Old 13th March 2022, 14:03   #121  |  Link
TDS
Formally known as .......
TDS's Avatar
Originally Posted by kedautinh12 View Post
Change last() to last
Now it's showing this...just can't win.
Script error: There is no function named 'LWLibavAudioSource'.
(D:\AWB\AWB new.avs, line 8)
(C:\Temp\RipBot264temp\job1\getinfo.avs, line 2)
That's for Lsmash, this script uses FFMS...
We all need to get a life, before it's over.
Long term RipBot264 user.
Ryzen 5950X, 5900X & 3950X.
Dual Xeon E5-2697v2.
2 x Dell Poweredge R720's (dual E5-2680v2)
and many others
TDS is offline   Reply With Quote
Old 13th March 2022, 14:05   #122  |  Link
kedautinh12
Change aa=LWLibavAudioSource("D:\AWB\nobody.mkv") to aa=ffms2("D:\AWB\nobody.mkv")
Edit: my mistake
Change aa=LWLibavAudioSource("D:\AWB\nobody.mkv") to aa=FFAudioSource("D:\AWB\nobody.mkv")
Old 13th March 2022, 14:18   #123  |  Link
TDS
TDS's Avatar
Now it's this :-
AudioDub: need an audio and a video track
(D:\AWB\AWB new.avs, line 10)
I tried this, but it stalls the process:-
LoadPlugin("D:\AWB\Lsmash\LSMASHSource.dll")
LoadPlugin("D:\AWB\GRunT\grunt.dll")
LoadPlugin("D:\AWB\RgbAdapt\RgbAdapt_x64.dll")
LoadPlugin("D:\AWB\RT_Stats\RT_Stats_x64.dll")
Import("D:\AWB\RGBAdapt_Awb_Process.avs")
LWLibavVideoSource("D:\AWB\nobody.mkv")
va=last
AudioDub(va,aa)
AWB_Func()
and many others
Old 13th March 2022, 14:32   #124  |  Link
TDS
TDS's Avatar
Edit: my mistake
Sorry ked, it's stalling at Demuxing 100%, and that's it.
Speaking of that's it, it's way passed my bed time, well after midnight.
Thanks for your help.
and many others
Old 13th March 2022, 16:45   #125  |  Link
Bernardd
In accordance with http://avisynth.nl/index.php/FFmpegSource
to have audio, you must write
ffms2("D:\AWB\nobody.mkv", atrack=-1)
Bernardd is offline   Reply With Quote
Old 14th March 2022, 02:41   #126  |  Link
TDS
TDS's Avatar
Thanks Bernardd, but that didn't seem to want to work...
It stalls during the demuxing process, and it also tries to produce a .wav file.
So what I've done is demux the "nobody.mkv", and add the audio .ac3 manually.
Just did a test encode, and it's working well, albeit a slightly more involved procedure.
Curiously importing a script this different way, doesn't allow RipBot to launch & use it's most impressive feature, "Distributed Encoding", which is major problem.
I'm still going to have to try and write the script the "RipBot" way.
UPDATE:- Well, unfortunately, I won't be using this filter, as not only doesn't work happily with RipBot264 (regardless what the 3 ppl that "tested" say), but it doesn't allow RipBot to use "Distributed Encoding", like I said above, that IS the most impressive function.
And even if I do an encode the "slow" way, the results are not desirable, the white's seem to be too white, and red's & skin colour's are too dark or too reddish, depending greatly on the brightness of the scene.
So Bernardd, I appreciate your hard work to create this in the first place, but it's not for me
Cheers
PS:- I did try it in VD2, but it's just way too slow !!!
Another update:- (If anyone is interested), I thought I'd see what Staxrip would do with this script, and it seems to work rather well.
However, it still does not import the audio track.
and many others
