Old 30th December 2012, 11:03   #1  |  Link
Avisynthesizer_Mod 20 Feb 2014
A SendTo App that allows Windows Explorer selection of video files and fills in a user supplied Template with the filenames.
Can concatenate (join/splice) selected files (default as original non mod version) and create a single output AVS file OR,
batch create multiple AVS files, one for each input source file (MOD version only).
Has a GUI to select required template and sort input files if multiple input files selected.
Was not altogether happy with this handy little app so I changed it a little.
20 Feb 2014, Added Batch Mode (non-repeating section) templates.
Changes made to Avisynthesizer by StainlessS.
Uses "___FILE___" (thats 3 underscore either side) instead of "%f" which can be mistaken for float spec in eg String() function.
Converted to using "++" aligned splice instead of "+" unaligned splice.
Each file command output on it's own line with a line concatenation "\" backslash.
Does NOT auto install, copy dir somewhere and execute "Install_SendTo.Cmd" to install (can then right click files and "sendTo").
"UnInstall_SendTo.Cmd" to uninstall.
7 Aug 2013, Added ___FILECNT___
___FILECNT___ Replaced with number of filenames given as arg to Avisynthesizer_Mod,
can be used anywhere in file, but there is no further processing of that line, ie
not on same line as ___FILE___ replacement.
20 Feb 2014, Added Batch AVS creation mode.
 If template has a repeating section {enclosed in square brackets eg [AviSource("___FILE___")]} then will
 use the standard mode, creating a single file with multiple sources concatenated.
 If template DOES NOT have a repeating section {not enclosed in square backets eg AviSource("___FILE___")}
 then will create multiple AVS files, one for each source file.
SOURCE MODS
Supplied source project upgraded to VS6 and definitely need the Platform SDK or will not compile.
Original source also supplied.
CPP Files -------------------
genscript.cpp
 CreateScript()
Original Mod
    char acLine[100], acRep[100];           --->    char acLine[4096], acRep[4096];         # Longer script lines
    pcFileNameLoc = strstr(acLine, "%f");       --->    pcFileNameLoc = strstr(acLine, "___FILE___");   # Dont confuse with float spec
    pcFileNameLoc = strstr(acRep, "%f");        --->    pcFileNameLoc = strstr(acRep, "___FILE___");    # Dont confuse with float spec
    (pcFileNameLoc + 2) << endl;            --->    (pcFileNameLoc + 10) << endl;           # skip "___FILE___"
    Script << acRep << *it << (pcFileNameLoc + 2);  --->    Script << acRep << *it << (pcFileNameLoc + 10); # skip "___FILE___"
    Script << " + ";                    --->    Script << " ++ \\\n";               # Aligned Splice & 1 file per line
    // ssS, Look for File Count                                             // ssS
    char* pcFileCntLoc = strstr(acLine, "___FILECNT___");                   // ssS
    if(pcFileCntLoc!=NULL) {                                                // ssS
        *pcFileCntLoc = '\0';                                               // ssS
        Script << acLine << gFileList.size() <<                             // ssS
                (pcFileCntLoc + 13) << endl;                                // ssS
        continue;                                                           // ssS
    }        // ssS
Resources -------------------
IDD_ASYNTHER_DIALOG Made wider for longer file paths.
FILEVERSION & PRODUCTVERSION Changed from 5.0.1 to 5.0.4
20 Feb 2014,
genscript.cpp
  Added functions
    bool CreateScriptSSS(const char* pcTemplateFileName, int fileix);                       // ssS Added function
    int ScanTemplateSSS(const char* pcTemplateFileName);                                    // ssS Added function
MainDlg.cpp
    void CMainDlg::OnOK()
        int nSelectedFile_Index = TemplateList_.GetCurSel();
        if (nSelectedFile_Index == LB_ERR) {
            AfxMessageBox("FYI: No template was selected, so no Avisynth "
                    "script will be generated.");
        else {
    // Original Source
    //      int nTemplateNum = TemplateList_.GetItemData(nSelectedFile_Index);
    //      CreateScript(gTemplateList[nTemplateNum].sFileName_.c_str());
    // ssS
            int status = ScanTemplateSSS(gTemplateList[nTemplateNum].sFileName_.c_str());
            if(status & 0x01) { // Repeating section avs creator
            } else {    // Non-repeating section avs creator
                unsigned int i;
                for(i=0;i<gFileList.size();++i) {
                    CreateScriptSSS(gTemplateList[nTemplateNum].sFileName_.c_str(),i);
        CDialog::OnOK();
Author's email:      Warren Young <wdyoung@acm.org>
AVISynthesizer home: http://www.cyberport.com/~tangent/video/asynther.html
An example template file that I use (still in development)
#ASYNTHER RoboSplice
Global G_FILECOUNT=___FILECNT___
Global G_DEBUG=True
Global G_QBC=True           Global G_SAMPLES=32         Global G_QBC_THRESH=-32.0  Global G_INTERLACED=False
Global G_AL_STRENGTH=0.95 Global G_AUTOGAIN=False
Global G_DEBLOCK=22
Global G_RPOW2=false
Global G_DISPWID=0      Global G_DISPHIT=0      Global G_FRNUM=0            Global G_FRDEN=0
Global G_MCD=0          Global G_SIGMA=1.6      Global G_SHARPEN=0.01
Global G_CHANNELS=2     Global G_SAMPLERATE=44100   Global G_BITS=16        Global G_NORMALIZE=(G_FILECOUNT>1)
[GetTrim("___FILE___")]
Above RoboSplice.avst template, is used to concatenate (splice together) multiple clips of perhaps
differing characteristics. The GetTrim() function is contained in an avsi script in plugin directory
and loads in a filename clip, makes adjustements to that clip based on above global variables.
Eg, if G_DISPWID and G_DISPHIT are 0 (unset) then will change Global G_DISPWID and G_DISPHIT to dimensions
of the first gotten clip (after any auto cropping of letterboxing, and perhaps resizing to standardized
dimensions), subsequent clips are resized to match the now set G_DISPWID and G_DISPHIT Globals.
The plugin dir script, also contains a function called GetFile() [called by GetTrim()] which just loads
the file using perhaps differing strategies depending upon filename extension. and then GetTrim() calls a DoTrim()
function which matches characteristics to the first clip or pre set Global Variables.
Added ___FILECOUNT___ so as to avoid multiple audio normalizing (in script, then again in MeGUI) when
only a single file is being processed (perhaps other uses).
GetTrim() is NOT provided here, just explaining what I use the ___FILECNT__ thing for.
Here a Batch Mode template
#ASYNTHER BATCH-AVISOURCE
FileCount = ___FILECNT___  # WILL always be set to 1 in non-repeating Batch template
# Below not enclosed in square brackets, so is Non-Repeating ie Batch Mode, multiple AVS files generated.
AVISource("___FILE___")
Contains original source and all VS6 compiler files for easy build.
Required Platform SDK and thats for sure.
Original Author's site with original usage: http://tangentsoft.net/video/asynther/
EDIT: Above linked page seems to have been removed (but copy of page included in the zip).
Brief description as webpage removed. Can select clips in Windows Explorer and SendTo Avisynthesizer where it will
create an avs script to concatenate (join together) all selected clips. Modified so that it is also possible to create an individual
avs file for all selected clips (batch creation of avs files). You supply templates to get whatever effect is required.
Alternative page about Avisynthesizer (original version):
http://www.digitalfaq.com/forum/vide...-complete.html
See MediaFire in sig.
EDIT: Original executable tended to chop off the end of a script if more than about a dozen lines, I have done nothing
to fix that but, that problem seems to have disappeared. Perhaps the wrong executable was supplied with good source.
EDIT: Avisynthesizer_Mod is an offshoot of the original Avsynthesizer by Warren Young and nothing to do with SwiftAVS
which seems to masquerade itself as the "New Avisynthesizer", and not in any way similar. (SwiftAVS is on sourceforge
as Avisynthesizer for some inexplicable reason, perhaps there was a name conflict and so he just changed it).
EDIT: Here a demo BATCH script template using TWriteAVI to create lossless AVI and call ffmpeg encoder on result. http://forum.doom9.org/showthread.ph...48#post1750548
Here original home page on Archive.org:- https://web.archive.org/web/20140331...ideo/asynther/
And the manual (also available via above link):- https://web.archive.org/web/20130318...er/manual.html
Old 30th December 2012, 11:26   #2  |  Link
Also, handy link here:-
Customize the Windows 7 “Send To” Menu Option
Which also applies to XP. Can create SendTo shortcuts for whatever you like.
Old 7th August 2013, 16:14   #3  |  Link
Avisynthesizer_Mod 7 Aug 2013, update, see 1st post.
Added ___FILECNT___ insertion marker, inserts count of files given.
Old 13th February 2014, 16:50   #4  |  Link
Scripts posted here because of this post: http://forum.doom9.org/showthread.ph...97#post1667897
Was not really intending to make public, leastwise not yet.
