#941 | Link | |
A channel on S-VHS / VHS capture and AviSynth restoration https://www.youtube.com/channel/UCMs...h1MmNAs7I8nu4g |
#942 | Link | |
#943 | Link | |
bwdif looks pretty bad and intense in terms of moire too. That's why you shouldn't deinterlace progressive material . I know this series has other problems in some scenes, but IVTC with TFM(pp=0) looks better For me, the moire is very distracting ; more distracting than other artifacts |
#944 | Link | ||
Also make sure you have the latest version of bwdif as that clip I uploaded is BFF and there was a recent bugfix for BFF video: https://github.com/Asd-g/AviSynth-BW...ent-1407702275 Quote:
imo bwdif(field=-2, thr=2, pass=true, edeint=nnedi3(field=-2)) is quite a bit superior to QTGMC, and very cheap on the CPU. I think some sources look better without the edeint param tho, eg. if the source already has antialiasing baked into it, then the nnedi3 pixels just make it look a bit softer. But for very sharp unfiltered 480i/576i then I would say nnedi3 pixels look subjectively "better". Last edited by flossy_cake; 11th March 2023 at 01:13. |
#945 | Link |
I had this before and rechecked what I did to solve it.
InputType=0 or 2 or 3 created moire but InputType=1 was superb. I used this:- QTGMC(preset="Medium", InputType=1, sourceMatch=3, sharpness=0.2, tr2=2, ediThreads=8) Filters like MAA2, DAA, HQDeringmod() made it slightly worse and Sangnom2 created moire as same as InputType=0 or 2 or 3 |
#946 | Link | |
It seems that with InputType=1 there is no deinterlacing done, so we must feed it progressive frames with TFM(PP=0).TDecimate() beforehand. So InputType>0 is really just a "repair pixels" mode for progressive frames - that's useful for me as I want to repair the field alignment issue mentioned in Babylon 5. I found that InputType=1 would not repair the field alignment issue at all, but InputType=2/3 does repair it (but SourceMatch must by >0 for it to work). But the downside is I am seeing shimmer/flicker on moving pixels (like you would get with mocomp deinterlacing - moving parts of the image dropping to half vertical res) and there is still some moire on her sleeve that the simple nnedi3 blend solution doesn't have: https://imgsli.com/MTYxODI2 https://imgsli.com/MTYxODI3 Again for context: the source video has field alignment issue and the whole purpose of using QTGMC was only to repair the field alignment issue without softening the picture too much and without introducing significant moire artefacts. |
#947 | Link |
TDeint and eedi filters creates moire. Also when using pel or subpel parameters. ie. pel=1 or 2 or 4, avoid using pel=1 as it creates slight moire. Use pel=2 is best.
You mentioned Babylon 5, done that. Most of the frames are progressive according to TFM. Interlaced is common on space scenes, badly out of focus and damage scenes - generally have bigger black borders compare to progressive live scenes. Use TFM then QTGMC. |
#948 | Link |
Does anyone have any tips for the best settings when using QTGMC only for interpolated pixels, like eg. bwdif(edeint=qtgmc) or tdeint(edeint=qtgmc).
The best I've gotten so far is this: Code:
LWLibavVideoSource("c:\480i 3-2.mkv", stream_index=-1, repeat=true, cache=true) propDelete("_FieldBased").bwdif(field=-2, thr=2, edeint=QTGMC(preset="slow", Sharpness=0.0, SrchClipPP=0, Rep0=1)) The issue appears to be that QTGMC pixels are so different from original pixels, that using them as interpolated pixels is risky because they don't necessarily weave very nicely with original pixels, so you can get this aliasing/mice teeth effect. But those last 3 params seem to be mitigating it quite a bit, not sure why. edit: for reference these are the pixels being interpolated, shown by bwdif(debug=true). I believe dark green means weave, the others like light green, pink etc. are interpolated, i.e swapped/blended for QTGMC pixels. Last edited by flossy_cake; 20th March 2023 at 13:39. |
#949 | Link |
Not sure if it helps, but a setting trying to force QTGMC to "retain" original look can be something like:
QTGMC(preset="slow", matchpreset="slow", matchpreset2="slow", sourcematch=3, tr1=2, tr2=1, NoiseTR=2, sharpness=0.1)
#950 | Link |
Ah yes, the source matching mode, also with lossless=1 setting. It definitely helps, but the performance penalty is quite high - precludes realtime use for me.
