Old 12th December 2017, 00:06   #201  |  Link
ilko
hmm, I was interested into testing its potential but aegisub doesn't detect its presence like vsfiltermod or xy-vsfilter.
It might be a good alternative for fansubbers (I do typesetting / edition).
AviSynth+ Fansub Edition
ilko is offline   Reply With Quote
Old 12th December 2017, 00:10   #202  |  Link
sneaker_ger
Well, Aegisub already does offer libass rendering...
Old 12th December 2017, 00:35   #203  |  Link
ilko
of course, and the latest libass that it's based on is the v0.13.1. Since then, there have been improvements and fixes.
Just for example, vsfiltermod crashes when vector shapes have coordinate values in floating point (after re-sampling the resolution).
Old 13th December 2017, 04:18   #204  |  Link
Blitzker
Libass support in aegisub is unfortunately built-in so to keep it up to date, you have to build the entire aegisub project.
But i took a look at the csri interface and it was simple enough so i included it in assfiltermod. Now you can just copy assfiltermod.dll in the csri folder of aegisub and you can select it just like vsfilter.
Here is a build that i tested on Aegisub 3.2.2 and all seems fine.
I added a new entry in the registry "CSRIFontsDir" that you can fill with a path(full folder path) to fonts files you want to auto-load.
x32: http://www.mediafire.com/file/73h86i...sri_v2_x32.zip
x64: http://www.mediafire.com/file/3pb5ae...sri_v2_x64.zip
It seems stable but will need some testing!
Have fun!
EDIT:
- Fixed a rendering glitch with csri (shadow box around subtitles on a dark background)
- Added support for font ligatures with the registry key "DisableFontLigatures" (0 = Enabled, 1 = Disabled)
- Added Avisynth support:
 - Works only on RGB32
 - Filter name is "AssRender(file, fonts, scale, lig, mask)
 - file(string) = .ass file (Required)
 - fonts(string) = fonts folder to auto-load (Default: "")
 - scale(double) = subtitles scaling (Default: 1.0)
 - lig(bool) = font ligatures (Default: false)
 - mask(bool) = when true, render on a black background (Default: false)
Latest dev builds of AssFilterMod can be found here: https://www.mediafire.com/folder/w1w...s/AssFilterMod
Blitzker is offline   Reply With Quote
Old 9th January 2018, 12:53   #205  |  Link
vinnytx
AssFilterMod doesn't load external subtitles.
The only way to do so it's forcing AssFilterModAutoLoad. But this isn't an optimal solution because in this way AssFilterMod is loaded even when it isn't necessary
vinnytx is offline   Reply With Quote
Old 13th January 2018, 15:00   #206  |  Link
Khaled1323
it seems i cant change subtitle's font like xysubfiltter
Khaled1323 is offline   Reply With Quote
Old 28th January 2018, 16:04   #207  |  Link
Klaus1189
I am interested in WEBVTT support. WEBVTT is used by YouTube for all of its videos which contains one or more subtitle streams.
However if I have a file with a muxed WEBVTT subtitle stream, I would like to play it with my favourite Media Player, which his Directshow based.
Steps I did already:
https://github.com/mbunkus/mkvtoolnix/issues/1592
-> MKVToolNix can mux WEBVTT according to the specs they released for this.
-> asked nevcairiel, the author of LAV Filters to add support for WEBVTT
Now there is a subtitle renderer needed to support it.
I hope you are interested in it and add support of WEBVTT.
If you have any question, need a sample file or anything else, let me know
Old 30th March 2018, 09:06   #208  |  Link
Robbl
Installing doesn't work for 0.4, I always get the error message that the assfiltermod.dll module could not be found.
EDIT: Nvm, resetting pc worked...
Robbl is offline   Reply With Quote
Old 19th July 2018, 14:55   #209  |  Link
JayeDog
does assfiltermod load external subs when there are embedded subs in the mkv file? doesn't seem to do so for me
JayeDog is offline   Reply With Quote
Old 20th November 2019, 15:02   #210  |  Link
Magik Mark
Does anyone have a solution to make the subtitle dim when using it in HDR videos? Maybe luminance similar to HD
Sent from my iPhone using Tapatalk
Aora Master - Intel i9 - RTX 2060 - DDR4 24GB Predator - LG OLED C9 - Yamaha A3030 - Windows 10 x64 - Kodi with DSplayer - Lav - MadVR
Magik Mark is offline   Reply With Quote
Old 20th November 2019, 23:26   #211  |  Link
amayra
Quality Checker
amayra's Avatar
AssFilterMod is DEAD like every like every DirectShow subtitle renderer in the wild about try MPV and test with least version
I love Doom9
amayra is offline   Reply With Quote
Old 3rd April 2021, 21:35   #212  |  Link
Sunspark
Bug report: On the SRT settings tab, for font style, no matter what you select, it always reverts back to "Regular".
For those seeking a workaround if there is never another update to this module my suggestion is to use a font that is already weighted as medium. Swiss 721 Medium (Bitstream's Helvetica) is a decent choice. Filenames are tt0759m_.ttf and tt0760m_.ttf
