Old 7th September 2019, 17:10   #81  |  Link
quietvoid
Originally Posted by Nico8583 View Post
Thank you, I get only 2 FPS when I use it (I use copy to video codec, I don't recode it).
Could you give me the ffmpeg version you use and the command line ? Thank you.
Zeranoe FFmpeg builds should work, there's an example CLI:
ffmpeg -i "input.mkv" -c:v copy -vbsf hevc_mp4toannexb -f hevc - | hdr10plus_parser.exe -
quietvoid is offline   Reply With Quote
Old 9th September 2019, 15:02   #82  |  Link
Nico8583
Thank you, I just replaced an old ffmpeg with the newest version and now I get 500 fps instead of 50 fps...
Nico8583 is offline   Reply With Quote
Old 24th September 2019, 18:31   #83  |  Link
mini-moose
double post by mistake. can be deleted.
mini-moose is offline   Reply With Quote
Old 24th September 2019, 18:50   #84  |  Link
mini-moose
hi quietvoid
I was playing around with a recent hdr10+ disc I got.
The tool dialog added something called "Mastering peak flag enabled":
Parsing HEVC file for dynamic metadata...
[00:02:25] 100%
Reading parsed dynamic metadata... Mastering peak flag enabled
Done.
Writing metadata to JSON file... Done.
the "Mastering peak flag enabled" repeats about 40-50 times.
Then I tried to serve the json to x265 and encode the vid.
Looked at the MediaInfo report and it shows just this:
HDR format : SMPTE ST 2094 App 4, Version 1
On previous encodes I did show up like this:
HDR format : SMPTE ST 2094 App 4, Version 1, HDR10+ Profile A compatible
or
HDR format : SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
From the little I understand, it appears it can't recognize it as hdr10+
Old 24th September 2019, 19:40   #85  |  Link
quietvoid
Originally Posted by mini-moose View Post
hi quietvoid
[00:02:25] 100%
Done.
or
Hi, thanks for the feedback.
That part of the metadata was not implemented, I can't remember whether it was in the specs sheet I was using.
If it was, I did note that it was not supposed to be enabled in the version's specs.
So it is possible there is a new version of the spec, where some of these flags are actually being used now.
I had received some feedback regarding a disc failing to parse recently, but I have not had the time to look into it.
Can you share the title? If I remember correctly it was Shaun of the Dead.
Edit: I have done a bit of research and it seems the HDR10+ LLC alliance has published a press release on 2019/09/04.
Released this month is an updated Technical Specification to respond to industry’s request of new device categories and codecs as well as a comprehensive whitepaper to introduce the technology and it’s benefit to new adopters
So there's likely no access for now, even x265 will likely need to update their implementation.
Old 24th September 2019, 20:51   #86  |  Link
mini-moose
I figured out the issue with x265, but like you said, the json made with this new hdr10+ profile may not have all that is required to work properly.
Old 27th September 2019, 23:19   #87  |  Link
quietvoid
Turns out your issue was an edge case.
Updated the parser to 0.2.4
Fix edge case when AverageRGB, MaxScl are 0 but not targeted_system_display_maximum_luminance.
Add asserts to avoid invalid data.
Error when the dynamic metadata is from a (possibly) unsupported version.
https://github.com/quietvoid/hdr10plus_parser/releases
Old 28th September 2019, 13:25   #88  |  Link
mini-moose
thanks for the update!
Edge case you mean why I couldn't get x265 to identify hd10+ without cutting out the first second?
Old 28th September 2019, 14:47   #89  |  Link
quietvoid
The edge case was present in the first second so the JSON was most likely invalid for the first second.
So now if the parser doesn't error, the metadata should be valid.
Old 10th November 2019, 09:42   #90  |  Link
PapitaHD
problem with American Gangster UHD BluRay
Hi all,
First of all let me thank quietvoid for the hdr10+ parser, works great and very easy to use!
