#661 | Link | |
#662 | Link | |
Oz of the zOo
Here's an excerpt from spy++, the menu is shown at the 3rd line WM_ENTERIDLE, then I move the mouse cursor outside of the menu area. I could try to debug it in Visual Studio if you provide the pdb files. Code:
000C0636 R WM_DRAWITEM fProcessed:True 000C0636 S WM_ENTERIDLE fuSource:MSGF_MENU hwnd:008C0560 000C0636 R WM_ENTERIDLE 000E0972 P WM_TIMER wTimerID:5 tmprc:00000000 003507EA P WM_TIMER wTimerID:1 tmprc:00000000 000C0636 P WM_MOUSEMOVE fwKeys:0000 xPos:1456 yPos:472 008C0560 S message:0x01E5 [Unknown] wParam:FFFFFFFF lParam:00000000 000C0636 S WM_ENTERIDLE fuSource:MSGF_MENU hwnd:008C0560 000C0636 R WM_ENTERIDLE 008C0560 P WM_TIMER wTimerID:65529 tmprc:00000000 000C0636 S WM_CAPTURECHANGED hwndNewCapture:00000000 000C0636 R WM_CAPTURECHANGED 008C0560 S message:0x0090 [Unknown] wParam:00000000 lParam:00000000 008C0560 S WM_WINDOWPOSCHANGING lpwp:002CF400 005D0204 S message:0x0090 [Unknown] wParam:00000000 lParam:00000000 005D0204 R message:0x0090 [Unknown] lResult:00000000 005D0204 S WM_WINDOWPOSCHANGING lpwp:002CF400 005D0204 R WM_WINDOWPOSCHANGING 005D0204 S WM_WINDOWPOSCHANGED lpwp:002CF400 005D0204 R WM_WINDOWPOSCHANGED 005D0204 S WM_DESTROY 005D0204 R WM_DESTROY 005D0204 S WM_NCDESTROY 008C0560 S WM_WINDOWPOSCHANGED lpwp:002CF400 008C0560 S WM_DESTROY 008C0560 S WM_NCDESTROY 000C0636 S WM_UNINITMENUPOPUP 000C0636 R WM_UNINITMENUPOPUP 000C0636 S WM_MENUSELECT uItem:0 fuFlags:FFFF (menu was closed) hmenu:00000000 000C0636 S WM_SETMESSAGESTRING wStringID:0000E001 lpszString:00000000 000C0636 R WM_SETMESSAGESTRING 000C0636 R WM_MENUSELECT 000C0636 S WM_EXITMENULOOP fIsTrackPopupMenu:True 000C0636 R WM_EXITMENULOOP Last edited by wOxxOm; 11th August 2019 at 19:27. |
#663 | Link |
https://i.imgur.com/6XL7iqX.gifv (sorry, forgot this)
I guess this has been here for long time, I wonder if you consider to fix/change this. https://i.imgur.com/yeCl8xA.gifv if I hold Shift+Scroll Up/Down on Download Subtitles dialog, it will download subtitle. Is it a bug? I guess this also happen on vanilla build. |
#664 | Link |
Status bar on subtitles download dialog still shows searching while main window shows completed
https://i.imgur.com/BvgLQF1.gifv |
#665 | Link |
Navigate->Chapters not themed (dark theme)
https://i.imgur.com/KwbBl3Z.png Error when remove last shader from active pre-resize shaders (dark theme) https://i.imgur.com/vNwvqoh.gifv buttons looks good to me now ![]() |
#667 | Link |
cosmic entity
![]() I cant whait for the Final Release.. also you can only activate teh Dark theme when you go with the menue on top, if you use the right click menue on player theres no "Drak Theme" found. Since i only use the Player without the Menue Bar on Top this is kinda un handy.. ![]() Pics: Dark theme is listed: https://i.imgur.com/hXXksci.png Dark Theme is NOT listed: https://i.imgur.com/MaVQjLJ.png Greetz |
#668 | Link |
no space between subtitles name and language (dark theme)
https://i.imgur.com/CiFe3j7.png weird characters on subtitles download dialog, filename in arabics, happened with korean characters too. it occurs on vanilla build too https://i.imgur.com/wlGU4Rt.png the look of some dropdown menu after click apply hasn't fixed yet. I wonder if it was overlooked. here is another gif. https://i.imgur.com/Ss0wgf6.gifv I don't know how to describe this, but here is the gif https://i.imgur.com/MRQXPTE.gifv hiding horizontal scrollbar formats and transform filters will be fixed later, right? thanks for all previous issue that have been fixed. |
#672 | Link |
cosmic entity
![]() ![]() Tested teh new Build, as far as i can tell everything works as it should ![]() THANK YOU !!1! Edit: When i use an "Dark" Windows Theme (WIN7) and enable Dark mode some Text is unreadable.. But its not the Players Fault i think.. Some Dark Themes will have Problems with it.. Pic: https://i.imgur.com/FpzuOLP.png Greetings Last edited by BetA13; 21st August 2019 at 18:18. |
#674 | Link |
The seekbar timestamp has weird flickering with the dark theme on at least Windows 7 when using either the classic theme or one of the high contrast themes.
Again, this is with no DPI scaling with everything set to 100% DPI, I've simply zoomed in the actual animations so that you can more clearly see the issue. Oh and yeah, these are animated PNGs since this type of content compresses and optimizes extremely well and it lets me piggy-back on any old standard image host (or at least the ones that don't re-encode PNGs) so that I can hotlink and embed it directly into my post. So if the image isn't animating, then make sure you're not using a browser made by Microsoft nor some mobile-only browser. ![]() Win7 + "Windows Classic" theme ![]() Win7 + "High Contrast Black" theme ![]()
____HTPC____ | __Desktop PC__
2.93GHz Xeon x3470 (4c/8t Nehalem) | 4.6GHz Pentium G3258 (2c/2t Haswell) Radeon HD5870 | Intel iGPU 2x2GB+2x1GB DDR3-1333 | 4x4GB DDR3-1600 Win7 x64 |
#675 | Link |
Hi everyone, clsid has been relaying your concerns over to me on github. I have been responding on the pull request. If you have bugs (ONLY related to the dark theme), go ahead and post them there. Otherwise, I can and will respond once I notice, but only over there.
Thanks https://github.com/clsid2/mpc-hc/pull/90 |
#676 | Link |
cosmic entity
hy,
i just read your response on Github, but since i do not have an Github account i cant reply there.. --> https://github.com/clsid2/mpc-hc/pul...ment-524484864 i dont use a High Contrast theme, i use a custom 3rd Party theme that i edited a bit.. Hence why i sayd "its not the Players fault, etc". Im allready happy as it is, since it really looks nice now.. I know that when using a 3rd party theme i cant expect it to work perfect, since its not the "normal" case.. So im all fine with it.. Just wanted to let you know.. GREAT WORK by the way ![]() Greetings.. Last edited by BetA13; 24th August 2019 at 02:27. |
#677 | Link |
What would cause the x64 version to crash hard on subs with xysubfilter and vsfilter but not 32bit? (going back to at least 1.7.13)
https://www.filehosting.org/file/det...track4_eng.zip |
#678 | Link |
No crash here. I muxed the ASS to mkv with random video/audio (fonts as attachments). MPC-HC x64 1.8.7 + LAV Filters 0.74.1.22 + madVR 0.92.17.
Tested: - ISR - XySubFilter 3.2.0.802 (pinterf) - xy-vsfilter 3.2.0.802 (pinterf) https://github.com/pinterf/xy-VSFilt.../tag/3.2.0.802 |
