Old 27th March 2011, 20:38   #1  |  Link
pio_fawad
How to Add watermark
hi,
is there any plugin to add text / watermark in video while encoding in Megui .
Without loss of quality ??
Please tell thanx
Regards
Pioneer
pio_fawad is offline   Reply With Quote
Old 28th March 2011, 05:18   #2  |  Link
manono
Just adding a watermark/logo results in a huge loss of quality. Don't do it. No one wants to see you deface a video like that. And since no one would even think of doing such a thing just for their own use, my guess is you're planning on distributing the movie (foolishly thinking that's going to keep someone else from stealing it), and therefore you're on the verge of a Rule 6 violation.
Old 28th March 2011, 11:40   #3  |  Link
pio_fawad
no man i am using for personal use not for distributing, Please tell
Old 28th March 2011, 11:53   #4  |  Link
Didée
Internal Avisynth filter:
Subtitle("This is my text-over-video!")
However, I strongly tend to
If you don't know how to add a watermark, then you don't need to add a watermark.
Old 28th March 2011, 12:00   #5  |  Link
pio_fawad
@didee thanx is there any way to select X Y dimension to place TEXT on Video
and change color of text thanx Didee
Old 28th March 2011, 12:19   #6  |  Link
manono
I don't believe you even for a second.
.is there any way to select X Y dimension to place TEXT on Video
You could always try reading the Subtitle page at AviSynth.org:
http://avisynth.org/mediawiki/Subtitle
Old 28th March 2011, 12:22   #7  |  Link
pio_fawad
thanx manono and Didée got it ,thanx
watermark
