6th January 2020, 10:29 | #221 | Link |
Big Bit Savings Now !
Just throwing this in here unrelated (not in time, but better to be not overlooked, since it was in a different thread).
Has probably been implemented already successfully, I guess... It is pelican9's finding about the location of some DV relevant parameters: https://forum.doom9.org/showthread.p...92#post1889392
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 6th January 2020 at 10:31. |
6th January 2020, 10:40 | #222 | Link | |
Thank you very much |
6th January 2020, 16:39 | #225 | Link | |
Life's clearer in 4K UHD
This version of TSmuxer GUI that ocean obtained from GitHub (on Thu 02 Jan 2020) works fine with Dolby Vision 4K UHD Blu-ray sources
6th January 2020, 21:05 | #226 | Link | |
And a big thank also to tymoxa for his help in verifying the BD outputs. I still need some help to work on the TS buffer management, as TsMuxer simply divides the PCR gap between two frames by the corresponding number of AV packets to calculate the Arrival Time Stamps. I don't know if @drmpeg is still around... |
7th January 2020, 10:26 | #229 | Link |
Nice one
7th January 2020, 13:30 | #230 | Link | |
7th January 2020, 22:12 | #234 | Link |
Agreed...
7th January 2020, 23:16 | #235 | Link |
Here's a little information I found interesting for those who like to play and push the envelope a little. The new TSMUXER versions make it possible. Warning, though, I've only tried it on a few sources and a single UHD-BD player -- so mileage may vary.
7th January 2020, 23:25 | #236 | Link |
Feedback from the nightly build nightly-2020-01-07--01-09-43
- You can't create a folder from tsMuxer - macOS version doesn't work. When adding a file/playlist it shows an error message - Feature Request: Add option to make a specific audio the default track and a specific subtitle track a forced track Last edited by zeropc; 8th January 2020 at 15:15. Reason: edit picture link |
8th January 2020, 11:46 | #238 | Link |
@zeropc: I can't see the screenshot but if you can create an Issue over at GitHub we can take a look.
I need to go through this thread and transfer over all the reported issues to GitHub at some point but if people can report via GitHub it would help me out! |
8th January 2020, 21:36 | #240 | Link |
Good idea, you could ask somebody from ffmpeg to do it.
As an alternative, Madshi gave the eac3to solution to interweave the TrueHD stream with its low-bitrate AC3 (eg 64k if you don't want to use it) counterpart in 2008: http://forum.doom9.net/showthread.ph...00#post1177600 |
