Old 21st November 2022, 15:07   #21  |  Link
color
color's Avatar
Some scenes look awefull (Two above) but the last one is okey.
Automatic Colorization
color is offline   Reply With Quote
Old 21st November 2022, 15:14   #22  |  Link
kedautinh12
If your logo don't appear in all clip, you can trim only frame have logo appear. After join frame no logo and frame have logo in one
Ex: https://forum.doom9.org/showthread.p...80#post1975980
Old 21st November 2022, 15:20   #23  |  Link
color
color's Avatar
Its only first 270 frames is not vissible so I have used trim(270,11579).
What works "best" on some frames are "Inpaint" and "blend" on some. But Inpaint does look off on some frames.
First looks great, but other two, not so much.
I think I should use different and trim and use what works best for every scen instead as you say. I don't think it will work great on all scenes.
Old 21st November 2022, 15:29   #24  |  Link
kedautinh12
With Inpant mode you can try with turbo=-1 and with Deblend you can try some values with IntSpd, Interp, dPP
Old 21st November 2022, 15:37   #25  |  Link
kedautinh12
Or you can try with automask will be better with Analyze
Old 21st November 2022, 15:45   #26  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Share the full video of that logo, encode with lossless x264 this script:
LWLibavVideoSource("C:\video.mkv")
Crop(1388,944,-280,-24)
VoodooFX is offline   Reply With Quote
Old 21st November 2022, 15:52   #27  |  Link
color
color's Avatar
turbo=-1 did a much better job! I also tried IntSpd, Interp, dPP, but I don't see any difference between the 1-3 value for each also tried all three with deblend.
I did use automask. I used my own first but I saw automask did a better jobb.
Old 21st November 2022, 16:06   #28  |  Link
color
color's Avatar
Here you go lossless x264: LINK
I used
ffmpeg -i input -c:v libx264 -preset veryslow -qp 0 output.mkv
Old 22nd November 2022, 06:57   #29  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Looks like video is too low quality to deblend this logo, you've to use inpaint to delogo:
InpaintDelogo(mask="C:\1.bmp", Loc="1388,944,-280,-24", Mode="Inpaint", Turbo=-1)
Btw, logo has fade in/out animations, so you don't want to analyze such frames for deblend.
Old 22nd November 2022, 07:17   #30  |  Link
color
color's Avatar
Oh, i have not noticed more than the beginning.
Well its the highest quality on the image I got and no other source are available. Do you mean it does fade in and out in the video or do you mean in the beginning only?
I think I do a mix in that case.
Edit: mode "both" did work good on some frames "inpaint" and "deblend" did do bad.
Old 22nd November 2022, 07:24   #31  |  Link
kedautinh12
Oh, i habe not noticed more than the beginning.
Inpaint work better with solid logo or dynamic logo (fade in, fade out). Deblend work better with transparent logo. You use mode both when your logo has transparent and solid
Old 22nd November 2022, 07:29   #32  |  Link
color
color's Avatar
Inpaint work better with solid logo or dynamic logo (fade in, fade out). Deblend work better with transparent logo. You mode both when your logo has transparent and solid
Oh so it flips between solid and transparent. That I did not notice at all. I will still mix, i have exported inpaint, deblend and both, so i go through frame by frame and use whats best. (Exported to png).
Old 22nd November 2022, 07:45   #33  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
How fade out can be at the beginning? Of course it's at the end.
Yes, maybe Deblend can look better at some few random frames/scenes.
It's illusion, you just don't understand what is going on in "Both".
Don't use it here.
Can you share your ebmp file and the frame numbers where you think that Deblend or Both looks better for you?
Old 22nd November 2022, 08:08   #34  |  Link
color
color's Avatar
Don't use it here.
Yes, frame 4011. top "inpaint" bottom "both"
EDIT: I might have used another setting and not same on both like turbo...
Old 22nd November 2022, 08:46   #35  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Yes, frame 4011
Same frame, Inpaint vs Deblend, I don't see how Deblend is worse than "Both":
You didn't shared your ebmp file.
Old 22nd November 2022, 09:02   #36  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
You are even more hardcore than me, InpaintDelogo has zillion possible combinations of the parameters to make some specific frame look better.
Look, Inpaint [adjusted] vs Deblend:
Old 22nd November 2022, 09:18   #37  |  Link
kedautinh12
I think you need share scripts to help him faster
Old 22nd November 2022, 11:03   #38  |  Link
color
color's Avatar
yes, but i did try a few. You know what i mean.
I think as kedautinh12, you should share a script. ☺️ Its a bit hard not knowing a lot of english and understanding everything as well.
Old 22nd November 2022, 11:55   #39  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Where is your ebmp file?
InpaintDelogo(mask="C:\1.bmp", Loc="1388,944,-280,-24", Mode="Inpaint", Sharpness=60, preBlur=2.1, postBlur=12.6, Radius=16, oPP=-3, Optimize=0)
Core inpainting parameters: https://github.com/Purfview/InpaintD...logo.avsi#L876
I was thinking is it possible to create a image with alpha and only dark/black color and somehow use it in a transparent to darken the logo so its not visible?
Possible: https://github.com/Purfview/InpaintD...logo.avsi#L912
Old 22nd November 2022, 17:15   #40  |  Link
color
color's Avatar
Lets try again, I did attach file here, but it seems like it didn't want to.
https://sprend.com/download?C=b11d8c...a8d28fc926b9b1
avisynth, virtualdub