RoboSplice.avsi
Function IsClose(Float a, Float b, Float threshold) {
    threshold=Abs(threshold)
    return ((abs(a-b)+threshold) <= threshold*2.0)
Function ConvRates(clip c,int "num",int "den",int "Channels",int "SampleRate",int "Bits",bool "Norm") {
    c
    GScript("""
        if((!Defined(num) || !Defined(den)) || (num==0 || den==0)) {num = 0 den = 0}
        Channels=Default(Channels,AudioChannels)
        SampleRate=Default(SampleRate,AudioRate)
        Bits=Default(bits,AudioBits)
        Norm=Default(Norm,True)
        if(num == FrameRateNumerator && den == FrameRateDenominator) {
            RT_Debug("Using Original FrameRate ",String(FrameRate,"%.3f"))
        } else {
            if(num==0 || den == 0) {
                FPS = FrameRate
                if      (isClose(FPS,29.97,0.015))  {num=30000 den = 1001}
                else if (isClose(FPS,23.976,0.012)) {num=24000 den = 1001}
                else if (isClose(FPS,11.988,0.006)) {num=12000 den = 1001}
                else if (isClose(FPS,30.0,0.5))     {num=30 den = 1}
                else if (isClose(FPS,25.0,0.5))     {num=25 den = 1}
                else if (isClose(FPS,24.0,0.5))     {num=24 den = 1}
                else if (isClose(FPS,18.0,0.5))     {num=18 den = 1}
                else if (isClose(FPS,15.0,0.5))     {num=15 den = 1}
                else if (isClose(FPS,12.5,0.5))     {num=25 den = 2}
                else if (isClose(FPS,12.0,0.5))     {num=12 den = 1}
                else    {num=FrameRateNumerator den = FrameRateDenominator}
            if(isClose(Float(num) / Float(den),FrameRate,1.0)) {
                AssumeFPS(num,den,sync_audio=true)
                RT_Debug("Assuming FrameRate ",String(FrameRate,"%.3f"))
            } else {
                RT_Debug("Converting FrameRate to",String(Float(num) / Float(den),"%.3f"))
                if(false) {
                    super=MSuper(pel=1)
                    bvec=MAnalyse(super, isb=true, blksize=16)
                    fvec=MAnalyse(super, isb=false, blksize=16)
                    MBlockFps(super, bvec, fvec, num=num,den=den, mode=3)
                } else {
                    super=MSuper(pel=1, hpad=0, vpad=0)
                    backward_1=MAnalyse(super, chroma=false, isb=true,  blksize=16, blksizev=16, searchparam=3, plevel=0, search=3, badrange=(-24))
                    forward_1 =MAnalyse(super, chroma=false, isb=false, blksize=16, blksizev=16, searchparam=3, plevel=0, search=3, badrange=(-24))
                    backward_2 = MRecalculate(super, chroma=false, backward_1, blksize=8, blksizev=8, searchparam=0, search=3)
                    forward_2  = MRecalculate(super, chroma=false, forward_1,  blksize=8, blksizev=8, searchparam=0, search=3)
                    MBlockFps(super, backward_2, forward_2, num=num, den=den, mode=0)
        IsSilent=false
        if(!HasAudio) {
            RT_Debug("Adding Silent Audio")
            Aud=Last.Blankclip(audio_rate=SampleRate,channels=Channels)
            IsSilent=true
            Audiodub(Aud)
        if(HasAudio) {
            if(Channels == 0 && AudioChannels > 0) {
                KillAudio()
                RT_Debug("Killing Audio")
            } else if(Channels == 1 && AudioChannels > 1) {
                ConvertToMono()
                RT_Debug("Converting To MONO")
            } else if(Channels == 2 && AudioChannels ==1) {
                AudioDub(Last,MergeChannels(GetChannel(1),GetChannel(1)))
                RT_Debug("Converting To STEREO")
            if(HasAudio() && Bits != AudioBits) {
                if(bits==8)       { ConvertAudioTo8bit() }
                else if(bits==16) { ConvertAudioTo16bit() }
                else if(bits==24) { ConvertAudioTo24bit() }
                else if(bits==32) { ConvertAudioTo32bit() }
            if(HasAudio() && SampleRate != AudioRate) {ResampleAudio(SampleRate) }
            if(HasAudio() && Norm && !IsSilent) {
                Normalize(0.98)
                RT_Debug("NORMALIZING AUDIO")
    Return Trim(0,0)
Function DoTrim(clip c) {
    c
    GScript("""
        W=Width % 8 H=Height % 8
        Addborders(0,0,W==0?0:8-W,H==0?0:8-h).ConvertToYV12()
        if(G_DEBLOCK!=0) {
            RT_Debug("DEBLOCK("+String(G_DEBLOCK)+")")
            Deblock(G_DEBLOCK)
        if(G_RPOW2 ||((G_DISPWID>0 && G_DISPWID>Int(Width*Sqrt(2.0)))||(G_DISPHIT>0 && G_DISPHIT>Int(Height*Sqrt(2.0))))) {
            RT_Debug("RPOW2")
            NNedi3_Rpow2(2)
        if(G_QBC==true || G_SAMPLES!=0 || G_AL_STRENGTH>0.0 || G_AUTOGAIN) {
            RT_Debug("Calling RoboLevels")
            RoboLevels(Strength=G_AL_STRENGTH,samples=G_SAMPLES,qbc=G_QBC,QBC_Thresh=G_QBC_THRESH,DEBUG=G_DEBUG,Laced=G_INTERLACED,WMod=4,HMod=4)
            if(G_AUTOGAIN) {
                RT_Debug("AutoGain")
                TMPW=Int(Width /4)*4                                        # Mod 4 for AutoGain
                TMPH=Int(Height/4)*4                                        # Mod 4 for AutoGain
                TMP=Crop(0,0,TMPW,TMPH)
                AutoGain(Last,TMP)
        if(G_MCD==0) {
            if(G_SIGMA!=0.0 || G_SHARPEN!=0.0) {
                RT_Debug("FFT3DFilter")
                FFT3DFilter(Sigma=G_SIGMA,Sharpen=G_SHARPEN)
        } else {
            RT_Debug("MCDeGrain")
            MCDEGRAIN(G_MCD)
        ConvRates(num=G_FRNUM,den=G_FRDEN,Channels=G_CHANNELS,SampleRate=G_SAMPLERATE,Bits=G_BITS,norm=G_NORMALIZE)
        Global G_FRNUM = FrameRateNumerator
        Global G_FRDEN = FrameRateDenominator
        Global G_CHANNELS = AudioChannels
        Global G_SAMPLERATE = AudioRate
        Global G_BITS = AudioBits
        if(G_DISPWID!=Width || G_DISPHIT != Height) {
            if(G_DISPWID==0 || G_DISPHIT == 0) {
                WW=(Width  + (4-1)) / 4 * 4
                HH=(Height + (4-1)) / 4 * 4
                Global G_DISPWID = WW
                Global G_DISPHIT = HH
                if(WW==Width && HH==Height) {
                    RT_Debug("Using Original SIZE",String(G_DISPWID),String(G_DISPHIT))
                } else {
                    RT_Debug("Resizing MOD 4",String(G_DISPWID),String(G_DISPHIT))
                    Spline36Resize(G_DISPWID,G_DISPHIT)
            } else {
                RT_Debug("Resizing to match previous clip",String(G_DISPWID),String(G_DISPHIT))
        if(G_MCD!=0) {
    ConvertToYV12()
Function GetFile(string s) {
    GScript("""
        c=0
        Ext=LCase(RT_GetFileExtension(s))
        RT_Debug("Processing " + s,"for Extension",Ext)
        if(Ext==".avi") {
            c=AVISource(s)
            RT_Debug("AVISOURCE")
        if(!c.IsClip) {
            try {
                FFIndex(S) c=AudioDub(FFVideoSource(S), FFAudioSource(S))
                RT_Debug("FFMSSOURCE")
            } catch(msg) {
                try {
                    c=AudioDub(DSS2(s),DirectshowSource(s).KillVideo)
                    RT_Debug("DSSSOURCE")
                } catch(msg) {
                    c=DirectShowSource(s)
                    RT_Debug("DirectShowSource")
        W=c.Width % 8 H=c.Height % 8
        c=c.Addborders(0,0,W==0?0:8-W,H==0?0:8-h).ConvertToYV12()
    return c
Function GetTrim(string s) {
    Return GetFile(s).DoTrim()
RoboLevels.avsi (A hack of a different script)
Function RoboLevels(clip c,float "Strength",int "Samples",float "Ignore",Bool "ALQBC",Bool "QBC",Float "QBC_Thresh",int "X",int "Y",int "W",int "H", \
    int "Matrix",bool "PC",bool "DEBUG",bool "Laced", Int "WMod",Int "HMod",bool "Show") {
# Samples a number of frames from source clip and using minimum and maximum luma levels from those samples, auto levels clip.
# Default temporarily auto crop borders and samples the area remaining, or if both ALQBC and QBC == false then samples X,Y,W,H coords instead.
# Can optionally return border cropped clip when QBC==true.
# Args:
#  Strength, default 0.95 (0.0 -> 1.0). Auto levelling strength.
#  Samples, default 32. Number of frames sampled from source clip c.
#  Ignore, default 0.2 (0.0 -> 100%). Percentage of dark pixels to ignore when ascertaining YPlaneMin, YPlaneMax (noise).
