#1 | Link |
VSGAN - VapourSynth GAN Implementation, based on ESRGAN's implementation
https://github.com/rlaphoenix/VSGAN
docs: https://vsgan.phoeniix.dev VSGAN as of 1.6.0 is a port of multiple kinds of machine learning GAN Networks and Architectures. As of 1.6.0, ESRGAN (and its derivatives), and EGVSR is supported. For much more information, getting started, more details on supported models, networks, architectures, check the docs. Last edited by PRAGMA; 24th January 2022 at 09:03. |
#2 | Link |
Thanks, it works well
Any lists for nice pre-trained models ? I found a bunch on Google , but does anyone have any "favorites" that work well in specific situations? (including Pragma's own AD model) https://upscale.wiki/wiki/Model_Database Last edited by poisondeathray; 15th October 2019 at 23:51. |
#3 | Link | |
https://github.com/WolframRhodium/Super-Resolution-Zoo |
#4 | Link | |
But these are converted models (params , json ; not pth), are they drop in compatible ? (And some of the links to the original projects and papers have pth models) Last edited by poisondeathray; 16th October 2019 at 06:42. |
#5 | Link | |
The "spongebob model" looked also not bad for some older animes but had some blurry spots for some reason.
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database || https://github.com/avisynth-repository |
#6 | Link |
I get out of memory errors for 1080p content using a GTX 1070. Does it really need what much ram? used model 1x_DeSharpen
CUDA out of memory. Tried to allocate 1.48 GiB (GPU 0; 8.00 GiB total capacity; 2.56 GiB already allocated; 72.05 MiB free; 3.65 GiB cached) Restarting vsedit didn't help.
#7 | Link |
I think so...I can only use 1x_Desharpen on smaller dimensions . You can look at GPU caps viewer or similar utilities and it looks like it's using all
I wonder if there is a way to share system memory with CUDA memory ? eg. Although it's slower, some 3D/CG renderers can offload graphics card memory to system memory when doing calculations (like a shared pool) enabling you to complete if the scene is too large |
#8 | Link | |
PyTorch does have a "empty cache" function. Maybe you could call it every few frames with FrameEval. https://pytorch.org/docs/stable/cuda...ory-management |
#9 | Link | ||
#10 | Link | ||
But yes, generally speaking x1080 resolution content require quite a bit of memory, i'm trying to work out a way to split up the input frame into multiple split images, to then run them all separately and then combine them back to 1 frame and return, that way using the same amount of memory, but less memory simultaneously, would be slower, but would be the only viable option for most GPU's. I'm having a bit of trouble working it out right now but hopefully I or someone else, figures out a way to do so. |
#11 | Link | |
#12 | Link | |
I didn't end up using anything like EDSR though, instead I simply cropped the frame, and then ran them. |
#13 | Link |
Thanks for the update
Request: If you have time would it be possible to port EDVR ? Looks great and deals with video specific issues, temporal and motion blur https://xinntao.github.io/projects/EDVR https://github.com/xinntao/EDVR |
#15 | Link |
Request#2 , another pytorch implementation, PPON
https://github.com/Zheng222/PPON Someone forked it and wrote some demo code , would it be possible to implement in vapoursynth ? https://github.com/vlad3996/PPON/blo...rence_utils.py https://github.com/vlad3996/PPON/blob/master/demo.ipynb Thanks |
#17 | Link | |
As an aside, I wonder what speeds are you folks getting? With a GTX 1070, upscaling 480p content using the "PSNR_x4_DB.pth" model, I'm getting like... 1fps :/ |
#18 | Link | |
RTX 2080ti takes about 1.4s per frame for the same input. |
esrgan, gan, upscale, vapoursynth |
