Old 30th October 2011, 10:43   #21  |  Link
forclip
Originally Posted by IanB View Post
1. Avss.cpp
So you have the sources for this plugin?
forclip is offline   Reply With Quote
Old 30th October 2011, 16:14   #22  |  Link
mandarinka
mandarinka's Avatar
Dss2 uses the frame grab feature of Haali's directshow renderer.
So you need that as a minimum.
It is does not normally include itself in default graphs.
Sorry for being paranoid, but I have to ask, since Haali's renderer only supports yuy2 and rgb32 input.
Does dss2 keep the decoded video data in yv12 colorspace, or does it in fact force a colorspace conversion? I don't think the latter is likely to be the case, but I'd like to get a confirmation, if someone can give one!
mandarinka is offline   Reply With Quote
Old 30th October 2011, 22:07   #23  |  Link
IanB
Avisynth Developer
No, I only have some of the source.
IanB is offline   Reply With Quote
Old 31st October 2011, 14:20   #24  |  Link
TheRyuu
warpsharpened
It seems the avss source package that I have contains the fix mentioned by IanB so perhaps it was updated at somepoint.
Build: avss.7z
Source: avss-src.7z
TheRyuu is offline   Reply With Quote
Old 31st October 2011, 17:52   #25  |  Link
forclip
Originally Posted by TheRyuu View Post
Build: avss.7z
Source: avss-src.7z
Thanks! Unfortunately, I still can`t open my "C:\файл.mkv", so I think that avss.dll that I had before was already "fixed". May be this issue is similar to this one:
Originally Posted by TheFluff
DirectShow probably expects Unicode strings only and FFMS2 isn't converting them before passing them to the splitter or something.
Old 31st October 2011, 21:49   #26  |  Link
IanB
Avisynth Developer
Build: avss.7z
Source: avss-src.7z
Huh! This source still uses CP_OEMCP (Dosbox code page) instead of CP_ACP (Windows code page).
To test this theory, create the .AVS in something using the OEM code page like Edit under Cmd.exe.
Also thanks TheRyuu for the full source code
Old 1st November 2011, 18:21   #27  |  Link
forclip
Replaced, and it did the trick!
Old 2nd November 2011, 03:51   #28  |  Link
TheRyuu
warpsharpened
For some reason I thought you hilighted it because it was what changed in your original post. I didn't see the correlation between 1 and 2, brainfart.
Old 10th November 2014, 11:40   #29  |  Link
qwerty1983
Does this source filter convert my YV12 videos to YUY2? Can i avoid that?
Ok, i found the solution
qwerty1983 is offline   Reply With Quote
Old 10th November 2014, 14:39   #30  |  Link
TheFluff
Excessively jovial fellow
not in and of itself, no
Can i avoid that?
depends on your dshow environment
Old 10th November 2014, 19:12   #31  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
It's a DirectShow-based source filter, so it probably returns whatever color format is returned from DirectShow Filter-Graph.
What DirectShow Decoder-Filter do you use? If it's something like FFdshow or LAVFilters, you should have a look at the "Output Formats" box in the decoder configuration...
https://azurehakua.files.wordpress.c...o-decoder1.png
Old 10th November 2014, 22:13   #32  |  Link
qwerty1983
On the video decoder configuration (ffdshow) 'primary output color space' is set to auto. Even if i change it to YV12 the problem persists. I don't have LAVfilters. I'm not familiar with this stuff (directshow, vfw etc).
EDIT
I found the solution.
I went to Haali media splitter settings and changed the 'used custom media type for H264' from no to yes.
Old 10th November 2014, 22:40   #33  |  Link
forclip
DSS2mod
I think it is never too late, so here is my modded version of DSS2. README.txt - please read this first to avoid unnecessary questions.
