Old 7th January 2019, 11:37   #1  |  Link
kabelbrand
Compression mode: Lousy
kabelbrand's Avatar
x265 3.0 Dolby Vision encoding
Did someone manage to get an encode up and running with the new --dolby-vision-rpu option?
This is what the command line looks so far:
ffmpeg -loglevel quiet -i Cosmos_Laundromat_Dolby_Vision_24p_2048x858.mxf -pix_fmt yuv420p10 -f rawvideo - | x265-10b - --input-res 2048x858 --input-depth 10 --input-csp i420 --fps 24/1 --profile main10 --level-idc 5.1 --bitrate 30000 --vbv-maxrate 40000 --vbv-bufsize 40000 --repeat-headers --colorprim bt2020 --transfer smpte2084 --colormatrix bt2020nc --master-display G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,1) --max-cll 1000,400 --dolby-vision-profile 8.1 --dolby-vision-rpu cosmos_laundromat_vdm_hdr_p3d65_pq_20160525_01_2048x858_dovi_4000nit_metadata.xml --output Cosmos_Laundromat_Dolby_Vision_24p_2048x858.265
Is there something wrong with the metadata? I always get this error:
x265 [error]: Invalid Dolby Vision RPU startcode in POC 0
kabelbrand is offline   Reply With Quote
Old 7th January 2019, 12:21   #2  |  Link
nevcairiel
Judging from the error, it wants a binary encoded RPU file, and not a metadata XML.
Old 7th January 2019, 12:49   #3  |  Link
kabelbrand
kabelbrand's Avatar
Thanks, it's plain XML indeed. So how do I get a binary presentation of this? "metafier" does not seem to support it.
Btw. the source assets are linked in the command line.
Last edited by kabelbrand; 7th January 2019 at 15:02. Reason: added note about metafier
Old 12th January 2019, 11:41   #4  |  Link
Selur
Selur's Avatar
Would be interested in that too.
Also is there a way to extract the data somehow?
As a side note: does using
make sense here?
I thought those were HDR-10 settings and shouldn't be used with Dolby Vision.
Cu Selur
Old 14th January 2019, 10:53   #5  |  Link
kabelbrand
kabelbrand's Avatar
I guess when aiming for Dolby Vision profile 8.1 these should be included to also have HDR10 playback compatibility:
http://x265.org/x265-delivers-dolby-vision-streams/
Old 14th January 2019, 18:24   #6  |  Link
Selur
Selur's Avatar
Ah didn't know that.
Old 14th January 2019, 19:30   #7  |  Link
halls
Hi!
There is any way to extract metadata from an existing file into RPU file?
halls is offline   Reply With Quote
Old 15th January 2019, 23:01   #8  |  Link
benwaggoner
Yes, you should include the 2086 metadata if you want to use it. A device that can't use the 8.1 DoVi metadata will fall back to HDR-10 static metadata (or HDR10+ dynamic metadata if available and supported)
Ben Waggoner
My Compression Book
Old 13th February 2019, 16:35   #9  |  Link
djloewen
Am I correct in understanding that there's currently no way to extract the RPU information from the secondary Dolby Vision HEVC track on a commercially-produced UHD Blu-Ray, and use that data to encode in X.265?
djloewen is offline   Reply With Quote
Old 13th February 2019, 19:06   #10  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
I don't believe there is, at least not publicly available.
Also, it's x265 not X.265
Old 13th February 2019, 19:20   #11  |  Link
djloewen
Got it, thanks .
Old 16th April 2019, 12:05   #12  |  Link
nghiabeo20
Does DoVi file encoded with previous version of x265 (specifically 2.5) still has this fallback capability? Thanks!
nghiabeo20 is offline   Reply With Quote
Old 18th April 2019, 16:45   #13  |  Link
benwaggoner
It should, but I've never tried.
Ben Waggoner
My Compression Book
Old 10th November 2020, 22:28   #14  |  Link
Balling
Actually HDR10+ is preferred usually.
Balling is offline   Reply With Quote
Old 11th November 2020, 17:00   #15  |  Link
benwaggoner
Yeah, anything that supports Profile 8.1 or HDR10+ will use one of those before falling back to using the (pretty lame and vestigial) 2086 static metadata.
I don't know of any devices that have shipped with BOTH DoVi 8.1 and HDR10+, and it would be up to the device to pick which one to use if both are available. I don't know if there would be any practical advantage of one over the other. DoVi Profile 5 can, in theory, provide less banding and somewhat more efficiency due to its non-backwards compatible base layer and YCtCp. I've not tested that myself yet, though. It's be a pain to evaluate without a single display that can use both modes. Probably feasible with a couple of reference displays driven by a ColorFront Transcoder...
Ben Waggoner
My Compression Book
Old 20th November 2020, 17:11   #16  |  Link
Stacey Spears
Dolby Encoding Engine is available for $500 per year per node and can create a binary RPU from a Dolby Vision XML.
Stacey Spears
Co-Creator, Spears & Munsil Ultra HD Benchmark
Stacey Spears is offline   Reply With Quote
Old 21st November 2020, 00:10   #17  |  Link
Blue_MiSfit
DEE is a solid tool. I've used this for several projects using Dolby tech.
Old 21st November 2020, 23:10   #18  |  Link
quietvoid
Posting in this thread as it's the oldest.
I made a first release of my tool: https://github.com/quietvoid/dovi_to.../tag/0.1.0-fix
It can be used to create an RPU file from a profile 5, 7 or 8 HEVC encoded file.
Commands:
demux: Demuxes single track dual layer Dolby Vision into Base layer and Enhancement layer files.
extract-rpu: Extracts Dolby Vision RPU from an HEVC encoded file.
More info in the README.
Enjoy.
quietvoid is offline   Reply With Quote
Old 21st November 2020, 23:50   #19  |  Link
ghostshadow
Hello Quietvoid, thank you for your work
I used it on an El.hevc file containing the RPU and I have this error message
thread 'main' has overflowed its stack
ghostshadow is offline   Reply With Quote
Old 22nd November 2020, 01:53   #20  |  Link
quietvoid
It might be related to the memory, buffer allocations..
My stack size on linux was limited to 8MB, and I was using 4MB in the code.
I have lowered it way down, please try again.
dolby vision, dovi, hdr, rpu, x265
