Old 23rd August 2010, 20:31   #1  |  Link
Overdrive80
Anime addict
Overdrive80's Avatar
How convert video 30i to 120p
Hi, i like know how could convert hibryd material at 30i to 120p (fields for second). That should be a optional case if i dont want use matroska files.
One code could be:
DGDecode_mpeg2source("E:\Bleach\141.d2v", info=3)
Tdeint(mode=1)
Tdeint(mode=1)
I understand this metod up to frames numbers, but obtein a constant frame rate, dont it?
Thanks
Overdrive80 is offline   Reply With Quote
Old 25th August 2010, 02:08   #2  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
AFAIK, you should just convert to 60p, or keep it interlaced.
Two instances of TDeint(mode=1) won't do any good.
Derek
Old 25th August 2010, 06:39   #3  |  Link
Overdrive80
Anime addict
If I used some bobber based on interpolation of frames? I understand that not is good idea because tdeint duplicate frames, isnt it?
Old 25th August 2010, 07:39   #4  |  Link
MrVideo
MrVideo's Avatar
First off, 30i isn't 30 fields per second, but 30 frames per second.
Secondly, why are you wanting to go from 30 frames/sec interlaced to 120 frames/sec progressive? What are you hoping to achieve by doing that?
Old 25th August 2010, 12:52   #5  |  Link
Alex_ander
Alex_ander's Avatar
ChangeFPS(120)
in place of second TDeint would do the same duplication and slightly better.
No, the same as with second TDeint. But you could try MFlowFPS for 60->120fps interpolation after single TDeint.
Alex_ander is offline   Reply With Quote
Old 25th August 2010, 13:07   #6  |  Link
Didée
Guys ...
the question is not how to get 120fps. The question is WHY.
Reminder: Hybrid content, containing a mix of 24fps and 30fps. Does that ring a bell?
Now you can proceed with discussing.
Oh, BTW: keep in mind that CRTs are slowly disappearing (CRTs can handle 120fps - not all, but many), and 120Hz TFTs are quite new and not common yet.
Todays most typical desktop monitor is a 60Hz budget TFT that is unable to display 120Hz content.
Old 25th August 2010, 13:44   #7  |  Link
Overdrive80
Anime addict
@Dideé
Why? Because if i dont want use to matroska files, it is the only way to do good deinterlacing, isnt it?
I read post and post, and the mcm of 24 and 30 is 120. It is for this reason for which i like know as encoded at this constant framerate, with optimal result, from hibryd source.
Citing fields per second resulting video I referred to 120 fps (fields for second) after bobber deinterlaced.
If I am wrong on the technical basis, could you explain why, please?
Old 25th August 2010, 13:51   #8  |  Link
Didée
Thanks for explaining, but I already know the why's and how's. And also the whynot's and hownot's.
In a nutshell: you have to isolate the (telecined) 24 fps parts and the (interlaced) 60i parts, process them seperately (telecine parts: first IVTC, then make 3:3:3 pulldown // interlaced parts: bob deinterlace, then make 2:2 pulldown), and finally stitch everything together again.
Having accomplished this workflow, you have a 120fps clip that displays as intended on ancient CRT tubes and future 120Hz panels, but not on any typical 60Hz TFT of today.
Old 25th August 2010, 15:16   #9  |  Link
Overdrive80
Anime addict
LOL, then i understand bad ^^.
Ok, forgive me if I ask so much.
IVTC would be tfm() and Bobber (f.e.) McBob()
But when you say pulldown 3:3:3 and 2:2, i dont know how write it in code for script, maybe could help me, please? I have a thirst for knowledge
Old 25th August 2010, 16:03   #10  |  Link
Didée
Where did I have my brain, to write 3:3:3 pulldown? That's wrong, of course the 24fps parts need 5:5 pulldown to get 120fps.
For example, yes. Just that IVTC would be TFM().TDecimate(), and I for one would not use MCBob anymore.
But when you say pulldown ... i dont know how write it in code for script,
Okay, example. Let's assume a 30i source has FILM in frames [0,1000] and [4000,5000] and [8000,9000], all the rest is VIDEO.
source = whatever
# prepare the two different processings
vid24 = source.TFM().TDecimate()
vid60 = source.bob() # plenty of different bob filters are available, can't tell which one you prefer
# prepare frame pulldown
vid24_120 = vid24.selectevery(1, 1,1,1,1,1) # for every 1 frame, do output 5 times the same frame
vid60_120 = vid60.selectevery(1, 1,1) # for every 1 frame, do output 2 times the same frame
# splice together
vid24_120.trim(    0*4, 1000*4 + 3 ) ++ vid60_120.trim( 1001*4 , 4000*4 - 1 ) ++ \
vid24_120.trim( 4000*4, 5000*4 + 3 ) ++ vid60_120.trim( 5001*4 , 8000*4 - 1 ) ++ \
vid24_120.trim( 8000*4, 9000*4 + 3 ) ++ vid60_120.trim( 9001*4 ,    0       )
return(last)
Old 25th August 2010, 16:09   #11  |  Link
Overdrive80
Anime addict
WOW its wonderfull, thanks you very much. I go to test it and more or less, i understand the code althought im not programmer.
