Old 27th April 2020, 08:30   #5541  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by real.finder View Post
I don't use an ARM PC but this is cool
Picture Apple is thinking about switching to ARM...
@turment on Telegram
tormento is offline
Old 27th April 2020, 08:31   #5542  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by qyot27 View Post
Ask for a hand, get an ARM instead.
Cool.
Any benchmark for us? Let's say simple denoise script with x264.
tormento is offline
Old 27th April 2020, 11:49   #5543  |  Link
MeteorRain
結城有紀
Originally Posted by tormento View Post
Understood. And why not the complete set of SSE, i.e. 4.2, but 4.1 only?
Since SIMD is probably a popular dev topic I suggest you to take a look at what each instruction set provides.
For example, usually integer operations are provided after floating points, so SSE=float and SSE2+=int, AVX=float and AVX2=int.
Then because SSE appeared in early days, more and more instructions are added because later they were found useful but not provided. For example SSSE3 added horizontal additions. SSE4.1 is pretty sweet, it added lots of useful tools like extending data width (8bit extending to 16bit, which are useful in high bit depth), min and max on unsigned data (clamping pixel channels), and floating point rounding (used in converting internal floating to integers). As you can see, lots of them are naturally used by lots of filters.
SSE4.2 however is irrelevant to computing. It has instructions for strings (such as comparing strings or get length of a string), and for CRCs. It's close to useless for filters.
That's why most of the filters will use up to SSE4.1. Some can limit their usage under SSE/SSE2 because some SSE4.1 operations can usually be done in SSE/SSE2 at relatively low cost. It's author's discretion to support which one.
Projects
x265 - Yuuki-Asuna-mod Download / GitHub
TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS
Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median
MeteorRain is offline
Old 27th April 2020, 11:52   #5544  |  Link
tormento
Acid fr0g
tormento's Avatar
Very interesting explanation!
Thank you!!!
tormento is offline
Old 27th April 2020, 13:36   #5545  |  Link
Maybe there is not much use for it.
SSE4.2
SSE4.2 added STTNI (String and Text New Instructions),[10] several new instructions that perform character searches and comparison on two operands of 16 bytes at a time. These were designed (among other things) to speed up the parsing of XML documents.[11] It also added a CRC32 instruction to compute cyclic redundancy checks as used in certain data transfer protocols. These instructions were first implemented in the Nehalem-based Intel Core i7 product line and complete the SSE4 instruction set. Support is indicated via the CPUID.01H:ECX.SSE42[Bit 20] flag.
https://en.wikipedia.org/wiki/SSE4#SSE4.2
EDIT: OOPS sorry, was looking at last post on previous page of thread, thought is was the last post in thread. [already answered by MeteorRain]
StainlessS is offline
Old 27th April 2020, 14:13   #5546  |  Link
tormento
Acid fr0g
tormento's Avatar
Kindness is never enough. Thank you too!
tormento is offline
Old 27th April 2020, 14:23   #5547  |  Link
pinterf
Anyway, non SSE4.1 processors are so rare that months pass until someone report a bug on that (executing sse4.1 instruction instead of sse2), lately in VapourSynth Expr, but such bug existed in an old mvtools2 as well and probably once in Avisynth+)
pinterf is offline
Old 27th April 2020, 18:17   #5548  |  Link
real.finder
Originally Posted by pinterf View Post
@real.finder, what about a mode25 test instead? Check rgtools site. This took one week's time including my earlier attempts on it, I do hope there are no other unavoidable modes.
did some tests, mode 25 seems work ok in x64 and HBD
See My Avisynth Stuff
real.finder is offline
Old 27th April 2020, 18:20   #5549  |  Link
real.finder
Cool.
You will be lucky if you get 1 fps every 1 minute since it's arm and there are only c (no asm)
Old 27th April 2020, 18:30   #5550  |  Link
pinterf
And behind the scenes mode 26-28 are ready from C up to avx2. I decided to do the Repair side as well because these things are ugly when done half finished.
pinterf is offline
Old 27th April 2020, 18:34   #5551  |  Link
real.finder
big thanks!
I think I will add SoftSharpen my edits/modeds scripts
Old 27th April 2020, 22:11   #5552  |  Link
pinterf
And we have an RgTools of which version no longer starts with zero
pinterf is offline
Old 27th April 2020, 23:34   #5553  |  Link
real.finder
what a happy day
and yes, as you said in github
pinterf: I swear that by seeing the code mode 28 is different from mode 27 but I cannot find a clip where 27 and 28 gave different results
seems the output is same for quick test!
