#1 | Link |
Retried Guesser
[solved] syncing clips with speed variation
I had to sync two clips recently where one of the clips sometimes ran way ahead, other times way behind. To get it to work I needed to sync the two clips at many intermediate points. After much @#$%& I arrived at this solution. It works well enough for me! Hope you like it too! Thanks to Gavino for GScript, which made this code possible, or at least much, much easier!
> > > Not a script for beginners! < < < Usage:
#Import("uusync.avsi") clpRef=XXSource("...") clpSyn=XXSource("...") ## we want to match sync to clpRef ## two lists of frame numbers, one for each video sSyn="207,1182,2650,3251,4021,4577,5039,6416" sRef="212,1218,2715,3312,4082,4640,5100,6451" clpSyn_2 = UUSyncSegments(clpSyn, clpRef, sSyn, sRef, debug=1>0, bypass=0>0) return StackHorizontal(clpRef, clpSyn_2) The clips in the samples below are still out by a frame or two; that's because I rushed getting my sync points. (this was a test video with random speed changes intentionally added) ![]() ![]() uusync.avsi Code:
# http://forum.doom9.org/showthread.php?t=147846 #LoadPlugin("GScript\GScript.dll") GScript(""" ####################################### ### sync 'syn' clip to 'ref' based on multiple common markers ## requires GScript http://forum.doom9.org/showthread.php?t=147846 ## ## NOTE: ## - frame rates must match (use AssumeFPS/ChangeFPS etc) ## - clips must be approximately in sync @ frame 0 ## - first sync point must be > 0 for both clips ## ## @ syn - clip to be synced ## @ ref - reference clip ## @ ssyn - 'syn' sync points (comma-delimited list) ## @ sref - 'ref' sync points ## @ pitchfix - if true, maintain audio pitch with speed ## (default false; allow pitch to rise or fall) ## @ noblend - if true, do not blend frames (default true) ## @ debug - if true, show debugging info (default false) ## @ bypass - if true, pass 'syn' unchanged to output ## ## @ return clip 'syn' with speed adjusted to sync to clip 'ref' ## ## @version 1.0 22-Oct-2015 raffriff42 ## @version 1.1 2-Dec-2015 head & tail handling; debug output; pitchfix ## @version 1.2 3-Dec-2015 handling of first sync point ## function UUSyncSegments(clip syn, clip ref, string sSyn, string sref, \ bool "pitchfix", bool "noblend", bool "debug", bool "bypass") { Assert(ref.FrameRateNumerator==syn.FrameRateNumerator \ && ref.FrameRateDenominator==syn.FrameRateDenominator, \ "UUSyncSegments: clips 'syn' and 'ref' must have same framerate") pitchfix = Default(pitchfix, false) noblend = Default(noblend, true) debug = Default(debug, false) bypass = Default(bypass, false) ## chop list into "_L" (left) and "_R" (right) parts ps = FindStr(ssyn, ",") pr = FindStr(sref, ",") ssyn_L = (ps==0) ? ssyn : LeftStr(ssyn, ps-1) ssyn_R = (ps==0) ? "" : MidStr(ssyn, ps+1) sref_L = (pr==0) ? sref : LeftStr(sref, pr-1) sref_R = sref ## get first sync point fsyn_L = Round(Value(ssyn_L)) fref_L = Round(Value(sref_L)) Assert(fsyn_L > 0 && fref_L > 0, \ "UUSyncSegments: first sync point must be > 0 for both clips") Assert(fsyn_L < syn.FrameCount, \ "UUSyncSegments: 'syn' frame number >= FrameCount") Assert(fref_L < ref.FrameCount, \ "UUSyncSegments: 'ref' frame number >= FrameCount") syn = (!debug) ? syn \ : syn.ShowFrameNumber(x=16, y=syn.Height-16) factor = Float(fsyn_L) / Float(fref_L) R = syn.Trim(0, fsyn_L-1) \ .UUChangeSpeed2(factor, pitchfix, noblend) R = (!debug) ? R : R.Subtitle( \ "syn in, out: 0, " + String(fsyn_L) \ + "\nref in, out: 0, " + String(fref_L) \ + "\nspeed mult.: " + String(factor, "%0.3f") \ , font="courier", size=R.Height/16, lsp=0) count = 256 ## infinite loop prevention while (count>0 && StrLen(ssyn_R)>0) { fsyn_L = Round(Value(ssyn_L)) fsyn_R = Round(Value(ssyn_R)) pr = FindStr(sref_R, ",") sref_L = (pr==0) ? sref_R : LeftStr(sref_R, pr-1) sref_R = (pr==0) ? "" : MidStr(sref_R, pr+1) fref_L = Round(Value(sref_L)) fref_R = Round(Value(sref_R)) Assert(fsyn_L < syn.FrameCount && fsyn_R < syn.FrameCount, \ "UUSyncSegments: 'syn' frame number >= FrameCount") Assert(fref_L < ref.FrameCount && fref_R < ref.FrameCount, \ "UUSyncSegments: 'ref' frame number >= FrameCount") Assert(fsyn_R > fsyn_L, \ "UUSyncSegments: 'syn' sync point " + String(count) + " <= previous") Assert(fref_R > fref_L, \ "UUSyncSegments: 'ref' sync point " + String(count) + " <= previous") factor = Float(fsyn_R - fsyn_L) / Float(fref_R - fref_L) S = syn.Trim(fsyn_L, fsyn_R-1) \ .UUChangeSpeed2(factor, pitchfix, noblend) S = (!debug) ? S : S.Subtitle( \ "syn in, out: " + String(fsyn_L) + "," + String(fsyn_R) \ + "\nref in, out: " + String(fref_L) + "," + String(fref_R) \ + "\nspeed mult.: " + String(factor, "%0.3f") \ , font="courier", size=S.Height/16, lsp=0) R = R ++ S ps = FindStr(ssyn_R, ",") ssyn_L = (ps==0) ? ssyn_R : LeftStr(ssyn_R, ps-1) ssyn_R = (ps==0) ? "" : MidStr(ssyn_R, ps+1) count = count - 1 } R = R ++ syn.Trim(fsyn_R, 0) return (bypass) ? syn : R } """) ####################################### ### change speed over a wide range ### with frame blending in fast forward by default. ## ## @ factor - 0.33 for 1/3 speed, etc; ## min = 0.001; max = min(FrameCount, 1000) ## (if > FrameCount, duration would be 0) ; ## if argument is out of range, an error occurs. ## ## @ pitchfix - if true, maintain audio pitch with speed ## (default false; allow pitch to rise or fall) ## ## @ noblend - if true, never blend frames (default false) ## ## @ version 1.0 24-Feb-2014 raffriff42 ## function UUChangeSpeed2( \ clip C, float factor, bool "pitchfix", bool "noblend") { Assert(factor>=0.001, \ "UUChangeSpeed2 bad argument: factor<0.001") Assert(factor<=1000.0, \ "UUChangeSpeed2 bad argument: factor>1000") Assert(factor<=C.FrameCount, \ "UUChangeSpeed2 bad argument: factor>FrameCount") pitchfix = Default(pitchfix, false) noblend = Default(noblend, false) AS = C.KillAudio.AssumeFPS(C.FrameRate * factor) ASI = C.KillAudio.AssumeFPS(C.FrameRate / factor) temprad = Round(0.5 * factor) TS = (factor<1.0 || temprad==0 || noblend) \ ? AS \ : Overlay( \ AS, \ AS.TemporalSoften( \ temprad, 255, 255, 48, 2), \ opacity=0.7) ffx = Min(Max(0.0, 25.0/factor), 100.0) (factor<1.5 && noblend==false) \ ? AS.ConvertFPS(C) \ : TS.ChangeFPS(C.Framerate, linear=(factor<10.0)) A = (pitchfix) \ ? C.KillVideo.ConvertAudioToFloat.TimeStretch(tempo=factor*100.0) \ : C.KillVideo.ConvertAudioToFloat.TimeStretch(rate=factor*100.0) A = (C.AudioBits==32) ? A.ConvertAudioTo32bit \ : (C.AudioBits==24) ? A.ConvertAudioTo24bit \ : (C.AudioBits==16) ? A.ConvertAudioTo16bit \ : (C.AudioBits==8) ? A.ConvertAudioTo8bit \ : A return (Abs(factor-1.0) < (0.5/C.FrameCount)) ? C \ : (C.HasAudio==false) ? Last \ : Last.AudioDub(A) } Last edited by raffriff42; 16th March 2017 at 23:57. Reason: (fixed image links) |
#3 | Link |
Perfect, if you could automate creation of frame number lists (not an insurmountable problem)
#4 | Link |
Retried Guesser
Thanks StainlessS, but I had to match two visually unrelated clips*; I don't see how to really automate that process. Only a human such as myself, who knew how the 2nd clip (think alternate camera angle) related to the reference, could know when it was in sync or not. The video was only about twelve minutes anyway, so finding a dozen sync points took only a few minutes. (I'll release it to YouTube when & if I get around to finishing it) Now, if the task had been really huge and repetitive, I might have tried to work up some automation. Maybe next time... * (and audibly unrelated - the 2nd clip was MOS) Last edited by raffriff42; 5th December 2015 at 13:19. Reason: MOS |
#5 | Link |
If you want a one-button solution to this problem, I recommend you look at:
PuralEyes You used to be able to get it by itself, and for not much money. Now it looks like it is only available as part of an expensive suite. It's too bad that so many companies are following the Adobe Creative Suite model. |
avisynth, gscript, synchronization |