#  ALQBC, default=true. Use temp auto cropped clip coords for auto levels sampling.
#  QBC, default false. If true then returns border cropped clip else non cropped.
#  QBC_Thresh, default -32.0. Threshold used for border detection. See RT_QueryBorderCrop.
#     NOTE, RT_QueryBorderCrop 'massages' DEFAULT THRESH (exactly -32.0) if low samples count or if short clip. Reason being to avoid
#     overcropping when insufficient data available for reliable cropping. It is considered better to not crop enough or at all, than
#     to overcrop. You can override by simply setting an explicit threshold (+ve) of eg 40.0, or setting a NON-DEFAULT auto thresh (-ve)
#     eg -16.0 or -32.1, where YPlaneMin is established for the sampled frames and then abs(thresh) is added to that value which is
#     then used as an explicit thresh.
#  X,Y,W,H. All default 0, ie full frame. Coords for luma sampling, only used if both ALQBC and QBC are both false.
#  Matrix default= 2(PC601) if clip width<720 else 3(PC709).
#     Conversion matrix for conversion of RGB to YUV-Y Luma.  0=REC601 : 1=REC709 : 2 = PC601 : 3 = PC709:  YUV not used
#     DO NOT USE Matrix of 0 or 1.
#  PC default = false. If YUV and PC == true then auto level PC Levels 0->255 instead of TV levels 16->235. RGB always 0->255
#  Debug default false. If true then send info the DebugView.
#    Recommended, DebugView: http://technet.microsoft.com/en-gb/sysinternals/bb545027
#  Laced, default = true. Alters Interlaced default for HMod, HMod doubled if true.
#  WMod, default = the natural cropping WMod for clip c colorspace (eg 2 for YV12 and YUY2, 1 for RGB).
#  HMod, default = the natural cropping HMod for clip c colorspace (eg 2 for YV12 and 1 for YUY2 and RGB), but doubled if Laced==true.
#    NOTE, WMod, HMod, If overridden must all be multiples of natural cropping WMod and HMod for clip c colorspace.
#    NOTE, VirtualDubMod and some players, may not like any colorspace WMOD less than 4 (Vdub latest, OK).
#    NOTE, If eg VDMod show blank frame, OR eg player halts saying eg "No combination of filters cound be found to render frame"
#    then set WMod to a multiple of 4. We do not do this by default as Current VDub and some player/encoders may work just fine.
#    If you dont care about possibility of losing a couple of pixels then always supply WMod=4 to avoid display problems.
#  Show, default false. If true, shows Levels() used on frame.
    myName="RoboLevels: "
    c
    Frames=FrameCount
    Strength=Float(Default(Strength,0.95))
    Samples=(!Defined(Samples)) ? 32 : (Samples > Frames) ? Frames : (Samples < 1) ? 1 : Samples
    Ignore=Float(Default(Ignore,0.2))
    ALQBC=Default(ALQBC,True)
    QBC=Default(QBC,False)
    QBC_Thresh=Float(Default(QBC_Thresh,-32.0))
    Matrix = Default(Matrix,(width <= 720) ? 2 : 3)
    PC=Default(PC,False)
    DEBUG=Default(DEBUG,False)
    SHOW=Default(Show,false)
    QBCropXP = Default(X,0) QBCropYP = Default(Y,0) QBCropWP = Default(W,0) QBCropHP = Default(H,0) # prep
    Assert(Strength>=0.0 && Strength <=1.0, myName + "0.0 <= Strength <= 1.0")
    GScript("""
        if(ALQBC || QBC) {
            QBCS=RT_QueryBorderCrop(samples=Samples,thresh=QBC_Thresh,debug=DEBUG,ignore=Ignore,matrix=Matrix,laced=laced,wmod=WMod,hmod=HMod)
            Eval(QBCS)
        QLMMS=RT_QueryLumaMinMax(c,samples=Samples,ignore=Ignore,x=QBCropXP,y=QBCropYP,W=QBCropWP,H=QBCropHP,debug=DEBUG,matrix=Matrix)
        Eval(QLMMS)
        if(IsRGB() || PC) {
            CSMin = 0
            CSMax = 255
        } else {
            CSMin = 16
            CSMax = 235
        ALMin = Int(CSMin - ((CSMin - QLMMMin) * Strength) + 0.5)   # Round Up
        ALMax = Int(CSMax - ((CSMax - QLMMMax) * Strength))         # Round down
        if(QBC) {
            CropS="Crop("+String(QBCropXM)+","+String(QBCropYM)+","+String(QBCropWM)+","+String(QBCropHM)+")"
            (DEBUG)?RT_Debug(MyName,CropS,false):NOP
            Crop(QBCropXM,QBCropYM,QBCropWM,QBCropHM)
            (SHOW) ?RT_SubTitle(CropS,y=20):NOP                     # NOTE, After Cropping
        LevelsS="Levels("+String(ALMin)+",1.0,"+String(AlMax)+","+String(CSMin)+","+String(CSMax)+",Coring=False)"
        (DEBUG)? RT_Debug(MyName,LevelsS,false):NOP
        (SHOW) ? RT_Subtitle(LevelsS,y=0):NOP
        Levels(ALMin,1.0,ALMax,CSMin,CSMax,Coring=False) # DO NOT use Coring
    return Last
Anything in comments can be taken with a pinch of salt.
EDIT: Will probably crash if more than about 28 clip names supplied (seems to be general sourcefilter problem).
EDIT: And current BASE template as it stands
Global G_DEBUG=True
Global G_DEBLOCK=22
Old 20th February 2014, 18:34   #5  |  Link
Avisynthesizer_Mod Update, see 1st post.
Old 15th December 2014, 01:18   #6  |  Link
Post #1 of 2.
Updates to a few scripts in-progress. Also uses MCDegrain.avsi and FavC.avsi. (+ a number of plugins).
RoboSplice.Avst (Avisynthesizer_Mod template)
Global G_DEBUG=True
Global G_AL_STRENGTH=0.95   Global G_GAMMA=1.0          Global G_AUTOGAIN=False
Global G_DEBLOCK=20
Global G_USE_INTERFRAME=False
Global G_ASPECT_DARX=0       Global G_ASPECT_DARY=0
Global G_MCD=0          Global G_SIGMA=1.65         Global G_SHARPEN=0.0
GetFile.avsi
Function GetFile(string vFN,string "aFN",Int "Prefer",Float "AudioDelay") {
	myName="GetFile: "
    START=RT_TimerHP
    Assert(vFN!="",myName+"Empty VideofileName")
    vFN = LCase(vFN)
    aFN = LCase(Default(aFN,""))
    Prefer=Default(Prefer,0)            # Default 0=Avi if "AVI", 1, 1 = L-SMASH, 2 = FFMPegSource
    Prefer = (Prefer<0 || Prefer>2) ? 0 : Prefer
    AudioDelay=Float(Default(AudioDelay,0.0))
    SepAud = (aFN!="" && aFN!=vFN)
	Ext=RT_GetFileExtension(vFN)
    Function IsISOFileName(String s) {
        s=Lcase(RT_GetFileExtension(s)) Return(s==".mov"||s==".mp4"||s==".3gp"||s==".3g2"||s==".mj2"||s==".dvb"||s==".dcf"||s==".m21")}
	GScript("""
		c = 0
        FLGS = 0
   		RT_DebugF("\nOpening Video %s for Extension %s",vFN,Ext,name=myName)
        try {
            # Attempt open for some formats by extension, NOT AVISource as could be non seekable, Allow AVI Indexing via later Source Plugs.
