Old 20th April 2019, 21:54   #161  |  Link
Manni
Originally Posted by Klaus1189 View Post
@GTPVHD thank you, do you have more info about Intel? I think it's time to add info for Intel users.
@NM20 and Manni should I remove the Nvidia Note about magenta bug and JVC projectors in the first post?
@all if you have any info about Intel or you think that something is missing and should be added, please let me know.
Thank you
NM20 made a mistake, there is no reason for checking “report BT2020” with a rec-709 calibration. The magenta bug is still an issue for many JVCs, so I would leave the link as it might be useful for others.
Win10 Pro x64 b1809 MCE
i7 3770K@4.0Ghz 16Gb@2.18Ghz EVGA GTX 1080 Ti SC2 11Gb@2GHz 398.11 RGB Full 8bits
MPC-BE/LAV/MadVR/jRiver/MyMovies V5.25
Denon X8500H>HD Fury Maestro>JVC RS2000
Old 23rd April 2019, 14:25   #162  |  Link
GTPVHD
https://www.nvidia.com/en-us/geforce...-ready-driver/
Nvidia GeForce 430.39 WHQL driver, should be the WDDM 2.6 driver but Win10 May 2019 update still not yet officially released.
GTPVHD is offline   Reply With Quote
Old 23rd April 2019, 14:45   #163  |  Link
kostik
New branch... [r430_34-5] WDDM 2.6. Finally it switches to HDR mode immediately and they fixed the 'bug' where seek bar unhidden was causing the screen to change to SDR mode and once hidden again to HDR. I hope metadata is also fixed, waiting for the experts test
TV :LG OLED 65C8 ; PC:CPU: I7-7700K OC 5.1GHz ; GPU: Gigabyte GeForce® GTX 1080 WINDFORCE OC 8G ;Memory: Corsair Vengeance RGB (2X8GB) DDR4 3100MHz, ;
kostik is offline   Reply With Quote
Old 23rd April 2019, 15:39   #164  |  Link
j82k
It's even in the release notes of 430.39:
Fixed Issues in this Release[madVR][HDR]: MadVR is not rendering videos in HDR mode using MPC player. [200505657]
j82k is offline   Reply With Quote
Old 23rd April 2019, 15:47   #165  |  Link
grendelrt
Is HDR metadata being passed correctly (not 1000/20 for everything)?
grendelrt is offline   Reply With Quote
Old 23rd April 2019, 16:21   #166  |  Link
j82k
4000 nit metadata is passed correctly. HDR triggering when madVR is set to 8-bit works too. So far so good....
Old 23rd April 2019, 16:30   #167  |  Link
Klaus1189
Do custom refresh rates work on Win10 1809 without CRU in 430.39?
Old 23rd April 2019, 16:34   #168  |  Link
nevcairiel
You should always prefer to use CRU in any case, it gives you far better control.
Old 23rd April 2019, 18:39   #169  |  Link
SamuriHL
SamuriHL's Avatar
I like this driver very much. It looks to me like they fixed the metadata but I have no real way to confirm. HDR triggers perfectly. I'm very pleased. I think we have a new baseline driver. Of course, others will need to chime in here.
HTPC: Windows 10, I9 9900k, RTX 2070 Founder's Edition, Pioneer Elite VSX-LX303, LG C8 65" OLED
Old 23rd April 2019, 18:50   #170  |  Link
Manni
Only checked briefly with my LG 4K monitor, the HDR metadata passthrough is fixed and it looks like it was able to switch to HDR in 8bits.
I'll report back if I see any issues with the JVC later tonight.
Looks like a good one though
Old 23rd April 2019, 19:16   #171  |  Link
brazen1
I've installed the new nVidia driver 430.39. It is now once again allowing madVR to switch HDR mode. It has also rectified the long lingering audio problem - Multi channel vs stereo auto switch dependent on AVR state on and off.
As expected, nVidia no longer supports 3D. It has been completely removed from the driver install. So far I have installed 3D vision from an older driver. I get a notice that 3D vision does not match the new graphics driver after installing it. I also ran the 3D .reg file in madVR. The 3D option no longer shows up in Windows display properties or NCP. I did attempt to play a 3DMVC.iso in PowerDVD. 3D mode does not engage. I also tried MPC-BE. It displays some strange SBS and then does engage 3D mode. This is a frame packed MVC iso. It shouldn't go into SBS mode imo.
