Old 4th February 2015, 16:26   #281  |  Link
NikosD
Thanks for the prompt and detailed reply.
Win 10 x64 (18362.388) - Core i3-9100F - nVidia 1660 (436.15)
HEVC decoding benchmarks
H.264 DXVA Benchmarks for all
Old 10th February 2015, 15:41   #282  |  Link
Neet009
CPU:core2quad Q9550
GPU:GTX 960 (driver 347.25)
OS:win7 x64
I did some test with LAV 0.63.0.75-git:
Astra clips(4K 10bit HEVC), Copy-Back direct mode
DXVAChecker x64, decode, P010 out
76~78 fps , 15% CPU
DXVAChecker x64, decode, NV12 out
92~93 fps, 14% CPU
DXVAChecker x86, decode, P010 out
67~69 fps, 15% CPU
DXVAChecker x86, decode, NV12 out
86~88 fps, 14% CPU
Ducks-2160p@50fps-4Mbps, Copy-Back direct mode
152~154 fps, 15% CPU
153~154 fps, 16% CPU
It seems the 10bit results are slower than Nevcairiel's test. What reason is likely to make a difference? Is my cpu too old or lack of some instruction sets?
Neet009 is offline   Reply With Quote
Old 10th February 2015, 16:49   #283  |  Link
cyberbeing
Broadband Junkie
Assuming nevcairiel's i7-4770K results still hold true, it's probably both your CPU & Memory subsystem being too slow, especially if you see a similar performance difference with P010 vs NV12 output when using software decoding of 10bit H264 video. P010 output requires transferring 16bit (padded) data, while NV12 is only 8bit data. Use of P010 output doubles the bandwidth requirements, the amount of data being transferred across system memory, and to/from your GPU over PCI-E. It's not abnormal for the overhead of outputting P010 directly to be larger than the CPU overhead of converting to NV12, especially on an older system.
Old 10th February 2015, 21:44   #284  |  Link
nevcairiel
Note that I'm on a i7-5930K now with DDR4 memory, so my memory performance is quite good, and core 2 is quite old, the memory may be much more of a bottleneck there than on newer CPUs.
Interesting is the difference between NV12 and P010. LAV has to read the full P010 from the GPU in any case, in the NV12 case its just converted before writing to sysmem (in processor registers), so that would clearly point to the system memory being a bottleneck here, since the only major difference is the amount of memory being written into system memory.
Old 11th February 2015, 15:40   #285  |  Link
Neet009
OK, it seems that system memory would be bottleneck on some old systems when using 4K 10bit HW decoding. Thank you for explaining.
Old 11th February 2015, 16:53   #286  |  Link
NikosD
CPU:core2quad Q9550
OS:win7 x64
Could you test using your GTX 960 with latest DXVA Checker 3.3.2 x64 in DXVA native and "decode" mode using latest LAV x64 0.63.0.75 the clip below ?
http://xhmikosr.1f0.de/samples/2160p...x264.CRF25.mkv
It's a 2160p H.264 video with huge bitrate.
Old 11th February 2015, 18:50   #287  |  Link
Neet009
OK!
DucksTakeOff_2160p50.x264.CRF25
DXVAChecker 3.3.2 x64, DXVA native, decode
78.5 fps, cpu 2% (Test 5 times, Avg)
DXVAChecker 3.3.2 x64, DXVA copy-back direct, decode
77.9 fps, cpu 9%
Old 11th February 2015, 23:12   #288  |  Link
NikosD
OK!
77.9 fps, cpu 9%
Thanks! I thought so!
It seems that Nvidia uses the same H.264 decoder for 960, like the previous models VP6.
They didn't improve H.264 performance, so it's still a 4K80 fps H.264 decoder.
Just for comparison, my Core i7-4790- iGPU HD 4600 (GT2) at 1.5GHz has these results:
200 fps, cpu 1% (Test 5 times, Avg)
Old 14th February 2015, 11:21   #289  |  Link
NikosD
CPU:core2quad Q9550
OS:win7 x64
NVIDIA GTX 960 Benchmarks
I encoded a 2160p50fps-HEVC_Main10 file with an average bitrate of 128Mbps close to BluRay UHD.
The clip is here:
http://www.filedropper.com/crowdrun2...main10-127mbps
I also added, just for testing reasons, a 300Mbps clip here:
http://www.filedropper.com/crowdrun2...cmain10300mbps
I would like to see some results using LAV x64 v0.64 DXVA-CBD of Nvidia 960 of both decode and playback modes.
I'm interested in MIN/AVG/MAX fps.