    		if(Ext == ".d2v") {c = MPEG2Source(vFN,UPCONV=1) RT_DebugF("MPEG2Source Succeeds:",name=myName)}
            Else if(Prefer==0 && Ext == ".avi") {
                c = AviSource(vFN)
                try {c=AviSource(vFN) RT_DebugF("AVISource Video Succeeds:",name=myName) }
                catch (msg) {RT_DebugF("AVISource Video Fails:- '%s'",msg,name=myName) }
            if(!c.IsClip) {
                if(Prefer<=1) {
                    If(IsISOFileName(Ext)) {
                        FLGS=RT_BitSet(FLGS,0)
                        c = LSMASHVideoSource(vFN) RT_DebugF("LSMASHVideoSource Video Succeeds:",name=myName)
                        if(!SepAud) {FLGS=RT_BitSet(FLGS,1) try{c=AudioDubEx(c,LSMASHAudioSource(vFN)) } catch(msg){} }
                    if(!c.IsClip) {
                        try {FLGS=RT_BitSet(FLGS,2) c=LWLibavVideoSource(vFN) RT_DebugF("LWLibavVideoSource Video Succeeds:",name=myName)
                            if(!SepAud) {FLGS=RT_BitSet(FLGS,3) try{c=AudioDubEx(c,LWLibavAudioSource(vFN)) } catch(msg){} }
                        } catch (msg) {RT_DebugF("LWLibavVideoSource Video Fails:- '%s'",msg,name=myName) }
                } Else {
        			try {FLGS=RT_BitSet(FLGS,4) FFIndex(vFN)  c=FFVideoSource(vFN)  RT_DebugF("FFMSSource Video Succeeds:",name=myName)
                        if(!SepAud) {FLGS=RT_BitSet(FLGS,5) try{c=AudioDubEx(c,FFAudioSource(vFN)) } catch(msg){} }
                    } catch(msg) {RT_DebugF("FFMSSource Video Fails:- '%s'",msg,name=myName)}
        } catch (msg) {c=0 RT_DebugF("Open Video by Extension Fails:- '%s'",msg,name=myName)}
		if(!c.IsClip) {
            if(!RT_BitTst(FLGS,4)) {
    		if(!c.IsClip) {
        		if(!RT_BitTst(FLGS,2)) {
        		if(!c.IsClip) {
                    if(!RT_BitTst(FLGS,0)) {    # Not tried LSmash Video yet
                        try {c = LSMASHVideoSource(vFN) RT_DebugF("LSMASHVideoSource Video Succeeds:",name=myName)
                        } catch (msg) {RT_DebugF("LSMASHVideoSource Video Fails:- '%s'",msg,name=myName) }
            		if(!c.IsClip) {
        				try {c = DSS2(vFN) RT_DebugF("DSS2Source Video Succeeds:",name=myName) }
        				catch(msg) {RT_DebugF("DSS2Source Video Fails:- '%s'",msg,name=myName)
                            if(Ext==".avi") { # One last go before DirectShowSource
                            if(!c.IsClip) {
                                try {c=DirectShowSource(vFN,pixel_type="YV12") RT_DebugF("DirectShowSource(YV12) Video Succeeds:",name=myName) }
                                catch(msg) {RT_DebugF("DirectShowSource(YV12) Video Fails:- '%s'",msg,name=myName)
                                    try {c=DirectShowSource(vFN,pixel_type="YUY2") RT_DebugF("DirectShowSource(YUY2) Video Succeeds:",name=myName) }
                                    catch(msg) {RT_DebugF("DirectShowSource(YUY2) Video Fails:- '%s'",msg,name=myName)
                                        try {c=DirectShowSource(vFN,pixel_type="RGB") RT_DebugF("DirectShowSource(RGB) Video Succeeds:",name=myName) }
                                        catch(msg) {Assert(False,myName+"DirectShowSource(RGB) Video Fails: "+Chr(10)+msg)}
                        if(!c.HasAudio && !SepAud) {try{c=AudioDubEx(c,DirectShowSource(vFN,video=false) ) } catch(msg){} }
        if((!c.HasAudio&&Ext!=".d2v") || SepAud){
            RT_DebugF("Attempting Get Audio")
            a = 0
            aFN = (aFN=="") ? vFN : aFN
            Ext=RT_GetFileExtension(aFN)
            if(SepAud) {
                RT_DebugF("Opening Audio %s for Extension %s",aFN,Ext,name=myName)
                try {
                    if(Ext==".ac3") {a=NICAC3Source(aFN,channels=2,DRC=0) RT_DebugF("NICAC3Source Succeeds:",name=myName) }
                    Else if(Ext==".mpa"||Ext==".mp1"||Ext==".mp2"||Ext==".mp3") {
                        a=NicMPG123Source(aFN,Normalize=False) RT_DebugF("NicMPG123Source Succeeds:",name=myName) }
                    Else if(Ext==".wav") {a=RaWavSource(afN) RT_DebugF("RaWavSource Succeeds:",name=myName) }
                    Else if(Ext==".dts") {a=NicDTSSource(aFN) RT_DebugF("NicDTSSource Succeeds:",name=myName)}
                } catch (msg) {a=0 RT_DebugF("Extension based Audio Fails:- '%s'",msg,name=myName) }
            if(!a.IsClip) {
                if(SepAud || !RT_BitTst(FLGS,5)) {
        			try {
                        if(SepAud || !RT_BitTst(FLGS,4)) {FFIndex(aFN)}
                        a = FFAudioSource(aFN) RT_DebugF("FFAudioSource Succeeds:",name=myName)
                    } catch(msg) {RT_DebugF("FFAudioSource Fails:- '%s'",msg,name=myName)}
                if(!a.IsClip) {
                    if((SepAud || !RT_BitTst(FLGS,3))) {
                        try {a=LWLibavAudioSource(aFN) RT_DebugF("LWLibavAudioSource Succeeds:",name=myName) }
                        catch (msg) {RT_DebugF("LWLibavAudioSource Fails:- '%s'",msg,name=myName) }
                    if(!a.IsClip) {
                        if((SepAud || !RT_BitTst(FLGS,1))) {
                            try {a=LSMASHAudioSource(aFN)  RT_DebugF("LSMASHAudioSource Succeeds:",name=myName) }
                            catch (msg) {RT_DebugF("LSMASHAudioSource Fails:- '%s'",msg,name=myName) }
                        if(!a.IsClip && SepAud) {
                            try {a=DirectShowSource(s,video=false) RT_DebugF("DirectShowSource Succeeds:",name=myName) }
                            catch (msg) {a=0 Assert(aFN!=vFN,myName+"Audio Fails: "+Chr(10)+msg)}
            c = (a.IsClip)   ? AudioDubEx(c,a)          : c
            c = (c.HasAudio) ? DelayAudio(c,AudioDelay).Trim(0,0) : c
        RT_DebugF("Checking dimensions")
        if(W > 0 || H > 0) {
            W=(W==0)?0:8-W  H=(H==0)?0:8-H
            if(c.IsRGB()) {
                yMin=c.RT_YPlaneMin(n=0,threshold=0.2)   # Default matrix @ PC levels
                Col = (yMin * 256 + yMin) * 256 + yMin
                RT_DebugF("RGB Adding Borders %dx%d, Y=$%06X",W,H,Col,name=myName)
                c=c.Addborders(0,0,W,H,Col)
            } Else {
                Col = (yMin * 256 + $80) * 256 + $80
                RT_DebugF("YUV Adding Borders %dx%d, Y=$%06X",W,H,Col,name=myName)
                if(W>0) {c=c.StackHorizontal(c.Blankclip(color_yuv=Col,Width=W))}
                if(H>0) {c=c.StackVertical(c.Blankclip(color_yuv=Col,Height=H))}
        RT_DebugF("ConvertYV12")
        c = c.ConvertToYV12()
        RT_DebugF("Convert Stereo")
        c = FAVCStereo(c,c)         # Output is YV12 + Stereo, Width & Height Mod 8
    T=RT_TimerHP - START
    RT_DebugF("Total File Open Time = %.2fsecs",T,name=myName)
	return c
Old 15th December 2014, 01:19   #7  |  Link
Post #2 of 2.
RoboLevels.avsi
# Args:
    c
    Frames=FrameCount
    Default(Matrix,(width > 1100 || height > 600) ? 3 : 2) # Default to PC levels
    GScript("""
        if(ALQBC || QBC) {
            Eval(QBCS)
        Eval(QLMMS)
        if(IsRGB() || PC) {
            CSMin = 0
            CSMax = 255
        } else {
            CSMin = 16
            CSMax = 235
        if(QBC) {
            (DEBUG)?RT_DebugF(CropS,name=myName):NOP
        LevelsS=RT_String("Levels(%d,%f,%d,%d,%d,coring=false)",ALMin,G_GAMMA,AlMax,CSMin,CSMax)
        (DEBUG)? RT_DebugF(LevelsS,name=myName):NOP
        Levels(ALMin,G_GAMMA,ALMax,CSMin,CSMax,Coring=False) # DO NOT use Coring
    return Last
RoboSplice.avsi
Function ConvRates(clip c,int "num",int "den",Bool "InterFrame",int "Channels",int "SampleRate",int "Bits",bool "Norm") {
    myName="ConvRates: "
    c
    GScript("""
        InterFrame=Default(Interframe,false)
            RT_DebugF("Using Original FrameRate %.3f",FrameRate,name=myName)
        } else {
                FPS = FrameRate
                RT_DebugF("Assuming FrameRate %.3f",FrameRate,name=myName)
            } else {
                if(Interframe) {
                    RT_DebugF("Interframe: Converting FrameRate to %.3f",Float(num) / Float(den),name=myName)
                    Interframe(NewNum=num,NewDen=den,cores=1)
                } Else {
                    RT_DebugF("MVTools: Converting FrameRate to %.3f",Float(num) / Float(den),name=myName)
                    if(False) {
                        super=MSuper(pel=1)
                    } else {
        IsSilent=false
        if(!HasAudio) {
            RT_DebugF("Adding Silent Audio",name=myName)
            IsSilent=true
            Audiodub(Aud)
        if(HasAudio) {
                KillAudio()
                RT_DebugF("Killing Audio",name=myName)
                ConvertToMono()
                RT_DebugF("Converting To MONO",name=myName)
                RT_DebugF("Converting To DUEL Channel MONO",name=myName)
                Normalize(0.98)
                RT_DebugF("NORMALIZING AUDIO",name=myName)
    Return Trim(0,0)
    myName="DoTrim: "
    c
    GScript("""
        if(G_DEBLOCK!=0) {
            RT_DebugF("DEBLOCK(%d)",G_DEBLOCK,name=myName)
            Deblock(G_DEBLOCK)
        if(G_RPOW2 ||((G_DISPWID>0 && G_DISPWID>Int(Width*Sqrt(2.0)))  ||  (G_DISPHIT>0 && G_DISPHIT>Int(Height*Sqrt(2.0))))) {
            RT_DebugF("RPOW2",name=myName)
            NNedi3_Rpow2(2)
            RT_DebugF("Calling RoboLevels",name=myName)
            if(G_AUTOGAIN) {
                RT_DebugF("AutoGain",name=myName)
                TMP=Crop(0,0,TMPW,TMPH,align=True)
                AutoGain(Last,TMP)
        if(G_MCD==0) {
                RT_DebugF("FFT3DFilter(Sigma=%f,Sharpen=%f)",G_SIGMA,G_SHARPEN,name=myName)
        } else {
            RT_DebugF("MCDeGrain(%d)",G_MCD,name=myName)
            MCDEGRAIN(G_MCD)
                    RT_DebugF("Using Original SIZE %d %d",G_DISPWID,G_DISPHIT,name=myName)
                } else {
                    RT_DebugF("Resizing MOD 4, %dx%d",G_DISPWID,G_DISPHIT)
            } else {
                RT_DebugF("Resizing to match previous clip %dx%d",G_DISPWID,G_DISPHIT)
        ConvRates(num=G_FRNUM,den=G_FRDEN,Interframe=G_USE_INTERFRAME,Channels=G_CHANNELS,SampleRate=G_SAMPLERATE,Bits=G_BITS,norm=G_NORMALIZE)
        if(G_MCD!=0) {
        if(G_ASPECT_DARX>0 && G_ASPECT_DARY>0) {
            RT_DebugF("SignalDAR2(%d,%d)",G_ASPECT_DARX,G_ASPECT_DARY,name=myName)
            RT_SignalDar2(G_ASPECT_DARX,G_ASPECT_DARY)
    ConvertToYV12()
Template given can be used on lone source or for concatenating multiple sources.
