Go Back   Doom9's Forum > General > Linux, Mac OS X, & Co
Thread Tools Display Modes
Old 17th February 2017, 21:04   #1  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
ffxvid for Linux/BSD
I've received a number of requests from people who asked for a script that helps to encode to Xvid, so here it is. It's a modified script of ffx264 for Xvid encoding with FFmpeg
https://sourceforge.net/projects/ffxvid/
Enjoy
Old 18th February 2017, 17:55   #2  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.0.2
* Switch to using libxvid instead of mpeg4 encoder
* Set appropriate threads amount for encoding
* Update default encoding options
Old 19th February 2017, 06:19   #3  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.0.3
* Enable Variance AQ by default
* Correct a few things in man page
* Update the preset.txt file
Old 22nd February 2017, 16:15   #4  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.0.4
* Support high FPS -> low FPS conversions
* Bugfix: missing options in FPS conversion menu
Old 18th March 2017, 22:57   #5  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.0.5
* Update audio compression level values
* Update colorspace entry for NTSC video
* Fixed bug in the video_colorspace_func() values
Old 13th May 2017, 19:11   #6  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.0.7
* Support accurate rounding for the software scalers
* Support full chroma interpolation for the software scalers
* Use the flags option of the scale option instead of -sws_flags to set scaler and its options
* Bugfix: software scaler code missing
Old 14th May 2017, 10:33   #7  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.0.8
* Bugfix in the software scale code. Use an if conditional to check for an y/n answer
Old 16th May 2017, 09:50   #8  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.0.9
* Added support for FFmpeg's internal Opus audio encoder
Old 1st June 2017, 13:02   #9  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.1.0
* Simplify the scale variable a bit
* Support SMPTE170M colorspace conversion
Old 4th June 2017, 22:40   #10  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.1.1
* Match software scaler options in config file with the ones inside the script. $SCALER in config file now takes a value between 0 and 9
* Do some basic checking of scaler option when it's set in the config file
Old 5th June 2017, 04:51   #11  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.1.2
* Remove redundant software scaler warning and exit in the sws_func() function for the config file
* Added support for the experimental software scaler
* Added support for software scaler tuning where applicable
* Removed additional encoder info on max audio channels support
Old 8th June 2017, 15:44   #12  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.1.3
* Report software scaler set in the config file
* Merge the bicubic and spline scaler tuning code
* Mention for the Lanczos scaler that the scaler tuning value is the filter length and not sharpness
Old 9th June 2017, 09:46   #13  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.1.4
* New function, video_chars_func(), to detect and display video characteristics like color range/space/transfer/primaries
* Detect and display video resolution if video scaling is enabled
* Detect and display pixel format
Old 10th June 2017, 08:51   #14  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.1.5
* Replace numbers in array variable char of the video_chars_func() function with the ones from the for loop
* Pipe the ffprobe string to tail -1 to work around issues with some problematic files
* Some small improvements to the video_colorspace_func() function
Old 13th June 2017, 00:57   #15  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.1.6
* Bugfix in the video_colorspace_func() function. Wrong value used for the ispace option of the filter. Must be bt2020ncl instead of just bt2020
Old 14th June 2017, 13:11   #16  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.1.7
* Make software scaler tweaking optional
* Added support for the unsharp filter for sharpen/blur
* Use a colon symbol as separation for input/output color range in the video_colorspace_func() function as to be consistent with the other options. Also set the default to tv:tv
Old 20th July 2017, 19:45   #17  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.1.8
* Bugfix: use realpath instead of readlink for the OUTPUT var when running in batch mode. Fixes the issue where readlink will follow the full path in case the input is a symlink which may result of encoding files we were not asked to
* Don't print cropped resolution during runtime if batch mode is selected
* Remove check for realpath. It is now required and not optional
Old 23rd August 2017, 10:50   #18  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.1.9
* Support full chroma input for the software scaler
Old 29th September 2017, 16:42   #19  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.2.0
* Support setting the output video aspect ratio
Old 22nd October 2017, 18:32   #20  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.2.1
* Support dialog level normalization for AC3/EAC3 audio
Thread Tools