Using my Core i7-4790 the results are:
1st clip (130Mbps)
Decode: 20/38/42
Playback (1280x720):12/33/35
2nd clip (300Mbps)
Decode: 3/27/30
Playback (1280x720):0/24/28
Last edited by NikosD; 14th February 2015 at 12:46. Reason: Added a 300Mbps clip, just for testing
Old 14th February 2015, 12:05   #290  |  Link
nevcairiel
Decode (P010): 94/100/104
Decode (NV12): 94/100/105
Playback (NV12, 720p): 36/89/101
I'm not sure when the Playback min value occured, it did seem to run through the video very fast at all times. Maybe right at the start when it was still loading or something. Not sure I would put too much value on it.
Old 14th February 2015, 12:48   #291  |  Link
NikosD
Just added a 300Mbps test clip.
It's either that you write or the clip has some spikes with huge bitrate.
A simple bitrate viewer I have it's not compatible with HEVC in order to check it out.
Old 14th February 2015, 16:28   #292  |  Link
Neet009
My results:
(GTX 960, Q9550 3.4GHz, DDR3-1333 16G)
1st clip (130Mbps)
Decode(P010): 73/80/83
Decode(NV12): 84/92/95
Playback (1280x720):54/85/91
2nd clip (300Mbps)
Decode(P010): 60/78/82
Decode(NV12): 64/79/84
Playback (1280x720):39/75/84
Old 17th February 2015, 20:10   #293  |  Link
P.J
LAV 0.64.0 got much better but the only problem is the glitches
The video doesn't play smoothly while the CPU/GPU are ~50%
P.J is offline   Reply With Quote
Old 18th February 2015, 10:03   #294  |  Link
NikosD
For anyone interested in testing, I encoded a 8K (7680x4320) HEVC clip at 60fps in both 10bit and 8bit versions.
Of course, you can't HW accelerate the decoding of those clips even if you have a 960 card, due to high resolution.
You need a very fast CPU.
The clips are just 1 sec and very small.
Clip 1- HEVC 4320p60fps -10bit
http://www.filedropper.com/crysis3-7...1sec-hevc10bit
Clip 2 - HEVC 4320p60fps -8bit
http://www.filedropper.com/crysis3-7...1mbps1sec-hevc
Tests
DXVA Checker x64 3.3.2 - LAV x64 v0.64 - Core i7 4790
Clip 1
Decode 2/16/17
Clip 2
Decode 10/21/22
I'm sure you are going to need a faster processor, like Core i7-5960X for realtime decoding of those 8K HEVC clips
Old 18th February 2015, 10:41   #295  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
What was the cpu utilization like? Pegging all 8 threads? I wonder how much of that is just CABAC processing at 140mbps.
Old 18th February 2015, 12:45   #296  |  Link
NikosD
It sure uses all 8 threads and the CPU utilization is on average ~80% by putting 16 threads in LAV Video properties, as in the above benchmark tests.
Looking at the decoding performance of the 4K HEVC 10bit ~130Mbps, it has more than double fps (38 fps vs 16 fps) than 8K HEVC 10bit ~140Mbps.
So, the resolution plays the most important role for decoding.
Old 21st February 2015, 05:29   #297  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Hi all.
I buy GTX 960, test LAV Video Decoder on HEVC 10bit, then modify MPC-BE's video decoder. And ... perfect work DXVA HEVC 10bit, EVR Custom accept P010 DXVA input.
Here test build - http://aleksoid.voserver.net/MPC-BE/...VC_4K_10Bit.7z - it's test build and work only 10bit HEVC DXVA decoder.
P.S. Only MPC-BE' EVR Custom can accpet P010 DXVA.
I7 2600K@4.2 /Asrock P67 Extreme4 Gen 3 /Kingston HyperX 8Gb 1866 (4x2) Kit /OCZ Vertex 3 256Gb /Gigabyte GTX 960 /BenQ EW2430 /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is offline   Reply With Quote
Old 21st February 2015, 07:17   #298  |  Link
NikosD
So, does that mean that you can use DXVA native with 10bit HEVC ?
I asked nevcairiel about EVR-CP but he didn't answer.
What's the difference between MPC-HC EVR custom and MPC-BE EVR custom ?
Old 21st February 2015, 07:24   #299  |  Link
Aleksoid1978
Yes - native DXVA HEVC 10bit but only in EVR Custom, vanilla EVR show only white screen.
About MPC-HC - it's use hook and drop P010 input for EVR
Old 21st February 2015, 07:42   #300  |  Link
wanezhiling
Any proof?
Like dxva checker trace log.
