Old 12th April 2013, 01:55   #1  |  Link
minaust
x264 - 8-bit vs 10-bit?
Howdy everybody...
I've done a bit of homework here as to the pros and cons of 8-bit versus 10-bit encoding, and here are my assumptions:
1. 10-bit encodes will play only on my PC. Nowhere else.
2. 10-bit encodes don't have a banding problem endemic to the 8-bit encoder.
As to my needs, 1 is no problem as I use my PC as a video jukebox, and I haven't encountered 2 (yet). Is there any reason to NOT switch to 10-bit x264? Are my assumptions correct? Any more pros or cons I should know about?
Thanks for any replies.
minaust is offline   Reply With Quote
Old 12th April 2013, 02:19   #2  |  Link
Asmodian
Those are the basics but also:
Pro: 10-bit is higher quality (not just the improvement in banding) at the same bitrate.
Con: 10-bit encodes a bit slower and takes more CPU power to play.
Old 12th April 2013, 05:42   #3  |  Link
Overdrive80
Anime addict
Overdrive80's Avatar
In my opinion, bigger 10bit encoderīs trouble is compatibility. If this isnt trouble then x264 10bit is your best choice.
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Nvidia GTX750 2GB DDR5 + SSD Vertex 4 256 GB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite
Overdrive80 is offline   Reply With Quote
Old 12th April 2013, 06:57   #4  |  Link
minaust
I ran a test - I grabbed my nearest DVD and ripped a trailer. Basic processing: Autoceop, resize to 852x364, removegrain, then sharpen a little.
10-bit - 78 fps.
8-bit with same settings - 93 fps.
10-bit is indeed slower, but not unacceptably so. Now on my old 'puter , an old 2.8ghz P4 it would be a big deal.
Playback is with Media Player Classic HC using MADVR as the renderer. Will 10-bit use more CPU, GPU, or both? Not that it really matters - when I'm doing an encode or playing back it's typically the only thing going on. Only my CPU fan will care.
Old 12th April 2013, 07:13   #5  |  Link
minaust
Thank you gentlemen. You've sold me on 10-bit builds of x264 henceforth.
On the other hand, now I gotta re-rip my whole inventory....
Old 12th April 2013, 07:30   #6  |  Link
kypec
User of free A/V tools
kypec's Avatar
Does your whole inventory suffers from visible deficiencies like banding? Otherwise it's pretty pointless to re-encode dozens of DVD when existing 8-bit quality pleases one's eyes enough.
Mainly CPU because 10-bit decoding is not possible with current GPU. I'm not familiar with MadVR requirements for 10-bit post-processing though...
kypec is offline   Reply With Quote
Old 12th April 2013, 13:04   #7  |  Link
minaust
No, they suffer from a brain fart on my part. I accidentally formatted the external drive storing them. Fortunately my vidcaps were elsewhere.
Since I was already going to re-rip anyway.... Let's straighten out this 8/10-bit thingie...
Old 15th April 2013, 06:49   #8  |  Link
ChiDragon
ChiDragon's Avatar
It is possible to "unformat" a drive if you haven't put any new files on it yet. Otherwise things get trickier.
ChiDragon is offline   Reply With Quote
Old 16th April 2013, 05:15   #9  |  Link
minaust
I thought about that about 30 seconds too late... Ah well, nothing irreplaceable was lost. Just a bunch of re-ripping.
If my vidcaps has been on that drive.... I wouldn't be fit company for a while.
encoders, x264