Old 19th December 2014, 00:47   #8  |  Link
Here another multi-sourcefilter loader script by MpegAutoSource Vampiredom+
http://forum.doom9.org/showthread.php?t=162930
Old 13th February 2019, 18:22   #9  |  Link
I have located original AviSynthesizer home page on Archive.org, below, [I guess the original author may have gotten tired of questions about the Mod version, so page deleted].
NOTE, changed a little since above manual (uses ___FILE___ instead of %f as filename insert marker), and does not support BATCH mode available in AviSynthesizer_Mod.
Old 10th May 2019, 03:52   #10  |  Link
A Pretty reasonable simple multi-source filter template script for splicing multiple source files (of similar characteristics).
Remove the square brackets around filename to make a Batch template (where makes one script for each selected source script).
ie make [GetSeq("___FILE___")] >>>======>>> GetSeq("___FILE___")
Can also extract and use the GetSeq() function in your scripts.
Does not use any fancy FFMS2 or LSMash args (just defaults).
Simple_AVI_LSmash_FFMS_Reader.avst [EDIT: The Name shown in template selector dialog box is in first line below, followinging "#ASYNTHER ".
#ASYNTHER Simple_AVI_LSmash_FFMS_Reader
# Requires RT_Stats
Function GetSeq(String vFn,String "aFn") {
    Function IsISOFileName(String s)  {s=RT_GetFileExtension(s) Return(s==".mov"||s==".mp4"||s==".m4v"||s==".3gp"||s==".3g2"||s==".mj2"||s==".dvb"||s==".dcf"||s==".m21")}
    Function IsRiffFileName(String s) {s=RT_GetFileExtension(s) Return(s==".avi"||s==".wav")}
    myName="GetSeq: "                                           aFn = Default(aFn,"")           aFn = (aFn=="") ? vFn : aFn
    Assert(vFn!="",RT_String("%sVFn Cannot be ''",myName))      vFn = vFn.RT_GetFullPathName    IsRiffV = vFn.IsRiffFileName    IsIsoV = vFn.IsISOFileName
    Assert(aFn!="",RT_String("%saFn Cannot be ''",myName))      aFn = aFn.RT_GetFullPathName    IsRiffA = aFn.IsRiffFileName    IsIsoA = aFn.IsISOFileName
    c=0 a=0
    Try { # 1st Try specialized AVI
        c = (IsRiffV)                            ? vFn.AviSource        : NOP
        (c.IsClip)                               ? RT_DebugF("AviSource opened Video\n  '%s'",vFn,name=myName)                                                       : NOP
    } catch (msg) { RT_DebugF("Catch: %s",msg,name=myName) }
    Try {
        a = (c.IsClip && c.HasAudio && aFn==vFn) ? c : (IsRiffA) ? aFn.WavSource        : NOP
        (a.IsClip && a.HasAudio)                 ? RT_DebugF("%s opened Audio\n  '%s'",(c.IsClip && c.HasAudio && aFn==vFn)?"AviSource":"WavSource",aFn,name=myName) : NOP
    # Next try specialized ISO LSMash
    Try {
        IsOpenV=(c.IsClip && c.HasVideo)
        c = (IsIsoV)                       ? LSMASHVideoSource(vFn)                                                : c
        (IsIsoV)                           ? RT_DebugF("LSMASHVideoSource opened Video\n  '%s'",vFn,name=myName)   : NOP
    Try {
        IsOpenA=(a.IsClip && a.HasAudio)
        a = (IsIsoA)                       ? LSMASHAudioSource(aFn)                                                : a
        (IsIsoA)                           ? RT_DebugF("LSMASHAudioSource opened Audio\n  '%s'",aFn,name=myName)   : NOP
     # Next try FFMS2
    Try {
        (!IsOpenV)    ? FFIndex(vFn)                                                    : NOP
        c=(!IsOpenV)  ? FFVideoSource(vFn)                                              : c
        (!IsOpenV)    ? RT_DebugF("FFVideoSource opened Video\n  '%s'",vFn,name=myName) : NOP
    Try {
        a=(!IsOpenA)  ? FFAudioSource(aFn)                                              : a
        (!IsOpenA)    ? RT_DebugF("FFAudioSource opened Audio\n  '%s'",aFn,name=myName) : NOP
    # Next try LSmash non ISO Video
    Try {
        c = (!IsOpenV && !IsIsoV)          ? LWLibavVideoSource(vFn)                                                : c
        (!IsOpenV && !IsIsoV)              ? RT_DebugF("LWLibavVideoSource opened Video\n  '%s'",vFn,name=myName)   : NOP
    Try {
        a = (!IsOpenA && !IsIsoA)      ? LWLibavAudioSource(aFn)                                                : a
        (!IsOpenA && !IsIsoA)          ? RT_DebugF("LWLibavAudioSource opened Audio\n  '%s'",aFn,name=myName)   : NOP
    Assert(c.IsClip, RT_String("%s failed open on\n  '%s'",myName,vFn))
    (!c.HasAudio && a.IsClip && a.HasAudio) ? AudioDubEx(c,a) : c
    (!HasAudio) ? RT_DebugF("Audio failed Open on\n  '%s",aFn,name=myName) : NOP
    return Last
Return last
EDIT: You could put GetSeq() function (excluding client call code) into and avsi file in plugins, and just use this as template NON batch mode template)
return last
EDIT: OR batch mode template
#ASYNTHER BATCH-Simple_AVI_LSmash_FFMS_Reader
FN = "___FILE___"
GetSeq(FN)
return last
Old 13th June 2019, 23:24   #11  |  Link
Batch mode template, Perhaps of use, not for MT nor x64 [TWriteAVI does not support].
Requires prev post script function [minus any calling code, as GetSeq.avsi in plugins], RT_Stats, TWriteAVI.
Load src, do some processing, write to AVI lossless file, make an awful noise when completed.
#ASYNTHER BATCH-AVI_WRITER
FN="___FILE___"         # AvisynthesizerMod BATCH mode usage.
OUTPATH = "D:\OUTPUT\"  # Must exist, include Trailing backslash
FOURCC  = "ULY0"        # Ut_Video, YUV 420 TV Levels I think
FN=RT_GetFullPathName(FN)
OUTFN = OUTPATH + RT_FilenameSplit(FN,4) + ".AVI"     # 4 = Name node only (no drive/path/extension)
GetSeq(FN)             # source
########## DO PROCESSING Of SOME SORT ###
# Import("D:\MYSTUFF\GENERIC_PROC_1.avs")             # Generic pre-process script (Affect all template expanded scripts [even already existing ones] with single GENERIC_PROC script edit)
#Sharpen(0.3)                                         # Whatever
# Import("D:\MYSTUFF\GENERIC_PROC_2.avs")             # generic post-process script
########## END OF PROCESSING ############
#return last                                          # Comment OUT for final
TWriteAVI(OUTFN,Overwrite=true,fourcc=FOURCC)         # Write Sharp AVI whilst clip is played
#return Last                                          # Write File as you play
ForceProcessAVI()                                     # Force Write above TWriteAVI file without playing clip.
Return Colorbars.Subtitle("ALL DONE\nWritten:- "+RT_FilenameSplit(OUTFN,12),size=48,align=5,lsp=0)   # Complete with nice TONE as user attention getter. (12=Name + extension)
### TWRITEAVI - NOT FOR MT USE ###
###         x86 ONLY           ###
###  x64 Requires Asm progger  ###
Old 25th July 2019, 14:46   #12  |  Link
GillesH
Hello StainlessS,
I use GetSeq and it works fine. Thank you for this very effective function.
But, for FFMS2, I would like to put the .ffindex file in a directory other than that of the Clip.
Is it possible to modify GetSeq to have this possibility ?
GillesH is offline   Reply With Quote
Old 25th July 2019, 16:18   #13  |  Link
Wanna try this [Can add Global string def to some avsi to auto set to temp directory, or whatever].
LSMash and AVI sources do not support Cachefile thing.
# GetSeq.avsi
#Global GLB_FFMS_CACHE_DIR = ".\OUT"
#Global GLB_FFMS_CACHE_DIR = RT_GetSystemEnv("TEMP")        # Write FFMS index's to User's Temp directory
Function GetSeq(String vFn,String "aFn",Val "fpsNum",Val "fpsDen") {
    Req:- RT_Stats, FFMS, LSmash.