Main changes:
1. Fixed codepage issue (see previous messages in this thread).
2. Doesn't hangs at the end of the stream (see previous messages in this thread).
3. Doesn't requires Haali Media Splitter.
4. Can load and use LAVFilters in "portable" mode with ConnectDirect-way of building the Graph.
5. Added "preroll" for more precise seeking (very nice thing for badly-seeking sources). By default preroll=0 (disabled), but I recommend you to set it to something meaningfull.
6. Added "pixel_type" (string) - allowed colorspace (YV12, YUY2, RGB24, RGB32 or RGB - only one of them; or "" for all), it seems I forgot to mention this key in README
7. Some other things.
Examples:
DSS2("D:\file.mkv", fps=23.976)
- works almost the same way as the original DSS2 does.
DSS2("D:\file.mkv", fps=23.976, preroll=15, lavs="L3", lavd="L3")
- uses preroll and LAVFilters with ConnectDirect. You can write whatever you want instead of "L3" (which is "l3", which is default loading mode), but not leave it empty, because only non-empty string is a "ON"-switcher for this mode.
DSS2("D:\file.mkv", fps=23.976, preroll=15, lavs="L3", lavd="L3 hm1 hc5")
- the same as above, but LAVVideo is configured to use CUDA (hm1) for H264 and MPEG2 (hc5, 5=1+4).
DSS2 mod (2.0.0.13) + LAVFilters (0.63.0)
SVN-src
P.S. avss_26.dll (for AviSynth 2.6) does NOT support any additional colorspaces of AviSynth 2.6! And I don't have enough skills to implement it by myself, so patches are welcome. The same for audio support
Old 10th November 2014, 22:40   #34  |  Link
LoRd_MuldeR
Software Developer
Why not simply use FFmpegSource then?
Handles pretty much everything "out of the box" and doesn't need any external decoders/splitters (i.e. no DirectShow-dependencies, no VFW-dependencies).
Old 10th November 2014, 23:25   #35  |  Link
qwerty1983
@forclip Than you, i'll try this.
@LoRd_MuldeR Because i have some clips (like the one i posted here) that only load flawlessly (with no blocks and back-and-forth movement) with dss2 (i have tried AVCsource, LWLibavVideoSource, FFVideoSource)
Old 11th November 2014, 00:56   #36  |  Link
buchanan
@forclip : I use your modded DSS2 very often and find it very convinient, especially the preroll, thank you for that.
Could you please provide a 64 bit version of your plugin ? I intend to use it with 64bit Avisynth+
buchanan is offline   Reply With Quote
Old 11th November 2014, 17:14   #37  |  Link
forclip
Firstly I must set up DirectShow-related build environment on my new PC, because currently I can build DSS2 only on my old PC and only as 32-bit. After that at least I can try And of course I don't mind if someone else will make his own build meantime.
Meantime, here it is (AviSynth+ x64), for testing purposes..
Old 11th November 2014, 18:36   #38  |  Link
manolito
manolito's Avatar
I want to take the opportunity to say thank you to forclip...
I have been using DSS2Mod for quite some time now (together with LAV Filters), and I find it very reliable - more than ffms2.
What would be a "meaningful" value in your opinion? I remember reading somewhere that the value should be at least twice the frame rate of the source. I tried that, but this setting really slows down the HCenc 1-pass mode (not the actual encoding run, but the first sample run where a lot of seeking is involved).
Cheers
manolito
Old 11th November 2014, 21:28   #39  |  Link
forclip
I don't know how it can be related to fps, I would say it is more related to key frames interval. As long as your file+splitter+decoder can be seeked fine (without frozen frames or artifacts) you don't need to raise this value too much. In other case you must find your own "meaningful" value. Just perform some random seeks (in AvsP, for example) and see frame-by-frame what's going on after each one. Increase this value if the result is incorrect. And keep trying..
Old 13th November 2014, 03:01   #40  |  Link
GMJCZP
GMJCZP's Avatar
Thanks for the plugin forclip, I will try it.
GMJCZP is offline   Reply With Quote
