Old 31st May 2009, 13:48   #1  |  Link
bsmith1593
Decimation Usage
I'm having a problem with decimating one of my videos. I assumed that I should leave it 29fps because when I used Decimate(), it looks jerky in some parts. After looking through the frames, however, I see some duplicate frames. The problem with them, however, is that there is no set pattern for when they occur. They could go like, after 7 frames, after 8 frames, after 10 frames, after 6 frames, and then so on. Would I have to do a manual decimation to get rid of the duplicate frames? And if I did, what would the framerate turn out to be? Also, I'm pretty sure I wouldn't get the fade in intro and fade-out exit correctly. Can anybody help me?
And if you need to see the video, I'll be glad to upload it...
bsmith1593 is offline   Reply With Quote
Old 31st May 2009, 14:14   #2  |  Link
manono
Yep, 10 seconds or so with movement would be good.
Old 31st May 2009, 14:17   #3  |  Link
bsmith1593
I'll get right on it.
Old 31st May 2009, 14:42   #4  |  Link
bsmith1593
I did the first 22 seconds of the video: http://eva.adriels.com/miscellaneous...m9.demuxed.m2v
Old 31st May 2009, 16:48   #5  |  Link
lansing
your source was double hard telecined, so AnimeIVTC(mode=2, aa=0) should do it
Old 31st May 2009, 17:44   #6  |  Link
bsmith1593
What filter do I need to have loaded to use AnimeIVTC?
Old 31st May 2009, 17:58   #7  |  Link
lansing
http://forum.doom9.org/showthread.php?t=138305
the plugin package is available for download in the first post, as long as the document
Old 31st May 2009, 18:08   #8  |  Link
bsmith1593
Thanks
Old 31st May 2009, 18:09   #9  |  Link
BigDid
Actually in reserve
Read the first post of the thread related to animeivtc(), you will find links to guide, set of filters etc...:
It is a good habit to use the search function of this forum extensively (and from google also) and find your answers directly; and welcome to the forum
Did
Having a problem with AutoGK? Read & use the FAQ & MORE FAQ first
Want to exchange on AutoGK? try doom10.org
In reserve (inactive) for an undefined period of time.
BigDid is offline   Reply With Quote
Old 31st May 2009, 19:11   #10  |  Link
bsmith1593
How do I load AnimeIVTC into my .avs? Sorry if this is kind of annoying, but there's a lot of plugins and I don't usually load other .avs's into another .avs.
Old 31st May 2009, 22:10   #11  |  Link
lansing
ok, first download the plugin package, and then put everything that end up with the dll and avsi extension to your Avisynth plugin directory, if you see avs extension, simply change it to avsi and put those in too, this way it will auto load whenever you call it like a regular filter. If you see some files with multiple SSE version, choose only one, SSE2 for Pentium 4 or under, SSE3 for Core Duo.
Remember to download the AnimeIVTC script separately from here to replace the original. And also, put the AvsRecursion.dll file to your C:\windows\system32 folder
Old 31st May 2009, 23:12   #12  |  Link
manono
It mostly has 2 duplicate frames in every 15, with some variation because of edits breaking the pattern. Unless you're real particular about it, I'd just go with a simple:
TFM()
TDecimate(Mode=0,Cycle=15,CycleR=2)
Old 3rd June 2009, 02:11   #13  |  Link
bsmith1593
What do I actually need to put into MY .avs to make it work though? Here's what I have:
LoadPlugin("C:\PROGRA~1\GORDIA~1\DGMPGDec\DGDecode.dll")
LoadPlugin("C:\PROGRA~1\GORDIA~1\AVISYN~1\Decomb.dll")
mpeg2source("C:\PROGRA~1\GORDIA~1\AVISYN~1\D2Vs\Behind These Hazel Eyes.d2v")
AssumeTFF()
AnimeIVTC(mode=2,aa=0)
What do I put where it says "***?***" to make AnimeIVTC work?
Old 3rd June 2009, 03:44   #14  |  Link
lansing
AssumeTFF()
ok, I see your problem. You'd installed an old version of AviSynth from that outdated Gordian Knot package, which is about 5 years old.
That old Avisynth version doesn't have the auto load function, so what you need to do is to uninstall the AviSynth part from the package if you can, or just uninstall the whole package because it's way too old.
Then download and install this newer version. Then put all your filter to the directory's plugins folder.