My only issue is the same that mini-moose mentioned a few posts back. I'm trying to encode the quite recent American Gangster BD which has hdr10+. I used the parser as advised to get the json file with the metadata, but after encoding the movie, the resulted file doesn't have the hdr10+ flag in mediainfo. It shows: SMPTE ST 2094 App 4.
What can be the issue, maybe the parser needs another update?
Thanks in advance!
PapitaHD is offline   Reply With Quote
Old 20th November 2019, 20:42   #91  |  Link
quietvoid
Sorry, I hadn't seen your post.
As far as I'm aware, HDR10+ is a format in conformance with SMPTE ST 2094 App 4.
MediaInfo sometimes includes a HDR10+ profile compatibility, but I have no idea what they mean.
The "HDR10+ profile A/B compatible" flag seems to be lost after reencode sometimes, however the presence of ST2094 App 4 metadata is still detected.
It mostly happens with titles released after the September 4 2019 specifications release.
If anyone has information regarding the HDR10+ profiles, it would be useful.
Otherwise I don't really know what is missing for HDR10+ profiles compatibility.
Old 20th November 2019, 21:26   #92  |  Link
mini-moose
Maybe another edge case like mine had?
Old 20th November 2019, 22:46   #93  |  Link
quietvoid
Well, the metadata gets parsed correctly.
There might be some data missing (in the JSON or after x265's encode) but without the new specifications or an updated example JSON I don't know what the difference would be.
Old 21st November 2019, 07:25   #94  |  Link
quietvoid
Sorry for the double post.
I've tested with the x265 example and it always has HDR10+ Profile B compatible.
Turns out it's not being flagged if there is no BezierCurveData object in the JSON.
So added it (it used to only be added when there is actual data for it), and refactored the code to be more readable. Also improved the JSON to be properly generated.
Fixed the cargo run not working, tested that all the input/output arguments work just like before. Hopefully nothing breaks.
Updated to 0.2.5
Old 21st November 2019, 22:27   #95  |  Link
PapitaHD
Thanks a lot, it's working perfeclty now!
I encoded The Shining and American Gangster with hdr10+ successfully and I'm gonna test it on Ad Astra as soon as it's out.
Old 22nd November 2019, 01:09   #96  |  Link
quietvoid
Further more, I just stumbled across this in the September 2019 White Paper from https://hdr10plus.org/wp-content/upl...WhitePaper.pdf
No matter the workflow used, HDR10+ technology can support the full range of HDR standards to 10,000 cd/m2, 8K and BT.2020 color gamut.
Being resolution agnostic, metadata needs to be created only once and can be applied to any target resolution.
So it seems there should be no problem with cropping and/or resizing.
Old 22nd November 2019, 01:16   #97  |  Link
nevcairiel
Actually with cropping you would need to adjust the metadata, but resizing should be fine, as long as the relative dimensions and aspect ratio stay the same (but to change that you would probably crop anyway).
Old 22nd November 2019, 03:06   #98  |  Link
quietvoid
I still think there's nothing relevant to the resolution/aspect ratio in the current version.
The Bezier curve data specifies info for the curve generation only.
The processing windows (which do mention pixel coordinates) are not in this version.
The only thing that might need adjustment is the average/max RGB values if they were calculated with the black bars not accounted for.
Unless I'm missing something..
Old 22nd November 2019, 09:45   #99  |  Link
nevcairiel
Oh, I didn't check what might be in there, I only remember from implementing HEVC metadata parsing that it contains the processing windows - on second thought they would probably also need adjustment for scaling, but thats easier since you just have to scale their coordinates.
But even then, resizing the processing windows is trivial, what the Whitepaper refers to would indicate actually having to determine full new metadata, which can be avoided that way.
Old 31st December 2019, 16:26   #100  |  Link
jlpsvk
just a question... shoudn't be then all HDR video encoded without cropping? average CLL and MAX-CLL are calculated with the black bars, if I am right. so without it, it could cause playing somehow different, as with black bars... it's just my quess...
AMD Ryzen 9 3950X, 32GB DDR4-3200 CL16, RTX 2070, 1TB NVMe SSD, 56TB NAS
jlpsvk is offline   Reply With Quote