Old 25th August 2010, 16:15   #12  |  Link
Didée
There's a stupid mistake in it - the base framerate is 30fps, hence the factor is "4" (120/30), not "5". I'm editing the script right now.
Edit: Done.
Old 25th August 2010, 18:47   #13  |  Link
Overdrive80
Anime addict
I test two codes for separated
First
DGDecode_mpeg2source("E:\DB_1\Opening\NF\ope.d2v", info=3)+\
DGDecode_mpeg2source("E:\DB_7\41\41.d2v", info=3)
ColorMatrix(hints=true, interlaced=true, threads=0)
source=last
vid24_120
Framecount indicates 177225
Second
source=last
vid60_120
Framecount indicates 177230
Dont should framecount be the same in both cases?
Old 25th August 2010, 20:45   #14  |  Link
Didée
Not necessarily. The *exact* number of total framecount after IVTC is a dice game. IVTC makes 4 output frames out of 5 input frames. If you have an input stream of 50 frames, the output (should) be 40 frames. But what if your input stream is 49 or 48 frames, or 51 or 52?
The exact number depends on the length of the input, on how the pattern is distributed, on how the decimator is making decisions, and so on. There is definetly an uncertainty of +/-1 frame, and even +/-2 frames would not be a surprise. And since the IVTC'ed frames are 5-folded (to make 24fps->120fps), you can easily get a difference of 5 frames, or maybe even 10 frames, in the total frame count.
Old 25th August 2010, 21:10   #15  |  Link
Overdrive80
Anime addict
Ok thanks
Old 26th August 2010, 05:20   #16  |  Link
MrVideo
MrVideo's Avatar
I'm a little confused, since MPEG video wrappers (TS, MP4, MKV), AFAIK, do not allow mixed frame rates. You can have multiple source files where they can have different frame rates, but not different frame rates in a single source file.
Progressive video does not have fields, only complete frames. Interlaced video is the only type that has fields. You do not care if the source of the progressive video was interlaced or not, the description is always based on the video format at hand. In this case, the video at hand is 120p, which is only available in frames per second.
BTW, the video rates are really 23.976, 29.97, 59.94 and 119.88, not 24, 30, 60 or 120. You can thank our idiot FCC for causing that problem way back when color TV was standardized all those many years ago.
Old 26th August 2010, 11:28   #17  |  Link
Overdrive80
Anime addict
Yes, you are saying correctly all. But hibryd material have different part of material encoded as interlaced. Someone could be identify as FILM and others as VIDEO.
Ok, yes only have frames. But the fields in each frame are used for the reconstruction of duplicaded frames; for this reason i said it.
Yeah, i did know it. Is the way of talking
24000/1001=23.976..
30000/1001=29.970..
60000/1001=59.970..
120000/10001=119.88..
Bye
Old 26th August 2010, 18:45   #18  |  Link
MrVideo
MrVideo's Avatar
I've never heard anyone call that hybrid before. Even if you bump everything up to 119.88, the 23.976 source material is still going to be effectively 23.976 frames per second and the 29.97 source material is still going to effectively be 29.97 frames per second. Just what are you trying to accomplish going to 119.88p? Other than getting a frame rate that pretty much can't be played anywhere.
It is still a wrong description of progressive video. Once you have progressive video, you do not have fields anymore. Forget what kind of video was used to create it. So that EVERYONE understands you correctly, you need to use the correct terms.
The same thing applies when I take 1080i29.97 video that is sourced from 1080p23.976 and convert it back to 1080p23.976 using AVISynth tools. The result, even though it came from interlaced video, having fields, the result is now progressive and is frames only. The correct terms MUST be used according to the video material type.
Old 26th August 2010, 19:00   #19  |  Link
Overdrive80
Anime addict
Well If I am wrong, when they refer to hybrid material, is that video that has parts telecined and other purely interlaced. Both parts have the same frame rate, but have been so interlaced different.
Get a constant frame rate that is multiple of both for not using VFR.
There are Japanese video at these rates, which may be actually encoded videos at 120 fps using a video capture with that option
Sure that i didnt explained correctly. I know that when a video is progressive never has fields because only appears in interlaced video. In all time, I was referring to the process of moving interlaced video to progressive, using the reconstruction of fields.
Old 28th August 2010, 17:21   #20  |  Link
Wilbert
MP4 and MKV (not sure about TS) don't use a constant frame rate. Look up timecodes.
If you want to create a 120 (frames) fps avi you need to add drop frames: http://avisynth.org/mediawiki/VFR#en..._cfr_-_120_fps (instead of encoding all the 120 frames).