    Specify FrameRate using fpsnum (Numerator) and fpsden (Denominator)    # *** INGNORED if AVI ***
        num only,  eg fpsnum=25.0,               FrameRate = 25.0  FPS
        num & den, eg fpsnum=24000 fpsden=1001,  FrameRate = 23.976 FPS (Both should be type Int).
        neither specified                        FrameRate = UnDefined, ie whatever source filter thinks it is.
        ALWAYS:- use named args if using fpsnum/fpsden, argument order may change.
    FFMS Cachefile (used for .ffindex file) directory can be set using global variable GLB_FFMS_CACHE_DIR, NO trailing backslash.
        eg, Global GLB_FFMS_CACHE_DIR = "Z:\MyFFMSCacheDir".
    Assert(vFn!="",RT_String("%svFn Cannot be ''",myName))      vFn = vFn.RT_GetFullPathName    IsRiffV = vFn.IsRiffFileName    IsIsoV = vFn.IsISOFileName
    c=0 a=0
    def = fpsnum.Defined ? (fpsden.Defined ?1:0) : (!fpsden.Defined) ? 2 : -1    # 0=NumOnlyDef, 1=BothDef, 2=NoneDef, -1=DenOnlyError
    Assert(0<=def,myName+"Cannot specify framerate using fpsden only")
    #              Rate=num            :  Rate=num/den             : Rate=Undefined
    num=(def==0) ? Round(fpsnum * 1000): (def==1) ?    Int(fpsnum) : RT_Undefined
    den=(def==0) ?                1000 : (def==1) ?    fpsden      : RT_Undefined
    Try {
    Try {
        c = (IsIsoV)                       ? LSMASHVideoSource(vFn,fpsnum=num,fpsden=den)                          : c
    Try {
     # Next try FFMS2
    CacheFile = RT_Undefined
    Try {
        IsOpenV=(c.IsClip && c.HasVideo)    IsOpenA=(a.IsClip && a.HasAudio)
        if(RT_VarExist("GLB_FFMS_CACHE_DIR") && GLB_FFMS_CACHE_DIR.IsString && Exist(GLB_FFMS_CACHE_DIR) && vFn==aFn && !IsOpenV && !IsOpenA) {
            Cachefile = RT_GetFullPathName(GLB_FFMS_CACHE_DIR + "\" + RT_FilenameSplit(vFn,12) + ".ffindex")
            RT_DebugF("Set FFMS CacheFile = %s",CacheFile,name=myName)
    Try {
        (!IsOpenV)    ? FFIndex(vFn,cachefile=CacheFile)                                : NOP
        c=(!IsOpenV)  ? FFVideoSource(vFn,fpsnum=num,fpsden=den,cachefile=CacheFile)    : c
    Try {
        a=(!IsOpenA)  ? FFAudioSource(aFn,cachefile=CacheFile)                          : a
    Try {
        c = (!IsOpenV && !IsIsoV)          ? LWLibavVideoSource(vFn,fpsnum=num,fpsden=den)                         : c
    Try {
    return Last
# End of GetSeq.avsi
#GetSeq_Test.avs
FN="10Bit_Standard8_Scan_16FPS.avi"     # This 10 bit dont load with Avisource(), [and no audio]
#FN="ALTEST2.mp4"
#FN="heima_720p_500.mp4"
#FN="tears_of_steel_1080pwebm.webm"
Getseq(FN,fpsnum=33000,fpsden=1001)     # Test 33000/1001
Info
EDIT: Will only work where Video filename same as audio filename (which it usually would be [EDIT: When not supplied, is coerced to same as video filename]).
EDIT: Changed name a bit, to GLB_FFMS_CACHE_DIR due to lousy speelin.
16:29:54.129    InitExternalPlugins:
00000328    16:29:54.129    InitExternalPlugins: Auto load plugins script ENTRY
00000329    16:29:54.129    InitExternalPlugins:
00000330    16:29:54.129    InitExternalPlugins:ShowAvsInitInfo:
00000331    16:29:54.129    InitExternalPlugins:ShowAvsInitInfo: VersionString      = 'AviSynth+ 0.1 (r2900, MT, i386)'
00000332    16:29:54.129    InitExternalPlugins:ShowAvsInitInfo: Avisynth Bitness   = 32
00000333    16:29:54.129    InitExternalPlugins:ShowAvsInitInfo: ProcessName        = 'C:\Program Files (x86)\DAUM\PotPlayer\PotPlayerMini.exe'
00000334    16:29:54.129    InitExternalPlugins:ShowAvsInitInfo: OSVersionString    = 'Windows 7 (x64) Service Pack 1.0 (Build 7601)'
00000335    16:29:54.129    InitExternalPlugins:ShowAvsInitInfo: OSVersionNumber    = 6.100000
00000336    16:29:54.129    InitExternalPlugins:ShowAvsInitInfo: CPUName            = 'Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz / Yorkfield (Core 2 Quad) 6M'
00000337    16:29:54.129    InitExternalPlugins:ShowAvsInitInfo: Cores              = 04:04 (Phy:Log)
00000338    16:29:54.129    InitExternalPlugins:ShowAvsInitInfo: CPU Extensions     = 'MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1'
00000339    16:29:54.129    InitExternalPlugins:ShowAvsInitInfo: Total Memory       = 12221MB
00000340    16:29:54.129    InitExternalPlugins:ShowAvsInitInfo: Avail Memory       = 9837MB'
00000341    16:29:54.129    InitExternalPlugins:ShowAvsInitInfo: Screen Res         = 1920x1080
00000342    16:29:54.129    InitExternalPlugins:ShowAvsInitInfo: Screen BitPerPixel = 32
00000343    16:29:54.129    InitExternalPlugins:ShowAvsInitInfo: Time               = 'Thursday 25 July 2019 16:29:54[GMT Daylight Time]'
00000344    16:29:54.129    InitExternalPlugins:ShowAvsInitInfo:
00000345    16:29:54.129    InitExternalPlugins:AvsInit_Load_CPP_Plugin: DGDecode.DLL                     LOADED   OK
00000346    16:29:54.129    InitExternalPlugins:AvsInit_Load_C_Plugin:   ffms2.dll                        LOADED   OK
00000347    16:29:54.129    InitExternalPlugins:AvsInit_Import_Avsi:     ffms2.avsi                       IMPORTED OK
00000348    16:29:54.129    InitExternalPlugins:AvsInit_Load_CPP_Plugin: LSMASHSource.dll                 LOADED   OK
00000349    16:29:54.269    GetSeq: Catch: AVISource: couldn't locate a decompressor for fourcc v210
00000350    16:29:54.269    GetSeq: (D:\GetSeq_Test\GetSeq_Test.avs, line 30)
00000351    16:29:54.472    GetSeq: Set FFMS CacheFile = D:\GetSeq_Test\OUT\10Bit_Standard8_Scan_16FPS.avi.ffindex
00000352    16:29:54.535    GetSeq: FFVideoSource opened Video
00000353    16:29:54.535    GetSeq:   'D:\GetSeq_Test\10Bit_Standard8_Scan_16FPS.avi'
00000354    16:29:54.550    GetSeq: Catch: FFAudioSource: No audio track found
00000355    16:29:54.550    GetSeq: (D:\GetSeq_Test\GetSeq_Test.avs, line 67)
00000356    16:29:54.550    GetSeq: Catch: LWLibavAudioSource: failed to get the audio track.
00000357    16:29:54.550    GetSeq: (D:\GetSeq_Test\GetSeq_Test.avs, line 79)
00000358    16:29:54.550    GetSeq: Audio failed Open on
00000359    16:29:54.550    GetSeq:   'D:\GetSeq_Test\10Bit_Standard8_Scan_16FPS.avi
Above file has no audio.
EDIT: Oops, had left "String CacheDir" as an arg to function, removed.
Old 25th July 2019, 17:07   #14  |  Link
GillesH
Great, StainlessS.
It works very well. The ffindex file is well transmitted in the directory that we wish.
This allows to have the clean video library.
You are a champion of reactivity and efficiency.
Old 25th July 2019, 17:16   #15  |  Link
See 1st bit in blue.
Could use Stickboy GetSystemEnv to get user specific TEMP directory, and set it to that.
Dont seem to be x64 version of GetSystemEnv, I do one.
EDIT:
# GetSeq.avsi
#Global GLB_FFMS_CACHE_DIR = ".\OUT" # Would require current directory relative folder called OUT, useful only really in avs not avsi
00000049    17:55:46.582    GetSeq: Catch: AVISource: couldn't locate a decompressor for fourcc v210
00000050    17:55:46.582    GetSeq: (C:/VideoTools/AvisynthRepository/AVSPLUS_x86/plugins/GetSeq.avsi, line 34)
00000051    17:55:46.629    GetSeq: Set FFMS CacheFile = C:\Users\root\AppData\Local\Temp\10Bit_Standard8_Scan_16FPS.avi.ffindex
00000052    17:55:51.028    GetSeq: FFVideoSource opened Video
00000053    17:55:51.028    GetSeq:   'D:\GetSeq_Test\10Bit_Standard8_Scan_16FPS.avi'
00000054    17:55:51.044    GetSeq: Catch: FFAudioSource: No audio track found
00000055    17:55:51.044    GetSeq: (C:/VideoTools/AvisynthRepository/AVSPLUS_x86/plugins/GetSeq.avsi, line 71)
00000056    17:55:51.044    GetSeq: Catch: LWLibavAudioSource: failed to get the audio track.