I don't want to spend anymore time fussing with this new driver and I will be reverting back to 416.81 video drivers. Instead of editing those drivers and applying the 388.59 audio driver (bug free) as I've been doing in the past, I will be attempting to use the newer 430.39 audio driver which at this time appears to also be bug free. This combo will update me to the newest working audio and video drivers that meet my demands.
*edit*
The audio bug still exists using the 430.39 driver. It doesn't survive a reboot. I will be using 388.59 audio driver with 416.81 video driver as usual.
W10 1903 9604GB RGB 4:4:4 @Matched Refresh Rates 8,10,12bit
KODI MPC-HC/BE PDVD19 DVDFab 3 & 5
65JS8500 UHD HDR 3D
Old 23rd April 2019, 19:19   #172  |  Link
SamuriHL
SamuriHL's Avatar
Yea I've been watching Infinity War since I installed it and it's flawless. I'm also running 1903 so having a driver that truly supports it and works for everything else is great. And hopefully the RTX owners can chime in on how it works for them, as well. I landed a new job so I started a rebuild of my HTPC. At some point I'll likely get a 2070 for the new 9900k I'm building. Would love to know we have a new baseline driver that works for everyone.
Old 23rd April 2019, 20:42   #173  |  Link
NoTechi
This is crazy ... in other words no more driver updates from now on ....
Time to start to look for AMD
NoTechi
NoTechi is offline   Reply With Quote
Old 24th April 2019, 01:24   #174  |  Link
hotripper
*edit*
Audio bug??? What is the issue? Just curious
4790K - RTX2070 - 970EVO - EVGA Supernova 750W Gold - Sony KD55X720E
hotripper is offline   Reply With Quote
Old 24th April 2019, 01:54   #175  |  Link
ryrynz
ryrynz's Avatar
One page back...
No auto switch from stereo to multiple speaker setup in Windows Audio considering if AVR state is On or Off.
Old 24th April 2019, 02:03   #176  |  Link
grendelrt
I launched a couple HDR games in Windows on the new 430.39 driver and they both reported 1000/400 metadata. Looks like it still doesn't update per game, but its no longer 1000 /20 :/
Old 24th April 2019, 10:20   #177  |  Link
NoTechi
What would be the best way to use an older audio driver? Not sure if it is the audio bug but from time to time windows audio is on stereo. Just a reboot fixes this.
Another problem is that I can't select Atmos anymore even though it was working for some time. Maximum I can select is 7.1. My guess is that this is also caused by communicating wrong EDIT information between AVR and Windows thats why I would like to try an older audio driver.
NoTechi
Old 24th April 2019, 13:06   #178  |  Link
clsid
Has 430.39 fixed the stuttering problems that some were having with previous drivers?
Old 24th April 2019, 17:24   #179  |  Link
Manni
I don’t think the OS has ever reported dynamic HDR metadata. It’s always been fixed. Not sure if the games ask for various values or not.
I can only confirm that with film content, HDR passthrough works fine and reports the actual metadata sent by madVR.
It doesn’t solve any of the outstanding issues on the JVCs (mainly the forced YCC422 in 12bits in RGB or YCC444), but it doesn’t seem to make anything worse.
Apart from the zapping of 3D, it looks like a pretty good driver, and the only one that users of RTX cards can use if they want HDR passthrough to work with madVR.
Old 24th April 2019, 17:37   #180  |  Link
SirMaster
This is NVIDIA Profle Inspector tool with an optimized profile for MPC-HC/BE.
Download
Most important settings it uses:
Power management mode = Adaptive
VSync = on
GSync = off
SLI = off
Prefer NVIDIA on Optimus systems
Is there a way to check if this actually worked?
I tried running this on my system with RTX 2060 on 430.39 driver, but how do I know it actually did something?
I thought I would see something like vsync ON in my nvidia control panel settings, but even after running the .bat file it still says "use application setting" for vsync in my control panel for example.
SirMaster is offline   Reply With Quote
