Old 21st September 2014, 22:45   #1  |  Link
kenny1999
how to add watermark image or text to video
I want to add watermark image and text to the video shot and made by me. I've tried doing with VLC player but it doesn't work. What else can I try? I hope it is not very difficult and will not generate a very huge file. I only need basic watermark image and text, nothing fancy needed.
kenny1999 is offline   Reply With Quote
Old 22nd September 2014, 09:40   #2  |  Link
fvisagie
In Avisynth() you could use something like Subtitle() (or even TextSub() for external subtitles) to add watermark text, and e.g. Overlay() to add an image. VirtualDub also supports the TextSub filter, but I'm not sure exactly how to overlay an image or video - perhaps something like merge layers can do that.
Many other tools, including Microsoft's XYZ Movie Maker, can also do this - the basic thing to look for is the ability to overlay text as well as image/video.
fvisagie is offline   Reply With Quote
Old 22nd September 2014, 11:30   #3  |  Link
kenny1999
I probably want an image watermark now. Microsoft? I lost my trust to Microsoft but I will try it soon. Thank you.
Old 22nd September 2014, 13:59   #4  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
In avisynth, this will add png file as a watermark. You will still need to encode the file using this input though.
FFVideoSource("MyVideoFile.mkv")
Image=ImageSource("MyImage.png",pixel_type="RGB32")
Overlay(last,Image,mask=Image.ShowAlpha(),x=10,y=10)
Old 22nd September 2014, 16:44   #5  |  Link
raffriff42
Retried Guesser
raffriff42's Avatar
VLC isn't listed in Wikipedia as compatible with AviSynth - maybe it is though.
I don't know much about VLC, but it claims to have a logo filter.
raffriff42 is offline   Reply With Quote
Old 22nd September 2014, 19:53   #6  |  Link
kenny1999
hi Sorry I know about command line but I don't know how to start putting my first command line. I have no knowledge about command line. I know there is also something about command line in VLC player. Can you introduce the basic concepts about command line and where to start?? It's not user-friendly
Old 22nd September 2014, 21:38   #7  |  Link
Asmodian
That is actually an Avisynth script, not a command line. You would need to install Avisynth and put the ffms2.dll plugin in Avisynth's plugin directory.
Then create a text file (notepad works) and save it as "name.avs". You can then open the avs file with VirtualDub or other encoding GUI.
Old 23rd September 2014, 15:43   #8  |  Link
Mole
Mole's Avatar
You can also check out avidemux, which will have a logo filter.
Or if it's an .avi you can use VirtualDub with logo filter
Mole is offline   Reply With Quote
Old 23rd September 2014, 17:15   #9  |  Link
Mole
Mole's Avatar
I know it doesn't do text, but since OP need overlayed both a watermark and text, it's most feasible to convert the text as image together with that overlay graphic.
For text subs one can use subtitler but it only works with subs in SSA format.
Old 23rd September 2014, 17:49   #10  |  Link
raffriff42
Retried Guesser
raffriff42's Avatar
Sorry Mole, I had deleted the post you are responding to. These are good suggestions, and I like Vdub, but OP seems to want to simplest possible solution.
I would like to ask him: what video editing software have you used before, besides VLC? If you want help with VLC you should describe exactly what you did, and quote the exact error message(s), if any.
Tempted to suggest Premiere Elements or Vegas Movie Studio, but they can have a steep-ish learning curve - at least if you want to learn all the ins and outs of them. They might not be so bad for such a straightforward task though.
Old 23rd September 2014, 17:52   #11  |  Link
Mole
Mole's Avatar
That's why I suggested avidemux. It's very simple to learn and the logo overlay filter is build in and avidemux supports a variety of formats.
No need to bother with any "command lines"....
Old 24th September 2014, 10:42   #12  |  Link
tuco76
Editing older stuff like Xvid/Divx AVIs,
you might stick to a prev. version 2.5.6., as the 2.6x tends to crash on avis.
For H264/AVC in MKV/MP4,- (thats where older versions tend to crash)- currently the 2.6.8 v2 works just fine for me.
Find older versions at sourceforge or videohelp
tuco76 is offline   Reply With Quote
Old 31st March 2017, 08:45   #13  |  Link
Poly21
Another way you can try
Hi, if you are not familiar with command, there is no problem. It is super easy to add overlay to video. You just need to use a video editor, drag the image or text that you want to add as overlay to the timeline. Then simply output the video.
Poly21 is offline   Reply With Quote