When writing your script, you don't have to load the filter, they will auto load, so the basic script will be like this
mpeg2source("xxx.d2v",info=3)
colormatrix(hints=true) #this will automatically do color correction if needed
AnimeIVTC(mode=2, aa=0) #aa is anti-aliasing, [0-4], 0=off, turn this off if you don't need it
Old 3rd June 2009, 03:52   #15  |  Link
bsmith1593
Okay, I'll try doing this tomorrow. Yeah, I had installed GordianKnot and its AviSynth. I installed the newest version the other day, but I installed it to the plugin directory in GordianKnot's folder, so that probably messed it up, I'll uninstall both, reinstall GK, delete its AviSynthPlugins folder, install the new AviSynth, and then re-extract all of the files from the requirements package and put them in the right places. I'll tell y'all my results when I eventually get there . Thanks for being patient.
Old 4th June 2009, 05:34   #16  |  Link
bsmith1593
I got all the files from the Requirements package moved to my plugins folder. Filters autoload like they should. Now I get this error in VirtualDub:
http://i243.photobucket.com/albums/f...ldub_error.png.
The line it's talking about tries to load "ColorYUY2.dll", which is not in the package :s. Oh, and some files have more than one version, like v.32 and v.54. Should I delete the older ones?
Old 4th June 2009, 14:25   #17  |  Link
bsmith1593
Okay, I managed to solve the last error by finding ColorYUY2.dll and putting it in the plugins folder, but now I get these:
http://i243.photobucket.com/albums/f...dub_error2.png
http://i243.photobucket.com/albums/f...dub_error3.png
Old 4th June 2009, 14:27   #18  |  Link
Can't you look at the ColorRGB.auf.avsi script and figure out the problem?
If not, post that script in its entirety.
Old 4th June 2009, 18:05   #19  |  Link
bsmith1593
I'm not very experienced in AviSynth except for scripts of others I've used and minor stuff. I know what it says is wrong, but I don't know how to fix it, several files have similar code and that's how they're supposed to work I guess.
http://eva.adriels.com/miscellaneous/ColorRGB.auf.avsi
info = LoadPlugin("ColorYUY2.dll")
filt = AvisynthFilters("RGB color adjust filter", info)
func = filt.AddFunction("ColorYUY2")
func.AddValue(0.0)
func.AddValue(0.0)
func.AddValue(0.0)
func.AddValue(0.0)
func.AddValue(0.0)
func.AddValue(0.0)
func.AddValue(0.0)
func.AddValue(0.0)
func.AddValue(0.0)
func.AddValue(0.0)
func.AddValue(0.0)
func.AddValue(0.0)
func.AddTrack("R(gain)", 0, -256, 256, -256.0, 256.0)
func.AddTrack("R(offs)", 0, -256, 256, -256.0, 256.0)
func.AddTrack("R(gamm)", 0, -256, 256, -256.0, 256.0)
func.AddTrack("R(cont)", 0, -256, 256, -256.0, 256.0)
func.AddTrack("G(gain)", 0, -256, 256, -256.0, 256.0)
func.AddTrack("G(offs)", 0, -256, 256, -256.0, 256.0)
func.AddTrack("G(gamm)", 0, -256, 256, -256.0, 256.0)
func.AddTrack("G(cont)", 0, -256, 256, -256.0, 256.0)
func.AddTrack("B(gain)", 0, -256, 256, -256.0, 256.0)
func.AddTrack("B(offs)", 0, -256, 256, -256.0, 256.0)
func.AddTrack("B(gamm)", 0, -256, 256, -256.0, 256.0)
func.AddTrack("B(cont)", 0, -256, 256, -256.0, 256.0)
func.AddArray("levels", 0, "", "TV->PC", "PC->TV", "PC->TV.Y", "TV->PC.Y", "709->601", "709TV->601PC", "709PC->601TV")
func.AddArray("opt", 0, "", "coring", "1-254")
func.AddArray("matrix", 0, "", "rec709", "rec601s", "rec709s")
func.AddTrack("debug",   0,  0,   5)
func.AddTrack("hscale", 70, 10, 100)
func.AddTrack("X", 0, -1, 1280)
func.AddTrack("Y", 0, -1,  960)
func.AddArray("interpolation", 0, "", "411->422", "411->422R", "411->444", "411->444R", "420->422", "420->444", "422->444")
func.AddArray("output", 0, "", "YUY2", "YV12", "I420", "RGB32", "RGB24")
return filt
Old 4th June 2009, 18:17   #20  |  Link
Leak
ffdshow/AviSynth wrangler
Leak's Avatar
Holy carp... after some googling this seems to be some kinda script for AviUtil, not AviSynth.
That stuff is ANCIENT. I doubt you'll get this to run in any way...
np: Sin Fang Bous - Poi Rot (Clangour)
now playing: [artist] - [track] ([album])
Leak is offline   Reply With Quote
decimation, trouble
