Old 9th March 2022, 15:02   #1061  |  Link
Lowpro
Originally Posted by pel9 View Post
I'm working on v0.52 and I need a lot of different menu structure to test it.
It would be a big help if anyone could send me the saved IG streams of different BD titles as .mnu files.
The most usable (diverse) collections will be rewarded with the new version of BDedit.
Thanks in advance for your contribution.
Most excellent! I'll be happy to send a few .mnu files your way.
Old 9th March 2022, 21:14   #1062  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
If I want to load any BD's menu .m2ts via Menu -> Load -> Extension Dropdown -> select .m2ts
after quick reading of stream packets I get "Stream read error" for all of them ? What do I do wrong ?
Ah, found Post #235:
Originally Posted by laserfan
Hmmm all I see under Menu tab is "Not loaded". How does one see any menu data..?
Answer by pel:
It shows an IG stream, so you have to find one on the CLIPINF tabsheet and use the '->' button to load to the Menu.
So all one has to do is scroll through the clpis, watch where the button "-> Menu" becomes ungrayed, and load this.
Ah, and loading the same stream via .m2ts into Menu tab indeed works !
All good here for 2 of 7 BDs.
The other BD's menus, containing some good candidates of "Main/Sub TS for Time based slideshows" are still unavailable.
Just checked: these are the JAVA discs, so no wonder... I hadn't thought that I had the majority of them.
Worth writing a guide, I think.
By someone who uses it more than I do, obviously ;-)
Lowpro ?
"Data reduction ? Yep, Sir. We're working on that issue. Synce invntoin uf lingöage..."
Old 10th March 2022, 13:36   #1063  |  Link
AVX
Sent some .mnu files via mail
AVX is offline   Reply With Quote
Old 19th March 2022, 17:22   #1064  |  Link
musiclover
Strange behaviour BDedit
I have a problem with changing the playlist OUT time on blurays using BDedit. When I set the edit mode and I click on the OUT time the numbers disapear. After I then fill in the numbers the length column gives a false number that can not be adjusted. To show you this behaviour I have made a few screen shots. This happens only on my laptop but with ALL blurays. On my desktop BDedit is working as it's supposed to.
Does anyone see this on his/her pc too?
Has anybody an idea what is going on and how to remedy this?
musiclover is offline   Reply With Quote
Old 29th April 2022, 13:16   #1065  |  Link
Emulgator
Emulgator's Avatar
Your pictures are still not approved, but a remote guess:
In the past I happened to see local update faults of desktop screens regarding small input pane areas differing with software, differing with systems.
A certain window of TheBat! "Menü Navigator" shone through other appliations
(with The Bat 5 (7 too ?.. forgot) on my Win7U64, no longer with TheBat! 9 on Win10Pro64).
You may try to switch Aero/non-Aero, compare graphics drivers etc.
Old 1st May 2022, 16:57   #1066  |  Link
mariner
Greetings pel9, thanks for the great work on BDedit.
Would you have any insight into what could be causing this?
mariner is offline   Reply With Quote
Old 1st May 2022, 21:36   #1067  |  Link
alexflin
I've been using the last version to try to add UHD videos into a Bluray UHD with menus created with DVDFab, it worked but the HDR is lost. There's any way to solve this problem? If I play the m2ts directly from the USB port of the Bluray player the HDR is working
alexflin is offline   Reply With Quote
Old 8th May 2022, 11:30   #1068  |  Link
POFFO
Hi Pel9,
noticed than when editing the PGs for a BD3D there is no change in the STN_Table_SS. This impact the link between PGs and respective 3D-plane numbers.
Was wondering it might be possible to implement such change so to generate a compliant mpls.
In my case I add some subtitle stream so would be convenient for me to find in the STN_Table_SS, for each new subtitles, a pre-set additional 0x FF 00. I can then change FF myself.
Changes should be the following, i/ Length of ExtensionData, ii/ Length of the STN_Table_SS, iii/ Starting point of the SubPath_entries_extension , iv/ remaining Length of the STN_Table_SS within the STN_Table_SS itself – sofar in all cases 2bytes per PG –, v/ include 0x FF 00 per PG (byte #23 of the STN_Table_SS onwards)
Hope t is possible and thanks beforehand in any case.
POFFO
POFFO is offline   Reply With Quote
Old 6th July 2022, 14:20   #1069  |  Link
tormento
Acid fr0g
tormento's Avatar
Is there any alternative to the original project?
@turment on Telegram
Old 27th July 2022, 05:34   #1070  |  Link
outgoing
I am not up to date, what has happened to Pelican's project, if not what are you looking for an alternative software to him?
outgoing is offline   Reply With Quote
Old 31st July 2022, 12:09   #1071  |  Link
pel9
You can just send (instead of donate) money to my email. It works.
The development will continue soon as I'll have more time.
I would like to thank all contributors especially Lowpro who helped a lot to improve the Menu tab.
pel9 is offline   Reply With Quote
Old 31st July 2022, 18:10   #1072  |  Link
outgoing
The development will continue soon as I'll have more time...
Glad to see you back here again and that you are still motivated and willing to take an interest in the development of the project. Keep up the good work!!
Old 29th August 2022, 09:35   #1073  |  Link
zhouting
I Use Yuhan UHD Creator : (https://yuhanmedia.com/), it can Create UHD with Menu, but bdedit can't load.
zhouting is offline   Reply With Quote
Old 30th August 2022, 10:30   #1074  |  Link
pel9
Could you send a sample BD structure (without the streams) you built to check?
Old 18th September 2022, 13:27   #1075  |  Link
Gundam
I'm new to BDEdit and it seems I'm having trouble with something that should be fairly straightforward; combining two playlist files.
I have a Blu-ray in which the movie is split over two MPLS playlist files, each one pointing to a different M2TS video file. Together the two M2TS files make up the whole film. To play the entire film, the player plays the first playlists and then loads and plays the second. There is a small pause as the second MPLS loads, which slightly alters the duration of the film.
How do I use BDEdit to combine the two playlists?
Gundam is offline   Reply With Quote
Old 27th November 2022, 19:29   #1076  |  Link
shearer69
Hi I haven't received link for latest version shearer69@sky.com I sent donation yesterday
shearer69 is offline   Reply With Quote
bd menu, bdedit, blu-ray