00000057    17:55:51.044    GetSeq: (C:/VideoTools/AvisynthRepository/AVSPLUS_x86/plugins/GetSeq.avsi, line 83)
00000058    17:55:51.044    GetSeq: Audio failed Open on
00000059    17:55:51.044    GetSeq:   'D:\GetSeq_Test\10Bit_Standard8_Scan_16FPS.avi
EDIT: I forgot, RT_Stats has already RT_GetSystemEnv().
Old 26th July 2019, 00:14   #16  |  Link
Update to GetSeq(), Needs a good tester
# GetSeq.avsi
#Global GLB_GETSEQ_FFMS_CACHE_DIR       =   RT_GetSystemEnv("TEMP")  # Set to the Current User's Temp directory.
#Global GLB_GETSEQ_DEL_INDEX_ON_CLOSE   =   True                     # If CallCmd() available, then auto delete index's on clip closure.  [FFMS or LSMASH]
    Req:- RT_Stats, FFMS, LSmash.  [Also CallCmd if auto delete of FFMS and LSMash indexes required]
    FFMS Cachefile (used for .ffindex file) directory can be set using global variable GLB_GETSEQ_FFMS_CACHE_DIR, NO trailing backslash.
    If CallCmd() dll is avalable, and  Global variable GLB_GETSEQ_DEL_INDEX_ON_CLOSE is True, then will auto Delete both FFMS and LSMash indexes on clip closure.
        Global GLB_GETSEQ_DEL_INDEX_ON_CLOSE = True    # If CallCmd available then Auto delete indexes on clip closure. # Could create stub which sets True/False depending upon your own arg.
    HasCallCmd = RT_FunctionExist("CallCmd")
    c=0 a=0
    CacheFile = ""  FFMS_Index_file = ""    LSMASH_Index_file=""
    msgNL = Chr(10)+"   "
        (c.IsClip)                               ? RT_DebugF("OK ... AviSource opened Video\n  '%s'",vFn,name=myName)                                                : NOP
    } catch (msg) { RT_DebugF("*** Catch *** %s",RT_StrReplace(msg,Chr(10),msgNL),name=myName) }
    Try {
        (a.IsClip && a.HasAudio)                 ? RT_DebugF("OK ... %s opened Audio\n  '%s'",(c.IsClip && c.HasAudio && aFn==vFn)?"AviSource":"WavSource",aFn,name=myName) : NOP
    } catch (msg) { RT_DebugF("*** Catch *** : %s",RT_StrReplace(msg,Chr(10),msgNL),name=myName) }
    Try {
        (IsIsoV)                           ? RT_DebugF("OK ... LSMASHVideoSource opened Video\n  '%s'",vFn,name=myName)   : NOP
    Try {
        (IsIsoA)                           ? RT_DebugF("OK ... LSMASHAudioSource opened Audio\n  '%s'",aFn,name=myName)   : NOP
     # Next try FFMS2
    Try {
        IsSetCache = (!IsOpenV && !IsOpenA && vFn==aFn && RT_VarExist("GLB_GETSEQ_FFMS_CACHE_DIR") && GLB_GETSEQ_FFMS_CACHE_DIR.IsString && Exist(GLB_GETSEQ_FFMS_CACHE_DIR))
        Cachefile = (IsSetCache) ? RT_GetFullPathName(GLB_GETSEQ_FFMS_CACHE_DIR + "\" + RT_FilenameSplit(vFn,12) + ".ffindex") : Cachefile
        (IsSetCache) ? RT_DebugF("!!! Set !!! ... FFMS CacheFile = %s",CacheFile,name=myName) : NOP
    Try {
        FFMS_Index_file = (!IsOpenV && CacheFile=="") ? vFn + ".ffindex" : CacheFile                               # May create Index on fail (so rem before we try)
        (!IsOpenV)    ? FFIndex(vFn,cachefile=CacheFile==""?RT_Undefined:CacheFile)                             : NOP
        c=(!IsOpenV)  ? FFVideoSource(vFn,fpsnum=num,fpsden=den,cachefile=CacheFile==""?RT_Undefined:CacheFile) : c
        (!IsOpenV)    ? RT_DebugF("OK ... FFVideoSource opened Video\n  '%s'",vFn,name=myName)                  : NOP
    Try {
        FFMS_Index_file = (FFMS_Index_file!="") ? FFMS_Index_file :  (!IsOpenA && CacheFile=="") ? aFn + ".ffindex" : CacheFile    # May create Index on fail (so rem before we try)
        a=(!IsOpenA)  ? FFAudioSource(aFn,cachefile=CacheFile==""?RT_Undefined:CacheFile)      : a
        (!IsOpenA)    ? RT_DebugF("OK ... FFAudioSource opened Audio\n  '%s'",aFn,name=myName) : NOP
    # Next try LSmash non ISO Video : Try even if have tried ISO Open
    Try {
        LSMASH_Index_file = (!IsOpenV) ? vFn + ".lwi" : LSMASH_Index_file                                      # May create Index on fail (so rem before we try)
        c = (!IsOpenV)                 ? LWLibavVideoSource(vFn,fpsnum=num,fpsden=den)                         : c
        (!IsOpenV)                     ? RT_DebugF("OK ... LWLibavVideoSource opened Video\n  '%s'",vFn,name=myName)  : NOP
    Try {
        LSMASH_Index_file = (LSMASH_Index_file!="") ? LSMASH_Index_file : (!IsOpenA) ? aFn + ".lwi" : ""        # May create Index on fail (so rem before we try)
        a = (!IsOpenA)                 ? LWLibavAudioSource(aFn)                                                       : a
        (!IsOpenA)                     ? RT_DebugF("OK ... LWLibavAudioSource opened Audio\n  '%s'",aFn,name=myName)   : NOP
    Assert(c.IsClip, RT_String("!!! %s failed open on\n  '%s'",myName,vFn))
    (!HasAudio) ? RT_DebugF("!!! Audio failed Open on\n  '%s",aFn,name=myName)                                         : NOP
    AutoDEL = (HasCallCmd && RT_VarExist("GLB_GETSEQ_DEL_INDEX_ON_CLOSE") && GLB_GETSEQ_DEL_INDEX_ON_CLOSE)
    Try {
        (AutoDEL && FFMS_Index_file!="" && Exist(FFMS_Index_file))
            \ ? CallCmd(close="CMD /C chcp 1252 && del " + RT_QuoteStr(FFMS_Index_file),   hide=true, debug=true, Synchronous=7)
            \ : last
    Try {
        (AutoDEL && LSMASH_Index_file!="" && Exist(LSMASH_Index_file))
            \ ? CallCmd(close="CMD /C chcp 1252 && del " + RT_QuoteStr(LSMASH_Index_file), hide=true, debug=true, Synchronous=7)
            \ : last
    return Last
# END OF GetSeq.avsi
Global GLB_GETSEQ_FFMS_CACHE_DIR       = ".\OUT OUT"          # Where FFMS index are written (Test SPACE in filename, and current path relative)
Global GLB_GETSEQ_DEL_INDEX_ON_CLOSE   = True                 # Auto Delete indexes where CallCmd() is available.  [FFMS or LSMASH]
#FN="D:\Parade.avi"
#FN="10Bit_Standard8_Scan_16FPS.avi"     # This 10 bit dont load with Avisource(), [and no audio]
#FN="ALTEST2.mp4"
Info
From DebugView [google]
00000062    23:53:27.307    GetSeq: !!! Set !!! ... FFMS CacheFile = D:\GetSeq_Test\OUT OUT\tears_of_steel_1080pwebm.webm.ffindex
00000063    23:53:30.442    GetSeq: OK ... FFVideoSource opened Video
00000064    23:53:30.442    GetSeq:   'D:\GetSeq_Test\tears_of_steel_1080pwebm.webm'
00000065    23:53:30.630    GetSeq: OK ... FFAudioSource opened Audio
00000066    23:53:30.630    GetSeq:   'D:\GetSeq_Test\tears_of_steel_1080pwebm.webm'
00000067    23:53:30.630    CallCmd: Constructor IN
00000068    23:53:30.630    CallCmd: CallCmd: v1.04 - 04 Apr 2018 - by StainlessS
00000069    23:53:30.630    CallCmd: Command for Frames = ''
00000070    23:53:30.630    CallCmd: Close Command (Destructor) = 'CMD /C chcp 1252 && del "D:\GetSeq_Test\OUT OUT\tears_of_steel_1080pwebm.webm.ffindex"'
00000071    23:53:30.630    CallCmd: FRAMES: About to Parse Frames String
00000072    23:53:30.630    CallCmd: Doing command on 0 Frames
00000073    23:53:30.630    CallCmd: Constructor OUT
00000074    23:53:33.192    CallCmd: Destructor IN
00000075    23:53:33.192    CallCmd: Close (Destructor) on command 'CMD /C chcp 1252 && del "D:\GetSeq_Test\OUT OUT\tears_of_steel_1080pwebm.webm.ffindex"'
00000076    23:53:33.259    CallCmd: SUCCESS Creating Process (WAIT)
00000077    23:53:33.259    CallCmd: WAIT, Process returned 0 (0x00000000)
00000078    23:53:33.259    CallCmd: Destructor OUT
EDIT: And on AVI where no decompressor available [on my system] and without audio. [both FFMS and LSMASH indexes created, and deleted {FFMS index re-directed to ".\OUT OUT"}]
00000016	00:38:13.788	GetSeq: *** Catch *** AVISource: couldn't locate a decompressor for fourcc v210
00000017	00:38:13.788	GetSeq:    (D:\GetSeq_Test\GetSeq_Test.avs, line 42)
00000018	00:38:13.834	GetSeq: !!! Set !!! ... FFMS CacheFile = D:\GetSeq_Test\OUT OUT\10Bit_Standard8_Scan_16FPS.avi.ffindex
00000019	00:38:18.000	GetSeq: OK ... FFVideoSource opened Video
00000020	00:38:18.000	GetSeq:   'D:\GetSeq_Test\10Bit_Standard8_Scan_16FPS.avi'
00000021	00:38:18.015	GetSeq: *** Catch *** : FFAudioSource: No audio track found
00000022	00:38:18.015	GetSeq:    (D:\GetSeq_Test\GetSeq_Test.avs, line 79)
00000023	00:38:18.889	GetSeq: *** Catch *** : LWLibavAudioSource: failed to get the audio track.
