16th June 2019, 11:48 | #181 | Link |
No need to apologise. Apparently I'm very bad at decoding ambiguous statements. I'm like a kitchen robot with speech control. If you don't give me clear commands I'll beat you with the pan instead of making fried eggs.
Groucho's Avisynth Stuff |
16th June 2019, 17:48 | #182 | Link | |
16th June 2019, 17:55 | #183 | Link |
D'oh. Fixed, thanks for pointing it out.
17th June 2019, 00:06 | #184 | Link | |||
Yes, thank you. And now that I'm a little less clueless, any suggestions for converting the AVSMeter results into improved encoding speed with AviSynth+? Around five years ago--geez, time flies--I used AVSMeter to find the most efficient memory settings for SEt's AviSynth MT, but I'm having trouble doing the same for AviSynth+. With no "SetMemoryMax()" line in the script, "PreFetch(5)" (on my quad-core, 16GB RAM setup) achieves better encoding speed than "PreFetch(1-4 or 6-8)". Under "SetMemoryMax" in the AviSynth wiki, it states: Quote:
17th June 2019, 19:51 | #185 | Link |
@LouieChuckyMerry
A couple of questions before going deeper: Why are you not using AVS+ 64 bit? What is the frame size of your source?
17th June 2019, 23:12 | #186 | Link | |
2) 1920x1080. |
17th June 2019, 23:27 | #187 | Link | |
Lastly, maxing out the CPU usage doesn't necessarily mean it's faster and/or more efficient. It's usually a trial and error process. AVSMeter is your friend.
19th June 2019, 01:21 | #188 | Link | |
20th June 2019, 00:27 | #189 | Link |
v2.9.3
- Added fftw library dependency check - New ini setting: "DisableFFTWDLLWarning". See included documentation for more info. - Removed some superfluous ini settings which are present as command line switches - Cleaned up documentation
7th July 2019, 11:24 | #190 | Link |
v2.9.4
- Updated CPU extension flags - Updated plugin type detection
Groucho's Avisynth Stuff Last edited by Groucho2004; 7th July 2019 at 17:28. |
22nd July 2019, 10:00 | #191 | Link |
v2.9.5
- Updated libcpuid (AMD Zen 2 support)
25th August 2019, 17:18 | #192 | Link |
Carried on from this post in Groucho2004 Avisynth Stuff thread:- https://forum.doom9.org/showthread.p...15#post1883115
Modified from VoodooFX script Code:
#clip = LWLibavVideoSource("C:\LagarithYV12.avi.lwi") # ssS: No idea if this works ie using named index, and not the clip name. clip=LSMashvideoSource("1941 Flint Michigan Parade [Low, 360p].mp4") clp = clip.ConvertToRGB24 a = clp.Trim(20,-30)+clp.Trim(2000,-30) a = a+a+a+a+a+a+a+a+a+a a = a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a a = a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a # Added a = a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a # Ditto a = a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a # Ditto return a # 96,000,000 frames ### Max possible frames = $7FFFFFFF, ~= 2,000,000,000 Here results, Avs v2.60 standard is indeed well faster than AVS+, I cancelled AVS+ timing at about same time as v2.60 standard had finished, and avs+ estimate has still about 50 minutes remaining till complete. It could stand a little bit of inverstigation. EDIT: Code:
BlankClip(length=1000000000) return Last
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 25th August 2019 at 17:48. |
25th August 2019, 17:50 | #193 | Link |
Try a different video source filter...
I have complained repeatedly about AVS+ being very slow with FFMS2 as well as with LWLibavVideoSource. No solution so far, but DSS2Mod is way faster with AVS+. |
25th August 2019, 18:16 | #194 | Link |
v2.9.6
25th August 2019, 18:38 | #195 | Link | |
Banana User
Look at my test, I didn't stopped AVS+, just took screenshot at ~same time when avs v2.6 finished. In my AVS+ test it had 12 hours left and it run ~5x faster than in your test. For some reason on my test AVS+ run on all 4 cores, when yours on 2, AVS 2.6 is same - 1 core. Code:
clip = LWLibavVideoSource("C:\LagarithYV12.avi.lwi") clp = clip.ConvertToRGB24 a = clp.Trim(20,-30)+clp.Trim(2000,-30) a = a+a+a+a+a+a+a+a+a+a a = a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a a = a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a a = a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a a = a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a+a return a Thanks Groucho2004 for new version. Can something to be done for overwriting "ini" file when I comment out "AVSDLL=" with path to AVS+(it disappears) and uncomment empty "AVSDLL=" to work with default avs 2.6? Last edited by VoodooFX; 25th August 2019 at 19:55. |
25th August 2019, 19:17 | #196 | Link | |
25th August 2019, 19:49 | #197 | Link |
There's currently no comment feature implemented for ini entries. I'll think about it.
25th August 2019, 20:02 | #198 | Link | |
Banana User
If I replace LWLibavVideoSource with BlankClip, AVS+ test goes down from ~12h to ~3h, still ~92 times slower(when takes ~3.7x more cpu load) than avs 2.6. Last edited by VoodooFX; 25th August 2019 at 20:11. |
25th August 2019, 20:35 | #199 | Link |
25th August 2019, 22:41 | #200 | Link | |
SetFilterMtMode("LWLibavVideoSource",MT_SPECIAL_MT,true)
See My Avisynth Stuff |