With stock settings I am surprised to find QTGMC is fast enough to run in realtime on "slow" and "slower". I'm seriously considering using it now for watching older DVDs that don't detelecine so well (dodgy ones with lots of weird edits, cadence breaks, video sections spliced in, etc.). The look of the QTGMC image can be stunning at times, very smooth almost artificial and dreamlike, but not in a bad way. I love that it produces 60p output so the frame pacing is perfect - all those 90's CGI and opening sequences animating perfectly how it was meant to look. Of course this comes at a price - not full 480p res, and some moire artefacts on stippled patterns. But God damn it looks really good at times. There's a certain softness and smoothness to the image. Last edited by flossy_cake; 20th March 2023 at 22:28. |
#951 | Link |
I am astonished to find that QTGMC also cleans up analogue dot crawl and rainbows better than any of the others dedicated filters like DeDot, TComb and DotKill.
After playing around for a couple of hours, DeDot and TComb seem to only work on static images - anything that moves still has dotcrawl on it. For animation this is quite noticeable. DotKillZ seems to work on moving objects but only treats every 2nd frame (and it says so in the wiki as well, I've no idea if this can be worked around by somehow stacking up 2 offset clips and interleaving them - I tried without success - just got blended frames coming out). But QTGMC comes along and filters it out perfectly, and doesn't even mention it in the wiki. Last edited by flossy_cake; 27th March 2023 at 16:58. |
#952 | Link |
There is something weird that QTGMC does with 2:2 and 3:2 cadence video - it produces a geometric "warbling" on edges of moving objects. Seems to be something to do with the motion analysis part of QTGMC. If I step through each frame of the 60p output, rocking back and forth +/- 1 frame (field in the source) the shapes of objects are quite different between the two fields. Like a circle will be warbling slightly into an ellipse. At normal playback speed this warbling is unnoticeable. But it does seems to make very slow moving objects appear to have soap opera effect. It's like those tiny geometric distortions trick my brain into thinking there was a whole new intermediate frame in there, and it looks a bit like soap opera effect. It's extremely mild though, I'd imagine most people wouldn't notice it at all.
edit: here's an animated png showing it. The video source is 480i 3:2 TFF. The 3 images you're seeing are all from the 3 sequence in 3:2, so they all originate from the same progressive frame, yet it appears as though there are 3 separate images with motion. Notice the changing shape of the window skirting. Weirdly this is totally unnoticeable when played back at normal speed, so luckily it's not a dealbreaker as I otherwise love this plugin for lower quality sources. Last edited by flossy_cake; 27th March 2023 at 16:59. |
#953 | Link | |
# weave static parts of image, nnedi3 interpolation on changing parts propDelete("_FieldBased").bwdif(field=-2, thr=2, edeint=nnedi3(field=-2)) # QTGMC "progressive repair" mode to remove shimmering, aliasing & moire on changing pixels: cores=4 QTGMC(InputType=1, preset="slow", Sharpness=1.0, FPSDivisor=1, EdiThreads=cores/2) Prefetch(cores) ![]() Downsides are QTGMC suppresses film grain, and the soap opera effect on very small movements of 2:2 or 3:2 cadence. edit: test clip - https://drive.google.com/file/d/1WfW...usp=share_link Note that 1px patterns are fully resolved (weaved) while motion (like the glasses frames) get the QTGMC smoothing - best of both worlds? Last edited by flossy_cake; 28th March 2023 at 19:33. |
#955 | Link |
If the source is clean and good 3:2 with minimal cadence breaks, yes absolutely TFM.TDecimate all the way.
