20th May 2021, 20:27 | #181 | Link |
It's perfectly fine that you're getting yv16 output colorbars, since neo_f3kdb is converting the bit depth from 12 to 8, and planar 8bit for yuv422 is yv16. If you're not getting any trouble and you see the colorbars right, then it shouldn't be a neo_f3kdb problem the green video you're getting, or it doesn't fully depends on neo_f3kdb.
You said you're opening the file with LWLibav... how you see the file with just plain LWLibav (no neo_f3kdb) and what's its colorspace inside VDub2? |
20th May 2021, 22:28 | #182 | Link | |
21st May 2021, 02:39 | #184 | Link |
I have the last version of Lsmash, the 20210423.
Mediainfo data: Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Format Range@L3@Main Codec ID : hvc1 Codec ID/Info : High Efficiency Video Coding Duration : 21 min 2 s Bit rate : 1 384 kb/s Maximum bit rate : 3 199 kb/s Width : 640 pixels Height : 480 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 25,000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 12 bits Bits/(Pixel*Frame) : 0.180 Stream size : 208 MiB (93%) Writing library : x265 2.0+4-43ca544799c2:[Windows][MSVC 1900][64 bit] 12bit Encoding settings : wpp / ctu=64 / min-cu-size=8 / max-tu-size=32 / tu-intra-depth=1 / tu-inter-depth=1 / me=1 / subme=2 / merange=57 / no-rect / no-amp / max-merge=2 / temporal-mvp / no-early-skip / rskip / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / no-fast-intra / open-gop / no-temporal-layers / interlace=0 / keyint=250 / min-keyint=25 / scenecut=40 / rc-lookahead=20 / lookahead-slices=0 / bframes=4 / bframe-bias=0 / b-adapt=2 / ref=3 / limit-refs=3 / no-limit-modes / weightp / no-weightb / aq-mode=1 / qg-size=32 / aq-strength=1.00 / cbqpoffs=0 / crqpoffs=0 / rd=3 / psy-rd=2.00 / rdoq-level=0 / psy-rdoq=0.00 / no-rd-refine / signhide / deblock=0:0 / sao / no-sao-non-deblock / b-pyramid / cutree / no-intra-refresh / rc=crf / crf=21.0 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / ipratio=1.40 / pbratio=1.30 Encoded date : UTC 2016-07-18 23:03:09 Tagged date : UTC 2016-07-18 23:03:14 Codec configuration box : hvcC |
21st May 2021, 12:08 | #186 | Link |
Both with LsmahVideoSource and with the script that you propose, I get the same greenish image of 1280 * 480. If I add format = "yuv420p8" I do get the correct image but I would be giving up editing in Hbd and neo_f3kdb.
21st May 2021, 18:33 | #189 | Link |
I still find no issue whatsoever.
Correctly opened with both LW and LSMASH, and with VDub2 with ffmpeg decoder as well. Unless it's a recent bug of LW/LSMASH (you can try to use an older version just in case) I think you have something wrong somewhere on your system. Last edited by mp3dom; 21st May 2021 at 22:19. |
21st May 2021, 22:22 | #190 | Link | |
What is your script? Edit: with Dss2mod and Vdub2 directly i can Open the File without problem. Edit2: If I can open the file with dss2mod then the following question arises, why then use neo_f3kdb or f3kdb? of course this doesn't solve the problem with l-smash. Last edited by GMJCZP; 21st May 2021 at 22:44. |
22nd May 2021, 13:09 | #191 | Link |
neo_f3kdb is not the problem here, because you told me that even the plain LWLibav (opening plugin) give you the problem. You can try an older version of Lsmashsource and see if something change (btw I'm using a 07/2020 version of the plugin).
If you open the file with dss2mod I guess you're opening it at 8bit with (good) or without (bad) the dither applied, so you lose hbd processing. F3kdb main use is for debanding, but can be used for dithering. You have the latest Lsmashsource and latest neo_f3kdb... do you also have latest avs+ 3.7? |
22nd May 2021, 14:08 | #192 | Link | |
In short, at some point in the development of Lsmash a bug was introduced. PD: recently update to last version of Avs+ |
22nd May 2021, 14:23 | #193 | Link |
LWLibavVideoSource(".\Sample_yuv420p12le.mp4") # LSMASHSource_x86_20200322(HolyWu).dll info click to see Info(). EDIT: OK, you got it sorted.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 22nd May 2021 at 14:27. |
22nd May 2021, 15:08 | #196 | Link |
already posted, ie
LWLibavVideoSource(".\Sample_yuv420p12le.mp4") # LSMASHSource_x86_20200322(HolyWu).dll info <<<<<<======= Here !!! so we knew what ver$ worked, or had problems. [EDIT: downloading all versions and comparing file size/MD5 is a real pain]
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 22nd May 2021 at 15:13. |
22nd May 2021, 15:19 | #197 | Link | |
The problem was introduced from this year, at least the latest version |
23rd May 2021, 01:52 | #199 | Link |
Thanks StvG, your comment motivated me to take action on the matter...
I was finally able to solve the problem, as follows: - I downloaded the latest version of Lsmash again - Then I noticed, by chance, that some videos were played wrong by mpc-hc, I updated it as well as lav filters (when I uninstalled it I had problems reinstalling it but it was solved) - Finally I tried the video and it worked correctly. It still seems a mystery to me that the latest version did not work at first, it is possible that there was a conflict with the programs I mentioned before. Thanks everyone for your help. |
23rd May 2021, 12:31 | #200 | Link |
Some time ago, there was some kind of problem concerning a VDub source plugin, and either ffmpeg or FfmpegSource, dll's.
It was something to do with path search order to find a dll, one softwares change in search order interfered with the other. No idea if relevant.
