Go Back   Doom9's Forum > General > Linux, Mac OS X, & Co
Thread Tools Display Modes
Old 4th September 2015, 13:21   #1  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
ffx264 & ffhevc for Linux/BSD
I wrote two small, simple and basic shell scripts for Linux. I did it because I encountered a few video remuxes (from my own Blu-rays) that I couldn't encode with my h264enc script so I turned to ffmpeg which was able to handle them.
ffhevc & ffx264 won't be anything big and professional like h264enc. I intend to keep them both basic and with the options I most often use so stuff like many audio/video filters, different input sources, etc, etc won't be added, unless I really need them on a frequent basis in the future.
However, if you need something and are willing to implement it, I accept patches.
ffx264: https://sourceforge.net/projects/ffx264/
ffhevc: https://sourceforge.net/projects/ffhevc/
Old 5th September 2015, 13:11   #2  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 1.3
* Added support for copying a single subtitle. Note that this is only supported when output container is set to mkv (default)
* Changed var OUTPUT in the config file to OUTDIR. Also changed internal var OUT to OUTPUT
* Updated the README file
ChangeLog for ffx264 1.5
Old 5th September 2015, 17:39   #3  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 1.4
* Implemented support for virtually an unlimited audio track encodings
* Ask for AC-3 bitrate instead of setting it in the config file
ChangeLog for ffx264 1.6
Old 6th September 2015, 00:10   #4  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 1.5
* Bugfix: dB was missing after the value of the audio volume filter
* Be a bit more consistent with the audio variables
* Added support for encoding to AAC audio
* Use eval instead of seq for the for audio loops as seq is Linux-specific
* Added an ASCII art banner
* Export encoding params to a shell script and source it for encoding
* Place the libx265 params in the config file for easy modifications
* Made auto-cropping optional. It can be disabled in the config file
* Made the SUBS var in the config file consistent with the ones that accept "y" or "n" as value
* Added support for specifying the audio language metadata
* Automatically add the title of the content based on provided output name
* Automatically add the audio codec name metadata
ChangeLog for ffx264 1.7
* Place the libx264 params in the config file for easy modifications
Old 6th September 2015, 11:22   #5  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 1.6
* Added support for setting the genre and year metadata
* Added support for virtually an unlimited amount of subtitles copy
* Colorized the banner
* Cosmetics
ChangeLog for ffx264 1.8
* Cosmetics
Old 7th September 2015, 15:37   #6  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 1.7 and ffx264 1.9
* Bugfix: the specified channels to decode wasn't honored due to missing 'a' in the -ac option
* Added support for encoding to DTS audio
* Reduced some duplication in the audio code
* More cosmetics
Old 8th September 2015, 09:29   #7  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 1.8 and ffx264 2.0
* Enabled subs copy for other containers than mkv
* Some tweaks in the audio code
Old 9th September 2015, 14:18   #8  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 1.9 and ffx264 2.1
* Removed the $ in the index of array variables
* Use an if conditional instead of case to check for DTS audio and to check which audio codec has been selected
* Support setting the paths to mplayer/ffmpeg/ffprobe in the config file
* Support setting the language metadata for subs copy
* Fixed a small issue in the subtitles code
Old 10th September 2015, 14:37   #9  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.0 and ffx264 2.2
* Tweaks to the audio code
* Somehow I removed the chapters option. Add it back
Old 11th September 2015, 13:25   #10  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.1 and ffx264 2.3
* Update to the default libx264/libx265 encoding params
Old 12th September 2015, 19:56   #11  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.2 and ffx264 2.4
* Added audio channel layout mappings
Old 13th September 2015, 09:46   #12  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.3 and ffx264 2.5
* Added support for scaling
Old 14th September 2015, 19:22   #13  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.4.0 and ffx264 2.6.0
* Fixed an issue where -vf was added despite not using any filters
Old 15th September 2015, 10:14   #14  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.4.1 and ffx264 2.6.1
* Added support for deinterlacing
Old 17th September 2015, 10:06   #15  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.4.2 and ffx264 2.6.2
* Small update to the channel layout mappings
Old 18th September 2015, 06:48   #16  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.4.3 and ffx264 2.6.3
* Removed the workaround for DTS audio since we always use "5.1(side)" for 6 channels output
* Support setting the MAX_AUD_TRKS and MAX_SUBS variables in the config file to "auto". When set to "auto", it will ask for as many as detected audio tracks/subtitles
Old 19th September 2015, 08:51   #17  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.4.4 and ffx264 2.6.4
* Added support for encoding to MP3, Vorbis, FLAC and Opus audio
* Do some sanity checks for AC3/DTS channels
Old 4th October 2015, 12:28   #18  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.4.5 and ffx264 2.6.5
* Removed a test condition in the mp3 code that is not really needed
* Cosmetics in the audio code
* Added a counter
Old 31st October 2015, 13:54   #19  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.4.6 and ffx264 2.6.6
* Added support for audio resampling
Old 2nd November 2015, 18:06   #20  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.4.7 and ffx264 2.6.7
* Use -filter:a:id aresample instead of -ar:a:id
Thread Tools