SoftSharpen now works! but no x64 since it use asharp but in any case I will did some edit for it (later!) to make it HBD ready
Old 28th April 2020, 17:24   #5554  |  Link
pinterf
And finally. 3.5.2. test builds, files only.
There are plugins and plugins64 folder inside, not plugins+ and plugins64+, sorry. But I think not much mixed environment (with avs 2.6) are left by now.
Those who cannot wait for the feature explanations please check readme_history.txt for changes.
But until I post about the new features use these builds as usual. If they fail in something test them with other scripts. Thank you.
This one with array support (preferred)
https://drive.google.com/open?id=1_4...lTIp3u5jFpAgRW
Without arrays
https://drive.google.com/open?id=1EY...uD--nSj12hILX4
pinterf is offline
Old 28th April 2020, 18:09   #5555  |  Link
Groucho2004
Without arrays
I just looked at readme_history.txt - Crikey, you've been busy.
Groucho's Avisynth Stuff
Groucho2004 is offline
Old 28th April 2020, 18:58   #5556  |  Link
From Brief comparison with previous issue.
AviSynth+_3.5.2_(r3218,_neo,_i386)_MOD_ADD_Function_List.TXT
NOTE, We cannot tell if more than single modification or addition has been made, some may have been omitted.
AlignedSplice             "cci"
###### NEW
Array                     ".*"
ArrayGet                  "a.+"
ArraySize                 "a"
BlankClip                 "[]c*[length]i[width]i[height]i[pixel_type]s[fps]f[fps_denominator]i[audio_rate]i[channels]i[sample_type]s[color]i[color_yuv]i[clip]c[colors]a"
ConditionalFilter         "cccn[show]b[local]b"
ConditionalReader         "css[show]b[condvarsuffix]s[local]b"
ConditionalSelect         "cnc+[show]b[local]b"
###### NEW
DumpFilterGraph           "c[outfile]s[mode]i[nframes]i[repeat]b"
###### NEW
Format                    "s.+"
###### NEW
Func                      "n"
###### NEW
IsArray                   "."
###### NEW
IsFunction                "."
###### NEW
OnCPU                     "n"
Prefetch                  "c[threads]i[frames]i"
###### NEW
propClearAll              "c"
propDelete                "cs"
propGetAll                "c[offset]i"
propGetAny                "cs[index]i[offset]i"
propGetAsArray            "cs[offset]i"
propGetDataSize           "cs[index]i[offset]i"
propGetFloat              "cs[index]i[offset]i"
propGetInt                "cs[index]i[offset]i"
propGetKeyByIndex         "c[index]i[offset]i"
propGetString             "cs[index]i[offset]i"
propGetType               "cs[offset]i"
propNumElements           "cs[offset]i"
propNumKeys               "c[offset]i"
propSet                   "csa"
propSetArray              "csn"
propSetFloat              "csn[mode]i"
propSetInt                "csn[mode]i"
propSetString             "csn[mode]i"
propShow                  "c[size]i[showtype]b"
ScriptClip                "cn[show]b[after_frame]b[local]b"
SetFilterMTMode           "si[force]b"
###### NEW
SetCacheMode              "[mode]i"
SetDeviceOpt              "[opt]i[val]i"
###### NEW
SetGraphAnalysis          "b"
###### NEW
SetMaxCPU                 "s"
SetMemoryMax              "[]i[type]i[index]i"
###### NEW
TypeName                  "."
UnalignedSplice           "cci"
###### NEW
UseVar                    "cs+"
WriteFile                 "c[filename]sn+[append]b[flush]b[local]b"
WriteFileEnd              "c[filename]sn+[append]b[local]b"
WriteFileIf               "c[filename]sn+[append]b[flush]b[local]b"
WriteFileStart            "c[filename]sn+[append]b[local]b"
Top Notch P, thanks
Old 28th April 2020, 19:08   #5557  |  Link
pinterf
propSets must be of different signatures.
Function with n-function parameter types are from Nekopanda's fork. And filter graph. And the mt fixes. Thanks for him.
pinterf is offline
Old 28th April 2020, 19:19   #5558  |  Link
tormento
Acid fr0g
tormento's Avatar
Crikey
I think it's 35 years I did not hear that word.
And it was from my 70 yo english teacher reading some XVIII century book.
tormento is offline
Old 28th April 2020, 19:22   #5559  |  Link
pinterf
If no instant fix is required then I will have time to explain the features, one per day . Unless you explain them to yourselves.
pinterf is offline
Old 28th April 2020, 19:23   #5560  |  Link
tormento
Acid fr0g
tormento's Avatar
Wow, what a work!
Can we use "old" plugins or they won't work as you told us?
tormento is offline