00000024	00:38:18.889	GetSeq:    (D:\GetSeq_Test\GetSeq_Test.avs, line 93)
00000025	00:38:18.889	GetSeq: !!! Audio failed Open on
00000026	00:38:18.889	GetSeq:   'D:\GetSeq_Test\10Bit_Standard8_Scan_16FPS.avi
00000027	00:38:18.889	CallCmd: Constructor IN
00000028	00:38:18.889	CallCmd: CallCmd: v1.04 - 04 Apr 2018 - by StainlessS
00000029	00:38:18.889	CallCmd: Command for Frames = ''
00000030	00:38:18.889	CallCmd: Close Command (Destructor) = 'CMD /C chcp 1252 && del "D:\GetSeq_Test\OUT OUT\10Bit_Standard8_Scan_16FPS.avi.ffindex"'
00000031	00:38:18.889	CallCmd: FRAMES: About to Parse Frames String
00000032	00:38:18.889	CallCmd: Doing command on 0 Frames
00000033	00:38:18.889	CallCmd: Constructor OUT
00000034	00:38:18.904	CallCmd: Constructor IN
00000035	00:38:18.904	CallCmd: CallCmd: v1.04 - 04 Apr 2018 - by StainlessS
00000036	00:38:18.904	CallCmd: Command for Frames = ''
00000037	00:38:18.904	CallCmd: Close Command (Destructor) = 'CMD /C chcp 1252 && del "D:\GetSeq_Test\10Bit_Standard8_Scan_16FPS.avi.lwi"'
00000038	00:38:18.904	CallCmd: FRAMES: About to Parse Frames String
00000039	00:38:18.904	CallCmd: Doing command on 0 Frames
00000040	00:38:18.904	CallCmd: Constructor OUT
00000041	00:38:21.042	CallCmd: Destructor IN
00000042	00:38:21.042	CallCmd: Close (Destructor) on command 'CMD /C chcp 1252 && del "D:\GetSeq_Test\10Bit_Standard8_Scan_16FPS.avi.lwi"'
00000043	00:38:21.111	CallCmd: SUCCESS Creating Process (WAIT)
00000044	00:38:21.111	CallCmd: WAIT, Process returned 0 (0x00000000)
00000045	00:38:21.111	CallCmd: Destructor OUT
00000046	00:38:21.111	CallCmd: Destructor IN
00000047	00:38:21.111	CallCmd: Close (Destructor) on command 'CMD /C chcp 1252 && del "D:\GetSeq_Test\OUT OUT\10Bit_Standard8_Scan_16FPS.avi.ffindex"'
00000048	00:38:21.178	CallCmd: SUCCESS Creating Process (WAIT)
00000049	00:38:21.178	CallCmd: WAIT, Process returned 0 (0x00000000)
00000050	00:38:21.178	CallCmd: Destructor OUT
Old 26th July 2019, 08:49   #17  |  Link
GillesH
Tester, yes. Good : I do not know!
Your latest version of GetSeq works very well.
I tested, too, with CallCmd. And the index file is deleted when closing the Clip.
Tip: Provide an additional note in the script ---> # CallCmd.dll needed
I had never used this DLL and looked for what CallCmd() meant.
But the search gave me the solution.
Conclusion: I am not a good tester !
Old 26th July 2019, 11:51   #18  |  Link
hello_hello
A minor thought.... ffms2 and lsmash have a cache option. When set to false, no index file is written and I assume there'd be no need to check for one to delete. If the index file is being deleted automatically when the script closes anyway, it might be a good idea to include "cache" in GetSeq.
Old 26th July 2019, 13:48   #19  |  Link
Already added.
Unfortunately, in case where video opens in AVI, but no audio, will try open audio and index in both FFMS and LSmash (Non ISO) and so scan entire clip twice
only to find that it aint got no audio. [took a long long time on audioless Starwars PAL DVD in UT_Video avi].
HH,
Does the Cache=False option [for both] avoid creation of index AND curtail scanning, ie halt immediately where clip has no audio ?
Also, without index, are both flavours just as frame accurate (as with index) ?
Me knew this was gonna balloon in size.
Old 28th July 2019, 02:56   #20  |  Link
From prev post.
Added Mifo_Library (Included in 7z). Avoids unnecessary (perhaps multiple) scans for non existing audio.
Here:- http://www.mediafire.com/file/xrf6rd...190728.7z/file
Now Require, RT_Stats, FFMS, LSmash, CallCmd, MediaInfo CLI, (tested only with v0.7.83, probably ok with later).
EDIT: Hard to tell exactly how long it took without timer (Media player start up etc, I'll add one) but above mentioned StarWars took ~= 2 seconds with Mifo_Library,
whereas was more like half an hour or more without it (so a bit faster, sometimes).
EDIT: MIFO_Library(slight mod included in GetSeq zip):- https://forum.doom9.org/showthread.p...hlight=library
EDIT: I suspect that giving a cachefile="whatever" type thing may have produced a full scan even when it was unnecessary, maybe.
EDIT: Non AVS+ guys will have to GImport() [gimport from GScript] the AVSI's, either from an avsi in plugins, or from the client script.
EDIT: Looks like this now (NOW requires either AVS+, or GSCript which must GImport the .avsi files GetSeq.avsi, and MIFO_Library.avsi. [STUFF added since zip upload in RED]
# GetSeq.avsi
Global GLB_GETSEQ_DEL_INDEX_ON_CLOSE   =   True                     # If True then auto delete index's on clip closure.  [FFMS or LSMASH]
    Req:- RT_Stats, FFMS, LSmash. CallCmd, MediaInfo CLI v0.7.83+ (may work with later versions)
    If Global variable GLB_GETSEQ_DEL_INDEX_ON_CLOSE is True, then will auto Delete both FFMS and LSMash indexes on clip closure.
        Global GLB_GETSEQ_DEL_INDEX_ON_CLOSE = True    # If true, Auto delete indexes on clip closure. # Could create stub which sets True/False depending upon your own arg.
    Assert(RT_FunctionExist("MIFO_Version"),RT_String("%sWe require MIFO_Library",myName))
    Assert(RT_FunctionExist("CallCmd"),RT_String("%sCallCmd essential",myName))
    Start_T = RT_TimerHP()
    c=0 a=0
    msgNL = Chr(10)+"   "
    VideoCount = MI_VideoCount(vFn,Debug=true)                      # Number of Video Streams in vFn
    RT_DebugF("File has %d Video streams.  '%s'",VideoCount,vFn,name=myName)
    Assert(VideoCount>0,myName+"File has no video\n'vFN'")
    AudioCount = MI_AudioCount(aFn,Debug=true)                      # Number of Audio Streams in aFn
    RT_DebugF("File has %d Audio streams.  '%s'",AudioCount,aFn,name=myName)
    Try {
        if(AudioCount>0) {
    Try {
    Try {
        if(AudioCount>0) {
     # Next try FFMS2
    Try {
    Try {
    Try {
        if(AudioCount>0) {
    Try {
    Try {
        if(AudioCount>0) {
    if(AudioCount>0) {
        c = (!c.HasAudio && a.IsClip && a.HasAudio) ? AudioDubEx(c,a)     : c
        Assert(c.HasAudio,RT_String("%s!!! Audio failed Open on '%s'",myName,aFn))
    AutoDEL = (RT_VarExist("GLB_GETSEQ_DEL_INDEX_ON_CLOSE") && GLB_GETSEQ_DEL_INDEX_ON_CLOSE)
    Try {
        c = (AutoDEL && FFMS_Index_file!="" && Exist(FFMS_Index_file))
            \ ? c.CallCmd(close="CMD /C chcp 1252 && del " + RT_QuoteStr(FFMS_Index_file),   hide=true, debug=true, Synchronous=7)
            \ : c
    Try {
        c = (AutoDEL && LSMASH_Index_file!="" && Exist(LSMASH_Index_file))
            \ ? c.CallCmd(close="CMD /C chcp 1252 && del " + RT_QuoteStr(LSMASH_Index_file), hide=true, debug=true, Synchronous=7)
            \ : c
    T = RT_TimerHP() - Start_T
    RT_DebugF("Time taken to Open clip = %.6f Seconds(%.6f Mins)\n    '%s'",T,T/60.0,vFN,name=myName)
    return c
avisynthesizer
