no work done on moving mattes. This is what I get out of Robocrop with the following settings: Code:
######## Temp OUTER RoboCrop args (to remove outermost/common border) RC_SAMPLES = Max(Round(FrameCount/(FrameRate*1.0)),12) # Sample 1 Frame every 1 seconds, RC_IGNORE = 0.04 RC_WMOD = 2 # Width multiple of this RC_HMOD = 2 # Height multiple of this RC_LEFTSKIP = 0 # Crop at least these RC_TOPSKIP = 12 RC_RIGHTSKIP = 0 RC_BOTSKIP = 12 CropLimit_Left=85 CropLimit_Top=12 CropLimit_Right=0 CropLimit_Bot=12 # EDIT: The dynamic border cropping max's (also see RLBT) ![]() And this is the result after removing autocontrast (vertical stretched): ![]() The function name might sound misleading, I wanted to call it DynaCrop but the seat was not vacant : P |
#17 | Link |
I tried DBSC a while back and was on the verge of suicide before I managed to get it to work almost properly (there was still some tweaking needed for it not to over-crop in a couple of places). I just love StainlessS's help files.
![]() For the DynaCrop stretching problem, I'll throw in a plugin for my CropResize function. https://forum.doom9.org/showthread.php?t=176667 If the source is anamorphic you could specify input and/or output sample aspect ratios (not an input display aspect ratio in this case though). Some silly cropping and adding of borders for testing. A = Crop(20,20,-20,-20).AddBorders(20,20,20,20).Trim(30000,30099) B = Crop(100,20,-10,0).AddBorders(100,20,10,0).Trim(30000,30099) A + B Frame #50 ![]() Frame #150 ![]() DBSC_DynaCrop("D:\New.ScanDB", "D:\New.SpliceDB", 640,480, CropLimit=100, CropThresh=16) Frame #50 ![]() Frame #150 ![]() DBSC_DynaCrop("D:\New.ScanDB", "D:\New.SpliceDB", 640,480, Resizer="CropResize(_W_,_H_)", CropLimit=100, CropThresh=16) Frame #150 ![]() DBSC_DynaCrop("D:\New.ScanDB", "D:\New.SpliceDB", 640,480, Resizer="CropResize(_W_,_H_, Borders=true)", CropLimit=100, CropThresh=16) Frame #150 ![]() DBSC_DynaCrop("D:\New.ScanDB", "D:\New.SpliceDB", 640,480, Resizer="CropResize(_W_,_H_, Borders=true, Frosty=true)", CropLimit=100, CropThresh=16) Frame #150 ![]() While I was messing around I made a new wrapper function for Dogway's SpliceResize. CropResize(640,480, Resizer="CR_SpliceResize") Code:
# ========== CR_SpliceResize() - Bicubic & Spline64 Wrapper Function ============
# Requires MaskTools2 http://avisynth.nl/index.php/Masktools2
# SpliceResize by Dogway https://github.com/Dogway/Avisynth-Scripts/blob/master/ResizersPack4.7.3.avsi
# Resizer which gets the best from 2 worlds, the "sharpness" of spline64 and the "ringing-free" catmull-rom,
# biased by a threshold.
# Slightly mod from javlak's function http://forum.doom9.org/showthread.php?p=1504678#post1504678
function CR_SpliceResize(clip Source, int target_width, int target_height, \
float "src_left", float "src_top", float "src_width", float "src_height", float "B", float "C", int "Threshold") {
Threshold = default (Threshold, 8)
B = default(B, 0.0)
C = default(C, 0.5)
mt_lutxy(BicubicResize(Source, target_width, target_height, \
src_left=src_left, src_top=src_top, src_width=src_width, src_height=src_height, b=B, c=C), \
Spline64Resize(Source, target_width, target_height, \
src_left=src_left, src_top=src_top, src_width=src_width, src_height=src_height), \
"x y - abs "+string(threshold)+" > y x ?") }
#18 | Link |
Yes, with CropResize it doesn't stretch anymore but still lots of overcropping and left out borders, (it tends to prefer cropping vertically than horizontally), not to talk about sliding mattes. Overcropping on digital borders seems like a big mistake to oversee, or probably I'm doing it wrong.
For clean borders such as BluRays I'm content with my function 99%, and to nail it to extend it to DVDs would be per shot averages... now I recall RT_Stats providing such info... I should investigate. EDIT: Yes, RT_AverageLuma() but doesn't have SC. Answering below: Yes, it's set as LACED=false as indicated in the client script Code:
OCROP = ORG.RoboCrop(SAMPLES=RC_SAMPLES,ignore=RC_IGNORE,WMod=RC_WMOD,HMod=RC_HMOD,
\ LeftSkip=RC_LEFTSKIP,TopSkip=RC_TOPSKIP,RightSkip=RC_RIGHTSKIP,botskip=RC_BOTSKIP,
\ LogFn=TmpCropLog,LogAppend=false,Align=True,laced=False)
#19 | Link | |
One thing I will say is that you should specify LACED=False [where so], otherwise YMOD [default gotten from natural colorspace croppable granularity]
will be doubled if default is left at LACED=true. I may come back again later. EDIT: In the provided DBSC sample script Code:
RC_LEFTSKIP = 0 # Crop at least these RC_TOPSKIP = 2 RC_RIGHTSKIP = 0 RC_BOTSKIP = 2 Quote:
CropLeft_limit etc should be set to [ideally] same or 1 pixel more than greatest thickness border [which is alread pre-Robocropped]. DBSC_ShowCrop() should NOT be called separately without pre-RoboCrop. Code:
CropThresh=-40.0, Auto thresholding, measures min and max luma in [already pre-robocropped] source, and in case of -40, sets threshold to minimum Y level + 40. [Old default was -32]. +16 is probably way too low, but -16 might be OK if you know what you are doing. Pre-Robocrop, gets rid of dark common border which removes those numbers, better measurements. EDIT: I've never played with blueray stuff, I've no idea what its like.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 4th April 2021 at 21:19. |
#20 | Link |
DynaCrop cropped just the borders for my example, except for maybe the 10 pixel border. I haven't looked closely at that one. The over-cropping in one screenshot was done by my script to prevent aspect error, and I think it defaults to mod4 even when adding borders, so any extra cropping when resizing and adding borders would've been my fault too.
I assume you could tell DynaCrop to leave the top and bottom borders alone if you want to keep them, but I was experimenting with removing them all, as that's what I'd normally do. StainlessS, I forgot about the Laced argument, although except for one, the borders were all mod4 anyway. Last edited by hello_hello; 4th April 2021 at 21:02. |
| Tags |
| align, automatic, crop, reframe |
| Thread Tools | |
| Display Modes | |