But I've been buying a lot of DVDs of older TV shows lately and many are using multiple cadences (mixture of 3:2, 2:2 and 1:1 sections) have too much compression noise, rainbows, dotcrawl, field alignment issue etc. It's a nice option to just throw the deinterlacer at it and get a nice perfectly frame paced 60p with high quality antialiasing and smoothing. Solve all the issues in 1 hit. Especially with the frame pacing, I spent days tuning my display modes in CRU to get no dropped frames only to end up with 41ms dropped frames here and there due to occasional cadence breaks in the source. Even with a "good" source you will still be needing to handle the odd combed frame here or there and it makes those frames look nicer too so you don't have to worry so much about the false positives of combed frame detection Code:
TFM(mode=0, slow=2, scthresh=100, PP=3, cthresh=9, MI=96, \ clip2=propDelete("_FieldBased").bwdif(field=-1, thr=2, edeint=nnedi3(field=-1))) TDecimate(mode=0, cycleR=1, cycle=5, hybrid=1, viddetect=2, vidthresh=4.5, \ denoise=true, chroma=false, hint=false) QTGMC(InputType=1, preset="slow", FPSDivisor=1, EdiThreads=cores/2, Sharpness=1.0) Prefetch(cores) Last edited by flossy_cake; 8th May 2023 at 12:41. |
#956 | Link |
Does anyone know if it's possible to completely disable motion vectors in QTGMC? I think they are responsible for (1) geometric warbling and (2) soap opera effect on small movements, when playing 2:2 or 3:2 cadence video.
I am not sure if motion vectors are needed for other stuff QTGMC does, like shimmer reduction etc., so maybe my request is unreasonable. I can avoid the issue by outputting half frame rate with FPSDivisor=2. But I want full frame rate, not half. Maybe something in MVTools can be turned off? edit: Rep0=13 seems to suppress the effect: Scene 1 (slow camera pan): default , Rep0=13 Scene 2 (medium camera pan): default , Rep0=13 Even though there is still a fair bit of geometric distortion, my brain cannot detect any soap opera effect from it on small movements, so that issue is solved. I still don't know if the distortion is low enough to not trick TDecimate into thinking there was a whole new frame there. edit: well here is what I consider to be the best deinterlacing mode in Avisynth. I reckon it gives TIVTC a run for its money, and is fast enough for real time use: Code:
propdelete("_FieldBased").bwdif(field=-2, thr=2, edeint=nnedi3(field=-2)) QTGMC(InputType=1, preset="slow", Sharpness=1.0, Rep0=13, Border=true, EdiThreads=cores/2) Prefetch(cores) Last edited by flossy_cake; 5th April 2023 at 07:50. |
#959 | Link |
Yes. Once upon a time, Didée modified TempGaussMC.
#960 | Link |
I had some border problems that took me quite a while to troubleshoot. I thought I had someone misaligned the fields on the first/last lines only. I was using border=true and I really don't understand why it does what it does, as an example:
White = BlankClip(length=1,width=40,height=160,color=$FFFFFF) Black = BlankClip(length=1,width=40,height=160,color=$000000) BlankClip(length=1,width=40,height=160,color=$FFFFFF) StackHorizontal(Last,Black) StackHorizontal(Last,Black) Frame1 = StackHorizontal(Last,Black) BlankClip(length=1,width=40,height=160,color=$000000) StackHorizontal(Last,White) StackHorizontal(Last,Black) Frame2 = StackHorizontal(Last,Black) BlankClip(length=1,width=40,height=160,color=$000000) StackHorizontal(Last,Black) StackHorizontal(Last,White) Frame3 = StackHorizontal(Last,Black) BlankClip(length=1,width=40,height=160,color=$000000) StackHorizontal(Last,Black) StackHorizontal(Last,Black) Frame4 = StackHorizontal(Last,White) Interleave(Frame1,Frame2,Frame3,Frame4) SeparateFields().SelectEvery(4,0,3).Weave() converttoYV16 qtgmc(border=true) |
